1 | .config:308:warning: trying to assign nonexistent symbol PCI_GOBIOS
2 | .config:309:warning: trying to assign nonexistent symbol PCI_GOMMCONFIG
3 | .config:310:warning: trying to assign nonexistent symbol PCI_GODIRECT
4 | .config:311:warning: trying to assign nonexistent symbol PCI_GOANY
5 | .config:312:warning: trying to assign nonexistent symbol PCI_BIOS
6 | .config:313:warning: trying to assign nonexistent symbol PCI_DIRECT
7 | .config:314:warning: trying to assign nonexistent symbol PCI_DOMAINS
8 | .config:315:warning: trying to assign nonexistent symbol PCIEPORTBUS
9 | .config:324:warning: trying to assign nonexistent symbol HOTPLUG_PCI
10 | .config:1047:warning: trying to assign nonexistent symbol EDD
11 | .config:1048:warning: trying to assign nonexistent symbol DELL_RBU
12 | .config:1049:warning: trying to assign nonexistent symbol DCDBAS
13 | .config:1050:warning: trying to assign nonexistent symbol DMIID
14 | .config:1261:warning: trying to assign nonexistent symbol EARLY_PRINTK
15 | .config:1262:warning: trying to assign nonexistent symbol DEBUG_STACKOVERFLOW
16 | .config:1263:warning: trying to assign nonexistent symbol DEBUG_STACK_USAGE
17 | .config:1264:warning: trying to assign nonexistent symbol DEBUG_PAGEALLOC
18 | .config:1265:warning: trying to assign nonexistent symbol DEBUG_RODATA
19 | .config:1266:warning: trying to assign nonexistent symbol DEBUG_RODATA_TEST
20 | .config:1267:warning: trying to assign nonexistent symbol DEBUG_NX_TEST
21 | .config:1268:warning: trying to assign nonexistent symbol 4KSTACKS
22 | .config:1269:warning: trying to assign nonexistent symbol DOUBLEFAULT
23 | .config:1270:warning: trying to assign nonexistent symbol IO_DELAY_TYPE_0X80
24 | .config:1271:warning: trying to assign nonexistent symbol IO_DELAY_TYPE_0XED
25 | .config:1272:warning: trying to assign nonexistent symbol IO_DELAY_TYPE_UDELAY
26 | .config:1273:warning: trying to assign nonexistent symbol IO_DELAY_TYPE_NONE
27 | .config:1274:warning: trying to assign nonexistent symbol IO_DELAY_0X80
28 | .config:1275:warning: trying to assign nonexistent symbol IO_DELAY_0XED
29 | .config:1276:warning: trying to assign nonexistent symbol IO_DELAY_UDELAY
30 | .config:1277:warning: trying to assign nonexistent symbol IO_DELAY_NONE
31 | .config:1278:warning: trying to assign nonexistent symbol DEFAULT_IO_DELAY_TYPE
32 | .config:1279:warning: trying to assign nonexistent symbol DEBUG_BOOT_PARAMS
33 | .config:1280:warning: trying to assign nonexistent symbol CPA_DEBUG
34 | .config:1340:warning: trying to assign nonexistent symbol VIRTUALIZATION
35 | .config:1341:warning: trying to assign nonexistent symbol LGUEST
36 | .config:1342:warning: trying to assign nonexistent symbol VIRTIO_PCI
37 | .config:1343:warning: trying to assign nonexistent symbol VIRTIO_BALLOON
38 | *
39 | * Restart config...
40 | *
41 | *
42 | * System Type and features
43 | *
44 | AVR32 board type
45 | > 1. ATSTK1000 evaluation board (BOARD_ATSTK1000) (NEW)
46 | 2. ATNGW100 Network Gateway (BOARD_ATNGW100) (NEW)
47 | 3. In-Circuit ICNova based board (BOARD_ICNOVA) (NEW)
48 | choice[1-3]: 3
49 | ICNova option
50 | > 1. ICNova without LCD nor 2nd MAC (BOARD_ICNOVA_NONE) (NEW)
51 | 2. ICNova with LCD-Controller (BOARD_ICNOVA_LCDC) (NEW)
52 | 3. ICNova with 2nd Ethernet-MAC (BOARD_ICNOVA_MACB) (NEW)
53 | 4. ICNova Base (BOARD_ICNOVA_BASE) (NEW)
54 | choice[1-4]: 1
55 | Boot loader type
56 | > 1. U-Boot (or similar) bootloader (LOADER_U_BOOT) (NEW)
57 | choice[1]: 1
58 | *
59 | * Atmel AVR32 AP options
60 | *
61 | AT32AP700x static memory bus width
62 | 1. 32 bit (AP700X_32_BIT_SMC) (NEW)
63 | > 2. 16 bit (AP700X_16_BIT_SMC) (NEW)
64 | 3. 8 bit (AP700X_8_BIT_SMC) (NEW)
65 | choice[1-3?]:
66 | GPIO /dev interface (GPIO_DEV) [N/y/?] (NEW) Y
67 | Preemption Model
68 | > 1. No Forced Preemption (Server) (PREEMPT_NONE)
69 | 2. Voluntary Kernel Preemption (Desktop) (PREEMPT_VOLUNTARY)
70 | 3. Preemptible Kernel (Low-Latency Desktop) (PREEMPT)
71 | choice[1-3]: 1
72 | Enable tracing for RCU - currently stats in debugfs (RCU_TRACE) [N/y/?] n
73 | Memory model
74 | > 1. Flat Memory (FLATMEM_MANUAL)
75 | choice[1]: 1
76 | 64 bit Memory and IO resources (EXPERIMENTAL) (RESOURCES_64BIT) [N/y/?] n
77 | Ownership trace support (OWNERSHIP_TRACE) [Y/n/?] (NEW)
78 | NMI Debugging (NMI_DEBUGGING) [N/y/?] (NEW)
79 | Synopsys DesignWare DMA Controller support (DW_DMAC) [Y/n/m] (NEW)
80 | Timer frequency
81 | 1. 100 HZ (HZ_100)
82 | > 2. 250 HZ (HZ_250)
83 | 3. 300 HZ (HZ_300)
84 | 4. 1000 HZ (HZ_1000)
85 | choice[1-4?]: 2
86 | Default kernel command line (CMDLINE) [] (NEW)
87 | *
88 | * CPU Frequency scaling
89 | *
90 | CPU Frequency scaling (CPU_FREQ) [Y/n/?] y
91 | Enable CPUfreq debugging (CPU_FREQ_DEBUG) [Y/n/?] y
92 | CPU frequency translation statistics (CPU_FREQ_STAT) [N/m/y/?] n
93 | Default CPUFreq governor
94 | 1. performance (CPU_FREQ_DEFAULT_GOV_PERFORMANCE)
95 | 2. userspace (CPU_FREQ_DEFAULT_GOV_USERSPACE)
96 | 3. ondemand (CPU_FREQ_DEFAULT_GOV_ONDEMAND)
97 | > 4. conservative (CPU_FREQ_DEFAULT_GOV_CONSERVATIVE)
98 | choice[1-4?]: 4
99 | 'performance' governor (CPU_FREQ_GOV_PERFORMANCE) [Y/?] y
100 | 'powersave' governor (CPU_FREQ_GOV_POWERSAVE) [N/m/y/?] n
101 | 'userspace' governor for userspace frequency scaling (CPU_FREQ_GOV_USERSPACE) [N/m/y/?] n
