1 | #ifndef KEYPAD_H
2 | #define KEYPAD_H
3 |
4 | #include "Key.h"
5 | #include "PCF8574.h"
6 | PCF8574 PCF(0x20);
7 |
8 | // bperrybap - Thanks for a well reasoned argument and the following macro(s).
9 | // See http://arduino.cc/forum/index.php/topic,142041.msg1069480.html#msg1069480
10 | #ifndef INPUT_PULLUP
11 | #warning "Using pinMode() INPUT_PULLUP AVR emulation"
12 | #define INPUT_PULLUP 0x2
13 | #define pinMode(_pin, _mode) _mypinMode(_pin, _mode)
14 | #define _mypinMode(_pin, _mode) \
15 | do { \
16 | if(_mode == INPUT_PULLUP) \
17 | pinMode(_pin, INPUT); \
18 | PCF.write(_pin, 1); \
19 | if(_mode != INPUT_PULLUP) \
20 | pinMode(_pin, _mode); \
21 | }while(0)
22 | #endif
23 |
24 |
25 | #define OPEN LOW
26 | #define CLOSED HIGH
27 |
28 | typedef char KeypadEvent;
29 | typedef unsigned int uint;
30 | typedef unsigned long ulong;
31 |
32 | // Made changes according to this post http://arduino.cc/forum/index.php?topic=58337.0
33 | // by Nick Gammon. Thanks for the input Nick. It actually saved 78 bytes for me. :)
34 | typedef struct {
35 | byte rows;
36 | byte columns;
37 | } KeypadSize;
38 |
39 | #define LIST_MAX 10 // Max number of keys on the active list.
40 | #define MAPSIZE 10 // MAPSIZE is the number of rows (times 16 columns)
41 | #define makeKeymap(x) ((char*)x)
42 |
43 |
44 | //class Keypad : public Key, public HAL_obj {
45 | class Keypad : public Key {
46 | public:
47 |
48 | Keypad(char *userKeymap, byte *row, byte *col, byte numRows, byte numCols);
49 |
50 | virtual void pin_mode(byte pinNum, byte mode) { pinMode(pinNum, mode); }
51 | virtual void pin_write(byte pinNum, boolean level) { PCF.write(pinNum, level); }
52 | virtual int pin_read(byte pinNum) { return PCF.read(pinNum); }
53 |
54 | uint bitMap[MAPSIZE]; // 10 row x 16 column array of bits. Except Due which has 32 columns.
55 | Key key[LIST_MAX];
56 | unsigned long holdTimer;
57 |
58 | char getKey();
59 | bool getKeys();
60 | KeyState getState();
61 | void begin(char *userKeymap);
62 | bool isPressed(char keyChar);
63 | void setDebounceTime(uint);
64 | void setHoldTime(uint);
65 | void addEventListener(void (*listener)(char));
66 | int findInList(char keyChar);
67 | int findInList(int keyCode);
68 | char waitForKey();
69 | bool keyStateChanged();
70 | byte numKeys();
71 |
72 | private:
73 | unsigned long startTime;
74 | char *keymap;
75 | byte *rowPins;
76 | byte *columnPins;
77 | KeypadSize sizeKpd;
78 | uint debounceTime;
79 | uint holdTime;
80 | bool single_key;
81 |
82 | void scanKeys();
83 | bool updateList();
84 | void nextKeyState(byte n, boolean button);
85 | void transitionTo(byte n, KeyState nextState);
86 | void (*keypadEventListener)(char);
87 | };
88 |
89 | #endif
