Hi, Sorry for posting in english... I have followed the tutorial ( http://www.mikrocontroller.net/Eclipse%20und%20MSPGCC/ ) to configure eclipse to program and debug a msp430... Consequently I use : Platform : Ecplise-sdk-3.1.2-win32 Plugin : org.eclipse.cdt-3.0.2-win32x86 and net.sf.mspgcc Compiler : mspgcc-20060119 Anyway I have these problems : 1) When I create a project, this warning appears : error launching external scanner info generator (gcc -E -P -v -dD C:/NATATION/Eclipse/Workspace/.metadata/.plugins/org.eclipse.cdt.make.co re/specs.cpp 2) In the project properties, I can't specify the MCU type in the mspgcc gcc c/c++ linker Do you have any idea to reach these problems ??? Thanks
I have reached the 2 first errors... Anyway, it still does not work ! I'm using the files that are given in the tutorial... I add them to my project, but I haven't the binaries files as the pictures shows... Consequently, I can't use the debugger ?? Do you know what is my problem ?? Thanks
> 1) When I create a project, this warning appears : > error launching external scanner info generator (gcc -E -P -v > -dD Same here. Ignore this error. Eclipse is looking for the executable gcc-file that of course doesn't exist. C:/NATATION/Eclipse/Workspace/.metadata/.plugins/org.eclipse.cdt.make.co re/specs.cpp > > 2) In the project properties, I can't specify the MCU type in the > mspgcc gcc c/c++ linker Same here, too. You can enter the correct MCU type, apply the settings, close eclipse, open it and the entry is disappeared. Update to 3.3 or ignore this error. The linker will use your entry. Please post your two error messages.
