PHILIPS VPx500 Kernel/System Development
(Firma: DC3AX) #1653010
Ich eröffne jetzt einfach diesen Thread, der direkt mit diesem hier:
Beitrag "PHILIPS VP5500 VoIP Telefon bei Pollin"
in Zusammenhang steht. In diesem Thread hier geht es jedoch
ausschließlich um:
Entschlüsselung der Hardware
Treiber Entschlüsselung und Entwicklung
Kernel Entschlüsselung und Entwicklung
Bitte alles andere, Konfiguration, Anbindung an SIP Provider oder
Fritz!Box  in oben angeführten Thread belassen.
Verehrte Moderatoren, ich hoffe, ich habe Euer Einverständnis, dass
dieser Thread auch gemischt in Englisch geführt wird, da einige
verdiente Teilnehmer sonst ausgeschlossen wären.
Dear VPx500 users and developers,
this thread is directly related to the following one:
But this discussion is only for:
Decoding the hardware of the Philips VPx500 series phones
Decoding and developing of drivers and modules
Decoding and developing of kernels
Please keep any questions about configuration and SIP connection in the
other thread.
Best regards and thanks in advance
Ulrich
#1653039
Hi all,
thanks to Ulrich for finally starting a new thread. I'd propose that we
use English as the main language here (the main part of the
platform/kernel/toolchain related discussion has always been in
English). Of course, if the mikrocontroller.net rules require
communication to be in German, we'd be forced to create a mishmash ;-)
/G
#1653062
to understand the functionality of the hardware, we have to reverse
engineer the system software (and drivers?). So, my first question is:
What software is being reverse engineered right now?
There is a gdbserver on the phone, it should be possible to reverse
engineer /user_data/prod/bin/APPTvlink.exe. But maybe IDA is a better
choice?!
Are the *.qm files in /usr/local/i18n/nl just language-files? Viewed
under a hex-editor, it seems like they are just containing some strings.
Another question which comes up to my mind: Isnt it theoretically
possible to play music by using /dev/audio or something ? .au or .wav
files...
I'm not experienced in reverse engineering devices, but windows
software. Maybe i can help out anyway.
(Firma: DC3AX) #1653110
Eddy Sino schrieb:
> Hi,
Good question. I asked for a matrix of what we have, what we know and
what we need. But, as splitting the threads, you must simply start it
without thinking about cons and pros. But before I start the matrix, I
am busy with getting openocd connected to the phone.
> choice?!
I am not sure if the tv system is the right point of priority :)
But anyway, diving in deeper never is a wrong thing.
I never worked with gdb before, but should not be a problem if openocd
is running. I don't know if the gdb inside is configured for using the
serial port or the JTAG. We'll find out.
There is no reason to go both ways. People with good equipment should
concentrate on the hardware decoding, people with deeper linux knowledge
should concentrate on the software. If you are familliar with 'hacking'
and can work with those big battleships like IDA, keep it going.
> Another question which comes up to my mind: Isn't it theoretically
> files...
Yes, it should be, as the system already uses wav for ringtones. I doubt
that there is any mp3 support built in, but if this thread succeeds, we
should be able to do what we want on this device.
While we first have to get a toolchain going for the device, we later
need people who can write code for the device and may be tools for Linux
and Windows computers. So there is no argument against any sort of
programmer.
This whole project lives only from contribution, time, fun and people
that like to share knowledge and are willing to learn.
(Firma: Atelier Klippel) #1653117
Hello,
there are five files that are of interrest right now:
/user_data/prod/bin/APPSensor.exe - accessing the camera
/user_data/prod/bin/APPTvlink.exe - acessing the TV ouput
/user_data/prod/bin/aic14_conf and test_aic14 - acessing the audio
devices
/user_data/prod/HD1V00_ats.sh - various registers and controls
The last one is a shell script, so that is really easy.
The first four interact with the device nodes:
/dev/sensor - camera device
/dev/dspX - audio devices, earpiece, headset and handsfree have seperate
devices
/dev/fbX - frame buffer devices for LCD and TV-output
Things like the backlight, keyboard LED's, etc. are accessed through the
"mm" binary, that directly reads or writes of/to a given memory address
(= register of the ARM CPU).
Another important device node is /dev/buttons, this is the interface to
the buttons/keypad.
Most of the kernel drivers are available in the Freescale Linux BSP for
the i.MX21.
Next week or weekend i will start to reverse the four executables to
gather information about the used sysctl calls and read/write
operations. I'm going to use IDA-Pro for that task, since i'm already
familiar with it from another project that involved reverse engineering
of an existing firmware for an ARM chip. Using the gained information i
will write some little programs to demonstrate the access to the
devices.
Greetings,
Chris
(Firma: DC3AX) #1653409
Hardware / JTAG
Has anyone seen the JTAG Port on the VP6500? There is a contact row
looking the same like on the VP5500 beyond the LCD. But is has a
different pinning, as GND is not available on it. And it is located
right below the Wireless Chip. I fear it is for reprogramming this guy,
not the iMX...
Hat schon jemand den JTAG für den iMX auf dem VP6500 ausfindig gemacht.
Die kleine Test-Pin Reihe unter dem Display scheint eher für den Philips
Wireless Chip zu sein.
(Firma: DC3AX) #1653501
g457 schrieb:
> Das VP6500 hat neben dem WLAN-Chip unter der Abschirmung noch einen
> potenziellen TAP (siehe Foto in [1]).
Hi!
Also dann ist es wohl eher so, dass der Tap unter der Abschirmung für
den WLAN und der auf der Unterseite für den iMX ist. Hatte aber noch
nicht weiter gesucht. Hatte ein Problem mit dem Zerlegten VP6500 und
seiner Versorgung. Das NT hat wohl die Begrenzung zu niedrig gehabt und
nun bootet das Tel zwar bis zu einem gewissen Punkt, schaltet sich dann
aber aus. Kommt nicht übere die Sanduhr hinweg.
Egal, dafür soll das JTAG ja da sein :)
(Firma: Atelier Klippel) #1653723
Christian H. schrieb:
> Vielleicht hat es ja bereits jemand herausgefunden.
> Gibt es die Möglichkeit, das Telefon sofort beim Anlegen der Spannung zu
> starten und nicht per "EIN"-Taste? Das würde die Zweckentfremdung des
> Gerätes noch unterstützen.
> Can we start the phone on power-up an not by pressing the "hang-up"-key?
> I want to use the hardware not as phone.
It does start automatically when placed in the charging craddle. So
there seems to be some mechanism for that.
Greetings,
Chris
(Firma: Atelier Klippel) #1653849
Hello,
i finally succeeded in compiling/installing the Freescale BSP for the
i.MX21. The original package can be found here:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX21&fpsp=1&tab=Design_Tools_Tab
It's the "Linux BSP for Freescale i.MX21ADS"
Now, there have been some hickups initially, but i was able to sort them
out. On your host Linux, the symlink /bin/sh must point to /bin/bash.
For some reason on the Kubuntu box it pointed to /bin/dash instead,
which caused some errors for things that used stuff like "mkdir
{a,b,c}". Dash creates {a,b,c} literally, whereas bash creates the three
directories a, b and c instead.
Next thing is that you must use gcc/g++ version 3.x. The 4.x version
fails to compile some sources.
Now, during compiling, some stuff requires to include the file
"Python.h". This file is located under /usr/include/python2.X/, where X
is the minor version number. However, the standard include path is only
/usr/include, so it fails to find it. To solve that problem, you have to
do
export C_INCLUDE_PATH=/user/include/python2.X
Again, where X is the minor version number. Check out which directory
holds the Python.h file and have it point there.
Starting the install of the BSP will tell you about some packages that
you need to install. So install them first.
For some reason the first run of ltib sometimes fails, the log shows the
error:
Hello,
do
error:
ERROR: /tmp/rpm-XXXX/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm
would clobber reescale/ltib
where XXXX is the username you are logged in at. In that case, simply
delete all the rpm-XXXX directories under /tmp and run ltib again. This
time it should finish without any error.
The result is a working BSP for the chip used in the phone. It has the
exact same kernel version 2.4.20-celf3 compiled for the same
architecture, armv5EJl. The gcc/g++ and clib versions also match the
ones on the phone. They also use blob as bootloader.
This will give us a complete toolchain, kernel sources and modules for
most of the stuff on the phone. Missing kernel modules in the BSP for
the propietary thing in the phone can thus be replaced by the original
modules from that phone.
So, later this week i will start with reverse engineering the test-apps
from the phone.
Greetings,
Chris
(Firma: DC3AX) #1653870
Congratulations, Chris!
I'll investigate for the JTAG in the next Day but I will be on vacation
from Thrusday till Tuesday. Hope I got it finished till then including a
description here or in the wiki.
I think JTAG will give better performance of uploading a kernel to the
phone than serial port does....
(Firma: Atelier Klippel) #1653882
Well, depends on the JTAG interface used. Good ones are really fast,
average ones are still fast, but very simple/bad ones can be slower.
Does anyone here have some web/ftp space where i could upload the VMware
image for the stuff i'm working on? So far i got the BSP installed
cleanly, now i'll tweak the system a bit to give a nice development
environment. Once that is done, i'd like to upload the stuff somewhere,
so that others can use it as well.
Greetings,
Chris
Edit: Same goes for serial ports as well. A real serial port will give
you the full speed. A USB adapter will almost never give you the full
115200 baud. It's simply because of the way USB serial adapters work
(one 64 byte package max., every milisecond). If you then have to use a
protocol that has a lot of back-and-forth communication going, USB is a
bottleneck for that.
(Firma: DC3AX) #1653996
I use openocd-usb dongle from the mikrocontroler.net shop with openocd.
But I compile it agains FTD2xx drivers what gives a lot more speed that
libusb.
Depending on the target and board layout I use it with speeds from
6..10MHz.
I only have a personal server running at home, but DSL is not the best
carrier for such a thingy. Ask one of the mods how to deal with packages
like this.
(Firma: Atelier Klippel) #1654299
Hello,
so, i have the virtual machine set up so far. The BSP is installed, some
development tools, the helloworld program compiles using the toolchain
from the BSP.
If anyone is interrested in getting this VM image, just write me a
message there: http://www.mikrocontroller.net/user/show/mamalala
I will then get back to you with my address. Simply send an empty 4.7 GB
DVD (no double sided or other fancy stuff) in a padded envelope. Write
your own address on that envelope and put enough stamps on it. Then put
that into another, simple envelope and send that to me. I will then burn
the DVD and send it back to you.
If you are outside of Germany we have to find a different solution.
Either put some Euros in there for the postage, or through PayPal or
whatever.
Greetings,
Chris
Gast #1654354
Wie groß ist das vmware image denn aktuell? Eventuell könnte ich es bei
mir hochladen .... das problem an der geschichte ist das ich limierten
traffic habe und danach runtergeschaltet werde .... sind zwar zwei tb
aber wenn das ding entsprechend oft runtergeladen wird auch recht
schnell weg ;-)
(Firma: Nederland Live) #1654368
Hi All,
Sorry for my long absence, i'm kinda busy lately (have to make a living
somehow ;)). I just read up with the initial thread and saw this new
thread was made, great. It was getting kinda crowded over there ;)
@Chris
I see you already figured out the probs with LTIB, it was indeed picky
about dash/bash. I'm switching over all the time ;) It's also build by
someone using an .rpm based system.. not my cup of tea, but with some
work it works very well under .deb based systems (i'm using Karmic at my
desktop).
I can help out in supplying FTP space and/or (if wanted) a virtual
machine (OpenVZ, any *nix dist. possible). Because i don't have much
time to act as a daily system manager, i prefer to have one person
managing it and who is also responsible for giving out (shell) accounts.
Chris are you up for this? If so, please PM me!
Cheers,
Joost
(Firma: Atelier Klippel) #1654678
> Cheers,
> Joost
Definitely. My only problem is that i have to go online using UMTS. So,
uploading such a big file is basically a no-go. It has roughly 2GB right
now, compressed. I'll send you a PM now...
Greetings,
Chris
Gast #1654739
ich könnte die Datei auch hochladen ... ich sitze im uni netz und könnte
mit 100 MBit´s sowohl runter wie auch hochladen
i can uploade the file too..... i am student and live in a "hall of
residence"(says leo... Studentenwohnheim?) i can up an download with up
to 100MBit´s
Gast #1654993
wenn ihr wollt kann ich das Image auf einen Webserver legen.
Ich habe noch 40GB Speicherplatz frei.
Dann kann es jeder mit einer schnelleren Anbindung einfach
herunterladen.
Besteht Interesse?
#1655809
Da ich mich in letzten Tagen auch mit Freetz für meine Fritzbox
beschäftigt habe, habe ich in dem dafür erstelltem freetz-linux auch mal
unsere toolchain ausprobiert.
klappt wunderbar!
Da viele die Kombination fritzbox und VPx500 haben wäre das ideal.
freetz linux gibts hier:
http://www.ip-phone-forum.de/showpost.php?p=1400234&postcount=1
Das ist eine VM-Ware Appliance, mit eingerichtetem samba, ssh und allem
was man zum Bauen von freetz-images braucht.
(username freetz, password freetz)
ich werde im Wiki noch eine Anleitung hinzufügen
Man könnte aber auch darüber nachdenken direkt in diese VM die aktuelle
Freetz und arm-toolchain zu integrieren und es dann per torrent zu
verteilen.
Da würde man dem freetz-hoster auch etwas Bandbreite ersparen.
Ich werde heut abend mal probieren, wie groß es gepackt ist, wenn man
die arm-toolchain und den freetz-svn-trunk mit rein nimmt.
In the past few days i experimented a bit with with Freetz for my
Fritzbox. in the freetz-linux that was build for creating freetz-images
i also tried our toolchain.
works just fine!
because many of us have the fritzbox-vp5500-combination, that would be
ideal.
freetz linux is available here:
This is a VM-ware appliance, with fully equipped samba, ssh and
everything you need for building freetz-images.
I'll write a few lines to the tutorial in the wiki
maybe we also schould consider about integrate the freetz-trunk and the
arm-toolchain directly Freetz-linux-VM distribute it via torrent.
this also would save bandwidth of the freetz-hoster.
in evening i will try how big the packed archive with the arm-toolchain
and the svn-trunk of freetz will be
#1656026
I'm abroad (again), but thanks to my trusty dns2tcp link the good news
of Christian's BSP-built reached me anyway. Congrats!
@Vlad: Freetz in combination with the VPx500 sounds really interesting,
but I think that we shouldn't attempt to mix the two projects. Apart
from the circumstance that both toolchains require a Linux environment
they don't have much in common. Mixing code of the two projects would
also complicate the task of handling updates.
@Christian: in welcher Einöde lebst Du denn, dass Dich die Segnungen von
Breitband und Flatrate noch nicht erreicht haben?
#1656039
I do not want to mix the projects
I just want to dual use the vm to save space.
everybody who uses freetz also need this vm to build, even if he does
not want to deveolp for freetz.
the freetz-linux actually does not comes with freetz itself but
providing a linux-vm that is designed to be a build machine easy
accessable from windows.
everything you further need to do to use it for our purposes is to
untaring the arm-toolchain
#1656078
Hallo Leute,
ich habe in den letzten 2 Tagen mal eine Weile APPTvlink.exe mit IDA
reversed und es ist einfacher als ich dachte (ist es normal, dass die
Funktionsnamen noch in der binary stehen?).
Jedenfalls habe ich mal versucht zu verstehen was das Programm genau
macht, und wie es den TV anspricht. Ich weiß absolut nicht inwiefern das
alles hilfreich ist oder ob es nicht viel einfacher geht.
Habe das kleine Programm mal angehangen. Ihr könnt euch die binary auch
einfach per wget von meinem space ziehen (wget
http://eddy14.freeunix.net/tvlink) oder den Anhang (ich weiß gerade
nicht sorecht, ob archive als Anhang erlaubt sind, deswegen:
http://eddy14.freeunix.net/tvlink.tar).
Da ihr das alles per root ausführt, solltet ihr äußerst vorsichtig sein
(aber brauche ich ja nicht zu erwähnen oder?)
Also schließt erstmal euer Gerät an den Fernseher (falls es schon wieder
dunkel wird, müsst ihr einen Button auf dem Telefon drücken damit es
wieder an geht).
Zum an und ausschalten:
./tvlink on
./tvlink off
Zwischen PAL und NTSC modus wechseln:
./tvlink ntsc
./tvlink pal
Und zuletzt, den Bildschirm clearen:
./tvlink cleartv
oder sogar das display vom telefon:
./tvlink cleardisplay
Das mit dem clear habe ich gerade eben herausgefunden. Allerdings muss
ich genau 4 Bytes übertragen. Ich hätte ja zuerst auf RGB getippt, aber
dann bleibt ja ein Byte über. Sowas wie Transparenz kann es ja nicht
sein. Oder hat es etwas mit dem r565 zu tun? Ich weiß nicht genau,
welcher dieser Bytes welche Farbe repräsentiert. Vielleicht kennt sich
da ja einer aus, und kann mir da weiterhelfen.
Dann könnten wir auch schon theoretisch Bilder auf den TV zeichnen (ist
allerdings sehr langsam, hmmm).
Also habe ich mal mit den verschiedenen /dev/dsp mal rumgespielt, indem
ich ein paar lange binaries in die reingeschoben habe.
/dev/dsp1 scheint für die Freisprecheinrichtung zuständig zu sein.
bei dsp oder dsp0 tut sich nix und bei 2,3 und 4 meint er die devices
gibt es nicht
Ich hätte erwartet, dass eins davon der normale Hörer ist
Hintergrund ist, dass ich versucht habe tinysid zum laufen zu bekommen.
Nach Anpassungen des Makefiles und Auskommentieren eines ioctl-Aufrufs
(SNDCTL_DSP_STEREO) tut sich auch was.
Allerdings nur sehr abgehackt und. Man erkennt auf jeden Fall nicht, was
es sein sollte.
Jetzt weiß ich nicht, ob einfach die CPU-Listung nicht reicht, oder obs
andere Probleme sind.
Sids wäre cool für Klingeltöne ;) nehmen nicht so viel platz weg, wie
waves und sind so schön oldscool
Edit:
also laut top ist der tinysid-prozess bei 10%, daran wirds also nicht
liegen.
(Firma: Atelier Klippel) #1656393
In der Kulturhauptstadt Essen! Hehe. Angeblich ist der Verteiler auf der
Strasse voll belegt. Wenn überhaupt würde nur noch was von der TKom
gehen. Auf die habe ich aber wenig bis keine Lust. Nachdem ich mich
gerade mit meinem Ex-Provider QSC vor Gericht streiten muss habe ich
auch erstmal die Nase voll von lange laufenden Verträgen.
An sich ist UMTS garnicht mal so schlecht. 20 Euro für ne Flatrate mit
10GB Volumen bei voller Geschwindigkeit, danach bis Monatsende auf
64kBit runter. Je nach Wind- & Wetterlage komme ich bis auf 4 MBit/s
Geschwindigkeit...
Aber zum Hochladen von so Riesendateien ist das halt nix...
Grüße,
Chris
Gast #1656833
> 20 Euro für ne Flatrate mit 10GB Volumen bei voller Geschwindigkeit,
> danach bis Monatsende auf 64kBit runter. Je nach Wind- & Wetterlage komme
> ich bis auf 4 MBit/s Geschwindigkeit...
Konkurrenz, kabelgebunden: 6MBit im Downstream, 460kBit im Upstream (die
auch jeweils stabil erreicht werden), wetterunabhängig,
tageszeitunabhängig, ohne Volumenbeschränkung, EUR 20/Monat. Leider eine
Mindestvertragslaufzeit von 24 Monaten..
(Firma: Atelier Klippel) #1657252
Ulrich P. schrieb:
> Ist das Image schon irgendwo zum runterladen?
> Was brauchst noch? Nur einen VMWare-Player?
> Gruß, Ulrich
Noch nicht, ich schicke die DVD Morgen zum Joost, bin Heute nicht dazu
gekommen.
Ja, es wird nur noch der aktuelle VMWare-Player benötigt.
Grüße,
Chris
(Firma: Atelier Klippel) #1657260
Naja, das ist nicht wirklich billig für die mickrige Datenrate
kabelgebunden. Ausserdem hilft mir das alles nichts solange im Verteiler
auf der Straße alles voll belegt ist. Wäre dem nicht so müsste ich nicht
mit UMTS online sein. Allerdings ist das auch nicht weiter schlimm. Ich
bin keiner von diese Power-Saugern. Bin Jahrelang mit 2MBit glücklich
gewesen, da aber dann symetrisch mit 5 festen IP's.
Grüße,
Chris
Gast #1657287
Hierzupampa 'mussten' wir umsteigen, weil die Betreiber es erstens nicht
geschafft haben, mehr als Ultralangsam-DSL zu schalten und zweitens
mehrmals willkürlich rumgeschaltet haben (Ablauf: Callcenter ruft an
'Wollen Sie..' - 'Nein' - Einen Monat später trudelt ein Brief ein
'Danke für ihren Auftrag. Sie können den Auftrag weder widerufen noch
stornieren, wir machen einfach. Und wenn sie ein paar Tage ohne
Anschluss dastehen dann interessiert uns das auch nicht. Pech für Sie
dass sie von einem Callcenter angerufen worden sind.'
Tja, da hilft nur wechseln. Bei der Konkurrenz sind übrigens zwei
vollwertige Telefon(!)anschlüsse mit dabei, da kostet ein einzelner
andernorts auch ohne DSL schon das selbe, mit Schneckentempo-DSL dann
gut das doppelte.
Wie gesagt einziges Manko die lange (erste) Vertragslaufzeit.
So, aber ich will erstens keine Werbung machen und zweitens jetzt EOOT.
(Firma: DC3AX) #1657451
Um mal wieder auf den Kernel zurück zu kommen :)
Wenn man mit WinSCP auf den Dingern arbeitet, dann bekommt man immer
wieder die Meldung, dass die Groups nicht aufgelöst werden können. Da
die VPs ja in einer Menge Verzeichnisse als User:Group 301:504 statt
Namen haben, denke ich, dass da eine Datei oder ein Feature fehlt. Kann
man das mit Bordmitteln nachziehen oder ist dafür eine Runde
Kernel/Busybox fällig?
Gast #1657579
Das sollte daran liegen:
# groups
sh: groups: command not found
Freiwillige, die es unbedingt protieren wollen, bitte vortreten ;-)
> Da die VPs ja in einer Menge Verzeichnisse als User:Group 301:504 statt
Ja, aber weder eine Datei noch ein 'Feature' :-) Was fehlt sind die
Einträge in /etc/passwd und /etc/group (aka die User/Groups gibt es
schlicht nicht). Im wesentlichen gibbet drei Möglichkeiten:
1. Ignorieren. Das war jetzt einfach ;-)
2. Nachtragen.
# ls -l
drwxr-xr-x    2 301      504             0 May  1  2005 Documents
drwxr-xr-x    2 301      504             0 Feb 28  2007 Settings
drwxr-xr-x    2 301      504             0 Feb 28  2007 bin
# echo 'nogroup:x:504:' >> /etc/group
# ls -l
drwxr-xr-x    2 301      nogroup         0 May  1  2005 Documents
drwxr-xr-x    2 301      nogroup         0 Feb 28  2007 Settings
drwxr-xr-x    2 301      nogroup         0 Feb 28  2007 bin
Für den User analog.
3. chown-en. Da muss man nur aufpassen, dass man sich keine
Berechtigungen kaputt macht - ergo rausfinden ob irgendwelche Dämonen
mit der angegebenen UID/GID rumlaufen.
HTH
(Firma: Atelier Klippel) #1657696
Hello,
attached are the sources & makefiles for two simple programs.
The first is "mmaptest". It uses mmap() to map the processors PRP
registers to a local struct that represents them. It then sets these
registers according to the values that are used in the
"FUNC_VIEWFIND_ON_LCD()" function in the HD1V00_ats.sh test script that
resides on the 5500 phone.
The PRP is used to convert image formats, scaling, etc. This is used for
the built-in camera. The PRP can write the output of it's work to a
given memory address. In this case, it uses the framebuffer's address.
You could change that and have it point to a buffer that you malloc'd,
and then save the incomming stream. Or whatever pleases you ;)
The second program is "sensortest". I reverse engineered the
APPSensor.exe file from the phone to get the ioctl's used therein. Then
i reimplemented them in my source to control the camera. There are seven
ioctl's i could find:
0x6C01 - init the sensor
0x6C02 - set the contrast, values range from 0 to 4 inclusive
0x6C03 - set the cameras register. no idea what that does
0x6C04 - start capture
0x6C05 - stop capture
0x6C06 - set format, want's a struct consisting of uint16's for width,
height, and two other, yet unknown parameters
0x6C07 - power on the camera
To display the camera image on the LCD screen, first run mmaptest, then
run sensortest. Voila, you see yourself (or whatever you pointed that
thing at). To turn that off, start the phone's camera application once
and exit it. I was too lazy to add that functionality ;)
Greetings,
Chris
Gast #1657811
ich bin auch an OpenVPN auf der Kiste interessiert, kann mal jemand, der
den Platz und die Zeit hatte, das BSP komplett mit Kernel und allen
Modulen zu bauen zumindest die Kernel-Module hier posten? Ich wäre an
tun/tap interessiert. OpenVPN hab ich schon auf das Telefon gekriegt
(mit gcc, und lzo/ssl-Build mit sehr wenigen Anpassungen), aber dann
fehlt ihm eben genau das TUN/TAP-Device damit ich weiterkomme. Das
Kernelmodul alleine würde reichen!
Danke, danke! Ich werde dann auch den openvpn-Build hier posten (bzw.
Link), wenn es gewünscht ist.
(Firma: Atelier Klippel) #1658005
Onno schrieb:
> Das
Hello,
attached is the tun.o kernel module. You need to create the tun device
node first, something like:
mkdir /dev/tun
mknod /dev/net/tun c 10 200
Don't forget to set the proper permissions as needed.
Loading the module is done with:
insmod /path/to/tun.o
Greetings,
Chris
(Firma: Atelier Klippel) #1658148
Timo schrieb:
> @Chris:
> Wäre es für dich möglich, ein kleines Binary zu schreiben, dass die
> Daten der Kamera nicht in den /dev/fb0 schiebt, sondern in eine Datei?
> Danke & Gruß. Timo
Mal schauen wann ich dazu komme. Habe momentan etwas andere Prioritäten
;) Das Prinzip ist aber einfach. Mittels malloc einen buffer aus
u_int16_t anlegen der groß genug ist, dann als Argument für set_prp()
eben die Startadresse dieses Buffers übergeben. Capture starten, kurz
warten, Capture stoppen, danach den Buffer in eine Datei schreiben. Ggf.
noch ein wenig in den PRP einlesen, also im Datenblatt zur CPU, um
Ausgabeformat und -größe auf die eigenen Bedürfnisse anzupassen.
Grüße,
Chris
(Firma: Atelier Klippel) #1658306
bitte versteht das folgende nicht falsch. Der Sinn und Zweck dieser (und
zukünftiger) kleinen Programme ist lediglich zu zeigen wie man die
Hardware im Telefon benutzen kann. Das ist Primär dafür gedacht anderen
Leuten eine Basis zu geben.
Es gibt noch viel zu erforschen in dem Telefon. So werde ich mich z.B.
als nächstes an die Audio-Devices machen, um die ans Laufen zu bekommen.
Das ist doch einiges an Arbeit, vor allem das Reverse-Engineering und
testen. Zudem muss ich auch noch Arbeiten, um meinen Lebensunterhalt
irgendwie reinzubekommen.
Daher bleibt nur ein gewisser Teil an Zeit übrig den ich da reinstecken
kann. Und ehrlich gesagt, den verbringe ich eben lieber damit, Sachen zu
erkunden und gängig zu machen, und nicht damit irgendwelche Wünsche, die
nichts zu den Grundlagen beitragen, zu erfüllen.
Das ist nicht böse gemeint, aber ich kann meine Zeit halt nur einmal
verbrauchen. Wer es eilig hat und meint, ohne solche Funktionalitaet
nicht auszukommen, der ist herzlich Eingeladen das selber zu erweitern.
Dafür ist es ja schliesslich da!
Schöne Grüße,
Chris
(Firma: DC3AX) #1659478
Hi Christian,
das sehe ich genau so. Ziel dieses Threads sollte es sein, zu aller erst
mal die vollständige Software auf dem Telefon reproduzieren zu können.
Dann sollten wir versuchen Ersatz für die proprietären Treiber zu
finden.
Danach sind die Wege offen. Die Oberfläche bietet einiges
Verbesserungspotential,auch das Telefonieren könnte man einfacher
gestalten, also Freizeichen nicht über Lautsprechen, oder wenigstens mit
einstellbarer Lautstärke u.s.w.
Auch der eigentliche SIP Client scheint proprietär zu sein, ich habe
zumindest einige Config-Einträge ergoogeln wollen und keinen einzigen
Treffer landen können.
Ich denke dann haben wir ein richtiges Open-Surce Telefon und die Wege
werden sich dan trennen. Die einen sind damit zufrieden, die Anderen
wollen an der GUI arbeiten. Wieder andere (so auch ich) möchten
vielleicht einen Kernel 2.6.x laufen haben...
Gruß, Ulrich
(Firma: Atelier Klippel) #1659490
Ja, das ist der VeriCall Edge VoiP/SIP Stack.
Grüße,
Chris
Edit: Der SIP Stack ist in der libqtopiaphone eingebaut.
(Firma: Atelier Klippel) #1659510
Bzgl. Kernel/Hardware:
Also, so wie es aussieht ist der Großteil der Sachen sehr stark an das
ADS (Application Development System) von Freescale angelehnt.
Dementsprechend kann man dort vermutlich auch einiges an Erkenntnissen
gewinnen, wenn man einen neuen Kernel bauen möchte.
So ist z.B. das LCD ja über den LCDC des Prozessors angeschlossen. Die
Kamera scheint ebenfalls über das dafür vorgesehene Interface zu laufen.
Der Audio-Codec geht über I2C. Der TV Encoder ist ebenfalls genauso wie
auf dem ADS Board.
Was wirklich Haarig werden könnte sind die Treiber für die WLAN Sachen,
besonders beim 6500. Keine Ahnung ob man da einen 2.6er Kernel mit ans
laufen bekommt. Allerdings habe ich da auch nicht wirklich weiter
nachgesehen. Zumindest im 5500 scheint das WLAN Modul über den regulären
PCCard/PCMCIA Bus des Prozessors angebunden zu sein. Das entsprechende
Kernel-Modul für den Bus ist ja auch geladen.
Beim Audio-Codec mache ich langsam Fortschritte. Die wichtigsten
Register kann ich schon mal Lesen und Schreiben. Allerdings scheinen ein
paar Dinge nicht oder anders implementiert zu sein als wie im aic Test
Program. So kann man über das Programm ja angeblich die Codec-Register
einzeln auslesen. Das funktioniert aber nicht. Anstelle dessen habe ich
durch experimentieren einen anderen IOCTL Call gefunden, der alle
Register auf einmal in ein Array aus 10 u_int32_t lesen kann. Nur das
passende Gegenstück zum schreiben habe ich noch nicht entdecken können.
Vielleicht gibt es das ja auch garnicht.
Wie auch immer, da die Doku zu dem Codec ja vorhanden ist sollte es
theoretisch möglich sein auch gleich einen neuen Treiber dafür zu
schreiben, wenn nötig. Wie die Audio-Seite angebunden ist habe ich noch
nicht geschaut, das werde ich Morgen oder Übermorgen mal angehen. Würde
mich nicht wundern wenn auch das über die dafür vorgesehenen Teile des
Prozessors läuft.
Alles in allem bin ich sehr zuversichtlich das man, zumindest mit dem
2.4er Kernel und den Treibern auf dem Telefon, da was eigenes machen
kann. Es gibt ja einige SIP/VoiP Stacks als OpenSource, auch als
Kommadozeilen-Versionen. Soetwas ist Ideal als Basis, da klein und ohne
GUI. Die kann man sich dann selber dazubauen.
Der MP4 Encoder/Decoder (Hantro) ist ja im Freescale BSP soweit
vorhanden. Das ist ja zum Teil Hardware-Unterstützt, somit sollte auch
der Video-Link relativ Probelmlos und Performant zu realisieren sein.
Es muss ja auch nicht Qtopia bzw. QT Extended sein. Das
Framebuffer-Interface ist ja wirklich einfach. /dev/fbX öffnen, per mmap
auf einen lokalen Pointer mappen, und auf dem dann die ganzen Pixel
schreib-/lese Aktionen ausführen. Da kann man sich auch schnell was
eigenes Basteln.
Bzgl. des 5500: Es wäre natürlich schön wenn z.B. der Tino mal ausmessen
könnte ob wirklich alle PCCard/PCMCIA Signale der CPU auf dem Sockel für
den WLAN Adapter liegen. Wenn ja würde das ja auch ganz neue
Möglichkeiten zum Hacken eröffnen. So könnte man dann nämlich auch
andere Karten anstecken, z.b. für USB, Festplatten, etc. Auch der cfio
Treiber ist geladen (CompactFlash I/O).
Beim 6500 wäre auch mal Interresant zu wissen was von den ganzen Pins
des WLAN Chips auf welche Pins an der CPU gehen. Auf dem Bild
http://www.mikrocontroller.net/attachment/74205/V6500_Back.jpg sind ja
doch einige Pads zu sehen. Was natürlich extrem viele wären, wenn der
Chip angeblich nur über SPI angeschlossen ist. Vielleicht liegt ja auch
dort mehr an, nur das es (aus Zeitmangel, Treiberproblemen, was auch
immer) letztendlich dann nicht genutzt wurde.
Schöne Grüße,
Chris
#1659692
  ich habe mit ähnlichen Gedanlen gespielt und habe ein paar Infos
ergoogelt, welche evtl. helfen könnnen.
Das hatte ich schon mal im anderen Thread gepostet:
Für die es interessiert ein neues System aufzusetzen:
Bei Freescale gibt es ein angepasstes uBoot und einen relativ aktuellen
2.6er Kernel.
http://opensource.freescale.com/git
Es gibt auch noch ein paar andere alternativen:
http://en.wikipedia.org/wiki/User:Sogliphy/i.MX21_Linux
> auf dem ADS Board.
Das der Audio-CODEC über I²C läuft ist nur die halbe Wahrheit. Die Daten
laufen über I²S oder SPI. Die Config über I²C.
Info-Quellen zum WLan gibts hier:
http://avr32linux.org/twiki/bin/view/Main/WirelessNetworking
Angeblich wird der WLAN-Chip vom VP55 im 2.6er unterstützt.
Für den TV-Chip gibt es wohl einen Treiber im Montavista Linux. Leider
nicht OpenSource. Hier gibt es ein DIFF zum Code. Vielleicht kann das
helfen.
http://www.blackberry.com/support/blackberrypresenter/opensourcefiles/fs455_encoder.diff
viele Grüße
   Maarten
(Firma: DC3AX) #1660669
> auf dem ADS Board.
Nur der Vollständigkeit wegen:
Der Audio-Codec ist über I2C und I2S abgeschlossen. Dabei übernimmt I2C
die Steuerung (Umschaltung, Lautstärke...) und I2S liefert den
Audio-Datenstrom in beide Richtungen.
Ich hatte ja ursprünglich vermutet, dass das WLAN beim 5500er mehr
Probleme bereitet. Da es aber vom Hörensagen her einen Linux Treiber für
den beim 5500er genutzten WLAN Chip gibt, hat der es vielleicht auch in
die neuen Linux Versionen geschafft. Was ich nicht verstehe ist die
Unnötige Geheimniskrämerei bei NXP über den 211er Chipsatz. Wenn man das
Datenblatt liest, ist einem schnell klar, dass das ganze geheime
LowLevel Interface, aus dem alle Hersteller so ein Geheimnis machen,
bereits auf dem Chipsatz integriert. Man muss ihm per SPI nur ein paar
Befehle schicken und daskomplete WLAN steht. Die Geheimhaltung ist also
vollends unbegründet und die Opensource-Gemeinde und auch die ganzen
AVR...ARM7 Bastler würden NXP das Ding aus den Regalen reißen, wenn...
Ich werde da also nächste Woche mal ein paar Telefonate führen müssen,
selbst wenn ich nix erreiche, ich will es verstehen.
Adererseits sollte es eher einfach sein, das Modul vom 6500er für die
Kommunikation mit dem 211er WLAN Chip mit geeigneten Mittel reverse zu
engineeren. Denn dort drinn kann nicht sehr viel stecken.
Gruß, Ulrich
(Firma: DC3AX) #1660671
> http://www.mikrocontroller.net/attachment/74205/V6... sind ja
So wie ich das sehe ist nur der Außenkranz teilweise mit aktiven
Signalen belegt. Viele der Pinne sind Vcc und GND, auch ein JTAG ist
darüber geführt. Die vier Padflächen sind alle GND, wohl für eine gute
Antennen-Masse, EVM und Wärmeableitung.
(Firma: Atelier Klippel) #1660795
Ja, das habe ich in der Eile übersehen.
Bin mit den ioctl's des aic14.o und des aud.o fast fertig. Zumindest
soweit das man das meiste bereits benutzen kann. aud.o implementiert zum
Glück gängige OSS ioctl's, leider aber auch ein paar eigene.
Naja, zumindest die Register des aic14 konfigurieren geht schon mal,
ebenso das Abspielen von Sounds mit 8khz sowie 16khz Samplerate. Für
16khz muss man vor dem öffnen des /dev/dsp1 erstmal einen ioctl auf dem
/dev/aic14 machen (0x4004703E), damit er umschaltet. Sobald man das dsp1
schliesst, schaltet er automatisch auf 8khz zurück.
Lautstärke einstellen geht, Amp ein/aus ebenfalls, etc. Eigentlich
soweit alles was man braucht. Ich schau mal ob ich Morgen meinen
Testcode ein wenig aufgehübscht bekomme um ihn hier Hochzuladen.
Ansonsten halt Montag oder Dienstag.
Grüße,
Chris
(Firma: Atelier Klippel) #1660810
-r--r--r--    1 301      504        632836 Feb 28  2007 ga_linuxdrv.o
Satte 600 KB. Ich befürchte das dort mehr drinsteckt als einem Lieb sein
kann. Immer diese dämlichen, riesigen Binär-Blobs in den Treibern. Zum
Heulen.... Von 0x00013434 bis 0x0004AD24 ein Block, und dann weiter bis
0x0007E1BC der zweite Block gleich hinten dran, also insgesamt 437640
bytes. Beide in der Funktion "PhgHhalResetAndBootLoad" benutzt.
Und auch sonst gibt es sehr viele Funktionen in dem Treiber. Das wird
sicher ein Spaß werden.
Man könnte natürlich hergehen und über eine Firma dort die Informationen
anfragen, vermutlich nach Unterzeichnung eines NDA....
Grüße,
Chris
Gast #1660942
Das klingt vielleicht blöd, aber das ist vielleicht gar nicht mal so
schlecht. Die "dicken Brocken" könnten die Firmware des eigentlichen
WLAN-Chips sein. Falls dies der Fall sein sollte, wären sie ziemlich
uninteressant - zumindest inhaltlich. Wir wollen ja nicht den WLAN-Chip
hacken. Der Rest des Codes wäre also der interessante Teil, nämlich die
tatsächliche Schnittstelle. Der Name der Funktion deutet darauf hin, daß
sie eine Art Bootloader für den WLAN-Chip ist.
Andererseits blieben dann knapp 200k an relevantem Code, was auch kein
Zuckerschlecken ist. :-/
(Firma: Atelier Klippel) #1661125
Ja, schon klar. Ich bezog mich damit eher auf Ulrich's Aussage das in
dem Treiber ja nicht viel drin stecken könne. Wie das halt oft so ist
bei solch komplexen Chips. Die dürftigen Datenblätter jubeln immer wie
Leicht und Einfach doch alles damit geht, die Realität ist dann meistens
eine andere - leider.
Die Firmware und Treiber scheinen auch einige Probleme zu haben. So gibt
es z.B. die Funktionen "Leak_Malloc", "Leak_Free" und "Leak_Dump", wo
dann so Strings wie "No memory allocated / no leaks found" drinstehen.
Anstatt sauber die malloc's und free's zu benutzen implementiert man
also eigene die der Schlamperei dann hinterherräumen.
Auch Lustig sind Funktionen wie "PhgHhalCheckForHang",
"PhgHhalNotifyMacHang" und "HhalPlatformCheckForHang" etc. Klingt sehr
nach Rumgewürge um zu kaschieren das sich der Chip wohl gerne mal
verabschiedet.
Kein Wunder also das sie da ungern die Quellcodes rausgeben wollen ;-D
Aber mal Ernsthaft: Bei WLAN Sachen gibt es selten offene Quelltexte.
Diese Chips sind ja Universell einsetzbar. D.h. man kann
Frequenzbereiche und Sendeleistungen einstellen. Das hat natürlich zur
Folge das man Dinge auswählen könnte die im jeweiligen Land nicht Legal
sind. Das wollen sie wohl verhindern. Was ich allerdings als Gängelei
empfinde. Zumal man den Treibern ja auch ein anderes Land vorgaukeln
kann, woraufhin sie sich dann entsprechend anders verhalten.
Achja, insgesamt 260 exportierte Funktionen in dem Treiber. Dazu kommt
dann wohl noch die eine oder andere Funktion die nicht exportiert wird,
da als static deklariert im Code. Das zu zerlegen würde sicher ein
Riesenaufwand sein. Aber vielleicht hat ja jemand Lust dazu.
Grüße,
Chris
Gast #1661253
> verabschiedet.
Ich kann mir ein Schmunzeln leider nicht verkneifen... :-) Chipmasken
sind bekanntlich teuer, daher versucht man möglichst viele
(optimalerweise alle) Unzulänglichkeiten der Hardware mit der Firmware
auszubügeln. Also nichts Überraschendes hier. ^_^
Custom Malloc-/Free muß nicht unbedingt schlechten Code bedeuten. Zu den
2.4er-Zeiten hatte der Kernel keine wirklich guten Debugging-Funktionen.
Abgesehen davon weiß man nicht wirklich, wo der Treiber seinen Ursprung
hat. Oft portiert man einen Code-Blob zwischen verschiedenen OS und
versucht mit einem Zwischenlayer möglichst viele internen Funktionen
unverändert zu lassen.
Auch der Watchdog-Code muß nichts Schlechtes bedeuten. Das hier ist ein
Chip mit hauptsächlicher Embedded-Ausrichtung. Vor dem Hintergrund, daß
man "im Feld" oft keine weiteren Firmware-Updates durchführen kann, ist
so ein Watchdog vielleicht nicht elegant, allerding dürfte er die
eigentliche Systemverfügbarkeit letztendlich verbessern. Wir lieben ja
alle diese sporadischen Fehler, die nur bei Vollmond und gleichzeitiger
Donautemperatur von exakt 9,85 Grad auftreten. ;-)
Meines Wissens ist das nicht unbedingt das Problem. Schlimmer (aus Sicht
der Behörden) ist vielmehr die Tatsache, daß man mit den Chips auch
völlig andere Frequenzen anfahren -->könnte<--. Gerade die Freunde
jenseits des Atlantiks scheinen da sehr empfindlich. Die FCC (bzw.
indirekt das Militär) achtet wohl gezielt darauf, daß man als "User"
kaum etwas machen kann. Will man also etwas auf dem US-Markt plazieren,
kommt man nicht herum, nach deren Regeln zu spielen. :-/ Man könnte
natürlich die WLAN-Funktionalität komplett kapseln, allerdings scheinen
die SoftMAC-Implementierungen billiger, weil hier das Hauptsystem einen
Teil der Rechenleistung zur Verfügung stellen muß.
Ein gutes Beispiel für ein erfolgreiches Reverse-Engineering in diesem
Bereich ist der b43-Treiber für bestimmte Broadcom-Chips.
(Firma: DC3AX) #1661291
Auf dem 21er steckt noch ein LPC-like ARM7, der das ganze Protkoll
selbst abfrühstückt, das normalerweise der Treiber macht. Ich rate mal,
dass es aus Produktionssicht günstiger ist, solch einem Modul die
aktuelle Software aus dem eigentlichen Produkt zu übergeben, als einen
weiteren In-Production JTAG Prozess vorzuhalten. Das hat einen Vor- und
einen Nachteil für uns.
Nachteil: Die Blobs müssen vermutlich sauberst übernommen werden, wenn
man einen eigenen Treiber schreibt.
Vorteil: Die Probleme mit neuen Basisstationen, wie der FB72xx, können
vermutlich nur durch ein Bugfix in eben diesen Blobs korrigiert werden
und ich denke, dass es einfacher ist solch einen Blob irgendwoher zu
bekommen, als ein Image, das man über ein nicht dokumentiertes JTAG auf
solch ein Modul laden muss.
(Firma: DC3AX) #1661305
Hmm.... Das kenne ich doch, ist aber nur geraten, da ich hier imUrlaub
weder IDA, noch die Objects der VP habe :)
Es gibt einige Implementationen von Schichten-Basierten Treibern, die
ein eigenartiges System verfolgen, um ein versandfertiges Paket zu
produzieren.
Sie allozieren den Speicher in der reihenfolge, wie er benötigt wird.
Also zuerst gibt es ein my_malloc( netto_daten), dann ein
my_malloc_before( netto_daten, netw_layer), dann ein my_malloc_before(
netw_layer, llc_layer)...
Es wird also ein Paket im RAM reserviert, dass anschließend von vorne
erweitert wird. Das alles nur, um hinterher mit einem einzigen memcpy
das komplette Paket an den Tranceiver senden zu können.
Persönlich halte ich das für schön lesbar und verständlich, aus sicht
eines kleinen Systems aufgrund wilder memcpy Vorgänge aber für vollends
schwachsinnig. Ich nutze für Layer-basierte Systeme ein Pointer-Array,
welches ich zuerst alloziere und das aus Pointern zu den verschiedenen
Layer-spezifischen Structen besteht.
Das Pointer-Struct wird so, wie die Datenfelder bekannt werden
mitgültigen Zeigern aufgefült. Beim Senden gibt es dann einen memcpy pro
Layer. Das klingt komplizierter, ist aber vermutlich um Faktoren pro
Layer schneller, da man weder auf ausreichend leere Puffer vor einem
Layer-Puffer achten muss, noch, wenn das nicht der Fall ist, schwere
Umkopier-Aktionen starten muss.
(Firma: DC3AX) #1661312
Es ist aber reich rechtlich Sache des Geräteanbieters die Einhaltung der
Landesspezifischen Funk-Standards zu garantieren, nicht die des Chip- /
Modulherstellers. Der Chiphersteller kann allemal Application-Notes
beisteuern, die eine erfolgreiche Zulassung unterstützen.
Stellt sich mir die Frage, welche der Funktionen tatsächlich verwendet
werden, was man doch auch herausfinden können müsste. Ich habe aber,
zugegeben, noch nie größere Systeme durch den IDA gejagt. Bislang habe
ich das nur für AVR, ARM7 und einige kleine Prozessoren aus OnBoard
Radio/Navis geraucht um z.B. eine Lenkradfernbedienung nachrüsten zu
können.
Stelemich da gerne mal zur Verfügung, wenn ich Fragen dazu vielleicht an
diesem Thread vorbei per eMail an Wissende senden darf?
Hmmm, leider ist NXP nicht mehr Philips. In meiner Zeit bei Philips habe
ich einige NDAs unterschrieben, so dass es vielleicht eine Chance
gegeben hätte an die Specs vom 211er heran zu kommen. Es würde ja allen
reichen, wenn einer einen aktuellen laufenden Treiber zur Verfügung
stellt.
(Firma: DC3AX) #1661320
Also gerade bei Broadcom kann ich mich nicht beschweren. Die haben mir
als Privatperson gegen NDA einen Zugang ins eigene Developer-Netz
angeboten. Ich bin letztendlich nicht darauf eingegangen, weil die Chips
eben wegen SoftMAC zu viel Last auf dem ARM7 verursachen würden.
Beim 211er sieht as ganze ganz anders aus, das Teil wäre für alle, die
einen AVR oder einen ARM7 ans WLAN bringen wollen echt ideal. Fast wie
das BTM222 Modul für Bluetooth.
(Firma: Atelier Klippel) #1661435
Müsste dann aber schon einer der größeren AVR's sein, oder zumindest mit
passendem Interface zu externem Speicher. Das dann auch noch möglichst
schnell. Wenn da 400 KB Blob's zum Chip gehen müssen, dann wollen die ja
auch irgendwo gespeichert und übertragen werden.
Wie dem auch sei, ich mache mal an dem Audiokram weiter.
Grüße,
Chris
Gast #1661577
> angeboten.
Also beschweren wollte ich mich keinesfalls. Broadcom hat sich IMHO auch
ziemlich gut entwickelt, was OpenSource angeht. :-)
Allerdings ist der Broadcom-Treiber ein gutes Beispiel fürs sog.
Clean-Room-Design ist. Einge Gruppe "reverse-engeneered" den
Ursprungstreiber (meines Wissens damals den Binary-Blob vom WRT54G) und
dokumentiert die Register, Zugriffsmuster, usw. Eine zweite Gruppe
programmiert anhand dieser Doku den offenen Treiber. So geht man
rechtlichen Problemen (Copyright) sowie NDAs aus dem Weg.
Naja, in unserem Fall fürchte ich, daß die "User-Base" einfach zu klein
ist. :-/
(Firma: Atelier Klippel) #1661594
ich habe einen kleinen Daemon geschrieben der alle 10 Sekunden den
Wachhund kitzelt ;)
Es wird ja ein watchdog.o Kernelmodul geladen. Wenn man nun Qtopia
abschaltet wird selbiger nicht mehr aktualisiert. Das hat zur Folge das
sich das Gerät ständig neu startet. Dieser Daemon beseitigt das Problem.
Zusätzlich sollte man noch die Dateien /sbin/reboot und /sbin/shutdown
umbenennen, z.B. in *.old. Irgendein Prozess ruft die nämlich auf wenn
Qtopia nicht läuft, hab aber noch nicht geschaut welcher das ist. Evtl.
reicht es ja den ticklewdt in qpe umzubenennen (Start-Script
entsprechend anbassen!) damit der Prozess ausgetrickst werden kann.
Apropos qpe: In der Datei /usr/local/startup/daemon.sh in Zeile 146
steht ein "$CMD &". Das startet das qpe (Qtopia). Wenn man das
auskommentiert startet es dann nicht mehr. Ich brauche das derzeit so um
mit den Sound-Devices ordentlich spielen zu können. Das Playback-Device
für den Codec ist zwar auch so ansprechbar (solange qpe nicht drauf
zugreift), aber das Aufnahme-Device eben nicht. So kann man
sicherstellen das außer dem eigentlich System nichts anderes auf die
Devices zugreift.
Für die Detailverliebten: Man öffne /dev/watchdog und schicke ein ioctl
0x80045705 ohne weitere Parameter dort hin um den Hund zu kitzeln. Das
muss natürlich periodisch passieren.
Grüße,
Chris
(Firma: DC3AX) #1662463
> Naja, in unserem Fall fürchte ich, dass die "User-Base" einfach zu klein
> ist. :-/
Hmmm... Also zwei sind doch genug dafür? Da ist einer, der sich mit IDA
und reverse Engineering auskennt und ich sehe mich durchaus in der Lage
einen Network-Stack zu schreiben. Aber vielleicht hilft ja auch noch
einer oder zwei :)
(Firma: DC3AX) #1662467
Das ist so nicht notwendig. Wenn man die Blobs in einen externen
SPI-Flash ala AT45Dxx auslagert ist das kein Problem, denn die müssen ja
nur ein einziges mal geladen werden. Ein AVR kann solch einen Speicher
mit einigen MBit ansprechen, ein AT91SAM7X schiebt bei mir hier ein
Funkmodul mit 24MHz mit Daten voll. Ist also Problemlos machbar.
Ich gehe auch davon aus, dass von den vielen zur Verfügung gestellten
Funktionen nur wenige benötigt werden, wenn die Reklame von NXP auch nur
ein wenig zutrifft.
(Firma: Atelier Klippel) #1662572
Hello,
since a few days i'm looking into the audio stuff of the phone. I got it
partially working, however, i'm not satisfied at all. The whole setup is
a bit awkward. There are three drivers involved:
i2c-aic14.o
aic14.0
aud.o
Also, there are six device nodes used:
/dev/cod
/dev/aud0
/dev/dsp0
/dev/aud1
/dev/dsp1
/dev/mixer1
The cod device seems to be the raw audio interface to the codec chip.
aud0 is the "network" recording device, dsp0 the "network" playback
device. aud1 and dsp1 are for the "player", again aud is for recording
and dsp for playback. mixer1 is a rudimentary mixer that only has two
controls: "Vol" and "Spkr".
However, and this is where the fun starts: If qpe is running, i can
write to /dev/dsp1 and hear the sound on the speaker. aud1 is blocked
because it is opened by qpe. Sending data to dsp0 gives no output, i
guess that is used internally by the voip stack. Also, aud0 is opened.
The cod device is also in use and can not be opened.
If qpe is not running, i can write to cod and hear the sound. However,
the aud and dsp devices are non-funct. The reason is that dma buffers
are created upon request. These have to be handled somehow, and i guess
that is what also happens through qpe, or better, qss (the sound
server). Opening aud0 and aud1 cretes dma buffers for the audio devices,
which can be seen by "cat /proc/aud". However, no (dma) buffers are
created for the aic14, as can bee seen by "cat /proc/aic14". With some
weird combination of my code and the aic14_conf program, some buffers
are created. However, still no playback through the dsp devices.
I think the best way would be to re-implement the drivers, using the
dbmx sound drivers as a base (they are available as source in the
Freescale BSP for the iMX.21). The only other choice would be to dig
deep into the Qtopia binaries and attempt to find out what's going on.
My guess is that a clean reimplementation would be the faster way. This
would also allow to implement a simple audio mixing routine to allow
multiple opens on the dsp device for playback. The final transfer itself
of the audio data is done through the SSI peripherial of the iMX,
together with dma buffering.
So, if anyone is interrested, i can upload some example code using the
/dev/dsp1 device for playback. However, it is pretty pointless that way,
since that would only run if qpe is running as well, and no recording of
sound is possible anyways.
Greetings,
Chris
(Firma: Atelier Klippel) #1662577
> einer oder zwei :)
Kommt halt drauf an wie lange man warten will. Mit nur zwei Leuten wird
das lange dauern. Zumal diese Leute ja noch Arbeiten müssen und auch
ansonsten noch ein Leben ausserhalb des Telefon-Hackens haben ;)
Grüße,
Chris
(Firma: Atelier Klippel) #1662595
> ein wenig zutrifft.
Ja, das meinte ich ja, externen Speicher dann halt.
Wieviele von den Funktionen nun letztendlich auch genutzt werden kann
ich natürlich nicht sagen. Nur das es viele sind... Viele sind aber
recht klein.
Grüße,
Chris
(Firma: Atelier Klippel) #1662612
SD-Fritze schrieb:
> Hey *,
> i still wait for my VP, so I couldnt try.
> Does
> dd if=/dev/sensor of=/dev/fb? //? for the tv fb
> work?
> Greets,
>   SD-Fritze
Hello,
no. it's not that simple. The camera is connected using the CSI
interface, and the image data is pre-processed through the PRP part of
the iMX. However, it can be set-up so that the PRP writes it's output to
the same memory region that the fb device uses.
See these two messages for the code:
Beitrag "Using the camera"
Beitrag "camtest binaries"
You could change the code so that it uses a malloc'd memory region
instead of the fb, so that you can actually capture images and save them
elsewhere.
Greetings,
Chris
(Firma: DC3AX) #1664480
Ok, Licht kommt ins Dunkle...
NXP hat seine RF-Sparte in eine Kooperation mit ST geschickt, die
ihrerseits das ganze wieder in Kooperation mit Ericsson machen. Das
ganze ist letztes Jahr passiert. Daher ist von dem an sich genialen Chip
nix mehr zu hören.
Bei ST tauchen nun zwei ähnliche Modelle auf:
http://www.stericsson.com/sales_marketing_resources/STLC4560FL_1.pdf
http://www.stericsson.com/sales_marketing_resources/CW1100FL_1.pdf
kommt den Daten des BGW211 ziemlich nahe, es gibt auch einen großen
Bruder:
http://www.stericsson.com/sales_marketing_resources/CW1200FL_1.pdf
Ich fürchte, es wird bei NXP also kaum noch etwas zu holen geben.
(Firma: Atelier Klippel) #1664499
Was man noch versuchen könnte: Wenn man mal nach dem Chip und Linux
googelt finden sich doch einige Seiten. Es nutzen wohl auch einige
andere Geräte diesen Chip. Man sieht dann oft irgendwelche Updates für
irgendwelche Dinger mit Linux 2.6.x. Nun müsste man noch ein Gerät
finden das ebenfalls einen ARM9 benutzt und dann probieren ob man den
Treiber aus dem Update zusammen mit einem 2.6er Kern für das Telefon ans
laufen bringen kann.
Behebt zwar natürlich nicht das Quellcode-Problem, aber man könnte so
mit etwas Glück einen Treiber für 2.6er Kernel bekommen.
Wobei sich natürlich immer noch die Frage stellt, zumindest mir, warum
man überhaupt einen 2.6er auf dem Telefon haben will. Das Gerät hat ja
nun doch recht limitierte Resourcen, und wird sich Hardwaremäßig wohl,
anders als normale PC's die man ab und an mal erweitert, auch nicht
ändern.
Grüße,
Chris
#1665233
> ändern.
Die Diskussion kenn ich von OpenWRT. Für mein Teil bin ich bei embedded
Linux zufrieden mit dem 2.4er - die Verwendbarkeit der nur als Binary
vorliegenden Treiber ist mir wichtig.
Devfs und ungeschränkten hotplug-Fähigkeiten sind kein Problem (die
VPx500 haben derzeit je nicht mal USB). An der Leistungsaufnahme des
Geräts ist nichts auszusetzen und viel besser wird diese durch einen
"tickless kernel" wahrscheinlich auch nicht.
Schließlich wird der 2.4er auch heute noch gepflegt (die aktuelle
Version 2.4.37.7 ist von November 2009
http://marc.info/?l=linux-kernel&m=125761436627901). Es könnte sich
lohnen die eine oder andere "relevante" Korrektur in den 2.4.20
einzupflegen.
Grüße
/G
#1665320
> einzupflegen.
Ein paar Suchen mit grep über die ChangeLogs des Kernels ab 2.4.21
zeigen schon ein paar wichtige Korrekturen. Die meisten Änderungen sind
für unser Gerätchen natürlich uninteressant.
Ich nehme an, dass dem einen oder anderen bereits der folgende "Zombie"
9 root      35  10     0    0     0 Z N   0.0  0.0   0:01 jffs2_gcd_mtd2 <defunct>
aufgefallen ist. Hier ist etwas über die Ursache zu lesen:
http://mhonarc.axis.se/jffs-dev/msg01647.html. Offensichtlich passiert
das nur, wenn eine JFFS-Root-Partition verwendet wird (und das ist wohl
ziemlich ungewöhnlich).
/G
(Firma: Atelier Klippel) #1665381
Ja, das ist auch ein Grund. Allerdings werde ich mich dransetzen und
nach und nach die meisten Treiber reimplementieren, eben damit Quellen
dafür vorhanden sind. Wenn alles so läuft wie ich mir das vorstelle
bleibt am Ende nur noch der WLAN Treiber als Binary übrig.
Das meiste sollte auch kein sonderlich großes Problem sein. Die Basis
ist ja im BSP als Quellcode vorhanden. In den jetzigen Treibern auf dem
Telefon steckt einfach zuviel Mist drin. Beispiel kpp.o, der für die
Tasten zuständig ist. Der Großteil des Treibers besteht aus Routinen zum
abfangen einer speziellen Sequenz, und daraufhin das Handling von
Produkt-Tests, ausgeben von diversen Systemdateien, etc. Das muss ja da
alles nicht rein.
Vermutlich nicht. Man muss halt abwägen ob der Aufwand den
letztendlichen Mehrnutzen Wert ist. Ich vermute mal eher nicht.
Das soll aber natürlich niemanden davon abhalten einen 2.6er für das
Gerät zu bauen ;) Jeder so wie er es mag....
> einzupflegen.
Ah, Interresanter Fund!
> Grüße
> /G
Grüße,
Chris
Edit: Ups, mit dem Fund meinte ich natürlich die Nachricht bzgl. des
JFFS2.
(Firma: Nederland Live) #1665398
Hi All,
I received the dvd from Chris and uploaded it to:
https://vpx500.nederlandlive.nl/ (http://vp6500.bd8.nl is also redirect
to this new place now). Maybe Chris can explain what the contents of
each file exactly are (haven't tryed it out myself yet). If anyone wants
to mirror go ahead, it's always good to have two versions online!
Cheers,
Joost
#1665428
Hallo zusammen!
es gäbe schon einige gute Gründe auf 2.6.x zu wechseln. Als Beispiel sei
hier IPv6 angeführt, an dem langfristig sicher nichts vorbei geht.
Ansonsten kann ich nur sagen das hier verdammt gute Arbeit abgeliefert
wird. Da könnte sich mancher Hersteller eine Scheibe von abschneiden :)
Sind inzwischen eigentlich neue Erkenntnisse zum WLAN Problem zwischen
FritzBox 72xx 75xx und VP6500 zu verzeichnen? Ich hörte das es ein
Fehler in der FritzBox sein könnte.
Gruß Marcel
(Firma: DC3AX) #1665544
> ändern.
Naja, der Kernel 2.6.x ist nicht dicker als der 2.4.x sondern anders und
an einigen Stellen sogar schlanker / schneller.
Abgesehen davon ist der Weg alles mit altem Kram zurecht zu prepeln aus
der Not heraus sicherlich richtig. Aber die Option mit neuen Tools mehr
zu machen ist verlockend.
Und das WLAN hat nun einmal Probleme:
- WMM wird benötigt, damit man garantiert die Sprachverbindung halten
kann, funktioniert aber nicht mit neuen Basen ala FB72xx
- Multiple SSIDs laufen nicht, d.h. das Telefon kann sich zwischen
verschiedenen Basistationen nicht umbuchen.
Also wäre ein Quellcode für den BGW211 sehr nützlich. Ob man den jetzt
für den Kernel 2.4.x repariert oder für die Aufrüstung auf 2.6.x nutzt,
ist letztendlich egal :)
(Firma: DC3AX) #1665550
Da wiederum könnte es helfen, den debug im BGW Treiber zu aktivieren, es
sind einige Strings enthalten, die auf diese Fähigkeit hin deuten, aber
ich habe noch nicht heraus gefunden, wie man das aktiviert :)
@All:
Does anyone know how to 'usually' enable debug output in linux drivers?
The BGW211 disassembly shows some informational strings in the code
which I'd like to activate for testing.
(Firma: Atelier Klippel) #1665559
Hello,
Joost R. schrieb:
> Hi All,
> Cheers,
> Joost
ahh, thats good news indeed!
As for the files, i placed the original BSP from Freescale as well as
the QTopia Greenphone SDK on there as well, just for convenience.
"PhoneDevelop.tgz" is the actual VM. It is about 2GB in size, and you
need about 6GB or so to unpack it. It has a Kubuntu 8.04LTS base
install, with a few extra programs added. It also has german and english
language support, the default for KDE is set to german. More details
about it below.
The file "imx21ads_20070612-ltib-rel7.2-rc2.iso" is the original Linux
BSP from Freescale. This is what is installed on top of the Linux VM.
Then there is "qtopia-greenphone-sdk-4.3.2.iso". It is the full SDK for
the Greenphone. It uses QTopia, and a full version of that. This means
that things like QTopiaPhone are also there, including sources. This
should give a nice starting point to replace the software on the phone
at some later date in the future.
About the Kubuntu VM. It uses VMWare. Simply download and install the
VMWare Player, open the VM file there and start it. The username is
vpx500, the password is the same. Once started and logged in you end up
on the desktop. The "Konsole" icon at the upper left opens a shell
window that directly drops you into the VPx500/code subdirectory in the
home directory. You will find the helloworld example there.
Tip: there is mc installed, a norton-commander like thing to navigate
easily on the shell.
As editor you can use kate, which is a nice program including
syntax-highlighting, a shell-window, etc. Press Alt+F2, enter "kate" and
hit return. You can also reach it through the normal K menu at the
bottom left.
The BSP base is placed under BSP/ltib-imx21ads-20070609 in the home
directory. If you want to change stuff there, like compiling a kernel
etc., use ./ltib <options> from within that directory. You can get the
available options by using "./ltib --help". The actual installation of
the BSP is in the /opt directory. In the "mtwk" subdirectory there is
the actual toolchain. The helloworld example is already adjusted to that
directory, so you can use that as a template.
Hint: the linux console and console-windows have an tab-completion
feature. For example, if you enter "cd ~/BSP/lt" and then hit the TAB
key, it auto-completes that into "cd
/home/vpx500/BSP/ltib-imx21ads-20070609/"
Note that ~ is the short form for your home directory.
So, that's it for now. Any questions about linux in general should
please go to the propper forums/wikis/whatever, as that would be beyond
the scope of this thread. Linux and Kubuntu is well documented
elsewhere. Note that Kubuntu is basically the same as Ubuntu, just with
KDE instead of the Gnome Desktop. So if you search for something, look
for Ubunto as well.
Greetings,
Chris
(Firma: Atelier Klippel) #1665562
Das mag sein. Nur ist die Frage zum einen: lebt das Telefon solange? Zum
anderen: Wann kommt es denn nun, dieses IPv6? Immer wird gejammert das
der Adressraum ausgeht, und nun endlich v6 kommt. Seit Jahren. Aber
wirklich was passieren tut da bisher nicht so recht.
Zudem: Selbst wenn das ganze iNet nun v6 spricht, im Heimnetz wird man
sicher weiter v4 nutzen können, der Router erledigt das dann schon...
Grüße,
Chris
(Firma: Atelier Klippel) #1665565
Ich meinte damit jetzt nicht das der Kernel größer wäre. Sondern eher
die Tatsache das das Telefon halt kaum erweiterbar ist, und so vieles
von dem was es an neuen Sachen im 2.6er gibt eh nicht benutzt werden
wird.
Das ist allerdings richtig. Dann ist der Treiber aber nur die halbe
Miete: anschliessend geht es weiter beim wpa_supplicant, der ebenfalls
einen Philips-spezifischen Teil enthält.
Grüße,
Chris
Edit: Natürlich ist es nicht verkehrt auf mehreren Fronten gleichzeitig
zu arbeiten. Ich habe mir erstmal das Treiber-Neuschreiben für LCD,
Sound, Power-Management und "Tastatur" zur Aufgabe gemacht. Jeder der in
Richtung 2.6 arbeiten will ist natürlich herzlichst dazu eingeladen ;)
Später kann man das ganze dann ja zusammenführen (für 2.6) oder
Backports machen (auf 2.4).
(Firma: Atelier Klippel) #1665583
About the WLAN drivers and wpa_supplicant:
One could disassemble the driver, split it up in function blocks and
write c-wrappers to the resulting assembly functions. The function
arguments and return types can be derived more or less from that
assembly source. That could be used as a base to gradually convert it
into C.
As for the supplicant: One could compile the very same version from
source. Then walk through the disassembly of both versions to isolate
the philips specific driver code in there (and maybe changes to the base
code, if there are any). Then integrate the changes back into the real
source, and add the philips specific driver again as a mixture of
assembly-code and c-wrappers.
Quite some work, sure, but i think a feasible solution if everything
else fails.
Greetings,
Chris
(Firma: DC3AX) #1666796
Hi!
The BGW211 driver consists out of doezends of small functions accessing
the Device via SPI or addressing a shadow memory. By their names it
should be more or less obvious, what they do. This can be used to
reverse engineer the chips registers without using wrappers.
I am still hasseling with the setup of IDA, but it will go on. I hate
dynamic memory mapping or I/O mapping :)
Best regards,
Ulrich
(Firma: DC3AX) #1666901
The 'debug code' found in the driver and mentioned by me before is
active, if the TIN line is low. These strings are sent to the serial
console then.
SPI2:: drvIoctl :dot11LongRetryLimitAC1 = 8
SPI2:: drvIoctl :dot11LongRetryLimitAC2 = 8
SPI2:: drvIoctl :dot11LongRetryLimitAC3 = 8
SPI2:: drvIoctl :dot11ShortRetryLimitAC0 = 8
SPI2:: drvIoctl :dot11ShortRetryLimitAC1 = 8
SPI2:: drvIoctl :dot11ShortRetryLimitAC2 = 8
SPI2:: drvIoctl :dot11ShortRetryLimitAC3 = 8
SPI2:: drvIoctl :PA Request
SPI2:: drvIoctl :No state change!
SPI2:: drvIoctl :Fast PS Request
PhgHhalDoM2SDMA:1661:-->P1
SPI2:: drvHhalEventIndicationHandler :PS Ind (1) in Drvmain
If e log the complete startup until the registreation is completed, we
might get a line the driver follows and an idea of what the functions
are doing.
#1668506
> console then.
You'll see the same when you type "cat /proc/kmsg". The VP6500 seems to
be a bit more talkative than the VP5500 (it won't show the debug
messages you listed, but try removing the VPx500 from the cradle,
activate and turn the camera).
Btw: the command prompt of the VP5500 seems to be a lot more responsive
than that of the VP6500. Processes on the VP6500 wait much longer for
execution, while the CPU is idle. There is a module "doze", which I
suspect is responsible for making the CPU sleep, even if processes are
waiting for execution. However, I have no clue what sends the CPU to
sleep and what makes it react immediately to GUI events, even if the
console is sluggish (if not QTopia itself ;-).
/G
(Firma: DC3AX) #1668584
Hi Gert,
I recognize these slow console behavior only on the serial port. Via
Putty/ssh there is no problem of delayed characters.
The debug messages are part of the philips driver for the BGW211 chip.
As the VP5500 has an other chip on its module, there is other or, as you
said, no debug code.
With or without the debug... if you do not have the detailed datasheet
of the chip, the info is nice but not really helpfull. Lot of shortcuts
in it. May be it helps if I work myself through the 802.11 standards...
Regards, Ulrich
Gast #1668697
other Resources about the BGW211:
* BGW200 datasheet: http://www.ic72.com/pdf_file/14pdf/bgw200eg.pdf
Isn't enough to write a driver but helps to understand to host
communication
* The compulab CMX270
http://www.compulab.co.il/x270cm/html/x270-developer.py
also has the bgw211 wifi onboard. 2.6 drivers are binary only
* Beck Wl01 is another source.
http://www.beck-ipc.com/de/products/sc2x/wl01.asp  As usual no code
available only a binary lib
I suspect we won't find the sourcecode.
best regards
Dirk
(Firma: DC3AX) #1670659
Hi Dirk!
> communication
Right, got that before.
Hmm, yes looks like there is one on the board, but then later they
mention the Mavell Chipset...
No, but some things that a disassembler really likes :) But it's x86
code. Beck doesn't use ARM afaik.
Don't give up so early :)
Best regards, Ulrich
Gast #1676918
Hi Chris,
i fear not much. BGW200 was the predecessor of BGW211 but they have not
very much in common except the pinout.
The VP5500 should be based on TI OMAP plattform (dont ask me which one)
and the BGW211 was a WLAN that was discontinued some years ago.
So there is also nothing that came behind.
I believe later versions of the VP phones should use another WLAN
(Marvell?).
So the WLAN stuff will be not compatible i assume.
There are some test points close to the BGW211. I assume at one there
should be some serial output with 115k2 8n1. Maybe you find another UART
output at this 6 or 7 testpoints at the other side of the PCB. Assume
115k2 8N1 as well.
Would be nice if anyone can post traces.
Mario
(Firma: Atelier Klippel) #1677004
Mario,
sorry to tell you, but before posting such stuff it would be great if
you could do some fact-checking. Read the Wiki-Page about the phones.
Read this and the main thread.
Virtually everything of your post is completely wrong.
Wrong. They actually have quite some things in common. They internally
use an ARM7 based controller. Both are connected through their SPI2 port
to the host CPU. Both have the same ports than can be used to upload the
firmware, one of them said SPI2. You can cleary see that if you look at
the disassembly of the driver from the phone. Yes, they probably have
(partially) different register, and a different RF frontend. However, to
get an understanding of the basic structure, the BGW200 can give quite
some hints.
Again, wrong. Both phones are based on the iMX.21 ADS from Motorola, now
part of Freescale. Both used the Linux-BSP for development, which you
can still download from there. Again, this becomes clear by looking at
the files on the phones. And, partial sources for the phones have
appeared, from phillips. And guess what they use? No, it is not OMAP.
> (Marvell?).
You could have spent a few minutes reading the Wiki-Article. The VP5500
uses an add-on card that has a Marvell chip on it. The 6500 uses the
BGW211. From the production date, the 5500 came first, after that the
6500. So, the BGW came later. However, the software revision number on
the 6500 is lower, which looks like a discrepancy. But then, it's quite
possible that they started a new branch for the 6500 that is completely
independant from the 5500, in terms of version-numbering.
Greetings,
Chris
Gast #1677512
Hallo Chris,
ich bitte erstmal um Entschuldigung. War da wohl etwas voreilig.
Die Wiki Seiten sind wirklich sehr informativ. Wegen der Plattform hat
mir
mein Gedaechtnis wohl einen Streich gespielt.
Der Hinweis zu den richtigen Versionen ist gut. Da war ich auch verwirrt
durch das Bild im Konfigurations Thread, aber auch da steht ja VP6500
drann.
Also was das WLAN betrifft:
- weshalb man so wenig hoert liegt daran, dass die WLAN Entwicklung bei
NXP
  2008 bereits vor dem Joint Venture mit ST eingestellt wurde.
  Ich glaube auch nicht, dass Teile aus der Entwicklung in die Systeme
von
  ST eingeflossen sind, auch wenn die vom Aufbau her ganz aehnlich sind.
- Das BGW200 war ein Vorgaenger Modell, allerdings nur fuer 11b WLAN.
  Das BGW211 ist als Drop In Replacement konzipiert worden. Deshalb hat
es
  nach aussen im wesentlichen die gleichen Schnittstellen.
  Der innere Aufbau ist natuerlich auch aehnlich, aber ich bezweifle,
dass
  die Treiber wirklich so aehnlich sind. Es liegt doch erheblich Zeit
  zwischen den beiden Devices. Mal schauen kann aber nicht schaden ;)
Also nochmal sorry wegen dem ueberstuerzten Beitrag.
Gruss
Mario
(Firma: Atelier Klippel) #1677580
> es
> dass
Ich denke das die beiden mehr miteinander zu tun haben. So geht das
Datasheet vom BGW200 ja auch auf den BGW211 ein, nämlich in der
Pin-Beschreibung. So findet sich dort "reserved for pin-compatibility
with BGW211" bei einigen Pins.
Da beide Chips auch prinzipiell die gleiche Funktion haben, nämlich ein
Interface zu WLAN herzustellen, ist anzunehmen das auch der prinzipielle
Aufbau der Kommunikation mit dem Chip sehr ähnlich ist. Es wäre aus
sicht von Philips bzw. NXP ziemlicher Unsinn da zwei völlig verschiedene
Versionen zu machen. Das würde nämlich ein komplettes Neudesign mit
entsprechend höheren Entwicklungskosten bedeuten. Verwertet man aber
"altes" und funktionierendes erneut, und modifiziert dies lediglich,
spart das ein haufen Geld. Zudem erleichtert das für die Kunden ein
"drop-in-replacement" wenn man einen Großteil der Software
wiederverwenden kann.
Letztendlich haben beide Chips intern einen ARM7 Kern der über die
Firmware, die man dann hochlädt, den Großteil der Funktionalität
implementiert. Nach außen hin gibt es wenig zu tun. Halt ein paar
Mailboxen für Datentransfer, dazu ein paar Kommandos für DMA etc. Ich
bin mir sicher das das bei beiden recht ähnlich ist, und der großteil
sogar identisch. Das ist ja eben der Sinn des ARM7 Kerns da drin: die
Schnittstelle und das Protokol nach außen hin zu vereinfachen. Worauf es
halt ankommt ist die Firmware die in die Chips geladen wird. Denn die
implementiert letztendlich auch das Interface nach außen.
Grüße,
Chris
Gast #1681056
ich versuche momentan, den crond für das VP5500 zu übersetzen (DANKE!
Chris für die VM). Hapert allerdings im Moment noch etwas.
Wenn irgendjemand noch Infos hätte, wie man zusätzliche "Programme" für
die GUI erstellen kann, könnte ich damit eine Wecker /
Terminerrinnerungsapp bauen.
Die wird dann (im Erfolgsfall) selbstverständlich auch hier
veröffentlicht!
Gruß,
LemonSquash
#1681187
kruemeltee schrieb:
> SDL mit Framebufferausgabe, wenn du willst, kann ich dir heute Abend ein
> Beispiel posten.
das wäre dann ja aber am qtopia vorbei, oder?
Ich vermute das das dann Probleme gibt, wenn qtopia irgendwelche
elemente updated, da dann Teile der Applikation überschrieben werden.
Edit:
Ich stell mir das so vor, dass es wäre, als wenn man unter Windows an
allen Anwendungen vorbei direkt auf den top-Level-HDC (getDC(0)) malt
Gast #1681339
I’m not familiar at all with the ltip stuff, but has anyone any hints or
links to documentation on how to start hacking the kernel for the phone?
I got the VM image running in VirtualBox and seem to have found the
kernel-source in ~/BSP/ltib-imx21ads-20070609/rpm/BUILD/linux, but
typing make there raises a bunch of errors, so I’m wondering on how to
get started.
Gast #1681567
>Edit:
Ja, da hab ich wohl einen Fehler gemacht und zu schnell gelesen. Ich
denke mal, dass da dann sowieso gar nichts geht, wenn X rennt, geht SDL
auf dem Framebuffer auch nicht bzw man sieht es nicht.
Seis wie es sei, SDL/fb ist sehr praktisch wenn man selbst was basteln
will, ist einfach und ich könnte ein Beispiel posten, welches auf dem
Framebuffer rennt.
#1681582
> Framebuffer rennt.
man kann schon den Framebuffer manuell beschreiben, das zeigt ja das
Schnippsel, was im Artikel steht um die bin splash screens anzuzeigen.
Für ne quick&dirty Anzeige aus einem Prog reicht das eventuell auch.
Gast #1681666
>> get started.
> RTFM
Thanks, maybe I should rephrase my question: where do I find TFM?
The doc/ directory was not particulary helpful, and it seemed I could
save myself a couple of hours trial/google/error if just asking here, as
probably some of you figured out a reasonable workflow for module
development, which again might also help others getting started.
(Firma: Atelier Klippel) #1682177
Hello,
cd ~/BSP/ltib-imx21ads-20070609
./ltib --configure
In the upcomming menu, scroll down a bit and check the "Configure the
kernel" option using the space key. Tab to "Exit" and answer the
following question with "Yes". It then starts the kernel configuration
dialog. Choose the options you want, select "Exit" and again answer
"Yes" if asked to save the config. It should then start to build the
kernel, and other packages if any new ones are selected.
You can get a list of options for ltib with "./ltib --help" executed
from the ~/BSP/ltib-imx21ads-20070609 directory. However, i'm not
familiar with ltib either....
Greetings,
Chris
Gast #1682687
Kruemeltee: Ich dachte zwar eher an eine art Applikation, die
einheitlich mit qtopia rennt (sozusagen ein Add-in ;) ).
Nichtsdestotrotz wäre ich dir für das besagte Beispiel dankbar, denn es
kann nie schaden ;)
Gruß,
Lemon
Gast #1682689
wenn du dich mit meinem Paket zufrieden gibst, brauchst du das nicht ->
guckst du http://thinksilicon.de/57/Hacking-the-VP6500.html einfach
entpacken und runlevel-Script entsprechend verlinken. Die entsprechenden
Einträge von Crontab + Script sind ebenfalls in der Dateistruktur
vorhanden ;)
Gast #1683925
Hi Thinksilicon,
das sieht doch schonmal ganz gut aus ;)
Bleibt noch die Frage nach der GUI dafür - ich möchte ja wie gesagt am
Ende eine Art Wecker / Terminerrinnerung für das VPx haben.
Danke soweit und MfG
Gast #1701487
I'm trying to access the VP6500 camera in order to stream it to a
network computer and display it there.
I used Chris's camtest.tgz file as a base for developing it, but I'm
afraid my skills in this area are quite lacking.
Chris writes:
I did exactly that, but my malloc'ed buffer doesn't get filled with any
camera data - it only contains zeros for the runtime of the application.
I tried to make it into shared memory by called mmap() but i guess I
don't really understand what it does.
You can find my current attempt here (testMode = 1)
http://github.com/arturh85/vp6500cam/blob/master/main.c
Would anyone take a look at it? Any help would be appreciated!
arturh
Gast #1703640
I researched some more into the topic and found out that I can't use
malloc because it allocates virtual uncoherent memory where I need
coherent physical memory.
As far as I see you need to use dma_alloc_coherent() for which I have to
be writting a kernel module.
Fact checking: Is that correct? Any viable alternatives?
http://mirror.linux.org.au/linux-mandocs/2.6.4-cset-20040312_2111/dma_alloc_coherent.html
Gast #1703956
I would be very interested, then I could try to use the phone as a kind
of portable WLAN radio :-)
Simply compiling madplay for arm did not work as an ioctl while opening
/dev/dsp fails - with your example code I can propably look into that.
Regards
Christian
(Firma: Atelier Klippel) #1704003
Hello,
sorry for my silence recently, but i'm quite busy these days and have
virtually no time to continue working on the phone.
Attached is a small dsp test program. It opens the aic and dsp1 devices,
gathers some information and then play back a 1 khz tone from the file
named sig1k.le. It does that twice, one time with 8khz and then with
16khz sampling rate.
Note that the sound system on the phone can only do these two sampling
rates, and only in mono. To use 16khz you have to issue the proper
ioctly always before playback. Once the devbice is closed it
automatically reverts back to 8khz.
The code also tries to read the mic input, but i haven't completely
figured out that one yes, so for now recording does not work.
As for the camera. The iMX itself has a section to handle the camera
input, scales it, does the color conversion, etc. It does so by using
DMA to read from the camera, and to write to the memory. So if you give
it a proper memory address, it should write the data there. Keep in mind
that linix itself translates memory addresses. The address that you get
through an alloc is probably not the correct physical address that the
cpu "sees". So it may be neccesarry to re-translate that address to the
real physical memory address.
Greetings,
Chris
Gast #1704777
And we now have music!
Thanks for your test program.  I took the aic14* files, plugged them
into madplay and it just works :-)
The patch and precompiled tarball are attached to this message.
To play an MP3 file, do this:
$ /usr/local/bin/madplay -o aic:/dev -R 16000 -m -b 16 <filename>
Playing audio streams/web radios:
$ wget -O- http://relay4.slayradio.org:8000/ | /usr/local/bin/madplay -o aic:/dev/dsp1 -R 16000 -m -b 16 -
Next thing on my list is to find a small mixer application and
crosscompile it, too, because listening to MP3s on top volume is kind of
annoying (or am I missing something and there is volume control hidden
in the phone menus?).
Regards
Christian
(Firma: Atelier Klippel) #1704947
Hello,
there is the /dev/mixer1 device that you could use. It is standard, so
you can use the regular OSS ioctl's for that. I attached a small sample
source that i did a while ago which lists the dsp capabilities and the
mixer stuff. Not sure if the mixer device can be opnened while qtopia is
running, didn't test that.
Greetings,
Chris
Gast #1705312
I got aumix running with a one line patch, but it just "did nothing".
I also wrote a small mixer app this afternoon - it works on my regular
PC, but on the phone it also does nothing (source attached).
/dev/mixer1 is opened successfully, the ioctl for setting the volume
throws no error but the volume is not changed at all.
I've never before written anything for sound devices under linux, so I'm
a bit out of ideas for now.
Regards
Christian
PS: When the phone goes to into one of it's sleep states (display goes
dark), trying to play an MP3 seems to result in a system freeze...
Gast #1713105
The DACGAIN, it does nothing :(
(bei ADCGAIN rührt sich übrigens auch nichts)
# /usr/local/bin/vp6500mixer 0
DAC Gain before:        2A (    0 dB)
DAC Gain after:         2A (    0 dB)
# /usr/local/bin/vp6500mixer 50
# /usr/local/bin/vp6500mixer 100
regards
Christian
Gast #1713144
grrr, forget my last post.  moving the "bytereg[0] = vol" line to the
correct position makes this work :-)
it definitely did not work before, though, that's why I added the
GET_DAC_GAIN calls for debugging...
btw, Christian, can I add your header files to a git repository or a big
tar.gz containing everything that's needed for MP3 output?  Can I
consider your files GPL'ed?
Regards
Christian
Gast #1731795
I was looking into this a while ago. Yes, you’ll need coherent memory +
its physical address.
However the camtest approach would probably suck. So for a good solution
you’ll need to write a kernel module, but then again the drivers for the
video are already there (linked at the wiki-page somewhere), so there’s
already software for talking to the hardware which will then take care
of most things including the encoding of the video.
I didn’t look too long into it, but there were some things that weren’t
as straightforward as I thought though ;)
Happy hacking!
Gast #1732050
I'm quite a newbie to kernel/drive development and reverse engineering,
but I'd love to hack further on this issue.
Could you give me any more information on where to find that video
driver (i guess it's the video.o file?) and how to access it?
Do i have to use ioctl like in the camtest example?
My current attempt is successfully transfering the camera image (out of
the framebuffer) to a python wxWidgets application which can draw the
uncompressed video stream at about 5 fps. Getting it hardware encoded
would certainly help :)
Regards, arturh
#1744484
Hi!
Is somebody still working on the phone (I am not talking about setting
up SIP as in the other thread). Any new insights on the Philips-Sources
(GPL...) or about WLAN and Display-Driver etc? Any chance the phone will
ever be usable without the linux (in terms of using its hardware in a
bare-metal system).
BR
Robert
Gast #1751483
The video-driver is linked here:
https://www.das-labor.org/wiki/VP5500#Camera
And contains basically all code needed to access the hardware, although
some is not used, or used in a complex fashion in the v4l system which
I’m not familiar with. There is also documentation available on the
hardware in the internet and how to access it and what all the register
information mean etc., tough I don’t have a link at hand right now.
Happy hacking :)
Gast #1835891
Hi all,
In a post of Mitch I see that volume-control (for MP3 playing) is
possible. I searched for a binary but not found yet. Anybody that can
give me a binfile for it?
Thanks,
Jan
PS next step would be to include MP3 play (stream from a fixed server)
and volume in the menus, seems to be possible,. Probably only need a
german translator ;-)
Gast #1849189
I've attached a binary to this posting.
Starting playback and changing volume via the menu is only writing some
small scripts, should be no problem.
But you propably will run into the problem with the power-saving: After
about 30 seconds the CPU is throtteled and MP3 playback starts to
jitter.
If somebody knows how to prevent the powersaving, please tell :-)
Regards
Christian
Gast #1882040
Mein Trick um momentan an nen bild von der Kamera zu kommen ist einfach
das vorher beschriebene sensortest laufen zu lassen und dann einfach mit
cat /dev/fb0 | nc server 5000
den framebuffer komplett an nen anderen rechner zu senden...
mit
netcat -l -p 5000 | ./scap | pnmtopng > out.png
hol ich das bild dann ab und mach nen png draus.
scap stammt von hier. http://handhelds.org/scap/code/scap.c
Dabei muss einmal die auflösung angepasst werden!
Ist alles nen bisle hässlich.. :)
Gast #1964284
auch, wenn es hier ziemlich ruhig geworden ist, habe ich mich nach einem
Treiber fürs BGW211-WiFi umgeschaut.
Auch, wenn ich nicht direkt fündig geworden bin, bin ich über ein paar
Informationen gestolpert, die hier noch nicht erwähnt wurden.
Das WiFi-Modul scheint den Code-/Platformnamen "Georgia" gehabt zu
haben, und wurde außer in den oben erwähnten Geräten offensichtlich auch
in diversen Multimedia-Playern von Archos verbaut. Der übliche
Treibername scheint ga_linuxdrv.ko oder bgw211.ko/BGW211.ko zu sein.
Zumindest ersteren findet man auch als Binärdatei, wenn man die bekannte
Suchmaschine verwendet. Der Ursprung schient hier bei den Archos-Geräten
zu liegen.
Ulrich P. schrieb:
> Es müsste eigentlich ein recht aktueller Treiberfür den BGW211
> exitieren, jedenfalls scheint es für die QBox einen für einen Kernel
> 2.6.17 zu geben:
> http://www.sat-universe.com/archive/index.php/t-124235.html
> Kann hier jetzt aber kein Kernelarchiv herunter laden, das spare ich mir
> dann für nächste Woche auf :)
Daran habe ich mir echt die Zähne ausgebissen, denn scheinbar gibt es
nur entsprechende Quellen nur für den Nachfolger, nämlich die Qbox HD.
Unabhängig davon, dürfte das Modul höchstens zur Extraktion der
BGW211-Firmware dienen, denn die Qbox-One scheint eine PPC-Architektur
zu haben. Natürlich gibt es die Firmware-Blobs des Herstellers,
allerdings habe ich keinen Weg gefunden, den Inhalt aus den QBU-Dateien
zu extrahieren.
Hier bin ich fündig geworden. :-)
In den GPL-ISO-Images von Archos für die Gerätegenerationen 4 und 5
(andere habe ich nicht überprüft) gibt es jeweils die Datei
buildroot/package/wpa_supplicant/driver_philips.patch (vom Inhalt her in
beiden ISO-Dateine bis auf CVS-Tags identisch).
Die ISOs findet man auf www.archos.com unter Support&Konto -> Downloads,
dann runterscrollen und bei "Notice of GNU General Public License and
Lesser General Public Licence" auf den Show-Button klicken.
Ich bin mir nicht sicher, aber der Patch sieht so aus, als ob man damit
auch einen Host-Treiber bauen könnte - zumindest Teile davon. Nachprüfen
kann ich das leider nicht, da mir einerseits einiges an Wissen,
andererseits ein Rechner mit entsprechender Entwicklungsumgebung fehlt.
Ich denke, Ihr (d.h. Christian und Ulrich) könnt damit mehr anfangen als
ich... :-)
Schöne Grüße,
Tom
#2061150
> Hallo,
> Grüße,
> Chris
ist es auch möglich dem Watchdog mitzuteilen, dass er das System bitte
neustarten soll?
Ginge das auch ohne C, per Shellskript?
Grüße
Stefan
