1 | // 2 servo planar stabilization system
2 | // wp
3 | // Jan 2016
4 | //
5 | // Based on Jeff Rowber's work found at
6 | // https://github.com/jrowberg/i2cdevlib/blob/master/Arduino/MPU6050/MPU6050.cpp
7 | //
8 | // Use at your own risk.
9 | //
10 | // This code is placed under the MIT License (MIT)
11 | //
12 | // Copyright (c) 2016 woojay poynter
13 |
14 | //Permission is hereby granted, free of charge, to any person obtaining a copy
15 | //of this software and associated documentation files (the "Software"), to deal
16 | //in the Software without restriction, including without limitation the rights
17 | //to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
18 | //copies of the Software, and to permit persons to whom the Software is
19 | //furnished to do so, subject to the following conditions:
20 |
21 | //The above copyright notice and this permission notice shall be included in all
22 | //copies or substantial portions of the Software.
23 |
24 | //THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
25 | //IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
26 | //FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
27 | //AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
28 | //LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
29 | //OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
30 | //SOFTWARE.
31 | //
32 |
33 | // Servo Connection
34 | // BROWN - gnd
35 | // red - 5v
36 | // yellow - d10 (pwm on Sero 1)
37 | // - d11 (servo 2)
38 |
39 | // MPU Connection
40 | //
41 | // VCC - 5v
42 | // GND - GND
43 | // SCL - A5 (w/ 10k PuR)
44 | // SDA - A4 (w/ 10k PuR)
45 | // INT - D2 (not used)
46 |
47 | #include <Servo.h>
48 | #include "I2Cdev.h"
49 | #include "MPU6050_6Axis_MotionApps20.h"
50 | //#include "MPU6050.h" // not necessary if using MotionApps include file
51 | #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
52 | #include "Wire.h"
53 | #endif
54 |
55 | #define LED_PIN 13
56 | bool blinkState = true;
57 |
58 | Servo Servo1; // First Servo off the chassis
59 | Servo Servo2; // Second Servo off the chassis
60 |
61 | int Servo1Pos = 0;
62 | int Servo2Pos = 0;
63 |
64 | float mpuPitch = 0;
65 | float mpuRoll = 0;
66 | float mpuYaw = 0;
67 |
68 |
69 | // define MPU instance
70 | MPU6050 mpu; // class default I2C address is 0x68; specific I2C addresses may be passed as a parameter here
71 |
72 | // MPU control/status vars
73 | uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
74 | uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
75 | uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
76 | uint16_t fifoCount; // count of all bytes currently in FIFO
77 | uint8_t fifoBuffer[64]; // FIFO storage buffer
78 |
79 | // orientation/motion vars
80 | Quaternion q; // [w, x, y, z] quaternion container
81 | VectorInt16 aa; // [x, y, z] accel sensor measurements
82 | VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
83 | VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
84 | VectorFloat gravity; // [x, y, z] gravity vector
85 | float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
86 |
87 | // relative ypr[x] usage based on sensor orientation when mounted, e.g. ypr[PITCH]
88 | #define PITCH 1 // defines the position within ypr[x] variable for PITCH; may vary due to sensor orientation when mounted
89 | #define ROLL 2 // defines the position within ypr[x] variable for ROLL; may vary due to sensor orientation when mounted
90 | #define YAW 0 // defines the position within ypr[x] variable for YAW; may vary due to sensor orientation when mounted
91 |
92 | // ================================================================
93 | // === INITIAL SETUP ===
94 | // ================================================================
95 |
96 | void setup()
97 | {
98 |
99 | Servo1.attach(10); // attaches the servo on D11 to the servo object
100 | Servo2.attach(11); // Second servo on D11
101 | delay(50);
102 | Servo1.write(0); // These are command checks to see if the servos work and
103 | Servo2.write(60); // to help w/ the initial installation.
104 | delay(500); // Make sure these movements are clear from the rest of the chassis.
105 | Servo1.write(180);
106 | Servo2.write(120);
107 | delay(500);
108 | Servo1.write(0);
109 | Servo2.write(90);
110 | delay(500);
111 |
112 | // join I2C bus (I2Cdev library doesn't do this automatically)
113 | #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
114 | Wire.begin();
115 | TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
116 | #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
117 | Fastwire::setup(400, true);
118 | #endif
119 |
120 | Serial.begin(115200);
121 | while (!Serial); // wait for Leonardo enumeration, others continue immediately
122 |
123 | // initialize device
124 | Serial.println(F("Initializing I2C devices..."));
125 | mpu.initialize();
126 |
127 | // verify connection
128 | Serial.println(F("Testing device connections..."));
129 | Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
130 |
131 | // load and configure the DMP
132 | Serial.println(F("Initializing DMP"));
133 | devStatus = mpu.dmpInitialize();
134 |
135 |
136 | // INPUT CALIBRATED OFFSETS HERE; SPECIFIC FOR EACH UNIT AND EACH MOUNTING CONFIGURATION!!!!
137 |
138 | mpu.setXGyroOffset(153);
139 | mpu.setYGyroOffset(-70);
140 | mpu.setZGyroOffset(5);
141 | mpu.setXAccelOffset(-2361);
142 | mpu.setYAccelOffset(-1722);
143 | mpu.setZAccelOffset(1225 );
144 |
145 | // make sure it worked (returns 0 if so)
146 | if (devStatus == 0)
147 | {
148 | // turn on the DMP, now that it's ready
149 | Serial.println(F("Enabling DMP"));
150 | mpu.setDMPEnabled(true);
151 |
152 | // enable Arduino interrupt detection
153 | Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)"));
154 | mpuIntStatus = mpu.getIntStatus();
155 |
156 | // get expected DMP packet size for later comparison
157 | packetSize = mpu.dmpGetFIFOPacketSize();
158 | }
159 | else
160 | {
161 | // ERROR!
162 | // 1 = initial memory load failed, 2 = DMP configuration updates failed (if it's going to break, usually the code will be 1)
163 | Serial.print(F("DMP Initialization failed code = "));
164 | Serial.println(devStatus);
165 | }
166 |
167 | // configure LED for output
168 | pinMode(LED_PIN, OUTPUT);
169 |
170 | } // setup()
171 |
172 |
173 |
174 | // ================================================================
175 | // === MAIN PROGRAM LOOP ===
176 | // ================================================================
177 |
178 | void loop(void)
179 | {
180 | processAccelGyro();
181 | } // loop()
182 |
183 |
184 |
185 | // ================================================================
186 | // === PROCESS ACCEL/GYRO IF AVAILABLE ===
187 | // ================================================================
188 |
189 | void processAccelGyro()
190 | {
191 |
192 | // Get INT_STATUS byte
193 | mpuIntStatus = mpu.getIntStatus();
194 |
195 | // get current FIFO count
196 | fifoCount = mpu.getFIFOCount();
197 |
198 | // check for overflow (this should never happen unless our code is too inefficient)
199 | if ((mpuIntStatus & 0x10) || fifoCount == 1024)
200 | {
201 | // reset so we can continue cleanly
202 | mpu.resetFIFO();
203 | Serial.println(F("FIFO overflow!"));
204 | return;
205 | }
206 |
207 | if (mpuIntStatus & 0x02) // otherwise continue processing
208 | {
209 | // check for correct available data length
210 | if (fifoCount < packetSize)
211 | return; // fifoCount = mpu.getFIFOCount();
212 |
213 | // read a packet from FIFO
214 | mpu.getFIFOBytes(fifoBuffer, packetSize);
215 |
216 | // track FIFO count here in case there is > 1 packet available
217 | fifoCount -= packetSize;
218 |
219 | // flush buffer to prevent overflow
220 | mpu.resetFIFO();
221 |
222 | // display Euler angles in degrees
223 | mpu.dmpGetQuaternion(&q, fifoBuffer);
224 | mpu.dmpGetGravity(&gravity, &q);
225 | mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
226 | mpuPitch = ypr[PITCH] * 160 / M_PI;
227 | mpuRoll = ypr[ROLL] * 160 / M_PI;
228 | mpuYaw = ypr[YAW] * 180 / M_PI;
229 |
230 | // flush buffer to prevent overflow
231 | mpu.resetFIFO();
232 |
233 | // blink LED to indicate activity
234 | blinkState = !blinkState;
235 | digitalWrite(LED_PIN, blinkState);
236 |
237 | // flush buffer to prevent overflow
238 | mpu.resetFIFO();
239 |
240 | Servo1.write(-mpuPitch + 90);
241 | Servo2.write(-mpuRoll + 90);
242 | //delay(10);
243 |
244 | // flush buffer to prevent overflow
245 | mpu.resetFIFO();
246 |
247 | } // if (mpuIntStatus & 0x02)
248 | } // processAccelGyro()
