1 | #include <content_xml.hpp>
2 | #include <Parser.hpp>
3 | #include <stdint.h>
4 | #include <stdlib.h>
5 | #include <string.h>
6 |
7 | using namespace std;
8 |
9 | extern volatile uint32_t Memory[1024];
10 |
11 |
12 | void ParserChar(char *ptr, uint16_t Len){
13 | //...
14 | }
15 |
16 | void ParserMem(uint32_t *ptr){
17 | //...
18 | }
19 |
20 |
21 | uint8_t StartParserXml(char *ptr, uint16_t Len){
22 | //...
23 | return 1;
24 | }
25 |
26 | uint8_t StartParserByte(uint32_t *ptr){
27 | //...
28 | return 1;
29 | }
30 |
31 | ClContent_xml** contentAdd(uint16_t inkrement){
32 | //...
33 | }
34 |
35 | uint8_t StartCheckXml(void){
36 | //...
37 | return 1;
38 | }
39 |
40 | uint8_t StartGenerateByte(uint32_t* ptr, uint16_t MaxLen){
41 | //...
42 | return 1;
43 | }
44 |
45 | uint32_t getByte(uint16_t i){
46 | //...
47 | return Value;
48 | }
49 |
50 | uint8_t NumData(char* ptr){
51 | //...
52 | return Nummer;
53 | }
54 |
55 | uint8_t IsNumeric(char* ptr){
56 | //...
57 | return 0;
58 | }
59 |
60 | uint8_t strToU8(char* ptr){
61 | //...
62 | return Val;
63 | }
64 |
65 | uint16_t strToU16(char* ptr){
66 | //...
67 | }
68 |
69 | uint32_t strToU32(char* ptr){
70 | //...
71 | return Val;
72 | }
73 |
74 | uint32_t strXToU32(char* ptr){
75 | //...
76 | return Val;
77 | }
78 |
79 | uint16_t* strToU16Array(char* ptr){
80 | uint16_t Val = 0;
81 | uint8_t Num = 0;
82 | uint8_t st = 0;
83 | uint16_t *Array, *LArray;
84 | char *Sptr;
85 | Sptr = ptr;
86 |
87 | // Anzahl der Zahlen ermitteln
88 | do{
89 | switch(*ptr){
90 | case '0':
91 | case '1':
92 | case '2':
93 | case '3':
94 | case '4':
95 | case '5':
96 | case '6':
97 | case '7':
98 | case '8':
99 | case '9':
100 | if((st & 0x02) == 0x00){
101 | Num++;
102 | st |= 0x02;
103 | }
104 | break;
105 | case ' ':
106 | case ',':
107 | if((st & 0x02) == 0x02){
108 | st = (st & ~0x02);
109 | }
110 | break;
111 | default:
112 | st |= 0x01;
113 | break;
114 | }
115 | ptr++;
116 | }while((st & 0x01) == 0);
117 |
118 | Array = new uint16_t[Num];
119 | LArray = Array;
120 |
121 | for(uint8_t i = 0; i < Num; i++){
122 | while((*Sptr == ' ') || (*Sptr == ',')){
123 | Sptr++;
124 | }
125 |
126 | *LArray = strToU16(Sptr);
127 |
128 | //printf("\n%i, Wert: %i, Adresse: 0x%x", i, *LArray, LArray);
129 |
130 | while(IsNumeric(Sptr)){
131 | Sptr++;
132 | }
133 | LArray++;
134 | }
135 | return Array;
136 | }
137 |
138 | uint32_t* strToU32Array(char* ptr, uint8_t Num){
139 | uint32_t Val = 0;
140 | uint8_t st = 0;
141 | uint32_t *Array, *LArray;
142 | char *Sptr;
143 | Sptr = ptr;
144 |
145 | Array = new uint32_t[Num];
146 | LArray = Array;
147 |
148 | for(uint8_t i = 0; i < Num; i++){
149 | // Leerzeichen ignurieren
150 | while(*ptr == ' '){
151 | ptr++;
152 | }
153 | if(1 == IsNumeric(ptr)){
154 | *LArray = strToU32(ptr);
155 | LArray++;
156 | do{
157 | ptr++;
158 | }while(1 == IsNumeric(ptr));
159 | }
160 | else{
161 | return Array;
162 | }
163 | }
164 | return Array;
165 | }
166 |
167 | uint32_t* strXToU32Array(char* ptr, uint8_t Num){
168 | uint32_t Val = 0;
169 | uint8_t st = 0;
170 | uint32_t *Array, *LArray;
171 |
172 | Array = new uint32_t[Num];
173 | LArray = Array;
174 |
175 | for(uint8_t i = 0; i < Num; i++){
176 | // Leerzeichen ignurieren
177 | while((*ptr == ' ') || (*ptr == ',')){
178 | ptr++;
179 | }
180 |
181 | if((1 == IsNumeric(ptr))){
182 | *LArray = strXToU32(ptr);
183 | LArray++;
184 | do{
185 | ptr++;
186 | }while((1 == IsNumeric(ptr)) || (*ptr == 'x') || (*ptr == 'X'));
187 | }
188 | else{
189 | return Array;
190 | }
191 | }
192 | return Array;
193 | }
194 |
195 | uint16_t setByteU8(uint8_t Value, uint16_t Inkrement){
196 | //...
197 | return Inkrement + 1;
198 | }
199 |
200 | uint16_t setByteU16(uint16_t Value, uint16_t Inkrement){
201 | //...
202 | return Inkrement + 2;
203 | }
204 |
205 | uint16_t setByteU32(uint32_t Value, uint16_t Inkrement){
206 | //...
207 | return Inkrement + 4;
208 | }
209 |
210 | uint16_t setByte(void){
211 | // MemByte in das Flash schreiben
212 | return 0;
213 | }
