LM1084 5V Schaltung
Gast #4760170
Hey
ich hab mal eine kleine Verständnis Frage zum Datenblatt des LM1084.
Dort wird beim Festspannungsregler als ja der 3.3V gezeigt, wie er
beschaltet wird (mit den 2 Kondensatoren) um eine Spannung größer gleich
4.5V auf 3.3V runter zu regeln. (Seite 10: 5V to 3.3V, 5A Regulator).
ist das jetzt für den 5V Regler das selbe? nur eben mit der höheren
Eingangsspannung?
#4760189
> Eingangsspannung?
JaNein, ER funst halt nur innerhalb seiner Specs....
Wenn notwendig, eher LoESR. ABER, nur keine Panik :)
Bei Last lieber Cap. als Induktiv....
Stability consideration primarily concerns the phase response of the
feedback loop. In order for stable operation,
the loop must maintain negative feedback. The LM1084 requires a certain
amount series resistance with
capacitive loads. This series resistance introduces a zero within the
loop to increase phase margin and thus
increase stability. The equivalent series resistance (ESR) of solid
tantalum or aluminum electrolytic capacitors is
used to provide the appropriate zero (approximately 500 kHz).
Aluminum electrolytics are less expensive than tantalums, but their ESR
varies exponentially at cold
temperatures; therefore requiring close examination when choosing the
desired transient response over
temperature. Tantalums are a convenient choice because their ESR varies
less than 2:1 over temperature.
The recommended load/decoupling capacitance is a 10-uF tantalum or a
50-uF aluminum. These values will
assure stability for the majority of applications.
The adjustable versions allow an additional capacitor to be used at the
ADJ pin to increase ripple rejection. If this
is done the output capacitor should be increased to 22 uF for tantalum
or to 150 uF for aluminum.
Capacitors other than tantalum or aluminum can be used at the adjust pin
and the input pin. A 10-uF capacitor is
a reasonable value at the input. See Ripple Rejection section regarding
the value for the adjust pin capacitor.
