1 | #include <msp430.h>
2 | #include "base.h"
3 |
4 | void SPI_init(void); // initialize the SPI communication
5 | void SPI_send(unsigned int data);
6 | void CS_Init(void); // clock system
7 |
8 | int main(void)
9 | {
10 | WDTCTL = WDTPW + WDTHOLD; // stop Watchdog timer
11 |
12 | CS_Init(); // set Timing
13 |
14 | SPI_init(); // Initialize SPI-Module UCA1
15 |
16 | while (1)
17 | {
18 | //_low_power_mode_3 (); // do nothing
19 | }
20 | }
21 |
22 |
23 | void SPI_init(void)
24 | {
25 | SETBIT(P2SEL1, BIT4); // Select secondary function of P2.4 (UCA1CLK)
26 | SETBIT(P2SEL1, BIT5); // Select secondary function of P2.5 (UCA1SIMO)
27 | SETBIT(P2SEL1, BIT6); // Select secondary function of P2.6 (UCA1SOMI)
28 |
29 | SETBIT(P2DIR, BIT3); // Declare P2.3 as Select Slave port
30 | SETBIT(P2OUT, BIT3); // Start with high on Select Slave P2.3
31 |
32 | SETBIT(UCA1CTLW0, UCSWRST); // Software reset enable. Have to be selected here
33 | SETBIT(UCA1CTLW0, UCCKPH); // select clock phase to rising clock phase
34 | SETBIT(UCA1CTLW0, UCMSB); // direction of shift register
35 | SETBIT(UCA1CTLW0, UCMST); // SPI master
36 | SETBIT(UCA1CTLW0, UCSYNC); // Synchronous mode enable
37 | SETBIT(UCA1CTLW0, UCSSEL_2); // SMCLK clock selected
38 | }
39 |
40 | void SPI_send(unsigned int data)
41 | {
42 | UCA1TXBUF = data; // send data
43 | }
44 |
45 | void CS_Init(void) //clock system
46 | {
47 | // set up Clock System
48 | CSCTL0 = CSKEY; // enable clock system
49 | CSCTL1 = DCOFSEL_3; // frequency = 8,0 MHz
50 | CSCTL2 = SELA__XT1CLK | SELS__DCOCLK | SELM__DCOCLK; // select clock sources
51 | CSCTL3 = DIVA__8 | DIVS__32 | DIVM__8; // set frequency divider
52 | CSCTL4 = XT2OFF | XTS | XT1DRIVE_0; // XT2 disabled, XT1: HF mode, low power, no bypass
53 | CSCTL0_H = 0; // disable clock system
54 | }
