Hallo zusammen hoffe einer kann mir weiter helfen, ich bekomme immer folgenden fehler von Multisim: run # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 0 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 0 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 0 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 0 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 0 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 0 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 1 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 1 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 1 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 1 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 2 Instance: /tb_sinc3_filter/inst_01 # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). # Time: 0 ps Iteration: 2 Instance: /tb_sinc3_filter/inst_01 soweit ich das richtig verstehe werden gleichzeitig zwei Signale an den Bus gelegt. Hoffe das jemand mal kurz Zeit hat und den fehler findet, ich finde ihn leider nicht.
So wie ich das lese, befindet sich ein 'U'|'X'|'W'|'Z'|'-' in einem Operand mit dem gerechnet wird (numeric_std)
hab hier ein Buch in dem Stand das bei dieser Fehler Meldung wohl eine doppel belegung vorliegt. hast du denn eine Ahnung woran es liegen könnte?
Ich denke das kommt aus den "Arith" Package: zum Zeitpunkt 0 ps sind einfach alle Signale noch U, und daran mäkelt das Package herum. Ich habs im Simulator einfach abgeschaltet (Ich weiß aber nicht wie das im "multisim" geht). Und dies habe ich noch aus einer hier wohlbekannten Homepage hierher kopiert: >Die gerne noch verwendeten Quasi-Industrie-Standards der Synopsis-Lib >sind schon geraume Zeit obsolete. >library IEEE; >use IEEE.STD_LOGIC_1164.ALL; >use IEEE.STD_LOGIC_ARITH.ALL; >use IEEE.STD_LOGIC_UNSIGNED.ALL; >Statt dessen sollte die Numeric_Std Library verwendet werden. Diese ist >herstellerunabhängig und über IEEE 1076.3 genormt. >library IEEE; >use IEEE.STD_LOGIC_1164.ALL; >use IEEE.NUMERIC_STD.ALL; aus http://www.lothar-miller.de/s9y/archives/14-Numeric_Std.html
None Blub schrieb: > # ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, > the result will be 'X'(es). Die Ursache wurde ja schon benannt. In diesem Modul findest Du die fragliche Rechenoperation: > # Time: 0 ps Iteration: 2 Instance: /tb_sinc3_filter/inst_0 Ich helfe mir so:
1 | # simulation start script |
2 | do wave.do |
3 | |
4 | set StdArithNoWarnings 1 |
5 | set NumericStdNoWarnings 1 |
6 | run 0 ps |
7 | |
8 | set StdArithNoWarnings 0 |
9 | set NumericStdNoWarnings 0 |
10 | run -all |
@bko: Auch ieee.numeric_std spuckt solche Warnungen aus... Duke
bko schrieb: > zum Zeitpunkt 0 ps sind einfach alle Signale noch U, und daran mäkelt > das Package herum. Ich habs im Simulator einfach abgeschaltet Ich würde Signale einfach vorbelegen... ;-)
