Arduino Mega NRF24L01+ Test Code --------------------------------- (c) NRFTestGuy Free for private non-commercial usage. This is the Mega2560 version of the test program published here: Beitrag "NRF24L01+ test program for Arduino Uno" It uses exactly the same wiring so you can use one test circuit for both Arduinos (Uno and Mega2560). You can use these programs as a test partner for devloping your own application for the NRF24L01+ or just check the correct functions of your modules. Also works with the Windows App NRF24_Tester available here: Beitrag "NRF24L01 - Testprogramm für Windows PC" Prerequisites --------------- - Arduino Mega 2560 must be set up to run at 16 MHz The Arduino is not absolutely required. You can use a naked ATMega2560 running at 16 MHz with RS232 connection to your computer. Just use the port pins (as documented in the Fritzing schematic) and the RX/TX lines that usually connect to the Arduino USB port. - USB Connection to Arduino's USB Port - NRF24L01+ wired to the Arduino (see Fritzing schematic) - a terminal Application on your PC - a programmer (such as AVRDude) to put the HEX file via USB connection on your Arduino - program the hex file in your ATMega2560 To run the program: -------------------- - start your terminal application - connect it to the port where your Arduino is located - set the baud rate to 57600 baud, 8 bit, no parity - the terminal should cause a reset on your Arduino board which would result in a program startup. The following menu should appear in your terminal application: Arduino Mega - NRF24L01+ Test Version 0.xx (c) NRFTestGuy (Build Xxx xx xxxx xx:xx:xx) ----------------------------------- T: Transmit Data R: Receive Data F: Fast Transmit G: Fast Receive D: Display Registers L: Loopback Test (SPI) O: Continuous Loopback Test S: Show Parameters A: Required Pin Assignments ----------------------------------- config:0x2D status:0x0E mem:6962 ----------------------------------- >
There's no source code. Try again. Ohne Quelltext wird das nichts.
