Zu den genauen Fehlermeldungen aus ISE und GHDL.
Da beide einen Fehler ausspucken, scheint als wäre etwas nicht
semantisch. Sofern wäre es interessant zu wissen.
1 | mem_data_r<= (others=>'Z') when uart_select='0' else
2 | -- X"000000"& receive_data when mem_address(2)='0'
3 | ((7 downto 0)=> receive_data,(others=>'0')) when mem_address(2)='0'
4 | else(0=>send_busy,8=>receive_empty,(others=>'0'));
5 | -- else X"000000" & send_busy & "000000" & receive_empty;
6 |
7 |
8 | mem_data_r<= (others=>'Z') when uart_select='0' else
9 | -- X"000000"& receive_data when mem_address(2)='0'
10 | ((7 downto 0)=> receive_data,(others=>'0')) when mem_address(2)='0' --zeile 109
11 | else(0=>send_busy,8=>receive_empty,(others=>'0'));
12 | -- else X"000000" & send_busy & "000000" & receive_empty;
Fehlermeldung in ISE
Parsing architecture <logic> of entity <uart>.
ERROR:HDLCompiler:806 -
"/home/red/projekt/mips/LM_CPU/rtl/device/uart/uart.vhd" Line 109:
Syntax error near ")".
ERROR:HDLCompiler:720 -
Positional association cannot follow named association
"/home/red/projekt/mips/LM_CPU/rtl/device/uart/uart.vhd" Line 110:
ERROR:HDLCompiler:1699 -
"/home/red/projekt/mips/LM_CPU/rtl/device/uart/uart.vhd" Line 109: Type
error near receive_data ; current type std_logic_vector; expected type
std_ulogic
ERROR:HDLCompiler:845 -
of aggregate cannot be determined without context ; 0 visible types
match here
"/home/red/projekt/mips/LM_CPU/rtl/device/uart/uart.vhd" Line 110: Type
match here
ERROR:HDLCompiler:854 -
"/home/red/projekt/mips/LM_CPU/rtl/device/uart/uart.vhd" Line 53: Unit
<logic> ignored due to previous errors.
VHDL file /home/red/projekt/mips/LM_CPU/rtl/device/uart/uart.vhd ignored
due to errors
Fehlermeldung in ghdl
../rtl/device/uart/uart.vhd:109:38: '=>' is expected instead of ')'
ghdl: compilation error
Weitere Variation
2 | X"000000"& receive_data when mem_address(2)='0'
3 | -- ((7 downto 0)=> receive_data,(others=>'0')) when mem_address(2)='0'
ISE
match here
due to errors
GHDL
../rtl/device/uart/uart.vhd:110:31: element associations must be all
positional or all named
make: *** [all] Error 1
