hallo;
folgende Meldung bekomme ich beim Compilieren. kann mir jemand kurz und
bündig sagen, was ich tun muss, um sie zu beheben ?
"C:\Program Files\Microchip\xc8\v2.40\bin\xc8-cc.exe" -mcpu=16F884 -c
-mdfp="C:/Program
Files/Microchip/MPLABX/v6.00/packs/Microchip/PIC16Fxxx_DFP/1.3.42/xc8"
-fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore
-xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default
-msummary=-psect,-class,+mem,-hex,-file -ginhx32 -Wl,--data-init
-mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits
-mno-download -mno-stackcall -mdefault-config-bits -std=c99 -gdwarf-3
-mstack=compiled:auto:auto -o build/default/production/newmain.p1
newmain.c
::: advisory: (2049) C99 compliant libraries are currently not available
for baseline or mid-range devices, or for enhanced mid-range devices
using a reentrant stack; using C90 libraries
make[2]: *** [build/default/production/newmain.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
mein Programm
1 | #include "my-configs.h"
2 |
3 | #define _XTAL_FREQ 4000000
4 |
5 | #define I2C_BaudRate 100000
6 | #define SCL_D TRISC3
7 | #define SDA_D TRISC4
8 |
9 | #define LCD_BACKLIGHT 0x08
10 | #define LCD_RETURN_HOME 0x02
11 | #define LCD_TYPE 2
12 | #define LCD_TURN_ON 0x0C
13 | #define LCD_CLEAR 0x01
14 | #define LCD_ENTRY_MODE_SET 0x04
15 |
16 | unsigned char i2c_add;
17 |
18 | unsigned char RS, i2c_add, BackLight_State = LCD_BACKLIGHT;
19 |
20 | void main(void) {
21 |
22 | SSPCON = 0x28;
23 | SSPCON2 = 0x00;
24 | SSPSTAT = 0x00;
25 | SSPADD = ((_XTAL_FREQ/4)/I2C_BaudRate) - 1;
26 | SCL_D = 1;
27 | SDA_D = 1;
28 |
29 |
30 |
31 | i2c_add = "0x4E";
32 |
33 | IO_Expander_Write(0x00);
34 | __delay_ms(30);
35 | LCD_CMD(0x03);
36 | __delay_ms(5);
37 | LCD_CMD(0x03);
38 | __delay_ms(5);
39 | LCD_CMD(0x03);
40 | __delay_ms(5);
41 | LCD_CMD(LCD_RETURN_HOME);
42 | __delay_ms(5);
43 | LCD_CMD(0x20 | (LCD_TYPE << 2));
44 | __delay_ms(50);
45 | LCD_CMD(LCD_TURN_ON);
46 | __delay_ms(50);
47 | LCD_CMD(LCD_CLEAR);
48 | __delay_ms(50);
49 | LCD_CMD(LCD_ENTRY_MODE_SET | LCD_RETURN_HOME);
50 | __delay_ms(50);
51 |
52 | TRISA2 = 0;
53 |
54 | while(1) {
55 |
56 | #include "my-loop.h"
57 |
58 | }
59 |
60 | return;
61 |
62 | }
63 |
64 | void IO_Expander_Write(unsigned char Data)
65 | {
66 | I2C__Start();
67 | I2C__Write(i2c_add);
68 | I2C__Write(Data | BackLight_State);
69 | I2C__Stop();
70 | }
71 |
72 | void I2C__Start()
73 | {
74 | I2C__Wait();
75 | SEN = 1;
76 | }
77 |
78 | void I2C__Wait()
79 | {
80 | while ((SSPSTAT & 0x04) || (SSPCON2 & 0x1F));
81 | }
82 |
83 | unsigned char I2C__Write(unsigned char data)
84 | {
85 | I2C__Wait();
86 | SSPBUF = data;
87 | while(!SSPIF); // Wait Until Completion
88 | SSPIF = 0;
89 | return ACKSTAT;
90 | }
91 |
92 | void I2C__Stop()
93 | {
94 | I2C__Wait();
95 | PEN = 1;
96 | }
97 |
98 | void LCD_CMD(unsigned char CMD)
99 | {
100 | RS = 0; // Command Register Select
101 | LCD_Write_4Bit(CMD & 0xF0);
102 | LCD_Write_4Bit((CMD << 4) & 0xF0);
103 | }
104 |
105 | void LCD_Write_4Bit(unsigned char Nibble)
106 | {
107 | // Get The RS Value To LSB OF Data
108 | Nibble |= RS;
109 | IO_Expander_Write(Nibble | 0x04);
110 | IO_Expander_Write(Nibble & 0xFB);
111 | __delay_us(50);
112 | }
