Hi, ich suche jemand der die oben genannte Kombination nutzt. Kann mir jemand sein funktionierendes config-file und Skript-file zum Flashen des uC geben? Bei mir bleibt das Script nach dem Flashen stehen und meldet nach der Wartezeit im Skript einen Timeout. Unten habe ich mal die Fehlermeldung angehängt. Danke im Voraus, Stefan Info: configuration.c:56 configuration_output_handler(): opened fury_ft2232_flash.cfg Info: jtag.c:1230 jtag_examine_chain(): JTAG device found: 0x3ba00477 (Manufacturer: 0x23b, Part: 0xba00, Version: 0x3) Info: configuration.c:56 configuration_output_handler(): opened program.script Info: target.c:236 target_init_handler(): executing reset script 'program.script' Info: configuration.c:56 configuration_output_handler(): requesting target halt... Warning: cortex_m3.c:433 cortex_m3_halt(): target was already halted Info: configuration.c:56 configuration_output_handler(): target already halted Info: configuration.c:56 configuration_output_handler(): waiting for target halted... Info: configuration.c:56 configuration_output_handler(): target halted Info: configuration.c:56 configuration_output_handler(): waiting for target halted... Info: configuration.c:56 configuration_output_handler(): target halted Info: configuration.c:56 configuration_output_handler(): flash 'stellaris' found at 0x00000000 Info: configuration.c:56 configuration_output_handler(): #0: stellaris at 0x00000000, size 0x00040000, buswidth 0, chipwidth 0 Info: configuration.c:56 configuration_output_handler(): Info: configuration.c:56 configuration_output_handler(): LMI Stellaris information: Chip is class 1(Fury) LM3S6965 vA.2 Info: configuration.c:56 configuration_output_handler(): did1: 0x1073402d, arch: 0x1073402d, eproc: ARMV7M, ramsize:64k, flashsize: 256k Info: configuration.c:56 configuration_output_handler(): master clock(estimated): 22500kHz, rcc is 0x78e3ad1 Info: configuration.c:56 configuration_output_handler(): pagesize: 1024, lockbits: 128 0xffffffff, pages in lock region: 2 Info: configuration.c:56 configuration_output_handler(): Info: configuration.c:56 configuration_output_handler(): erased sectors 0 through 255 on flash bank 0 in 0s 771109us User: target.c:390 default_mmu(): No MMU present Warning: stellaris.c:776 stellaris_write_block(): Algorithm flash write 87 words to 0x0, 87 remaining Info: configuration.c:56 configuration_output_handler(): wrote 348 byte from file ProjektNeu.bin to flash bank 0 at offset 0x00000000 in 1s 71541us (0.317154 kb/s) Info: configuration.c:56 configuration_output_handler(): Timed out waiting for reset Open On-Chip Debugger (2008-02-23 10:00 CET) svn: 320 $URL: http://svn.berlios.de/svnroot/repos/openocd/trunk $
