1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.numeric_std.all;
4 | entity sortierer is
5 | generic (
6 | CNT_OFL : positive := ERGÄNZE ; -- Sekundentakt overflow
7 | TIME_WEG_K : positive := ERGÄNZE im Praktikum; -- Kunststoff-Werkstück, langer Weg
8 | TIME_WEG_M : positive := ERGÄNZE im Praktikum; -- Metall-Werkstück, kurzer Weg
9 | FWD : std_logic := '0';
10 | BCK : std_logic := '1';
11 | RUN : std_logic := '1';
12 | STP : std_logic := '0';
13 | WEG_K : std_logic := '0';
14 | WEG_M : std_logic := '1'
15 | );
16 | port (
17 | reset_n : in std_logic; -- Key3
18 | clk : in std_logic; --50 MHz
19 | oe_in : in std_logic; -- Switch 9
20 | opt_sens : in std_logic; -- optischer Sensor
21 | ind_sens : in std_logic; -- induktiv Sensor
22 | oe_n_out : out std_logic;
23 | weiche_out : out std_logic; -- Weg A / Weg B -Umschaltung
24 | motor_pwr_out : out std_logic; -- ...
25 | motor_dir_out : out std_logic -- Motor Drehrichtung
26 | );
27 | end entity sortierer;
28 | architecture arch of sortierer is
29 | -- signals
30 | signal cnt : unsigned( ERGÄNZE );
31 | signal time_s : unsigned(4 downto 0);
32 | signal weiche : std_logic;
33 | signal motor_pwr : std_logic;
34 | signal motor_dir : std_logic;
35 | type main_state_t is (idle, ERGÄNZE );
36 | signal main_state, next_main_state : main_state_t;
37 |
38 |
39 | begin
40 | sort_control : process(clk, reset_n) is
41 | begin
42 | if (reset_n = '0') then
43 | ERGÄNZE
44 | elsif rising_edge(clk) then
45 | main_state <= next_main_state; -- z_reg
46 |
47 | -- fast counter, overflow = 1s
48 | if cnt = to_unsigned(CNT_OFL, cnt'length) or main_state = idle then
49 | cnt <= (others => '0');
50 | else
51 | cnt <= cnt + 1;
52 | end if;
53 | -- Sekunden timer
54 | if main_state = idle then -- reset timer
55 | time_s <= (others => '0');
56 | elsif cnt = CNT_OFL then
57 | time_s <= time_s + 1;
58 | end if;
59 |
60 | case main_state is
61 | when idle => -- warte auf opt_sens hi
62 |
63 |
64 |
65 |
66 | ERGÄNZE
67 |
68 |
69 |
70 | when ……. =>
71 |
72 |
73 |
74 |
75 | ERGÄNZE
76 |
77 | when ……. =>
78 |
79 |
80 |
81 |
82 |
83 | ERGÄNZE
84 | when ……. =>
85 | ERGÄNZE
86 |
87 | when ……. =>
88 | ERGÄNZE
89 | when ……. =>
90 | ERGÄNZE
91 |
92 | end case;
93 | end if;
94 | oe_n_out <= not oe_in; -- voltage translator active
95 | weiche_out <= weiche;
96 | motor_pwr_out <= motor_pwr;
97 | motor_dir_out <= motor_dir;
