1 | /* Private define ------------------------------------------------------------*/
2 | #define READBUF_SIZE (5 * 1024) /* Value must min be 2xMAINBUF_SIZE = 2x1940 = 3880bytes */
3 | #define BUFF_SIZE 4608
4 | typedef struct buffs
5 | {
6 | short BufData[BUFF_SIZE];
7 | struct buffs * Next;
8 | }BuffDef;
9 | BuffDef Buff[2];
10 | BuffDef* BuffP = &Buff[0];
11 | /* Private variables ---------------------------------------------------------*/
12 | AUDIO_PlaybackBuffer_Status BufferStatus; /* Status of buffer */
13 | s16 AudioBuffer[4608]; /* Playback buffer - Value must be 4608 to hold 2xMp3decoded frames */
14 | MP3FrameInfo mp3FrameInfo; /* Content is the output from MP3GetLastFrameInfo,
15 | we only read this once, and conclude it will be the same in all frames
16 | Maybe this needs to be changed, for different requirements */
17 | static HMP3Decoder hMP3Decoder; /* Content is the pointers to all buffers and information for the MP3 Library */
18 | volatile uint32_t bytesLeft; /* Saves how many bytes left in readbuf */
19 | volatile uint32_t outOfData; /* Used to set when out of data to quit playback */
20 | volatile AUDIO_PlaybackBuffer_Status audio_buffer_fill ;
21 | volatile int Audio_buffer_index = 0;
22 | volatile uint16_t Audio_buffer_size = 0;
23 | volatile s16 Audio_buffer_local[LOCAL_BUFFER_SIZE]; /* working buffer for MONO mode management */
24 | AUDIO_Playback_status_enum AUDIO_Playback_status ;
25 | AUDIO_Format_enum AUDIO_Format ;
26 | AUDIO_Length_enum AUDIO_Length ;
27 | AUDIO_PlaybackBuffer_Status bufferstatus_local;
28 | s8 *Audio_buffer;
29 | int Audio_buffer_local_size = LOCAL_BUFFER_SIZE;
30 | uint8_t readBuf[READBUF_SIZE]; /* Read buffer where data from SD card is read to */
31 | uint8_t *readPtr; /* Pointer to the next new data */
32 | uint32_t MP3Size;
33 | uint32_t MP3_Data_Index;
34 | uint16_t AUDIO_Frequency ;
35 | uint32_t n_Read; /* File R/W count */
36 |
37 | FIL fsra; // file objects
38 | UINT ba; /* File read/write count */
39 |
40 |
41 |
42 |
43 |
44 |
45 |
46 | /*******************************************************************************
47 | * Function Name : AUDIO_PlaybackBuffer_Status
48 | * Description : Gets the status of Playback buffer
49 | * Input : - value: 0 = get the current status, else reset the flag
50 | * passed in parameter
51 | * Output : None
52 | * Return : FULL=0, LOW_EMPTY=1, HIGH_EMPTY=2
53 | * Attention : None
54 | *******************************************************************************/
55 | AUDIO_PlaybackBuffer_Status AUDIO_PlaybackBuffer_GetStatus(AUDIO_PlaybackBuffer_Status value)
56 | {
57 | if ( value )
58 | audio_buffer_fill &= ~value;
59 | return audio_buffer_fill;
60 | }
61 |
62 | /*******************************************************************************
63 | * Function Name : AUDIO_Playback_Stop
64 | * Description : Stop the playback by stopping the DMA transfer
65 | * Input : None
66 | * Output : None
67 | * Return : None
68 | * Attention : None
69 | *******************************************************************************/
70 | void AUDIO_Playback_Stop(void)
71 | {
72 | /* Enable the SAI DMA Stream*/
73 | DMA_Cmd(AUDIO_MAL_DMA_STREAM, DISABLE);
74 |
75 | AUDIO_Playback_status = NO_SOUND;
76 | /* Shutdwon codec in order to avoid non expected voices */
77 | //codec_send( ACTIVE_CONTROL | INACTIVE );
78 | }
79 |
80 |
81 | /*******************************************************************************
82 | * Function Name : MP3_GetStrResult
83 | * Description : Convert file access error number in string
84 | * Input : None
85 | * Output : None
86 | * Return : None
87 | * Attention : None
88 | *******************************************************************************/
89 | const char* MP3_GetStrResult(int err)
90 | {
91 | switch(err) {
92 | case ERR_MP3_NONE : return "ERR_MP3_NONE";
93 | case ERR_MP3_INDATA_UNDERFLOW : return "ERR_MP3_INDATA_UNDERFLOW";
94 | case ERR_MP3_MAINDATA_UNDERFLOW : return "ERR_MP3_MAINDATA_UNDERFLOW";
95 | case ERR_MP3_FREE_BITRATE_SYNC : return "ERR_MP3_FREE_BITRATE_SYNC";
96 | case ERR_MP3_OUT_OF_MEMORY : return "ERR_MP3_OUT_OF_MEMORY";
97 | case ERR_MP3_NULL_POINTER : return "ERR_MP3_NULL_POINTER";
98 | case ERR_MP3_INVALID_FRAMEHEADER : return "ERR_MP3_INVALID_FRAMEHEADER";
99 | case ERR_MP3_INVALID_SIDEINFO : return "ERR_MP3_INVALID_SIDEINFO";
100 | case ERR_MP3_INVALID_SCALEFACT : return "ERR_MP3_INVALID_SCALEFACT";
101 | case ERR_MP3_INVALID_HUFFCODES : return "ERR_MP3_INVALID_HUFFCODES";
102 | case ERR_MP3_INVALID_DEQUANTIZE : return "ERR_MP3_INVALID_DEQUANTIZE";
103 | case ERR_MP3_INVALID_IMDCT : return "ERR_MP3_INVALID_IMDCT";
104 | case ERR_MP3_INVALID_SUBBAND : return "ERR_MP3_INVALID_SUBBAND";
105 | case ERR_UNKNOWN : return "ERR_UNKNOWN";
106 | default : return "?";
107 | }
108 | }
109 |
110 | /*******************************************************************************
111 | * Function Name : DMA_Configuration
112 | * Description : DMA1 channel5 configuration
113 | * Input : None
114 | * Output : None
115 | * Return : None
116 | * Attention : None
117 | *******************************************************************************/
118 | void DMA_Configuration( s8 * addr, int size)
119 | {
120 | DMA_InitTypeDef DMA_InitStructure;
121 |
122 | /* Enable the SAI */
123 | //SAI_Cmd(CODEC_SAI, DISABLE);
124 |
125 | /* Enable the DMA clock */
126 | RCC_AHB1PeriphClockCmd(AUDIO_MAL_DMA_CLOCK, ENABLE);
127 |
128 | /* Configure the DMA Stream */
129 | DMA_Cmd(AUDIO_MAL_DMA_STREAM, DISABLE);
130 | DMA_DeInit(AUDIO_MAL_DMA_STREAM);
131 |
132 | if(AUDIO_Format == STEREO)
133 | {
134 | /* Uses the original buffer */
135 | DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) addr; /* Set the buffer */
136 | DMA_InitStructure.DMA_BufferSize = size; /* Set the size */
137 | }
138 | else
139 | {
140 | /* Uses the local buffer */
141 | if ( AUDIO_Length == LG_16_BITS ) size *= 2;
142 | Audio_buffer = addr; /* Copy the pointer to real databuffer/source */
143 | Audio_buffer_index = 0; /* Copy the pointer to real databuffer/source */
144 | Audio_buffer_size = size; /* Size to the real databuffer/source */
145 | DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)Audio_buffer_local; /* Set the buffer */
146 | DMA_InitStructure.DMA_BufferSize = ((Audio_buffer_local_size)/2);; /* Set the size */
147 | }
148 |
149 | /* Set the parameters to be configured */
150 | DMA_InitStructure.DMA_Channel = AUDIO_MAL_DMA_CHANNEL;
151 | DMA_InitStructure.DMA_PeripheralBaseAddr = CODEC_SAI_ADDRESS;
152 | DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
153 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
154 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
155 | DMA_InitStructure.DMA_PeripheralDataSize = AUDIO_MAL_DMA_PERIPH_DATA_SIZE;
156 | DMA_InitStructure.DMA_MemoryDataSize = AUDIO_MAL_DMA_MEM_DATA_SIZE;
157 | #ifdef AUDIO_MAL_MODE_NORMAL
158 | DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
159 | #elif defined(AUDIO_MAL_MODE_CIRCULAR)
160 | DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
161 | #else
162 | #error "AUDIO_MAL_MODE_NORMAL or AUDIO_MAL_MODE_CIRCULAR should be selected !!"
163 | #endif /* AUDIO_MAL_MODE_NORMAL */
164 | DMA_InitStructure.DMA_Priority = DMA_Priority_High;
165 | DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
166 | DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
167 | DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
168 | DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
169 | DMA_Init(AUDIO_MAL_DMA_STREAM, &DMA_InitStructure);
170 |
171 | /* Enable the selected DMA interrupts (selected in "stm32_eval_audio_codec.h" defines) */
172 | #ifdef AUDIO_MAL_DMA_IT_TC_EN
173 | DMA_ITConfig(AUDIO_MAL_DMA_STREAM, DMA_IT_TC, ENABLE);
174 | #endif /* AUDIO_MAL_DMA_IT_TC_EN */
175 | #ifdef AUDIO_MAL_DMA_IT_HT_EN
176 | DMA_ITConfig(AUDIO_MAL_DMA_STREAM, DMA_IT_HT, ENABLE);
177 | #endif /* AUDIO_MAL_DMA_IT_HT_EN */
178 | #ifdef AUDIO_MAL_DMA_IT_TE_EN
179 | DMA_ITConfig(AUDIO_MAL_DMA_STREAM, DMA_IT_TE | DMA_IT_FE | DMA_IT_DME, ENABLE);
180 | #endif /* AUDIO_MAL_DMA_IT_TE_EN */
181 |
182 | /* Enable the SAI DMA request */
183 | SAI_DMACmd(CODEC_SAI, ENABLE);
184 | /* Enable the SAI DMA Stream*/
185 | DMA_Cmd(AUDIO_MAL_DMA_STREAM, ENABLE);
186 |
187 |
188 | /* If the SAI peripheral is still not enabled, enable it */
189 | if (SAI_GetCmdStatus(CODEC_SAI) == DISABLE)
190 | {
191 | SAI_Cmd(CODEC_SAI, ENABLE);
192 | }
193 | }
194 |
195 |
196 | /*******************************************************************************
197 | * Function Name : PlayAudioFile
198 | * Description : None
199 | * Input : None
200 | * Output : None
201 | * Return : None
202 | * Attention : None
203 | *******************************************************************************/
204 | void PlayAudioFile(void)
205 | {
206 | Buff[0].Next = &Buff[1];
207 | Buff[1].Next = &Buff[0];
208 |
209 | static UINT br;
210 | s32 offset; // Used to save the offset to the next frame
211 | int errs = 0; // Return value from MP3decoder
212 | FRESULT res;
213 | FILINFO finfo;
214 | DIR dirs;
215 | /* Reset counters */
216 | bytesLeft = 0;
217 | outOfData = 0;
218 |
219 |
220 |
221 | readPtr = readBuf;
222 | hMP3Decoder = MP3InitDecoder();
223 |
224 | //f_chdir("/MP3");
225 | /**/
226 | if (f_opendir(&dirs, "") == FR_OK) //Ŀ¼´ò¿ª³É¹¦
227 | {
228 | while (f_readdir(&dirs, &finfo) == FR_OK) //Ŀ¼ÏÂÊÇ·ñÓÐÎļþ
229 | {
230 | if (finfo.fattrib & AM_ARC)
231 | {
232 | if(!finfo.fname[0]) break;
233 |
234 | //Usart_Puts("\r\n Now Playing:[");
235 | //Usart_Puts(finfo.fname);
236 | //Usart_Puts("]\r\n");
237 |
238 | DrawString(200,350,finfo.fname,&Arial_16x25,Orange,BLACK);
239 | res = f_open(&fsra, finfo.fname, FA_OPEN_EXISTING | FA_READ);
240 | //res = f_open(&fsra, "FR", FA_READ);
241 | // Reset counters //
242 |
243 |
244 | res = f_read(&fsra,readBuf,READBUF_SIZE,&br);
245 | bytesLeft += br;
246 |
247 | //if( (res) ||(br == 0)) break;
248 |
249 | while(1)
250 | {
251 |
252 |
253 | // find start of next MP3 frame - assume EOF if no sync found //
254 | offset = MP3FindSyncWord(readPtr, bytesLeft);
255 | if (offset < 0)
256 | {
257 | outOfData = 1;
258 | break;
259 | }
260 | else
261 | {
262 | readPtr += offset; //data start point
263 | bytesLeft -= offset; //in buffer
264 | errs = MP3Decode(hMP3Decoder, &readPtr, (int *)&bytesLeft, (short *)AudioBuffer, 0);
265 |
266 | if (bytesLeft < READBUF_SIZE)
267 | {
268 | memmove(readBuf,readPtr,bytesLeft);
269 | res = f_read(&fsra, readBuf + bytesLeft, READBUF_SIZE - bytesLeft, &br);
270 | if( (res) ||(br == 0)) break;
271 |
272 | if (br < READBUF_SIZE - bytesLeft)
273 | memset(readBuf + bytesLeft + br, 0, READBUF_SIZE - bytesLeft - br);
274 | bytesLeft=READBUF_SIZE;
275 | readPtr=readBuf;
276 | }
277 |
278 | MP3GetLastFrameInfo(hMP3Decoder, &mp3FrameInfo);
279 |
280 | // Select the correct samplerate and Mono/Stereo //
281 | AUDIO_Init_audio_mode( ( AUDIO_Length_enum )mp3FrameInfo.bitsPerSample, \
282 | ((MP3DecInfo *)hMP3Decoder)->samprate, \
283 | (((MP3DecInfo *)hMP3Decoder)->nChans==2) ? MONO : STEREO);
284 | }
285 | }
286 | f_close(&fsra);
287 |
288 |
289 |
290 | }
291 | }
292 | //break;
293 | }
294 | //OSTimeDly(10);
295 |
296 |
297 | MP3GetLastFrameInfo(hMP3Decoder, &mp3FrameInfo);
298 |
299 | /* Select the correct samplerate and Mono/Stereo */
300 | AUDIO_Init_audio_mode( ( AUDIO_Length_enum )mp3FrameInfo.bitsPerSample, \
301 | ((MP3DecInfo *)hMP3Decoder)->samprate, \
302 | (((MP3DecInfo *)hMP3Decoder)->nChans==1) ? MONO : STEREO);
303 |
304 | }
305 |
306 | void DMA2_Stream5_IRQHandler(void)
307 | {
308 | /* Transfer complete interrupt */
309 | if (DMA_GetFlagStatus(AUDIO_MAL_DMA_STREAM, AUDIO_MAL_DMA_FLAG_TC) != RESET) /* DMA1 ͨµÀ5 ´«ÊäÍê³ÉÖÐ¶Ï */
310 | {
311 | /* Clear the Interrupt flag */
312 | DMA_ClearFlag(AUDIO_MAL_DMA_STREAM, AUDIO_MAL_DMA_FLAG_TC);
313 | bufferstatus_local |= HIGH_EMPTY;
314 | if(AUDIO_Format == MONO)
315 | {
316 | AUDIO_Cpy_Mono();
317 | }
318 | else
319 | {
320 | audio_buffer_fill |= HIGH_EMPTY;
321 | }
322 | }
323 |
324 | if (DMA_GetFlagStatus(AUDIO_MAL_DMA_STREAM, AUDIO_MAL_DMA_FLAG_HT) != RESET)
325 | {
326 | /* Clear the Interrupt flag */
327 | DMA_ClearFlag(AUDIO_MAL_DMA_STREAM, AUDIO_MAL_DMA_FLAG_HT);
328 | bufferstatus_local |= LOW_EMPTY;
329 | if(AUDIO_Format == MONO)
330 | {
331 | AUDIO_Cpy_Mono();
332 | }
333 | else
334 | {
335 | audio_buffer_fill |= LOW_EMPTY;
336 | }
337 | }
338 | }
339 |
340 |
341 | /*******************************************************************************
342 | * Function Name : AUDIO_Cpy_Mono
343 | * Description : Copy Mono data to small buffer, set both Left+Right Channel
344 | * to samme value
345 | * Input : None
346 | * Output : None
347 | * Return : None
348 | * Attention : None
349 | *******************************************************************************/
350 | void AUDIO_Cpy_Mono(void)
351 | {
352 | volatile uint16_t i;
353 | s16 temp;
354 |
355 | /* Stop if end of original buffer */
356 | if ( Audio_buffer_index > Audio_buffer_size )
357 | AUDIO_Playback_Stop();
358 |
359 | /* End of the first half working buffer */
360 | if(bufferstatus_local & LOW_EMPTY)
361 | {
362 | if (AUDIO_Length == LG_16_BITS)
363 | {
364 | for( i=0 ; i < ((Audio_buffer_local_size / 4) - 1) ; i = i + 2 )
365 | {
366 | temp = *(s16*)(Audio_buffer+Audio_buffer_index);
367 | Audio_buffer_local[i+1] = Audio_buffer_local[i] = temp;
368 | Audio_buffer_index += 2; /* 16 bit */
369 | }
370 | }
371 | else
372 | {
373 | for(i=0; i < ((Audio_buffer_local_size / 4)-1); i=i+2)
374 | {
375 | temp = ((s16)((*(Audio_buffer+Audio_buffer_index)^0x80)))<<8;
376 | Audio_buffer_local[i+1] = Audio_buffer_local[i] = temp;
377 | Audio_buffer_index++; /* 8 bit */
378 | }
379 | }
380 | bufferstatus_local &= ~LOW_EMPTY;
381 | }
382 |
383 | /* End of the second half working buffer */
384 | if(bufferstatus_local & HIGH_EMPTY)
385 | {
386 | if (AUDIO_Length == LG_16_BITS)
387 | {
388 | for( i = (Audio_buffer_local_size / 4) ; i < (Audio_buffer_local_size / 2 ); i = i + 2 )
389 | {
390 | temp = *(s16*)(Audio_buffer+Audio_buffer_index);
391 | Audio_buffer_local[i+1] = Audio_buffer_local[i] = temp;
392 | Audio_buffer_index += 2; /* 16 bit */
393 | }
394 | }
395 | else
396 | {
397 | for(i = (Audio_buffer_local_size / 4); i < ((Audio_buffer_local_size) / 2)-1; i=i+2)
398 | {
399 | temp = ((s16)((*(Audio_buffer+Audio_buffer_index)^0x80)))<<8;
400 | Audio_buffer_local[i+1] = Audio_buffer_local[i] = temp;
401 | Audio_buffer_index++; /* 8 bit */
402 | }
403 | }
404 | bufferstatus_local &= ~HIGH_EMPTY;
405 | }
406 |
407 | if ( Audio_buffer_index == (Audio_buffer_size/2) )
408 | {
409 | audio_buffer_fill |= LOW_EMPTY;
410 | if ( audio_buffer_fill & HIGH_EMPTY )
411 | {
412 | AUDIO_Playback_Stop();
413 | }
414 | }
415 | if ( Audio_buffer_index >= Audio_buffer_size )
416 | {
417 | audio_buffer_fill |= HIGH_EMPTY;
418 | Audio_buffer_index = 0;
419 | if ( audio_buffer_fill & LOW_EMPTY )
420 | {
421 | AUDIO_Playback_Stop();
422 | }
423 | }
424 | }
425 |
426 |
427 | /*******************************************************************************
428 | * Function Name : AUDIO_Init_audio_mode
429 | * Description : Initialization for Audio Mode use of the WM8731 codec.set WM8731
430 | * to Audio Mode via I2C. enable STM32 I2S communication to send
431 | * audio samples (SPI2/I2S2 port) in DMA mode
432 | * Input : - length: 8 bits or 16 bits length sample
433 | * - frequency: 8 KHz, 16 KHz, 22 KHz, 44 KHz, 48 KHz sample
434 | * - format: mono, stereo
435 | * Output : None
436 | * Return : None
437 | * Attention : None
438 | *******************************************************************************/
439 | void AUDIO_Init_audio_mode(AUDIO_Length_enum length, uint16_t frequency, AUDIO_Format_enum format)
440 | {
441 | /* The MONO mode uses working buffer to dupplicate datas on the two channels
442 | and switch buffer half by half => uses DMA in circular mode */
443 |
444 | NVIC_InitTypeDef NVIC_InitStructure;
445 |
446 | StartPlay(frequency);
447 | /* DMA IRQ Channel configuration */
448 | #if defined(AUDIO_MAL_DMA_IT_TC_EN) || defined(AUDIO_MAL_DMA_IT_HT_EN) || defined(AUDIO_MAL_DMA_IT_TE_EN)
449 | /* SAI DMA IRQ Channel configuration */
450 | NVIC_InitStructure.NVIC_IRQChannel = AUDIO_MAL_DMA_IRQ;
451 | NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = EVAL_AUDIO_IRQ_PREPRIO;
452 | NVIC_InitStructure.NVIC_IRQChannelSubPriority = EVAL_AUDIO_IRQ_SUBRIO;
453 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
454 | NVIC_Init(&NVIC_InitStructure);
455 | #endif
456 |
457 | Audio_buffer_index = 0;
458 | AUDIO_Playback_status = NO_SOUND;
459 | AUDIO_Length = length;
460 | AUDIO_Frequency = frequency;
461 | AUDIO_Format = format;
462 |
463 | /* Buffers are supposed to be empty here */
464 | audio_buffer_fill = (AUDIO_PlaybackBuffer_Status) (LOW_EMPTY | HIGH_EMPTY );
465 | bufferstatus_local = (AUDIO_PlaybackBuffer_Status) (LOW_EMPTY | HIGH_EMPTY );
466 |
467 | DMA_Configuration((s8 *)AudioBuffer,(mp3FrameInfo.outputSamps*2));
468 |
469 | printf( "-- MP3 file header information \r\n");
470 | printf( "-------------------------------- \r\n");
471 | printf( "-- MP3 bitrate = %d\r\n", mp3FrameInfo.bitrate); /* ±ÈÌØÂÊ */
472 | printf( "-- MP3 bitsPerSample = %d\r\n", AUDIO_Length);
473 | printf( "-- MP3 samprate = %d\r\n", AUDIO_Frequency);
474 | printf( "-- MP3 nChans = %d\r\n", AUDIO_Format);
475 | printf( "-- MP3 nGranSamps = %d\r\n", ((MP3DecInfo *)hMP3Decoder)->nGranSamps);
476 | /* Êý¾ÝÖ¡´óС FrameSize = (((MpegVersion == MPEG1 ? 144 : 72) * Bitrate) / SamplingRate) + PaddingBit */
477 | printf( "-- MP3 outputSamps = %d\r\n", mp3FrameInfo.outputSamps);
478 | printf( "-- MP3 layer = %d\r\n", mp3FrameInfo.layer);
479 | printf( "-- MP3 version = %d\r\n", mp3FrameInfo.version);
480 | }
