1 | -- Bresenham.vhd
2 | use ieee.std_logic_1164.all;
3 | use ieee.std_logic_arith.all;
4 | use ieee.std_logic_unsigned.all;
5 |
6 | ENTITY Bresenham IS
7 | generic
8 | (
9 | SHIFT_WIDTH : natural := 1
10 | );
11 | PORT
12 | (
13 | clk : in std_logic;
14 | reset_n : in std_logic;
15 | fval_in : in std_logic;
16 | lval_in : in std_logic;
17 | pval_in : in std_logic;
18 | ref_in : in std_logic_vector(15 downto 0);
19 |
20 | ref_out : out std_logic_vector(15 downto 0);
21 | fval_out : out std_logic;
22 | lval_out : out std_logic;
23 | pval_out : out std_logic;
24 | rdref : out std_logic
25 |
26 | );
27 | END Bresenham;
28 |
29 | ARCHITECTURE behavior OF Bresenham IS
30 |
31 | signal r_fval : std_logic_vector(SHIFT_WIDTH-1 downto 0);
32 | signal r_lval : std_logic_vector(SHIFT_WIDTH-1 downto 0);
33 | signal r_pval : std_logic_vector(SHIFT_WIDTH-1 downto 0);
34 |
35 | signal r_ref : std_logic_vector(11 downto 0);
36 | signal r_ref_in : unsigned(15 downto 0):=(others => '0');
37 | signal r2_ref_in : integer := 0;
38 | signal r3_ref_in : integer := 0;
39 | signal ref_result : std_logic_vector(15 downto 0):=(others => '0');
40 |
41 | signal state : std_logic:='0';
42 |
43 | BEGIN
44 |
45 | ref_out <= ref_result;
46 | fval_out <= r_fval (SHIFT_WIDTH-1);
47 | lval_out <= r_lval (SHIFT_WIDTH-1);
48 | pval_out <= r_pval (SHIFT_WIDTH-1);
49 | rdref <= state;
50 |
51 |
52 | process(reset_n, clk)
53 | variable x1 : unsigned(7 downto 0):=(others => '0');
54 | variable y1 : unsigned(7 downto 0):=(others => '0');
55 | variable ex : integer := 0;
56 | variable ex1 : integer := 0;
57 | variable x : integer := 0;
58 | variable y : integer := 0;
59 | begin
60 |
61 | if(reset_n = '0') then
62 | r_fval <= conv_std_logic_vector('0', SHIFT_WIDTH);
63 | r_lval <= conv_std_logic_vector('0', SHIFT_WIDTH);
64 | r_pval <= conv_std_logic_vector('0', SHIFT_WIDTH);
65 | r_ref <= (others => '0');
66 | r2_ref_in <= 0;
67 | r3_ref_in <= 0;
68 | r_ref <= (others => '0');
69 | r_offset <= (others => '0');
70 | ref_result <= (others => '0');
71 |
72 | elsif(clk'event and clk = '1') then
73 | r_fval <= r_fval (SHIFT_WIDTH-2 downto 0) & fval_in;
74 | r_lval <= r_lval (SHIFT_WIDTH-2 downto 0) & lval_in;
75 | r_pval <= r_pval (SHIFT_WIDTH-2 downto 0) & pval_in;
76 | ref_result1 <= ref_result;
77 |
78 | if (fval_in = '1' and lval_in ='0') then
79 | r_ref_in <= unsigned (ref_in);
80 | r2_ref_in<= conv_integer (r_ref_in (7 downto 0));
81 | r3_ref_in<= conv_integer (r_ref_in (15 downto 8));
82 | ex := r2_ref_in/2;
83 | state <= '0';
84 | end if;
85 | if (lval_in ='1') then
86 | if (state = '0') then
87 | if (x <= r2_ref_in) then
88 | if (ex < 0) then
89 | y := y + 1;
90 | ex := ex + r2_ref_in - r3_ref_in;
91 | x1 := conv_unsigned(x,8);
92 | y1 := conv_unsigned(y,8);
93 | ref_result ( 7 downto 0) <= std_logic_vector(x1);
94 | ref_result (15 downto 8) <= std_logic_vector(y1);
95 | x := x + 1;
96 | if (x > r2_ref_in) then
97 | state <= '1';
98 | else
99 | state <= '0';
100 | end if;
101 | else
102 | ex := ex - r3_ref_in;
103 | x1 := conv_unsigned(x,8);
104 | y1 := conv_unsigned(y,8);
105 | ref_result ( 7 downto 0) <= std_logic_vector(x1);
106 | ref_result (15 downto 8) <= std_logic_vector(y1);
107 | x := x + 1;
108 | if (x > r2_ref_in) then
109 | state <= '1';
110 | else
111 | state <= '0';
112 | end if;
113 | end if;
114 | elsif(x > r2_ref_in) then
115 | state <= '1';
116 | else
117 | ref_result ( 7 downto 0) <= x"00";
118 | ref_result (15 downto 8) <= x"00";
119 | end if;
120 | end if;
121 | if (state = '1') then
122 | ref_result ( 7 downto 0) <= std_logic_vector(x1);
123 | ref_result (15 downto 8) <= std_logic_vector(y1);
124 | end if;
125 | else
126 | x := 0;
127 | y := 0;
128 | state <= '0';
129 | end if;
130 | end if;
131 | end process;
132 | END behavior;
