1 | #include <Arduino.h>
2 | #include "display.h"
3 | #include <LiquidCrystal_I2C.h>
4 | #include <LCDMenuLib2.h> //https://github.com/Jomelo/LCDMenuLib2
5 |
6 |
7 | displayUtils::displayUtils(){
8 | }
9 |
10 | // =====================================================================
11 | //
12 | // Output function
13 | //
14 | // =====================================================================
15 |
16 | void lcdml_menu_control()
17 | {
18 | // If something must init, put in in the setup condition
19 | if(LCDML.BT_setup()) {
20 | // runs only once
21 | }
22 | /*
23 | // check if new serial input is available
24 | if (Serial.available()) {
25 | // read one char from input buffer,
26 | switch (Serial.read())
27 | {
28 | case _LCDML_CONTROL_serial_enter: LCDML.BT_enter(); break;
29 | case _LCDML_CONTROL_serial_up: LCDML.BT_up(); break;
30 | case _LCDML_CONTROL_serial_down: LCDML.BT_down(); break;
31 | case _LCDML_CONTROL_serial_left: LCDML.BT_left(); break;
32 | case _LCDML_CONTROL_serial_right: LCDML.BT_right(); break;
33 | case _LCDML_CONTROL_serial_quit: LCDML.BT_quit(); break;
34 | default: break;
35 | }
36 | }*/
37 | }
38 |
39 | /* ******************************************************************** */
40 | void lcdml_menu_clear()
41 | /* ******************************************************************** */
42 | {
43 | lcd.clear();
44 | lcd.setCursor(0, 0);
45 | }
46 |
47 | /* ******************************************************************** */
48 | void lcdml_menu_display()
49 | /* ******************************************************************** */
50 | {
51 | // update content
52 | // ***************
53 | if (LCDML.DISP_checkMenuUpdate()) {
54 | // clear menu
55 | // ***************
56 | LCDML.DISP_clear();
57 |
58 | // declaration of some variables
59 | // ***************
60 | // content variable
61 | char content_text[_LCDML_DISP_cols]; // save the content text of every menu element
62 | // menu element object
63 | LCDMenuLib2_menu *tmp;
64 | // some limit values
65 | uint8_t i = LCDML.MENU_getScroll();
66 | uint8_t maxi = _LCDML_DISP_rows + i;
67 | uint8_t n = 0;
68 |
69 | }
70 | }
71 |
72 |
73 | if(LCDML.DISP_checkMenuCursorUpdate())
74 | {
75 | // init vars
76 | uint8_t n_max = (LCDML.MENU_getChilds() >= _LCDML_DISP_rows) ? _LCDML_DISP_rows : (LCDML.MENU_getChilds());
77 | uint8_t scrollbar_min = 0;
78 | uint8_t scrollbar_max = LCDML.MENU_getChilds();
79 | uint8_t scrollbar_cur_pos = LCDML.MENU_getCursorPosAbs();
80 | uint8_t scroll_pos = ((1.*n_max * _LCDML_DISP_rows) / (scrollbar_max - 1) * scrollbar_cur_pos);
81 |
82 | }
83 |
84 | // display scrollbar
85 | if (_LCDML_DISP_cfg_scrollbar == 1) {
86 | if (scrollbar_max > n_max) {
87 | //set scroll position
88 | if (scrollbar_cur_pos == scrollbar_min) {
89 | // min pos
90 | lcd.setCursor((_LCDML_DISP_cols - 1), 0);
91 | lcd.write((uint8_t)1);
92 | } else if (scrollbar_cur_pos == (scrollbar_max - 1)) {
93 | // max pos
94 | lcd.setCursor((_LCDML_DISP_cols - 1), (n_max - 1));
95 | lcd.write((uint8_t)4);
96 | } else {
97 | // between
98 | lcd.setCursor((_LCDML_DISP_cols - 1), scroll_pos / n_max);
99 | lcd.write((uint8_t)(scroll_pos % n_max) + 1);
100 | }
101 | }
102 | }
103 | }
104 | }
105 |
106 | void(* ptr_lcdml_menu_display)() = &lcdml_menu_display;
107 | void(* ptr_lcdml_menu_clear)() = &lcdml_menu_clear;
108 | void(* ptr_lcdml_menu_control)() = &lcdml_menu_control;
