Circuit Cellar veranstaltet wieder einen Wettbewerb, bei dem man kostenlose Samples bekommen kann. Dieses mal ein TCP/IP-Modul (Chip mit Hardware-TCP/IP-Stack + MagJack): http://www.circuitcellar.com/wiznet/sample.html Obwohl ich am 24.9. schon darauf hingewiesen habe, sind immer noch Samples zu haben. Komisch... Die Dinger gehen doch sonst weg wie die warmen Samples.
Guten Tag Xenu Nach Deinem Hinweis von 24. Septemper habe ich mich um ein Sample beworben. Aber nie eine Antwort erhalten, geschweige denn ein Sample. Wenn jedem dasselbe passiert, ist es verstaendlich, dass die Samples nie ausgehen. :)
also ich hab mich heut darauf hin gemeldet und siehe da This e-mail confirms that your request for the WIZnet iEthernet Design Contest sample has been approved. All shipments are being sent via USPS for both Domestic and International shipments. Please allow 2-3 weeks for delivery. The WIZ810MJ is a network module that carries the W5100 (TCP/IP hardwired chip, includes PHY) and MAG-JACK (RJ-45 with X’FMR) with other glue logics. It can be used as a component and no effort is required to interface the W5100 and Transformer. The WIZ810MJ is an ideal option for users who want to develop their Internet-enabling systems rapidly. For more detailed information about the WIZ810MJ and the eligible contest part (the W5100), please review the datasheets that can be found at www.wiznet.co.kr/. You will also find the W5100 porting guide at the WIZnet site. Be sure to read the Circuit Cellar contest primer article iEthernet Bootcamp: Get Started with the W5100 You are welcome to physically use the WIZ810MJ as part of your project submission or you can make your own printed circuit board that includes the W5100. (The W5100 chip is the only required contest device. You may use any other MCU or peripheral device in addition to the W5100.) You may also use other WIZnet boards that include the W5100. These may be purchased through www.ewiznet.com/. usw usw usw Danke für den Tipp
Auch danke, ich habe das ausgefüllt, mal schauen was passiert.
Jouh, danke für den Tip, hab mich auch angemeldet und ne Bestätigungsmail bekommen, dass sie es mir schicken. Mal gespannt, ob das Teil jetzt ankommt... Gruß Boxi
"Obwohl ich am 24.9. schon darauf hingewiesen habe, sind immer noch Samples zu haben. Komisch... Die Dinger gehen doch sonst weg wie die warmen Samples." Ganz einfach: Das ist doch diesmal nur was richtig Billiges. Da lohnt sich der Aufwand nicht. 10-12 Euro ist der Krempel wert. Die letzten Wettbewerbe von CC haben immerhin Zeugs für nicht unter 40-50 Euro gebracht. Auch ich habe hier deshalb nicht mitgemacht.
@Der Abstauber:
> Auch ich habe hier DESHALB nicht mitgemacht.
Soll das heißen, du gehörst zu denen, die bei so was nur mitmachen, um
den Artikel danach gewinnbringend zu verscherbeln?
Ich glaube nicht, das das Sinn und Zweck solcher Aktionen ist!
Zwar hatte ich keine email-Bestaetigung erhalten, aber nichtsdestotrozt war gestern ein Riesen-Briefumschlag im Briefkasten. :) Nochmals ein Dankeschön an Xenu Gruesse aus Istanbul
"Soll das heißen, du gehörst zu denen, die bei so was nur mitmachen, um den Artikel danach gewinnbringend zu verscherbeln? Ich glaube nicht, das das Sinn und Zweck solcher Aktionen ist!" Naja, nicht nur. Von den AVR-Programmern habe ich 3 selber im Einsatz und die 4 Keil-LPC2138-Platinen sind auch alle verbaut, ebenso die 12 Samples dazu. Die Renesas-Kits habe ich allerdings in der Tat allesamt mit den Samples verkauft...
So heut ist mein modul gekommen und ich arbeite mich ins datenblatt ein. Ich werd ein mega64 verwenden zur kordination. Wie sieht es bei euch aus? Schon einer beim proggen? c.u Commtel
Und gibt es schon erfolge? Was für Software ist da AVR-technisch notwendig um das laufen zu bekommen? weil ein tcp/ip stack ist ja scheinbar schon dabei
Ich hab eine Platine für das Modul gezeichnet. Siehe hier: Beitrag "WIZ810 (WIZ5100) an XMEM Interface (AVR)" Die Platine ist auch kompatibel zum Mega 64. Gruß Robert
Mein Modul ist heute gekommen. Ging dann ja doch um einiges schneller als von denen angekündigt. "Dummerweise" bin ich in der Zwischenzeit auf den ENC28J60 gekommen, der ist für meine Zwecke vermutlich besser (weniger Pins, leichter erhältlich, etwas weniger Energieverbrauch, 10MBit reichen). Beide Chips sind aber recht "gierig", finde ich. Gibt es vielleicht noch was nettes in der Art? Den XPort habe ich schon verwendet, braucht auch viel Strom, finde ihn etwas überdimensioniert und zu teuer. Ist allerdings ein Zeitsparer.
