Forum: Projekte & Code Transistortester AVR
von PAULO C. (kalvin)
I bought in the "DX" (Chinese) Transistor tester kit (to assemble).
With 2x16 display and atmega328p that came not programed.
Please, could you send me the * .hex software or source to compile that
was used in your project.
THANK YOU
Übersetzt von Google
Ich kaufte in der "DX" (Chinesisch) Transistor-Tester-Kit (zu
montieren).
Mit 2x16 Display und atmega328p kam das außerplanmäßig.
Könnten Sie mir bitte die * .hex-Software oder -Quelle zur Kompilierung
schicken, die in Ihrem Projekt verwendet wurde?
DANKE
von kubi48 (Gast)
You find the hints for accessing the subversion (SVN) archive in this
wiki:
https://www.mikrocontroller.net/articles/AVR_Transistortester#Downloads_.28English.29
With the svnbrowser you should first select the directory, which you
wish to download. Of course you can also download the complete archive.
For your board you will probably find the right configuration in the
directory Software/trunk/mega328.
The actual PDF documentation is in directory  Doku/trunk/pdftex/english.
The complete SVN archiv is additionally cloned to a GIT archive:
github.com/svn2github/transistortester
von Klaus R. (klaus2)
Paulo, 2x16 is VERY uncomfortable...better ready flashed LCR T4 nxt
time!
Klaus.
> nxt
> time!
> Klaus.
Thank you for your attention.
But, first of all I need know if the kit that have from Chinese one
works properly.
The kit arrived with atmega328 ; an 8 Mhz crystal; a LCD 1602 - display
02x16
 without ISP connection.
I have make a inclusion of ISP connection by wiring a connector to the
pins like scripted in  your schematic and description file.
The *.hex file on default folder do not function .
Do the *.eep file is also needed
Could you help me , please ?
Thanks.
translation by GOOGLE -
Danke für Ihre Aufmerksamkeit.
Aber zuerst muss ich wissen, ob das Kit, das aus China stammt, richtig
funktioniert.
Das Kit kam mit atmega328; ein 8 Mhz Kristall; ein LCD 1602 - Display
02x16
  ohne ISP-Verbindung.
Ich habe eine ISP-Verbindung aufgenommen, indem ich einen Stecker an die
Pins angeschlossen habe, wie in der Schaltplan- und Beschreibungsdatei
beschrieben.
Die * .hex-Datei in Ihrem "default" - Ordner funktioniert nicht.
Wird die Datei * .eep benötigt?
Kannst du mir helfen ?
Vielen Dank.
von Joachim K. (jotka13)
mich würde es einmal interessieren, ob man die Firmware auch für einen
20 MHz Takt anpassen könnte, dieses ist ja das Maximum für den der
ATmega328 spezifiziert ist.
Dieses hätte mir für mich den Vorteil dass ich auch 16 MHz Quarze messen
könnte. Der Frequenzzähler würde auch höhere Frequenzen messen können.
Probiert habe ich es auch schon mit einem 20 MHz Quarz, nur muss ich
dann die angezeigten Werte um den entsprechenden Faktor korrigieren.
Ich danke Euch schon jetzt!
Viel Grüße,
Joachim
von Jörn G. (jrn_g)
Hallo Joachim, Deine Frage kann ich nicht beantworten, Dir aber
vorschlagen einen 10:1 Frequenzteiler zu nutzen. Das praktische ist bei
den Dekadenteilern, dass man auch ohne Anpassung der Sofwaŕe mit ihnen
arbeiten kann, da man die angezeigt Frequenz nur mit 10 multiplizieren
muss. Welchen IC ich wie genau in Betrieb habe, könnte ich morgen
mitteilen, wenn Interesse besteht.
Da ich mit höheren Frequenzen arbeite, habe ich vor dem Dekadenteiler
noch einen MB501 sitzen der mich bis zu 1,1GHz messen lässt, da dieser
aber 128:1 teilt, ist das Arbeiten nicht leicht. Hier wäre es sehr
schön, wenn man softwareseitig eingeben könnte, mit welcher
Frequenzteilung man arbeitet. Ich hatte dies weiter oben schon
angesprochen (den MB501 kann man auch direkt am Tester nutzen, wenn man
nur bis zu ca. 600MB arbeitet).
Grüße, Jörn
von Andreas I. (andy5macht)
Ich habe ebenfalls den Chinesischen Clone erhalten:
Beitrag "China Klon T3 T4 T5"
Also exakt das selbe Verhalten wie im Beitrag von hoteug.
Gibt es eine Compilierte-Version für diesen Type?
Habe ein JTAG-ICE3 hier, mit dem ich normalorweise in ATMEL-Studio
programmiere. Nur komm ich gerade mit den Makefiles nicht klar.
von Karl-Heinz K. (kubi48)
Es geht wohl mehr um die optionale Direkt-Messung von Quarzen oder
Resonatoren mit der SamplingADC Methode. Leider muß für diese Anpassung
das komplette Programm überprüft werden, was schon einen gewissen
Zeitaufwand bedeutet. Ich werde das aber demnächst weiter untersuchen.
Zur Zeit hatte ich Arbeit in die Weiterentwicklung des Optiboot
Bootloaders gesteckt, was ich hoffentlich bald abschließen kann.
Kannst Du einen Vorschlag machen, welchen Namen das Unterverzeichnis
haben soll?
Ich habe diese Version nicht vorliegen.
> haben soll?
Aber gerne doch.
Da die Platine keinerlei Bezeichnung hat aber als T4 verkauft wird würde
ich "mega328_T4_v2_st7565" vorschlagen
Super soeben aufgespielt.
Funkioniert! Vielen Dank!
von bianchifan (Gast)
Die alternative "M-Firmware" gibt es auch in einer 20-MHz Version,
getestet mit der Hardware "AY-AT".
Einzelheiten bitte im "20$ Transistor checker" Wurm im eevblog-Forum
nachlesen, es gab da wohl mal Probleme mit der Genauigkeit.
Zusatznutzen: Servotests!
Ich selber habe sie noch nicht getestet, mein 9$ AY-AT liegt seit fast
nem Jahr inner Schublade....
vielen Dank Euch allen für die Tipps!
Viel Grüße
Joachim
von Franz J. (Gast)
die Frage ist vielleicht etwas OT, betrifft aber das SPI-Display ST7735
des chinesischen TT-Clones. Hierbei ist ja das Display mit einem
Pegelwandler auf der Platine versehen.
Probeweise habe ich mal das Display extern an unterschiedlichen MC
betrieben (Atmega und STM32F103c BluePill). Über Software-SPI (Bitbang)-
wie auch im AVR-Transistortester realisiert - funktioniert es klaglos,
doch mittels Hardware-SPI ist keine Anzeige zu entlocken. Kennt jemand
den Grund hierfür, bzw. hat es schon ausprobiert?
Franz
von Oliver J. (skriptkiddy)
Hi Leute,
wollte mal meine Erfahrungen zum Transistortester hier zum Besten geben:
Zuerst mal ist das ein Projekt, das mehr als nur Respekt verdient. Es
wurde damit ein Gerät geschaffen, welches es zu einem erschwinglichen
Preis möglich macht eine Vielfalt von Komponenten mit für Bastler mehr
als ausreichender Präzision zu messen. An dieser Stelle möchte ich den 3
Hauptakteuren für ihre Arbeit Danken: dem Initiator Markus Frejek, dem
Projekt-Adoptivvater Karl-Heinz Kübbeler und Markus Reschke fürs das
mehr als notwendig gewesene Neustrukturieren/Neuschreiben des Codes.
Ich habe mir meinen Transistortester bei Amazon gekauft (Chinesisches
Fabrikat: LCR-T4) [1]. Ich war direkt erstaunt, was das kleine Teil
alles kann. Für mich war beim Kauf interessant, dass Spulen gemessen
werden können, aber es geht ja noch so vieles mehr: Transistoren,
Mos-Fets, Dioden, Widerstände, Kondensatoren, ...... - Einfach nur
geniales Projekt.
Jedoch sind die China-Teile nicht mit Präzisionskomponenten gefertigt
und somit entsprechen die Messungen eher einer Schätzung. Wenn man aber
die Messwiderstände gegen 0.1%-Varianten austauscht und für eine präzise
Vergleichsspannung sorgt, dann sinkt die Messungenauigkeit ziemlich. Auf
dem angehängten Foto kann man sehen, was ich verändert habe, um meinen
China-Transitortester zu tunen. Aktuell läuft bei mir die Firmware
v1.32m
Grüße Oliver
[1]
https://www.amazon.de/dp/B01ABOXBOQ/ref=cm_sw_em_r_mt_dp_U_NQTMAbMVAFN3J
von F. F. (foldi)
> werden können,
Apropos!
@Karl-Heinz
Vielleicht erinnerst du dich, dass ich den Tester mit deiner Hilfe
umbauen wollte?
Nun hatte ich die Gelegenheit, bei einer Schulung den nicht umgebauten
Tester an Drehstrommotoren mit Masseschluss und Windungsschluss zu
testen.
Habe an einem extra Kabel mit Klemmen gelötet.
Der Tester zeigt sehr zuverlässig alle Schäden genau genug an.
Und jetzt kommt`s! Unser neues Messgerät hat ein Zusatzmodul, eine Folge
von einzuhaltenden Messfolgen und kostet für uns(!), Karl-Heinz, du
weißt ja wo ich arbeite, einem großen Laden, fast 1800 Euro.
Für mich brauchen sie das Messgerät nicht kaufen, ich nehme sowieso den
Tester.
Weiß nicht wie oft ich mich schon dafür bedankt habe, aber das kann man
für deinen Einsatz sowieso nicht oft genug.
Danke Karl-Heinz!
von Barney G. (fuzzel)
> Danke Karl-Heinz!
Wie wahr.
von Angel G (Gast)
Hello, I have some feature requests:
- there is problem with small capacitance and inductor measurement.
Inductor can be detected as resistor. So maybe a menu to force the
element type could help.
There are famous schematics of better (0.1pF, 0.02uH) and very accurate
LC meter, based on LC generator with comparator (almost one and the same
scheme everywhere):
1. http://electronics-diy.com/lc_meter.php
2. https://sites.google.com/site/vk3bhr/home/lcm1
3. http://pwillard.com/?p=180 (with ATMEGA)
4.
http://www.kerrywong.com/2010/10/16/avr-lc-meter-with-frequency-measurement/
We can make a PCB with this LM311 oscillator and interface it to the
Transistortester so to extend it's functions with something very useful
can't we ?
> can't we ?
Did you know the SamplingADC feature of Pieter-Tjerk, which can be
activated by a Makefile option? You can use it with every transistor
tester which have enough flash memory without any hardware extension.
The resolution of capacity measurement is enhanced to 0.01pF for every
capacitor below 100pF. Inductors with low inductance can be measured by
connecting a parallel capacitor of about 18nF. The resonant frequency of
the parallel LC circuit is measured and the inductance value is computed
with the known capacity value of the parallel capacitor. Additionally
the quality factor of the parallel RC circuit is measured too.
With a additional option WITH_XTAL you can activate a SamplingADC
extension for additional measurement of ceramic resonators and crystals,
if you operate the tester with a 16MHz clock frequency.
von Glenn M. (glenndk)
Ich habe die Änderungen vorgenommen, um die dänischen Sprache
hinzuzufügen. Die Schriften wurden geändert.
(ComponentTester-1.32m, var_danish.h.zip)
(transistortester/Software/trunk/ langDANISH.h.zip)
wie ich gestern zufällig gesehen habe, hat Karl-Heinz die Funktionalität
für den Betrieb mit einem 20 MHz Quarz schon in der aktuellen Trunk
Version integriert.
Karl-Heinz, dafür schon einmal meinen aller besten Dank! Und auch für
die Arbeit, die Du immer wieder in dieses Projekt stehst.
Jetzt wollte ich das natürlich sofort ausprobieren.
Leider bin ich dabei auf folgedes Problem mit dem Atmel Studio 7 unter
Windows 10 64 Bit gestoßen.
Hier noch einmal die Fehlermeldungen aus dem Screenshot:
recipe for target 'TransistorTester.eep' failed
im Project: Transistortester
im File: finish.mk Line 94
recipe for target 'TransistorTester.lss' failed
im Projevt: Transistortester
im File: finish.mk Line 97
Die beiden betroffenen Zeilen aus dem finish.mk file sind folgende:
93 %.eep: $(TARGET)
94  -avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@ || exit 0
95
96 %.lss: $(TARGET)
97  $(AVR_TOOL/PATH)avr-objdump -h -S $< > $@
Kennt Ihr euch damit aus? Gibt es Unterschiede in der Syntax des
Makefile bei Linux bzw. Windows oder was könnte die Ursache sein?
Ich danke Euch vorab schon für eure Unterstützung!
Viele Grüße
Joachim
Eine Möglichkeit wäre beispielsweise, daß das falsche "make" Programm
genommen wird. Es sollte das GNU Make Programm verwendet werden.
Außerdem ist auch die Größe des übersetzten Programms von der avr-gcc
Version abhängig wegen unterschiedlicher Optimierung. Die neuere avr-gcc
Version 7.2.0 liefert ein gutes Ergebnis.
Übrigens macht bei 20MHz Betrieb die Quarz-Erkennung bei höheren
Frequenzen (16MHz) Probleme. Es ist wahrscheinlich schwierig, den Quarz
zum Schwingen zu bringen. Die erzeugbaren Pulse sind ja eigentlich viel
zu lang.
Danke für die schnelle Antwort!
Die Installation des Atmel Studio 7 ist bei mir noch unverändert so wie
ich sie von Atmel downloaden konnte, ich habe zuvor ein Update mit Hilfe
des integrierten Button durchführen lassen, weil ich gelesen hatte dass
eine ziemlich neu Version des avr-gcc benötigt wird.
Die Eigenschaften der Datei make.exe geben die Infos des Screenshots
her.
Die Version des avr-gcc habe ich noch nicht heraus bekommen. Vielleicht
hat da noch jemand einen Tipp für mich.
VG
Joachim
Folgende Infos habe ich noch mit der -v Option heraus bekommen:
Make:
GNU Make 4.1
Built for Windows32
Copyright (C) 1988-2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>;
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
avr-gcc:
gcc version 5.4.0 (AVR_8_bit_GNU_Toolchain_3.6.1_1750)
inzwischen habe ich die Ursache meiner Probleme mit dem Atmel Studio 7
gefunden. Vielleicht hilft es ja auch noch den ein oder anderen.
Da es mir bisher unter Windows noch nie gelungen war die Firmeware des
TT zu kompieren habe ich schon einiges probiert. U. a. habe ich auch den
WinAVR-20100110 und die Toolchain von SysGCC installiert.
Jetzt war mir aufgefallen, dass von den o. e. Installationen die Pfade
noch in den Umgebungsvariablen von Windows vorhanden waren. Nachdem ich
diese entfernt habe, funktioniert das Atmel Studio 7 problemlos, die
Kompilierung war auch effektiv genug und belegte 99,3% des
Flashspeichers beim ATmega 328.
VG
Joachim
von Angel G (Gast)
Karl-Heinz Kübbeler schrieb:
> Did you know the SamplingADC feature of Pieter-Tjerk..
Danke, no, I didn't know such feature exists, now thanks to you I know
and
I read him here: http://www.pa3fwm.nl/technotes/tn11b.html
I've found the absolutely cheapest USB AVR ISP based on STM32F103. It
itself is programmable via 3.3V serial port. For the people who want it,
here the link with the guide:
http://amitesh-singh.github.io/stm32/2017/05/21/FASTUSBasp-programmer-avr.html
Kleine schreibfehleren korrigieren:
(ComponentTester-1.32m, langDANISH.h-180325a.zip)
Beide .zip Dateien unterscheiden sich nur durch ein 'T' statt 't' in
Zeile 76 von langDANISH.h . Ist das richtig so? Oder sollte eine andere
Datei angehängt werden?
langDANISH.h-180325a.zip compared with the version from:
Beitrag "Re: Transistortester AVR"
Changes (diff):
76c76
< 'T','a','s','t','e','t','r','y','k','.',' ',
> 't','a','s','t','e','t','r','y','k','.',' ',
79c79
< 'S','e','l','v','t','e','s','t','e','n',' ','m','e','d',' ',
> 's','e','l','v','t','e','s','t','e','n',' ','m','e','d',' ',
82c82
< 'A','d','s','k','i','l',' ','f','ø','r','s','t','
','p','i','n','d','e','n','d','e',
> 'A','d','s','k','i','l',' ','f','ø','r','s','t',' ','p','i','n','d','e','n','e',
89c89
'"','A','d','s','i','l',LCD_CHAR_INSEP,'p','i','n','d','e','n','d','e','
> '"','A','d','s','i','l',LCD_CHAR_INSEP,'p','i','n','d','e','n','e','!',' "','
Aha! ;)
Klaus.
unzip langDANISH.h-180325a.zip
mv langDANISH.h langDANISHa.h
unzip langDANISH.h-180325.zip
diff langDANISH.h langDANISHa.h
76c76
Nicht anderes habe ich behauptet!
Ich habe die neuen langDANISH.h nicht mit der alten Version aus dem
SVN-Archiv verglichen!
These changes are still missing:
Small "s":
79c79
Delete a "d":
82c82
Delete a "d":
89c89
The reason for uploading "langDANISH.h-180325.zip" was to correct some
spelling mistakes.
Then I found another spelling mistake and tried to overwrite
"langDANISH.h-180325.zip" - that did not work. Then
"langDANISH.h-180325a.zip" was uploaded as the newest.
Now two "langDANISH.h-180325.zip" files was visible - and I could not
delete them from the post.
That was how it became messy.
von Apatewna (Gast)
Hello and thank you for your efforts on this project!
I built a custom breadboard version with an ATmega328p (5V, @16Mhz, SW
v1.32) and used a non supported color display (the back display of a
Nokia 6125, 98x70 pixels).
I know that this is a tiny display and maybe not in the interest of many
but I made it work so I'd like to share this knowledge with everyone.
After extensive search I discovered that this display is controlled by
ST7628 and has been used in the Nokia 1600 phone.
The closest supported display is the ST7735 which is pretty much the
same underneath except it is larger. So I went ahead and copied the
ST7735.c and ST7735.h to ST7628.c and ST7628.h respectively. I made all
the other necessary changes to add this display to the whole project.
The ST7628 uses 9-bit SPI (3-wire) and it was not hard to implement
granted that this project already uses 8-bit SPI bitbang for the
appropriate displays.
After all these changes, the display showed random RGB pixels and some
garbled text on one side (based on rotation and/or display flip).
I traced it down to LCD_AddressWindow in my ST7628.c file. It uses 16bit
addresses for row/column start/end but the ST7628 uses 8bit addresses.
My simple "fix" was to replace LCD_Data2(uint16_t Data) commands with
LCD_Data(uint8_t Data), effectively using the LSB of the 16-bit address.
After that, the display worked as expected.
I also replaced the LCD_Data2(uint16_t Data) with a simpler version:
 void LCD_Data2(uint16_t Data)
   LCD_Data(Data >> 8);
   LCD_Data(Data);
I am limited in time right now but I can upload my full list of
modifications to make this display work. Or just the bits and pieces the
developer needs to add this and possibly other 9-bit SPI displays into
the project.
Thank you for your time reading this.
von carrascoso (Gast)
Hallo Karl-Heinz.
Ich änderte und aktualisierte mein altes chinesisches Messgerät, das ich
nicht benutzt hatte, um es ein zweites Leben zu geben, wenn es möglich
war.
Änderte den ATmega168 durch einen 328, ersetzte D1 durch einen TL431,
setzte den Kondensator zwischen die Stifte 18-21 und die Anordnung eines
20MHz-Kristalls.
Ich habe Firmware K v1.13, "mega328_2X16_menu" mit 20MHz kompiliert.
Wenn ich irgendeine Komponente vermesse, erkennt sie keine und gibt
praktisch alle dieselben Ergebnisse, ohne sie zu unterscheiden.
Und das Ergebnis ist nutzlos, wie Sie auf den Fotos sehen können.
Mit den Widerständen erkennt sie weder und schaltet das Messgerät direkt
aus.
Die einzige Komponente, die gut erkennt, sind die Kondensatoren, aber es
gibt einen sehr hohen ESR.
Bei der Kalibrierung in dem Schritt, bei dem ein Kondensator von 4-30 nf
zwischen 1-3 platziert werden soll, muss der Kondensator, wenn er auf
unbestimmte Zeit gestoppt wird, entfernt werden, so dass er weiterläuft
und die Kalibrierung beendet.
Fügen Sie einige Fotos hinzu, und ich schätze Ihre Hilfe, um das Problem
zu lösen.
Vielen Dank
Hallo  carrascoso!
Mit dem Menü kann ein vollständiger Selbsttest aufgerufen werden.
Bei den Testfunktionen T1-T4, T5-T7 sollten alle Werte in der zweiten
Zeile klein sein. Die angegebenen Werte sind Abweichungen vom erwarteten
Wert in mV Einheiten.
Die beiden Kondensatoren (>100nF , 4-30nF) sind für die Kalibration
erforderlich. Bei fehlendem >100nF Kondensator gilt das Gerät als nicht
abgeglichen!
Wenn bei Tests von Bauteilen eine unerwartete Abschaltung erfolgt, liegt
das wahrscheinlich an der Spannungsüberwachung des ATmega (brown out
level).
Die Spannungsüberwachung kann mit den Fuses für Tests ausgeschaltet
werden.
Bei ausgeschalteter "brown out" Überwachung erwarte ich, daß keine
unerwartete Abschaltung erfolgt. Wenn die unerwarteten Abschaltungen
dann nicht mehr auftreten, sollte die 5V Spannungsversorgung überprüft
werden (geeigneter Spannungsregler, ausreichende Kapazität für die
Abblockung ...).
Bei Tests mit meiner Hardware sind mir beim 20MHz Betrieb keine
Besonderheiten aufgefallen. Gerne kannst Du mir aber Deine Makefile an
meine Email Adresse schicken (Titelseite der PDF-Dokumentation). Wenn
möglich, werde ich die Übersetzung (.hex, .eep) auf einer meiner
Platinen testen und Dir zur Kontrolle die übersetzten Files
zurückschicken.
von Joaquin S. (Firma: sanchez) (carrascoso)
Hallo Karl-Heinz
Das Problem, das alle Komponenten vermitteln musste, war auf diesen
Widerstand zurückzuführen, der nicht an Ort und Stelle geschweißt wurde.
Ich weiß nicht, ob es von zu Hause kam oder bewegt wurde, als der
ATmega168 vom Atmega 328 geändert wurde, aber das war das Problem.
Vielen Dank für Ihr Interesse und Ihr Angebot.
Grüße
...findest du die Lötstelken gut gelungen? Bist du mit deiner Leistung
so zufrieden?
Klaus.
Ja sehr zufrieden.
Ich wollte über F-Scaler fragen, und auch, was ich für dieses Gerät
benötigen würde, um Spannung zu messen, wie es im Menü erscheint.
Vielen Dank und sehr dankbar.
Grüße
Der F-Scaler kann einen Vorteiler für die Frequenzmessung
berücksichtigen. Es können nur 2-er Potenzen (1,2,4,8,..,512)
eingestellt werden. Wenn der F-Scaler richtig eingestellt ist, wird die
Eingangsfrequenz des Teilers angezeigt. Teiler mit Faktor 10 können
durch Verschiebung um eine Dezimalstelle leicht berücksichtigt werden,
bei 2-er Potenzen müßte man sonst die Anzeige mit dem Teiler-Faktor
multiplizieren.
Die Spannungsmessung ist in der PDF-Dokumentation als
"Zenerspannungsmessung" beschrieben. Verwendet wird ein 10:1
Spannungsteiler an PC3, der aber auch für die serielle Datenausgabe
benutzt werden könnte.
von Paul B. (Gast)
Noting the various versions of the transistor tester.
Just pointing out a common blunder in almost all circuits using these
LCDs.
The 10k potentiometer connected to pin 3 - "Vee" of the LCD - should
not connect to Vcc, either directly, or through another 10k resistor
as in some versions.
This is a mistake blindly carried over from the earliest "example"
circuits in the LCD datasheets.  With no connection to Vcc, the
potentiometer is used simply as a variable resistor and its value can be
reduced to 1k to give full-range control of the contrast voltage.
To understand why this is so, you need to know that on the LCD board
there is a 11k resistor ladder (five 2k2 resistors) from Vee to Vcc.
The contrast control simply adjusts the total voltage across the ladder,
generally to around 4.5 V.  The 3.3 V version of the LCD includes a
charge pump to develop this voltage and not to power the HD44780 chip
which works just fine on 3.3 V.
von Dominic K. (dominic_k)
Habe mal eine Frage...
Ich habe den meinen T4 Tester vor gut 2 Jahren mit Widerständen
ausgestattet und geflashed...
Er funktioniert auch, nach damals vielem hin und her wegen Dioden und
so...
Möchte diesen nun mal auf V1.12 updaten...
Oder bringt mir das Update nicht viel?
Welche Software muss ich hier nehmen?...
mega328_T3_T4_st7565 oder
mega328_T4_v2_st7565???
Wie ich das mit dem makefile gemacht hatte finde ich schon wieder im
Verlauf :)...
Lese hin und wieder auch von V1.13...
Diese gibt es aber anscheinend nicht für den T4 tester...
Dominic K. schrieb:
> Ich habe den meinen T4 Tester vor gut 2 Jahren...
Wuerdest du mich mal schlau machen was ein T4- Tester ist? Am Besten mit
Link.
Deine Fragen kann ich dir leider nicht beantworten, dafuer bin ich zu
lange raus.
Beitrag #5459831 wurde vom Autor gelöscht.
Ist dieser Tester, jedoch mit dem blauen Knopf...
Ein China Nachbau eben...
Aber er funktioniert :)... Nur eben noch mit V1.11k
https://www.amazon.de/LCR-Transistor-Capacitor-Resistor-Tester/dp/B00U6THU5I
von Suwan (Gast)
Dear  Karl-Heinz K.
On Riv796 I test on Jfet 2SK170BL ,Only G visible another display ? .
Suwan
Da müsste eigentlich die Konfiguration im mega328_T3_T4_st7565
Unterordner passen. Bei meinem Exemplar hatte ich übrigens die zwei
Dioden für die Spannungsversorgung des st7565 Displays durch einen
Spannungsregler (MCP1702-3302) ersetzt und anstelle des Tasters einen
Impulsdrehgeber mit Taster eingebaut. Natürlich kann die aktuelle
Entwicklerversion 1.13k benutzt werden (Software/trunk Pfad). Der
Impulsdrehgeber ist in der Makefile schon aktiviert. Der Tester kann mit
der gleichn Software aber auch ohne den Impulsdrehgeber benutzt werden.
There is no way for the tester to find out the correct drain and source
pin. Therefore the pins are only marked as two "?" characters.
Danke Dir :o)
Habe seinerzeit, also jetzt nun vor ca 2 Jahren denke ich die Pull-Up
Widerstände nachgerüstet. (Siehe Bild)
Eine Diode ist mir damals abgerissen (keine gescheite Lötspitze zur
Hand^^), darum schauts so aus.
Bin mir nicht mehr ganz sicher, welche Einstellunegn ich damals machen
musste, aber mir wurde sehr geholfen.
Der Tester läuft auch so, bisher auch bals 2 Jahre im StandBy mit einer
Batterie, denke habe damals alles richtig gemacht.
Nur mit den Einstellungen im Make File muss ich mich dann noch mal
auseindersetzen.
Werde dann mal versuchen V1.12 zu flashen.
V1.13 geht hier genau so, ohne große Probleme?
Und gibt es irgendwo eine Art ChangeLog in der auch die Änderungen zu
V1.13 vertreten sind?
Danke schonmal für die auch nach so langer Zeit immer noch echt raschen
Antworten und Hilfestellunegn :-).
Bei Version 1.13k sind mir keine besonderen Probleme bekannt.
Neben einigen kleinen Erweiterungen sind hauptsächlich kleinere
Fehler beseitigt.
Mit nachgerüsteten Pull-Up Widerständen kann die SPI-Schnittstelle im
Open-Collector Modus betrieben werden. Das hilft, die
Spannungsüberhöhung des st7565 Controllers zu vermeiden. Es scheint aber
auch ähnliche Controller zu geben, die 5V tolerante Eingänge besitzen.
Dann sind die Pull-Up Widerstände und die Option in der Makefile nicht
notwendig. Sonst muß in der Makefile die Option CFLAGS +=
-DLCD_SPI_OPEN_COL gesetzt sein. Das ist bei der Standard-Konfiguration
(mega328_T3_T4_st7565) nicht der Fall. Nach der Änderung der Makefile
muß die Software neu übersetzt werden (make).
Ein kurzes Protokoll der Änderungen gibt es in der Datei
Software/tags/changelog.txt. Die letzten Änderungen stehen immer oben,
bei einer abgeschlossenen Version steht die Versionsnummer mit Datum in
einer Zeile.
Die samplingADC Funktion von Pieter-Tjerk war auch schon bei der Version
1.12k integriert. Bei beiden Versionen wird bei der Kalibration ein
zusätzlicher Kondensator (10nF-30nF) benötigt, mit dem bei der Messung
später kleine Induktivitäten zum Schwingkreis ergänzt werden können. Aus
der Schwingfrequenz und der bekannten Parallel-Kapazität kann dann die
Induktivität vom Tester berechnet werden.
I
Danke für die wie immer schnelle und ausführliche Antwort
Daumen hoch ;-)
von Simone Chifari (Gast)
Hi Karl,
can you add support for ssd1327 display controller ?
https://www.amazon.it/gp/product/B079KRC9X3/ref=oh_aui_detailpage_o08_s01?ie=UTF8&psc=1
The ssd1327 controller can access only double columns with a write to
the GDDRAM. I will try to implement support for this controller, but
probably the driver must use the RAM of the ATmega (2Kbyte black/white)
for a correct image of the display content. Unfortunately the
TransistorTester-code is optimized for the st7565 controller, which can
access the rows in units of 8 rows and every column.
> to
Ok, tnks for your efforts.
Hello Simone,
at the time I have problems with the SPI interface of the ssd1327
display module. It seems, that the module disturb the data send by the
ATmega. I have adapted the 3.3V signal levels with 1k/2.2k resistor
dividers. But the correct serial data can be measured only without the
connected module. With the connected display module the serial data are
different. Probably the connection of DIN pin of the board to two pins
of the display module is the reason. Of course the two pins of the
display module must be connected to DIN for the I2C interface. Did you
test the ssd1327 display module with the SPI Interface?
...ohne den Thread kapern zu wollen - auch das sinnvolle Zubehör für den
KHK-TT ist sicherlich sehr interessant! Je selbstgebauter, desto
besser...
1) LiPo Batterie 7.4V im 9V Block Gehäuse
2) SMD Testplatine aus 3 Kuperinseln, welche federnd (!) gelagert sind
3) Testpinzette (ja, kann man auch kaufen)
Klaus.
You can test now the use of a ssd1327 display controller.
I have used the "1.5inch OLED Module" for testing. Please note, that the
module must be mounted 90 degree rotated (x and y interchanged).
I have used 1k / 2.2k resistors to get the correct voltage levels for
the SPI Interface. Unfortunately the "DIN" signal was destroyed by the
original module. I have cut the D2 (pin 18) connection of the display to
the DIN pin of the module to get a proper operation! Only the D1 (pin
17) signal of the display is still connected to the DIN pin of the
module. The operation with the I2C interface requires both pins (D1 and
D2) connected to the DIN pin of the module to enable the ACK signal
(original circuit of the module). But the default state of the interface
selection is 4-SPI.
The screenshots of my scope shows the correct (without_display) and the
destroyed initialize sequence of the ssd1327 display module.
> Hello Simone,
Sure, only tested with SPI interface on a arduino pro mini and it worked
correctly.
> correctly.
I am absolutely shure, that my two modules don't operate correctly in
the factory state (BS-0 for 4-SPI). With the original state the DIN pin
of the module was connected to signal D1 (pin 17) and signal D2 (pin 18)
of the display.
The signal D2 is used by the display for ACK output with the I2C
interface. You can see in the screen picture of my scope
(SPI-signals_with_display.png), that the 0-level of the DIN signal is
lower than the 1k serial resistor from the ATmega connection and the 10k
pull-up resistor (on board of the module) can reach. Only a output
signal from the ssd1327 controller can reach the shown little 0-levels.
With disconnected D2 signal the module operate normal.
Did you use any serial resistors between the SPI-signals of the module
and the ATmega? Probably the output of the ATmega is stronger than the
output of the ssd1327 controller.
> selection is 4-SPI.
Hi Karl,
which module are you testing ?
Mine can operate at 5 volts too.
von F. F. (foldi)
Simone, mach doch mal ein Bild von dem Modul.
Hier ist mein ssd1327 OLED Modul von der Rückseite. Das Modul hat
128x128 weiße Pixel (16 Graustufen).
Das Modul kann mit 5V versorgt werden, da ein Spannungsregler auf der
Platine ist. Das ssd1327 Datenblatt erlaubt aber keinen Signalpegel von
5V (lediglich 3.3V + 0.6V sind erlaubt).
von F. F. (foldi)
Deswegen soll Simone ein Foto machen. Vielleicht hat sie ja doch ein
etwas anderes Modul.
Simone hatte schon einen Link zum Anbieter gepostet. Da sind Fotos zu
sehen, die gleich aussehen:
Es kann natürlich sein, daß unterschiedliche Controller-Versionen
montiert sind. Das kann man aber nicht sehen, weil der Controller unter
dem OLED-Modul (an der flexiblen Leiterplatte) sitzt. Wenn die
ATmega-Ausgänge aber direkt mit dem Modul verbunden werden, kann es
sein, daß sich der stärkere Ausgang des ATmega durchgesetzt hat.
Ein Auszug aus dem Datenblatt als Nachtrag:
7.1.3 MCU Serial Interface (4-wire SPI)
The serial interface consists of serial clock SCLK, serial data SDIN,
D/C#, CS#. In SPI mode, D0 acts as SCLK, D1 acts as SDIN. For the unused
data pins, D2 should be left open. The pins from D3 to D7, E and R/W#
can be connected to an external ground.
Hier steht ausdrücklich, daß der Pin D2 frei gelassen werden soll für
die SPI-Schnittstelle!
Yes the module is exactly the same.
I've wired it by the white connector with no extra bridges directly to
an arduino pro mini 5V 16mhz and it worked.
The display on the right is there only for connections reference.
Can you add a 1k resistor in the line to the "DIN" input and test again
with the 4-SPI interface?
If the module works correctly with the 1k serial resistor, your module
is probably different from mine. But I am not shure, that the D2 output
of your display now works correctly after the direct connection of "DIN"
to the ATmega output. You can test the D2 output of your display, if you
use the I2C interface of your module. If you can use the I2C interface
too, the D2 output has no damage.
Please remember the hint for 4-SPI in the controller data sheet:
For the unused data pins, D2 should be left open. The pins from D3 to
D7, E and R/W# can be connected to an external ground.
But the Module has connected D1 and D2 together to the DIN pin
(independent to the selected type of interface)!
Well, actually with the 1k resistor it stop working in SW 4-SPI mode.
Not tested in I2C mode.
Additionally I have now checked the voltage of the internal regulator
output. If you connect only GND and VCC to a 5V power supply, you can
measure a output voltage of 3.3V . If you connect one of the module
inputs (DC or RST for example) with a 47 Ohm serial resistor to VCC, you
can detect a rising voltage at the regulator output (about 3.8V to
4.2V)! This voltage increase is caused by the internal protection diodes
at the ssd1327 inputs!
Of course the value of the voltage increase depends on the controller's
power consumption and the count of inputs switched to the 5V level.
von Gurke (Gast)
Hallo ihr da.
Ich habe ein chinesischen DIY ttester von 2016 mit Farbdisplay (GM328).
Die Firmware ist 1.12k. Von dieser gibt es ja mehrere Revisionen, meine
müsste rev.~681 sein. Ich benutze den ttester zu 99,9% um Elkos zu
messen. Jetzt hab gelesen bei rev.705 "ESR measurement with 470k",
welche Vorteile bringt dies?
Leider reicht die Auflösung des ADC bei weitem nicht aus, um eine
Auflösung von 0.01 Ohm für die Widerstandsmessung zu erreichen. Auch mit
der internen 1.1V Spannungsreferenz ist die Auflösung zu gering, wenn
nur 6.94mA Meßstrom (5V / 720 Ohm) verwendet wird. Bei einem Widerstand
von 0.01 Ohm ergibt sich bei diesem Meßstrom nur eine Spannung von nur
0.0694mV.
Durch Mittelwertbildung von vielen Einzelmessungen kann die
resultierende Auflösung verbessert werden, wenn das Signal sich leicht
ändert oder etwas verrauscht ist. Leider reicht das Rauschen beim ATmega
ADC oft nicht aus, um die Verbesserung der Auflösung zu erreichen. Mit
der Änderung soll ein kleiner zusätzlicher Strom vom 470k Widerstand für
die Hälfte der Einzelmessungen das Kippen einer ADC-Stufe begünstigen.
Schaden kann diese Maßnahme nach meiner Meinung nicht. Der Effekt ist
aber nicht sehr deutlich, weil der Strom sehr klein ist. Etwas
zugefügtes Rauschen wäre wesentlich günstiger für die Mittelwertbildung.
von Gurke (Gast)
Danke für die Info. Der ttester hat leider keine Schnittstelle zum
aufspielen einer neuen Fimware, also müsste ich den ATmega extern
programmieren... Ich bleib erstmal bei rev.681.
Interessant finde ich die ttester-Schaltung mit ATmega 644/1284. Evtl.
wird dies mein neues DIY-Projekt. Der ATmega 328 pfeift ja schon aus dem
letzten Loch, die Zukunft gehört so wohl dem 644/1284. xD
Vielen Dank kubi48 für deine tolle Arbeit.
von Diandra K. (diandra_k)
halo. Karl-Heinz K. (kubi48)
have a nice day...
how to add new mcu?with not in list on mcu option!,i'm use atmega128a,
can u help to add mega128a?if u not have much time...what header file
mus be edit...thanks
Diandra K. schrieb:
> i'm use atmega128a,
Please use a supported ATmega1284 instead of the ATmega128a.
With a ATmega128a you can not get the same ADC-performance, because it's
ADC is missing the internal 1.1V reference. Usually the reference of the
ADC is switched automatically to 1.1V for input values below 1V to
increase the resolution. The ATmega128a supports only a internal 2.56V
voltage reference!
von Mortimer N. (Firma: privat) (ranseyer)
-Möchte jemand den fish8840 Tester ohne Diplay kostenlos haben ?
Antworten bitte per Mail direkt an mich.
Hi Karl,
can a reference voltage of 4.096V be used ? How should i modify the code
how would it affect performance?
TYA
Currently the code is written with fixed constants for a 2.5V reference
in the file Calibrate_UR.c ! The optional voltage reference is
especially usefull, if the output of your voltage regulator does not
match the 5V with sufficient accuracy. If the VCC voltage match the 5V
better than 1%, the effect of a additional reference is very low. For
this condition you can omit the additional voltage reference. But a
Pull-Up resistor is still required for a defined voltage level. The
sense of the additional voltage reference is only to determine the
deviation of the VCC voltage from the expected 5V. You can measure the
level of the internal ADC voltage reference (1.1V) only with the VCC
reference. The internal ADC voltage reference is used with the analog
comparator to measure the time constant of a capacitor or inductor.
Of course all voltage measurements must also know the exact level of the
AVCC reference for best results.
I'm using a MCP1702 as voltage regulator.
With a REF3040 http://www.ti.com/product/REF3040 or a REF195E
http://www.analog.com/en/products/ref195.html can i get better ADC
accuracy by change the code ?
You can use a REF3025 or a REF192 without any code change. You should
keep in mind, that the accuracy is allways limited by the features of
the ATmega 10-Bit ADC. You can not get a better accuracy than the
ATmega-ADC allows.
> ATmega-ADC allows.
I already own some REF3040 so can i modify the code for those ?
You can try to modify the Calibrate_UR.c file at line 25-29:
  if ((mv2500 > (4096-250)) && (mv2500 < (4096+250))) {
     // precision voltage reference connected, update U_AVCC
     WithReference = 1;
     adc_vcc_reference = (unsigned long)((unsigned long)ADCconfig.U_AVCC
* 4090) / mv2500;
You can check the VCC voltage output at the start time.
Without changing the code, the 4.096V reference is not detected and no
VCC voltage is reported.
von Jacek Sobczak (Gast)
Ein geniales Projekt. Nur eine kurze Frage. Für den Chinesischen Bausatz
auf der Abbildung 2.23 in der Dokumentation gezeigt, soll ich die
Softwareversion mit "mega328_st7565_kit" getagt verwenden?
Jacek
Die Makefile und die Programmdateien sollten für diesen Bausatz passen.
Für den ähnlichen Bausatz mit dem Farbdisplay (Abb. 2.24) passen die
Dateien im Unterverzeichnis "mega328_color_kit". Für eine Neubeschaffung
würde ich die Version mit dem st7565 Kontroller bevorzugen, da weniger
Speicherplatz verbraucht wird und die Ausgabe schneller ist.
von Damian K. (damian_k)
Ehre
Ich kann die Version 1.33 Markus für den Tester mega328_T3_T4_st7565
nicht kompilieren.
Kannst du mir fertige Dateien geben (Hex und eep , 8MHz)
Danke
Leider habe ich keine passenden .hex und .eep Dateien.
Für die "m" Version von Markus muß neben der Makefile auch die Datei
config.h und config_328.h für die jeweilige Hardware und die gewünschten
Optionen angepasst werden. Die Datei README.de sollte einen Überblick
über die erforderlichen Arbeiten geben.
von ex.Nichteingeweihter (Gast)
Ich habe diese color-kit Version, weiße Schrift auf blauem Hintergrund
läßt sich gut ablesen und der Bausatz war auch noch sehr günstig.
Schutzrelais und JFET-Stufe (Frequenzmessung) nachgerüstet und die 1%
Widerstände durch 0.1% ersetzt, sowie die Referenz ausgemessen und
eingetragen. Den DIL durch einen Arduino nano (nur die Platine mit dem
µC, der µC wurde neu geflashed) ersetzt damit sich auch noch eine
Spannungsmessung und eine Seriellausgabe ausgeht, das ganze funktioniert
sehr gut, leider ist der Flash zu >99% voll, es geht sich keine weitere
Option wie Quarzmessung o.ä. mehr aus.
Läßt sich eventuell der Code für das Display noch optimieren wenn man
auf die Farben verzichtet?
Kapazitätsmessung im pF-Bereich ist mit dem LC-100 (PIC mit Komparator
und LC-Oszillator) teilweise stimmiger.
Können Sie diese Dateien für mich neu kompilieren? (Version 1.33 Markus)
von Horst O. (obelix2007)
Hallo an alle hier im Forum.
Vorab muß ich meine Bewunderung über diese großartige Leistung rund um
dieses Transistortester-Projekt ausdrücken.
Mein besonderer Dank an den Initiator Herrn Markus Frejek, den
Weiterentwickler Herrn Karl-Heinz Kübbeler und ebenso an Herrn
Pieter-Tjerk de Boer für die Software-Ergänzung zur Messung kleiner
Induktivitäten.
Danke auch all denen die hier unermüdlich und geduldig mit Rat und Tat
den Hilfesuchenden beistehen.
Seit längerem lese ich in diesem Forum und bin vor kurzem auf dieses
Thema hier gestoßen.
Ich habe mir dann den China-Clon T3 angeschafft und ihn oft und zur
Zufriedenheit eingesetzt und dann zum Vergleich noch einen GM328A von
GeekTeches (war sehr preiswert) gekauft.
Den hat dummerweise die Restladung eines Elkos zerstört, so das ich mich
mit der Programmierung eines Ersatzcontrollers beschäftigt habe:
Der GM238A ist ein Gerät mit Drehgeber und Grafik-Display. Nach
Recherchen hier fand ich die 1.13er Version aus dem Verzeichnis
../mega328_color_kit welche ich erfolgreich nutzten konnte.
Der nun vorhandene Drehgeber macht die Bedienung des Menüs wirklich
komfortabler. Bis auf die Frequenzmessung funktionierte nun alles. Im
Netz wurde der gleiche Tester nochmals billiger angeboten und ich
orderte gleich zwei weitere!
Als auch diese (vom selben Hersteller und baugleich) keine
Frequenzmessung konnten habe ich das Gerät mal genauer geprüft.
Es zeigte sich, das der hierzu verwendete Portpin zwar an eine
Leiterbahn angeschlossen war, diese aber kurz vor dem Verbindungspunkt
zu der Eingangsbeschaltung der Frequenzmessung in einer
Durchkontaktierung endete.
Eine kleine Lötverbindung mit Fädeldraht - jetzt zählt er auch noch!
Im Anhang Fotos von der Reparatur-Stelle.
Weiterhin viel Freude mit all den tollen Projekten hier und freundliche
Grüße Horst
von Florian Dollinger (Gast)
Grüß euch!
Danke für die Weiterentwicklung dieses kleinen feinen Gadgets!
Ich hab mit einen TC-1 zukommen lassen, da dieser einen zweiten uC für
die Aktivierung eines StepUp und die Button-Abfrage hat, habe ich dafür
eine alternative FW zusammengehackt: https://github.com/atar-axis/tc1-u4
Das ganze funktioniert Super mit Martins Version der FW, jetzt würde ich
aber auch mal gerne deine probieren @Karl-Heinz.
Das Teil hat einen ATmega324PA, ein Z180SN009 Farb-Display, einen TL431
als Spannungsreferenz, eine 35V Spannung für Zenerdioden, einen
einzelnen Knopf (kein Encoder), 16MHz externer Quarz.
Es scheint als gäbe es da noch keine fertigen Makefiles, oder übersehe
ich das nur? :) Wenn nicht würde ich mich darüber mal hermachen später
und mich ggf melden wenn was nicht klappt.
Grüße, Flo
von Teodoro I. (Firma: Creando Nuevas Soluciones) (netandino)
Hi, I have this tester GM328_3V_V1_20 which damaged the chip, we have
put a new chip but when recording the firmware Atmega_3.3V does not
work, I have the doubt of the fuses please someone can give me or if you
have the firmware functional?
regards
von Benny (Gast)
Hi zusammen,
mal kurz zur Geschichte:
Ich hatte in 2016, drei T-Tester gebaut.
Eines mit einem Dogm Display (ST 7565), eines mit einem 16x2
Display(HD44780,
und eines mit einem ST7920 Display.
Die Tester mit dem ST7565 und dem HD44780 Display funktionieren ohne
Probleme und die hatte ich bis dato auch immer genutzt.
Den Tester mit dem ST7920 Display hatte ich zusammengebaut, kalibriert,
und dann an die Seite gelegt.
Nun wollte ich den Tester mit dem ST7920 LCD gestern benutzen.
Habe dann einen 4700μF zum Testen angehängt und angezeigt wurden mir
etwas mehr als 1,2mF.
Also ca. das 3-fache. Nanu, was ist das?
Dann habe ich mehrere Kondis angehängt, und es ist so, dass bis 100μF
die Werte korrekt angezeigt werden. Aber alles was darüber ist, wird
immer mit dem ca. 3-fachen Wert angezeigt.
Ich habe bereits die Schaltung überprüft und konnte keine Fehler finden.
Alle anderen Messungen, also Transistoren, Spulen und Widerstände
funktionieren gut, und die Werte werden relativ genau angezeigt.
Relativ, wegen den Toleranzen etc..
Ursprünglich hatte ich die Version 1.12 Rev.669 installiert, und habe
dann probeweise mal die Version 1.12 Rev. 711 installiert, aber
komischerweise liegt der gleiche Fehler vor.
Was ja eigentlich auf die Hardware schließen lassen sollte, aber wie
gesagt, ich habe alles kontrolliert, und alle anderen Messungen
funktionieren gut, inkl. Kondis bis 100μF.
Wenn an der Schaltung was verkehrt wäre, dann würden die anderen
Messungen ja auch nicht funktionieren.
Ursprünglich hatte ich einen 16MHz Quarz drin und habe es dann auch mal
mit einem 8MHz externen Quarz probiert, aber auch damit wieder haargenau
derselbe Fehler.
Die Fuses wurden jeweils entsprechend gesetzt und jedes mal neu
kalibriert.
Ich weiß momentan nicht mehr weiter.
Habt ihr vielleicht noch eine Idee, woran das liegen könnte, dass die
Kondensatoren über 100μF nicht korrekt angezeigt werden?
Das ist in der Tat merkwürdig. Es wird also nur etwa 1/3 der Kapazität
angezeigt. Das würde bedeuten, daß die Ladespannung sich deutlich
schneller erhöht, als bei der Kapazität zu erwarten wäre. Bei dem ersten
Test wird immer ein 680 Ohm Widerstand zum Laden benutzt. Wenn die
Spannung sich zu schnell erhöht, wird für die Messung ein 470k
Widerstand benutzt (ungefähr unter 100uF). Die mit dem 470k Widerstand
gemessenen Kapazitäten sind OK, offensichtlich nur die mit dem 680 Ohm
gemessenen Kapazitäten nicht.
Als Fehlerquelle ausschließen kann man die gemessene VCC
Betriebsspannung,
da diese auch die Ergebnisse mit 470k Widerstand beeinflussen würde.
Ich gehe auch davon aus, daß der ISP-Programmer nicht mehr angeschlossen
ist. Der könnte auch die Messung natürlich auch beeinflussen.
Interessant sind noch die Ergebnisse der Sonderfunktion (über Menü)
"C+ESR@TP1:3". Hier werden auch kleinere Kapazitätswerte mit einem 680
Ohm Widerstand gemessen. Die Kapazitätsmessung ist hier aber generell
etwas ungenauer, weil hier besonders kleine Ladespannungen benutzt
werden.
Bei der normalen Messung wäre noch interessant, ob die Messung an
verschiedenen Port-Kombinationen immer gleich falsch ist.
von Benny (Gast)
Hallo Karl-Heinz,
erstmal danke dafür, dass du dir das Problem angenommen hast.
Die Bestriebsspannung ist auf jeden Fall Ok. Das hatte ich alles bereits
kontrolliert.
Der ISP-Programmer ist bei den Messungen grundsätzlich immer abgesteckt.
Bei den normalen Messungen ist das Ergebnis bei allen Pin-Kombinationen
gleich.
Was jetzt für mich etwas überraschend war, ist die von dir aufgeführten
Sonderfunktion "C+ESR@TP1:3".
Ich muss sagen, darauf war ich nicht gekommen, diese Menüfunktion
aufzurufen.
Die Macht der Gewohnheit :-) .
Habe ich eben noch getestet und bei der Messung per Menüaufruf
"C+ESR@TP1:3", werden auch die Kondensatoren über 100μF korrekt
angezeigt.
Jetzt ist es aber immer noch so, dass bei der Messung der z.B. 4700μF
Kondis, manchmal zuerst kurz der 3-fache Wert angezeigt wird, und ca.
2-3 Sekunden danach der korrekte Wert.
Ob die Eingangswiderstände einen weg haben?
Kann gerade nicht auf das Gerät zugreifen, aber ich werde dann nachher
mal die 680Ohm Widerstände einseitig auslöten und nachmessen.
Die Klaibrierung per Kondensator an Pin1 und Pin3 mit einem 10μF
Kondensator, funktioniert übrigens auch problemlos.
Vielen herzlichen Dank für deine hilfe. Ich werde nachher mal die
Widerstände durchchecken.
von Benny (Gast)
Nachtrag:
Ich hatte heute Morgen probehalber auch mal einen anderen Mega328-PU
dafür genommen.
Es war weiterhin das gleiche Ergebnis.
Benny
von Benny (Gast)
Ach Mensch, ich sehe gerade. dass ich mich vertippt hatte.
1,2mF bzw. 1200μF werden bei 470μF Kondensatoren angezeigt.
Bei den 4700μF Kondis werden mir 12mF, also 12000μF angezeigt.
Nicht ein drittel, sondern das dreifache des eigentlichen Wertes.
Es wird also viel zu viel angezeigt.
von Benny (Gast)
An den Eingangswiderständen liegt es nicht. Die sind alle Ok.
Nun ja, wenn ich dafür etwas mehr Zeit habe, muss ich mal schauen woran
das liegen kann.
Ist mir momentan noch unerklärlich.
Aber irgend etwas, muss es ja sein.
Benny
von Kim (Gast)
Hallo Karl Heinz,
please tell me know about what i can do with Makefile because i only add
files hex and epp to atmega328p,how can add Makefile ? I use programmer
Progisp. Thanks
Beitrag #5610202 wurde von einem Moderator gelöscht.
Kim, do you need "professional help"?
Klaus.
von Kim (Gast)
> Klaus.
Hallo Klaus, i just dont understand about Makefile because in folder
there are 3 files so i transferred only 2 of files : hex and eep to
at328p, it works but not full, the encoder work like a switch on off! so
maybe i got error right?
von G. H. (schufti)
you don't need the Makefile.
If something is not working, you chose the wrong fw or your hw needs
different options => try different or compile your own.
Klaus was suggesting you need "professional help" from people in white
cloaks, as your demanding behaviour (repeating question after few hours)
is quite unacceptable
von Kim (Gast)
Oh so sorry, i didn't understand the menu box in Deutsch lang.
Anyway thanks for sharing this project.
Best regards.
Kim
von G. H. (schufti)
@Kim: KHK knows most of the devices and it would be helpfull to him (and
others) if you have some more detail about your device:
vendor/model/picture.
I am sure somehow he can identify it and this will lead to best fitting
firmware suggestion ...
The Makefile in the same directory as the .hex and .eep files is right
configured to give instructions for the AVR developement system (i.e.
the avr-gcc compiler and linker) to build the .hex and .eep files from
source.
The source files are written in C language and some also in assembler
language. All source files are in the upper directory, which is common
for all kinds of hardware. The Makefiles for the different known
hardware types are in different subdirectories (mega168, mega328,
mega328_st7565_kit ...).
If you can not find the correct configuration of the Makefile for your
hardware, you can create a new subdirectory and copy a best matching
Makefile from a other subdirectory in this new subdirectory. You must
then edit the options in the Makefile with any source editor for your
needs. The options are documented in the Makefile (english) and in the
PDF-documentation. Please note, that not every configuration support the
rotary switch!
You can build new .hex and .eep files with a simple "make" command.
Of course the source files and the correct developement environment must
be installed at the local computer first.
For a Linux system you can find additional hints about the required
packages in the PDF-documentation.
Best regards,
Karl-Heinz
von Kim (Gast)
Hallo Karl-Heinz,
I'm very clear now, thank you so much.
Have a nice day
Kim
: Bearbeitet durch Moderator
von kardo (Gast)
Hello, thank you markus for this amazing project. can anybody send me
the latest version schematics and software to my email please?
softwarekardo@gmail.com
i'm not German so i cant read the forum. thank you
kardo schrieb:
> can anybody send me
You can find the latest software and also the PDF-documentation here:
Please follow the Download instructions.
You can find two different branches for the software at Software/Markus
and
Software/trunk directories. The "Markus" directory hold all releases of
this branch (m-version). The older releases of the k-version you can
find in the Software/tags directory. The actual documenation (PDF) you
can find in the Doku/trunk/pdftex/english directory.
von Christian S. (chris02)
ich wollte meinen Transistortester (Version von Moritz A.
Sammelbestellung - Beitrag "Sammelbestellung Transistortester") mal auf
den aktuellen Stand bringen.
Gerne würde ich die Version von Markus mal drauf machen. Allerdings sehe
ich aktuell das Problem des LCDs.
Verbaut wurde das DOGM welches bei Reichelt vertrieben wird
(https://www.reichelt.de/lcd-textmodul-48-3-x-12-mm-gelb-gruen-ea-dogm162l-a-p55130.html?&trstct=pos_1).
Laut Datenblatt ist ein ST7036 Controller verbaut. Laut Makefile wird
dieses aber von Markus' Version nicht unterstützt?
Sehe ich das korrekt?
Viele Grüße
Chris
von madires (Gast)
Yep, die m-firmware hat noch keinen Treiber für ST7036. Sollte jemand
ein Testexemplar bereitstellen, würde ich einen Treiber schreiben.
Testexemplar heißt wahrscheinlich, dass du Hardware brauchst?
Ansonsten kann ich auch gerne Firmwaretester spielen.
Meld dich doch einfach Mal per PN bei mir
von khalid (Gast)
Dear Karl-Heinz
first thanks for your great work it is really good piece of cake with
such wast option of measurement and making a good tool for work bench.
as in my country no serial or SPI graphic LCD available could it
possible for you to create a make file for 2x16 character LCD with
English language for attach T Tester hardware as they are easy to find
every where and i personly like standard LCD look forward for you kind
help.
further in the link mega328 is this software for standard LCD did it
work for attach T tester hardware
https://github.com/svn2github/transistortester/tree/master/Software/trunk/mega328
once again thanks for your effort and time to make this project alive
regards
khalid
von khalid (Gast)
Dear Friend
can some one guide me how to compile code using WinAVR- step by step i
would be great full i am using windows 10
regards
khalid
von Miro K. (mirokel)
erst mal ein riesiges Lob an Euch für dieses Projekt und Eure Beiträge!
Ich habe mir vor einiger Zeit einen China Tester zugelegt und war von
dem Teil sofort begeistert.
Nun ist mir das passiert was vielen passiert.
Ich habe vergessen nen Elko zu entladen.
Idee ... reparierste mal selbst!
Zwischenzeitlich habe ich nen Mega328P mit Bootloader bestellt und
mittels Arduino UNO auch eine HEX und eep datei auf den Controller
geladen.
Die Auswahl der Software war leider eher ein Ratespiel.
Ich habe dennoch folgendes Ergebnis.
Die Anzeige zeigt: "Bat. 9.2V OK" "Testing....."
Irgendwie misst das Gerät aber nicht.
Meine Vermutung ist das die Fuses gesetzt werden müssen.
Könnt Ihr mir sagen wie die Fuses zu setzen sind und welche Software die
100% richtige für meinen Chinesen ist?
Es ist die Variante mit Drucktaster.
16x2 Lcd ist doch Müll. Kauf die für <<10€ den LCR T4 in der Bucht.
Wirklich, du benutzt doch auch kein 3210 mehr...
Klaus.
> Klaus.
Mir geht es nicht darum ein neues Gerät zu kaufen.
Und erst recht nicht um den Preis.
Arduino Uno + Controler lagen über 10€!
Ein T4 ist sowieso unterwegs.
Es ist aber ein schönes Bastel Projekt für mich.
Hinzu kommt das man was dabei lernt und ein Verständniss für die
Funktion bekommt.
Mein 3210 ist, als Spielzeug, in Benutzung von meinen Kindern.
Miro
OK, da lässt sich natürlich nichts gegen sagen ;) ...da die Software
doch ÄUSSERST gut dokumentiert ist wird man da schnell rausfinden, wie
diese für ein 16x2 zu konfigurieren ist und wie man die Fuses einstellen
muss. Ich habe die mal für meinen T4 (wg aktueller Features) compiliert,
das ging alles ratz fatz und es bedurfte nur ein wenig Beschäftigung mit
Artikel & Doku.
Klaus.
Die Fuses müssen auf jeden Fall gesetzt sein wegen dem Teiler für die
Taktfrequenz. Für den ATmega328p mit Quarzbetrieb wird Lfuse=0xf7,
Hfuse=0xd9 und Efuse=0xfc (0x04) empfohlen.
Bei dem Bild ist allerdings der Kalibriervorgang zu sehen. Hier sollten
die Kurzschluß-Brücken zwischen T1,T2,T3 entfernt werden, damit es
weitergeht.
> weitergeht.
Dein Einwand mag richtig sein.
So weit bin ich aber leider noch nicht. Ich habe mir einfach ein
passendes bild bei Google gesucht!
Wenn ich Dich und die Software avrdude richtig verstanden habe, wird mit
den Fuses folgendes eingestellt:
LFuse = Einstellung für die Taktung des Controllers Extern/Intern + Takt
HFuse = größe des Bootloaders bzw. startpunkt des Speicher wo das
Programm beginnt
ExtFuse = ???
Ist das so korrekt bzw. was macht die ExtFuse?
Die Efuse stellt den "Brown-Out" Pegel ein, bestimmt also wann der
Prozessor wegen Unterspannung zurückgesetzt wird (oder Interrupt).
Die genaue Belegung der Fuses findet man in den Datenblättern. Man kann
auch ohne Garantie für die Richtigkeit die Internet Seite
www.engbedded.com/fusecalc benutzen.
von Leon L. (indman)
Karl-Heinz, thank you that you added support of HilandM644 of a clone
I have one question to you on measurement of ESR on ATMega644 -
at measurement of film or ceramic capacitors the indication of ESR is
incorrectly displayed. It accepts the zero, or very underestimated value
in comparison with measurement of the same capacity on the device from
ATMega328. For what reason does it occur?
The reason is probably the fast voltage change during the measurement of
capacitors with low capacity. You can position the sample time of the
ADC only to a increment of one clock period of the ATmega (125ns at 8MHz
clock). The ESR measurement can only be done with the 680 Ohm resistor,
which result to a total resistance of about 720 Ohm. With a 100nF
capacitor you get a time constant of 72µs. The voltage change for a
125ns step (for the ADC sample time) is 8.67mV.
You should know, that a 1 Ohm ESR results to only 6.9mV voltage change!
So I think, that the timing of the ADC mesurement is well, if a
additional serial resistor of about 1 Ohm can be measured nearly
correct.
Probably a difference in the ADC input circuit of the ATmega328 and the
ATmega644 can result in different measurement results. The ADC input has
a RC lowpass filter, which is probably different for different series of
the ATmega.
For capacitors with higher capacity the voltage change is slower and the
measurement is less critical.
Karl-Heinz,many thanks for the detailed answer, but there is one more
riddle - and how to explain that on earlier revision of a firmware
(1.12k) for ATMega644 where the measuring impulse for ESR was lasting 8
microsec, results of measurements for the same type of the condenser
differ from version 1.13k?
With final 1.12k the current pulse length for measuring the ESR was
reduced from 8µs to 2µs. Probably earlier developement versions of 1.12k
operate with 8µs pulses. The current pulse length is important for the
lower limit of testable capacitors. The test procedure requires a linear
voltage change during the pulse length. With the RC circuit you get
always a exponential (e) form of the voltage change. Only for a small
voltage change the e function can be approximated with a linear
function. For small capacities the GetESR.S function tries to correct
the difference between "e" and "linear" with a empirical correction
formula.
You should not expect high precision results for the ESR measurement,
especially for small capacities. But usually the ESR difference between
a film capacitor and a ceramic capacitor can be detected.
von Albert S. (rondo)
Hallo an alle.
Kurze Frage:
Die Singel- Board Version mit Display für kompletten Neuaufbau finde ich
gut.
Jetzt zur Frage wie sieht es aus, das Ganze für Arduino`s (Nano, Uno,
Mega2560 und Co) in Form von Steck-Boards mit I2C Display Connector
auszulegen, für jene die so ein Board in der Ecke ligen haben.
von Michael B. (laberkopp)
> auszulegen,
Niemand hindert dich daran, so etwas zu machen, alles ist dokumentiert,
just do it.
Achso, du willst daß andere die Arbeit für dich machen. Vergiss es, du
bist hier kein Chef.
>Michael B. (laberkopp)<
just do it.
bist hier kein Chef.<
Die ersten schritte kamen von Markus Frejek die jetzige Versino von
Karl-Heinz Kübbeler in zusammenarbeit mit den Personen hier im Thread
und externen Quellen.
Ich kann mich zwar wie die CN verhalten und dreist Kopieren oder
Nachfragen in welche Richtung hier schon gedacht wurde oder wie du so
schön schreibst "just do it".
Wenn die Urheber aber ein Problem hier Sehen und dieses verworfen haben,
muss man das Rad nicht neu erfinden.
Danke für deine Antwort.
von Martin (Gast)
> Die ersten schritte kamen von Markus Frejek ...
Das stellt die Leistung von Markus nicht korrekt da. Er hatte nicht nur
die sehr originelle Idee zum Tester, sondern hat ein vollständiges
Projekt entworfen und gebaut.
von Soul E. (Gast)
Die Originalschaltung erschien 2005 in der Elektor. Damals noch mit PIC.
Markus Frejek hat das Ganze dann auf einem AVR nachempfunden.
Den Originalartikel findet Google
hier:http://www.elektron.si/forum/files/download_190.pdf
@ Martin (Gast) und @ soul e. (souleye)
Ihr habt recht. Es sollte auch nur eine SEHR grobe Historie zeigen.
15.03.2009 20:08 Erster Eintrag im Thread von Markus Frejek
18.08.2012 letzter eintrag im Thread
08.02.2012 21:17 Erster Eintrag im Thread von Karl-Heinz Kübbeler.
Letzter eintrag offen.
Und wer den Beitrag vom 07.02.2012 20:27 von Karl-Heinz Kübbeler sieht
>Das mit den Softwareversionen tut mir leid. Ich hatte begonnen, meine Ideen
umzusetzen, ohne mich vorher abzusprechen.....<
Da dieses Project noch nicht abgeschlossen ist und man eine Idee hier
für hat, sollte man sich absprechen.
Danke
von zikileo (Gast)
Привет всем. А кто мне подскажет как работать с прошивками от Маркус для
LCD SIEMENS_C75_LPH9157-2 ?
von Asko B. (dg2brs)
Albert S. schrieb:
> Hallo an alle.
> Kurze Frage:
> gut.
da ja Karl-Heinz schon einmal schrieb, das der ATMEGA328 so langsam
zu klein wird, um das universelle "Schweizer Taschenmesser"
darzustellen,
orientiert er sich wohl eher Richtung ATMega 664 oder größer.
Wir können nur auf seine erfolgreichenden Tests und Vorschläge hoffen.
(ich jedenfalls, der nicht programmieren kann)
Gruss Asko
Da meine Frau schwer erkrankt ist und meiner Hilfe bedarf, habe ich
derzeit keine Zeit und Nerven das Projekt weiterzuführen.
Erste Clones aus China mit einem Atmega644 sind aber schon erhältlich.
Neben meiner Softwareversion gibt es noch die "m" Version von Markus R.
Die Software von Markus R. muß aber in Konfigurations-Dateien an die
Hardware angepasst werden, nicht wie meine "k" Version in der Makefile.
Mit dem ursprünglichen Entwickler der ersten Versionen Markus Frejek
habe ich leider keinen Kontakt aufnehmen können.
von Hardy F. (hardyf)
zikileo schrieb:
> Привет всем.
A tu videw wto lydi sdes po nemezki piwyt ?
Na verno angliski moshno
Davai vosmi google translator
von zikileo (Gast)
Hi everyone. And who will tell me how to work with firmware from Marcus
for LCD SIEMENS_C75_LPH9157-2 ?
How about "please can anyone tell me.... "  ?!?
Ya cnay tam gde tui wivew y ljydi ect' kultura. Snayt powaluista i
spasibo. Po4emy ne tui ?
von Peter (Gast)
von Peter (Gast)
von Klaus R. (klaus2)
Hallo KHK,
vielen Dank für deinen immerwährenden Einsatz in diesem (deinem) tollen
Projekt - alles Gute & beste Genesung für deine Frau!
Klaus.
Peter schrieb:
> oder ist aktuell ein anderes Modell empfehlenswert?
Bei Aliexpress "Transistor tester M644" suchen, dann findet man die
letzte Entwicklungsstufe mit ATmega644. Man kann statt M44 auch nach Kit
suchen, dann findet man einen Bausatz. Bei dem Kit würde ich nicht die
color Version (Farbdisplay) empfehlen, sondern das normale SW-Display.
Danke für diese Informationen in bezug zur MCU.
@ Karl-Heinz K. (kubi48)
Gute Besserung an ihre Frau und viel Kraft für Sie.
Danke für diese ausgezeichnete Vorarbeit.
Best regards
von zikileo (Gast)
you're not helping me and I'm helping you ?
von zikileo (Gast)
cultural people always respond to you regardless of age! you're MINE.
von zikileo (Gast)
I'm here for help and you're putting me in conflict. If you don't know
how to help me, it's not my fault.
Хорошо. Достаточно. Конец нашей беседы
Please note, that Markus R. (madires) is more active at this thread:
http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/5425/
von zikileo (Gast)
Большое вам спасибо.
von zikileo (Gast)
Thank you very much
von zikileo (Gast)
> Thank you very much
Vielen Dank
von Peter (Gast)
Hallo Karl-Heinz,
Vielen Dank! Auch wenn er ein "vielfaches" Kostet werde ich ihn mal
bestellen.
Was ich sehr schade finde: Ich habe keine Gehäuse gefunden, weder zum
kaufen noch auf Thingiverse
--> Hat hier aus dem Forum schon jemand ein Gehäuse entworfen?
Gute Besserung an deine Frau!
von Frank W. (frank_w)
da es für meine Version des Transistortesters (damalige Sammelbestellung
von Moritz) keine aktuelle Firmwareversion gibt, wollte ich mir eine
Variante aus China bestellen.
Diese soll dann auch mit der Firmware von Markus kompatibel sein.
Der Tester soll ein fertiges Gehäuse haben, weswegen mir LCR-TC1,
LCR-T6, LCR-T7 bei meiner Suche aufgefallen sind.
Von dem TC1 wird aufgrund des ATMega324 abgraten (wobei ein Austausch
gegen einen 328 vom Aufwand her kein Problem wäre).
Zu welchem ratet ihr mir?
Danke & Gruß
Chris
von Alexander S. (alex_1975)
Guten Tag!
Ich hätte eine Frage zum fish884 Tester. Würde gerne die Aktuelle
Software nutzen, jedoch bleibt nach dem flashen das Display dunkel.
Anscheinend hat mein Fish-Tester ein gänzlich anderes Display. Habe mal
zwei Bilder angehängt - evtl. kennt jemand dieses LCD und kann mir beim
Makefile helfen.
Vielen Dank!
Ein tolles Projekt übrigens!
Alex
von Peter King (Gast)
ich blicke da leider noch nicht ganz durch, was den AVR Transistortester
anbelangt.
Ich würde gerne diese Schaltung fertig kaufen, da ich im Löten von SMD
Bauteilen und speziell dem ATMega in seinem Gehäuse mit den vielen Pins
noch nicht so geübt bin.
Gibt es dieses Projekt auch fertig aus Deutscher Produktion zu kaufen
oder nur die Nachbauten aus China?
Wenn ich einen China Nachbau nehmen müsste, welchen genau müsste ich
nehmen, um die jeweils neuesten Firmwares in der Zukunft flaschen zu
können?
Wäre dieser hier von Aliexpress der richtige?
Link:
<https://www.aliexpress.com/item/M644-Multifunctional-Transistor-Tester-LCR-Resistance-Inductance-Diode-Capacitance-ESR-Frequency-Meter-PWM-Signal-Generator/32912063006.html?spm=2114.search0104.3.1.17c475cfMvkWTv&ws_ab_test=searchweb0_0,searchweb201602_4_10320_10065_10068_10547_319_317_10548_10696_10084_453_454_10083_10618_10304_10307_10820_10821_537_10302_536_10902_10843_10059_10884_10887_10319_321_322_10103,searchweb201603_6,ppcSwitch_0&algo_expid=2a72b2a0-bab8-4850-9844-042aa65c6560-0&algo_pvid=2a72b2a0-bab8-4850-9844-042aa65c6560&transAbTest=ae803_5>;
Danke für Eure Hilfe.
Peter
von madires (Gast)
k und m-firmware unterstützen den ATmega324 und auch 644. Das Problem
mit dem TC1 und dessen Varianten ist die zusätzliche MCU zur Steuerung.
Die MCU muss entweder neu programmiert oder durch eine kleine Schaltung
ersetzt werden, damit der Tester kompatibel wird. Die Schaltung findest
Du im Repo und die Firmwmare für die Steuerungs-MCU unter
https://github.com/atar-axis/tc1-u4.
von madires (Gast)
Yep, Hiland M644 oder ein AY-AT sind brauchbar.
von Artur Kawa (Gast)
Kennt Jemand diese Tester?
LCR-TC1 3.5inch Colorful Display Multifunctional TFT Backlight
Transistor Tester
<https://www.aliexpress.com/item/LCR-TC1-3-5inch-Colorful-Display-Multifunctional-TFT-Backlight-Transistor-Tester/32845051864.html?spm=a2g0s.8937460.0.0.49c12e0ek3xpBC>;
BSIDE ESR02 pro Multi-purpose Transistor Tester Diode Triode Capacitance
Resistor Meter MOS/PNP/NPN SMD Tester
<https://www.aliexpress.com/item/ESR-METER-TRANSISTOR-TESTER-DIODE-TESTER-CAPACITANCE-METER-MG328-VERSION-2017/32766775086.html?spm=a2g0s.8937460.0.0.49c12e0ek3xpBC>;
Was ist von Beiden zu halten?
...oh, sexy - hat da beim LCR-TC1 jmd IRMP eingebaut? DAS wäre natürlich
noch ein Argument mal vom LCR-T4 upzugraden und den "unverschämt hohen"
Mehrpreis wert :)
Wo findet man eine neuere Version für zB LCR-T4 oder ist 1.12k die
letzte (2017)?
EDIT: OK, es gibt neuere...nur der Artikel wurde nicht aktualisiert. Ist
jedoch nicht ganz einfach herauszufinden, was die neuen "Features" sind
- wenn einen nur das interessiert
"Lesbar":
https://www.mikrocontroller.net/svnbrowser/transistortester/Doku/trunk/pdftex/german/10-features.tex?view=log
Klaus.
von madires (Gast)
Nö; die modifizierte Firmware kann nur zwei Protokolle. Die m-firmware
unterstützt dagegen ca. 15. ;)
...ok, ich schaue ob "m" auf dem LCR T4 läuft - Danke!
Klaus.
Ich verstehe nur Bahnhof.
Gibt es da eine Quelle, wo man den aktuellen Stand des Projekts und
dessen Fähigkeiten erfahren kann? Ebenso WIE man die Updates durchführt?
...siehe meinen Link - aber ich finde das auch nicht direkt
übersichtlich. z.B. weiß ich nicht, ob die m328 Version ein Quarz messen
kann. Und das mit den IR Codes muss man auch erstmal wissen. Da wäre ein
"Features vs. Version vs. Hardware" Übersicht schön.
Nun - flashen: Die meisten aktuellen Versionen sind ja als .hex
vorkompiliert, das sollte mit diversen Anleitungen von Google dann nicht
emhr das Problem sein (aber hier auch nicht der Fokus).
Klaus.
Macht der Entwickler keine Angaben, zu dem was er da tut?
In den 90ern habe ich auch mal Freeware programmiert und der
Allgemeinheit angeboten. Aber da gab es auch eine Doku und Informationen
zum Projekt.
Ich habe mich auf der Seite hier bei Mikrocontroller informiert in der
Sektion "AVR Transistortester". Das war wohl das Ursprungsprojekt. Dann
wurde es wohl in verschiedene Richtungen entwickelt und letztlich haben
die Chinesen tausende modifizierte Kopien und Varianten davon übernommen
und selbst zum Teil halblebige Produkte draus gemacht.
Perfekter könnte das Chaos nicht sein...
...ruuuuhig, Artur - klickst du dich mal durch das svn und du findest,
was du suchst - habe ich ja auch. Aber das sind SO VIELE Infos &
Neuerungen, dass ich gar nicht weiß was ich zuerst versuchen möchte :)
Klaus.
OK. Ich mach das mal.
> zum Projekt.
Ruhig Blut, brauner....
Deine Meinung ist akzeptiert und wohlwollend aufgenommen.
Vor einigen Posts schrieb Karl-Heinz (der Software-weiter-Entwickler)
das er aus (verständlichen) privaten Gründen keinen "Nerv" mehr für
dieses Projekt hat.
Jungs, ... lest bitte nicht nur die letzten drei Posts, sondern auch mal
ein bischen mehr. Ich finde Euer "Gehampel" sehr unseriös.
Das ist meine persönliche Meinung, und dafür könnt Ihr nur mich
verurteilen. Lasst bitte die Traedersteller aussen vor, wenn Sie
"gerade nicht auf´m Damm sind" ...
Das ganze ist eine Freizeitaktion.
Wenn Jemand ein fertiges Gerät haben will, und dann die gewünschte
Funktion nicht erfüellt wird, dann möge er doch den entsprechenden
Verkäufer verklagen. Auch wenn er wohnhaft in China ist.
Die hier in Thread gemachten Vorschläge sind nur zum Vorschlag oder
Anreiz gedacht.
Das sich selbst solche Leiterplattenorganisationen von Barney oder
Moritz zu einem "Kassenschlager" herausstellten ist eine andere Sache.
Aber zu dieser Zeit hatte die Chinesische "Nachbauindustrie" davon
noch keinen Wind abbekommen.
Heutzutage sieht die Sache etwas anders aus, zu dem Preis, zu dem ich
per China-Post einen Transistortester bekomme, bekomme ich ich in
Deutschland
nicht einmal 1/3tel der Bauelemente, geschweige denn eine Leiterplatte
wo ich die drauflöten kann..
Und jetzt soll der Softwareschreiber JEDE Variante ausprobieren?
Wie soll das jemals gehen?
Bleibt nur.... selbst einbringen.
Da ich selbst nicht programmieren kann, dachte ich, ich helfe anderen
mit meinem Layout.
Aber ich bin da jahrelang hinterher.
Die Chinesischen Profis sind da echt besser.
Die machen das ja auch Beruflich ---  Karl-Heinz, Barney, Moritz und
meine wenigkeit dagegen nur als Hobby (oder Just for Fun).
Gruss Asko
Sorry, wenn Manche das in den falschen Hals bekommen haben.
Ich ging davon aus, es gäbe da ein Entwickler-Team. Also mindestens
Zwei.
Was mit Klaus ist, habe ich gelesen und wünsche seiner Frau gute und
baldige Besserung. Ich weiß selbst wie das ist, an einer schweren
Erkrankung zu leiden.
Karl-Heinz meinte ich, nicht Klaus. Sorry
von Benny (Gast)
Moin,
sagt mal, wie kommt man an die älteren Versionen der Software auf dem
SVN?
Wenn ich auf den SVN gehe, wird ja immer die aktuellste Software
angezeigt:
Ich wollte aber gerne einige ältere Versionen downloaden.
Wenn ich bei "Sticky Revision:" z.B. 669 eingebe, öffnet sich die Seite,
und ich kann den kompletten Versionsordner downloaden.
Da ich aber nicht weiß, welche Versionen jeweils nach Rev.711
rausgekommen sind, wollte ich gerne einen Überblick haben.
Ist das auf dem SVN nicht möglich?
Habe keinen link gefunden, der zu einer Übersicht führt.
Hat jemand evtl. einen link dafür?
von G. H. (schufti)
712, 713, 714, ...., 803, 804, 805
ist leider kein cvs mit branches und releases
Eine grobe Zuordnung:
Ver   Datum       Rev
0.97 / 09.06.2012    5
0.98 / 26.07.2012   21
0.99 / 15.08.2012   48
1.00 / 23.09.2012   62
1.01 / 19.10.2012   74
1.02 / 01.11.2012   79
1.03 / 24.11.2012  114
1.04 / 01.12.2012  124/125
1.05 / 19.01.2013  138
1.06 / 23.02.2013  155
1.07 / 19.04.2013  166
1.08 / 01.10.2013  183
1.09 / 30.11.2013  196
1.10 / 09.04.2014  270
1.11 / 07.02.2015  384
1.12 / 18.02.2017  717
in changelog.txt findet man die zugehörigen Änerungsvermerke
von Karl-Heinz K. (kubi48)
Im SVN findet man ältere "k" Versionen unter Software/tags als zip
Datei. Natürlich kann man mit subversion auch jede Zwischenstufe der
Uploads wieder rekonstruieren. Die "m" Versionen von Markus findet man
unter Software/Markus als tgz Dateien. Die Dokumentation der letzten
Entwicklerversion findet man unter Doku/trunk/pdftex/german/ttester.pdf
(und ttinfo.pdf). Diese Dokumentation bezieht sich auf die "k" Version.
Die Abweichung der "m" Version ist in den Informationsdateien der
jeweiligen tgz Datei zu finden.
Die Dokumentation der letzten fertigen "k" Version (1.12k) findet man in
Doku/tags/german und von älteren "k" Versionen in Doku/tags/old/german.
OK, also ist die 1.12k wirklich die letzte - nun gibt es noch die m, wo
mir aber nicht asap klar war, ob die zum LCR T4 kompatibel ist.
Klaus.
von Benny (Gast)
Hallo G.H. und Karl-Heinz,
vielen Dank für die Info´s :-)
Ben
Die letzte Entwicklerversion ist die 1.13k, zu finden im Software/trunk
Ordner. Der Unterschied zu einer finalen Version ist, daß im
Entwicklungsstadium noch einige Punkte geändert werden können.
von Max (Gast)
Ich habe mir einen M12864 gekauft.
Kit war vollständig- ist ja nicht immer der Fall.
Ich habe nach dem zusammenlöten 9V angeschlossen, jedoch geht auch beim
„drücken“ des Potis das Display nicht an.
Gibt es etwas zu beachten?
Wenn die Hintergrundbeleuchtung des Displays nicht leuchtet, stimmt
etwas mit der 5V Versorgung nicht. Beteiligt sind hier hauptsächlich der
PNP Transistor, der 5V Regler und die LED. Hier noch einmal alle
Bauteile überprüfen. Die LED kann zu Testzwecken überbrückt werden, um
eine Falschpolung der LED auszuschließen.
von Max (Gast)
Hallo Karl- Heinz,
Die LED ist richtig gepolt, soeben überprüft.
Bei welchem Bauteil handelt es sich um den 5V Regler?
von Max (Gast)
Müsste der TL431 sein, oder?
Ja, der TL431 ist ein Reglerbaustein. Bei gedrückter Taste sollte dieser
am Eingang über den PNP Transistor mit der Batteriespannung verbunden
sein.
von Max (Gast)
Mist, Fehler vmtl. gefunden: der 7550 war in der Eile falsch eingelötet.
Es kam wie es kommen musste- beim auslöten beinchen gebrochen und kein
Ersatz da. Jetzt erstmal nach einer Quelle suchen und warten :/
Danke!
von kapax (Gast)
oder IC2 in grund schaltplan 78L05?
TL431 ist Eine Spannung referens 2,5V (LT1004)
> Ersatz da.
Die Transistoren werden nur als Schalter benutzt. Die brauchen nur
genügend Stromverstärkung! Es sind 2 NPN und 1 PNP verbaut.
von Max (Gast)
Karl-Heinz K. schrieb:
> Ersatz da.
Das heißt was?
Max schrieb:
> Das heißt was?
Als PNP Transistor kommen z.B. BC328-40, BC327-40 oder BC556B in Frage.
Die NPN Transistoren sind noch unkritischer, da sollte eigentlich jeder
mit hFE>50 funktionieren.
von madires (Gast)
Kleine Verwirrung? :) Mit dem 7550 ist ein HT7550 gemeint. Das ist ein
LDO-Regler für 5V und 100mA.
von Andrew B. (b1ack) Benutzerseite
Hello!
I currently writing a better .H to .PNG converter to make better font
for my TransistorTester. For now it is in progress, output is not ready,
but already can read and simple analyze source files. And it found few
extra commas in the end of symbols definitions before } in file
24x32_vertical_LSB.h.
That bad commas are in the end of lines 81, 159, 238, 315, 377, 438.
Fixed file is included in archive, with current version of my converter
program (yes, there is no output, it only can report errors in input
file for now :) )
And about font 5x8_vertikal_LSB_1.h - in general it is 6x8 font. Maybe t
will be better to name it like 6x8_vertikal_5px_LSB_1.h ? It ruins all
naming and content ormat for other fonts, and for now my program uses
first letters of filename to determine font size (already adding extra
command line parameters for that).
Yeah! I did it! Now i can convert font to image, with any bytes and bits
order. Now I only need to write back conversion. And then the same for
Markus version :) Program will be shared when set will be finished.
Here is only image samples.
Found that 10x16 font is different formatted - it have bytes order not
from left to right, top to bottom, but top to bottom than left to right.
Bits order is default.
von Kai-M (Gast)
Hallo Karl-Heinz,
ich habe seit 2 Tagen eine China-Version des Testers, den GM328A von
Geekteches.
Mir fiel gestern beim Testen einiger alter Germanium Halbleiter auf, daß
das Gerät Probleme hat, Germanium-Dioden zu erkennen. Das habe ich
inzwischen auch unter Kapitel 7.1 deiner Beschreibung (Version vom
8.2.2015) als ungelöstes Problem gelesen. Trotzdem finde ich es sehr
merkwürdig und stufe es als bestimmt behebbar ein. Mit
Germanium-Transistoren AC151VI, AC151VII, AC128, AF136, 2SB324, SFT228
gab es kein Problem. Einige Germanium Dioden wurden als 26 pF
Kondensator "erkannt", bei OA85 und noch einer anderen wurde die
Flußspannung mit 9xx mV gemeldet statt der typischen 250...300mV, die
ein Multimeter anzeigt. Auch bei kleinen Silizium-Dioden ähnlich 1N4148
wurden knapp 900 mV statt der typischen 650...700 mV gemeldet. Wenn da
das übliche Verfahren eines Meßstromes von 500 uA...1mA verwendet würde,
sollte doch die "übliche" Flußspannung meßbar werden.
Kann es sein, daß China-Versionen ungüstig bestückt sind für diese
Messungen ?
MfG Kai
von madires (Gast)
Dioden werden mit beiden Messwiderständen geprüft, also mit ca. 7mA und
10µA. Hast du bei den Kleinsignaldioden in die Datenblätter bzgl. Vf
geschaut  (Vf-If-Kurve)? Bei den problematischen Germaniumdioden würde
mich interessieren, was die m-firmware erkennt. Es ist gar nicht so
leicht eine zuverlässige Diodenerkennung zu implementieren, wenn man
auch größere Leckströme berücksichtigen muss.
von Kai-M (Gast)
ich habe mir die Kennlinien im Bereich bis etwa 800 µA Vorwärtsstrom und
bis etwa -2V Sperrspannung angesehen. Außerdem habe ich mit zwei
Multimetern im Dioden-Meßmodus die Flußspannung geprüft. Letzteres ergab
immer die typischen Werte zwischen 270 µA und 300 µA. Messung bei 7 mA
ist nicht üblich. Die OA85 hat zugegebenermaßen eine etwas flachere
Vorwärtskennline als andere Germaniumdioden oder insbesondere die
Basis-Emitterdiode eines AC151. Die Sperrströme können von der 10 µA
Größenordnung gewesen sein, hab ich nicht nachgemessen. Trotzdem sollte
ein Diodentester nicht so drastisch von anderen gängigen Tests abweichen
und wegen zu hohem Leckstrom schon garnicht eine Diode als 26 pF
Kondensator ausweisen. 900 mV sind auch für eine 1N4148 untypisch (bei 1
mA). Das Datenblatt zeigt für 7 mA eine Variationsbreite zw. 0.7 ... 0.8
V an. Für 0.9V müßten demnach 20...80 mA fließen.
MfG Kai
Bei mir gibt es bei einer 1N4148 folgendes Ergebnis:
Uf=715mV
.48pF-.32pF@0-5V
Ir=4nA
Natürlich sind die Werte Exemplar-abhängig. Eine Flußspannung von 900mV
ist aber auch bei dem höheren  Meßstrom von etwa 6mA unplausibel.
Entweder ist die Diode defekt oder der Tester.
von G. H. (schufti)
oder es ist keine 1N4148 sondern "nur" eine optimistisch gelabelte
Si-Universaldiode ... für solche Erkenntnisse ist der Tester
gelegentlich auch ganz gut :)
von Kai-M (Gast)
da es für einen guten Zweck ist, hab ich mir mal die Mühe gemacht,
einige Dioden durchzumessen, insbesondere auch bei dem genannten
untypischen Meßstrom von 7 mA.
Zuvor hab ich bei drei vorhandenen Multimetern mit Dioden-Meßbereich
geprüft, mit welchem Strom sie messen.
Es sind ein UT603, ein UT61B und ein VC170. Sie messen mit etwa 1,05 /
0,82 und 0,56 mA. Die Kurzschlußströme sind 1,12 / 0,92 und 0,68 mA, die
Leerlauf-Meßspannungen 5,63 / 2,9 und 1,47 V.
Bei den folgenden Messungen habe ich dann das UT603 benutzt, weil sein
Strom 1 mA am nähesten kommt.
Außerdem habe ich die Spannung an der jeweiligen Diode bei Speisung aus
15V über 15 kOhm (ca. 1 mA) und über 2 kOhm (ca. 7mA) gemessen. Den
Abschluß bildet der Leckstrom bei -5 V Sperrspannung.
Ergebnisse:
            GM328A:Uf/Ir            UT603   ,15kOhm,  2kOhm   Ir@ 5V
1N4448 o.ä,: 713mV/6nA,             606mV,   623mV,   727mV,
OA85(1) 1 3:damaged part?,1 2:26pF, 335mV,   330mV,   854mV,  95µA
OA85(2)      780mV/2.1µA,           355mV,   359mV,   869mV,   1.4µA
OA85(3)      742mV/2.9µA,           343mV,   351mV,   834mV,   1.5µA
OA85(4)      912mV/1.8µA,           378mV,   380mV,  1016mV,   1.2µA(21.1µA @ 15V)
OA95(1)      836mV/2.1µA,           370mV,   375mV,   931mV,   3.2µA
OA95(2)      755mV/1.6µA,           357mV,   358mV,   831mV,
OA95(3)      733mV/1.8µA,           351mV,   350mV,   804mV,   1.8µA
AAZ18(1)     330mV/0.65µA,          233mV,   239mV,   344mV,   1.4µA
AAZ18(2)     340mV/1.5µA,           240mV,   240mV,   351mV,   1.5µA
AAZ18(3)     340mV/0.75µA,         .235mV,   233mV,   350mV,   0.7µA
BAT??Schottky 591mV/21nA,          .343mV,   343mV,   622mV,  <0.1µA
OA150        C : 29pF,              340mV,   331mV,  1066mV,  30.6µA
AC151VI B E  272mV/4µA,             182mV,   183mV,   285mV,   3.4µA
AC128 B E    223mV/4.6µA,           156mV,   156mV,   233mV,   3.7µA
(Die Tabelle wird leider vom Editor und Font verratzt, ist aber
hoffentlich trotzdem lesbar).
Bei den letzten beiden Objekten handelte es sich um die Basis-Emitter
Diode der genannten Transistoren.
Ich habe mehr als eine Kleinsignal-Silizium-Diode vermessen, hier aber
nur eine gelistet, weil die Ergebnsse sehr ähnlich sind. Das Argument,
die gemessene Diode sei defekt gewesen, greift daher nicht.
Frühe Germanium-Dioden waren recht "ohmig". Deren Kennlinie verläuft
daher nur bei recht kleinen Strömen bzw. Spannungen <=0.2 V
exponentiell. Darüber flachen sie durch den resistiven Anteil zu hohen
Spannungen hin ab. In alten Datenblättern findet man deshalb bei Strömen
von 30 mA oder mehr teils Spannungen von einigen Volt.
Positiv heraus ragen Golddraht-Dioden (Point-Contact...) und
insbesondere die Basis-Emitter-Dioden von Germanium-Transistoren, bei
denen man die kleinsten Fluspannungen findet.
Die Angabe einer Flußspannung ohne den Meßstrom ist nutzlos, wenn man
nicht Hintergrundwissen hat, womit zu vergleichen ist.
Es sieht so aus, als würden übliche Multimeter bei Strömen zwischen 0.5
... 1 mA messen. Damit findet man dann Flußspannungen, die noch etwas
unter den Werten des UT603 liegen. Alte Datenblätter geben oft die Werte
bei 0.1 mA und 10 mA an, manchmal auch bei 1 mA.
Ein Bastler auf Fehlersuche bekommt von seinem Multimeter und dem
Transistor-Tester zwei recht verschiedene Ergebnisse beim Dioden-Testen.
Dazu bräuchte er dann noch einen Würfel, um zu entscheiden, was wohl
stimmt.
Recht hoch-ohmige Dioden wie die OA150 werden nicht erkannt. Das liegt
vielleicht mehr an den deshalb hoch erscheinenden Flußspannungen als an
dem Leckstrom.
MfG Kai
[Mod: Code-Tags eingebaut, damit die Tabelle lesbarer wird]
Hallo hier im Forum
... hat jemand schon mal den Cina-Clon "Hiland - M644 Multifunctional
Transistor Tester LCR" mit Karl Heinz' Software V1.13
(mega644_hiland_m644) getestet?
... funktioniert bei mir bestens, allerdings ist bei der
Erst-Inbetriebname ja die Kalibrierung fällig. Hier fiel mir auf, das
der Warte-Schritt zum Einstecken des (ersten) Hilfs-Kondensators --||--
> 100nF nicht erfolgt - stattdessen ist nur kurz 200nF in der Anzeige
und es geht sofort weiter in der Kalibrierung.
Bei der etwas später erfolgenden Abfrage des zweiten Hilfs-Kondensators
(4-30nF)ist wie gewohnt der Warteschritt und die Kalibrirung wird dann
auch richtig abgeschlossen.
Verhält sich in diesem Punkt der "644er" anders als der "328er" oder
wird dieser Teil der Kalibrierung nicht mehr benötigt?
Die Messwerte des Testers sind durchaus brauchbar und plausibel, nur die
niedrigen ESR-Werte, die bei Testern mit dem "328er" zwischen 0,02- 0,5
Ohm liegen, werden vom "hiland-M644" mit 0,00 Ohm bewertet?
Gruß Horst
Die ATmega644/1284 Version benutzt einen eingebauten Kondensator. Daher
wird dieser Schritt ohne Wartezeit abgeschlossen. Die ESR-Messung werde
ich noch einmal überprüfen, wenn ich wieder mehr Zeit habe. Tritt die
ESR-Fehlmessung nur bei kleineren Kondensatoren auf oder auch bei Werten
>10uF?
Die Messung von kleinen Kondensatoren ist sehr zeitkritisch, da sich die
Ladespannung schnell ändert.
Hallo Karl Heinz,
danke für die schnelle Antwort.
Der größte Kondensator hierbei war ein 1uF Folien-Typ.
Gruß Horst
von Jean-Luc (Gast)
... ich habe das nochmal überprüft.
Der Fehler tritt auch bei größeren Kondensatoren auf - Werte < 0,8 Ohm
werden als 0.00 Ohm angezeigt - erst darüber sind die Werte mit denen
der "328er" vergleichbar.
Das trifft im übrigen auch bei Widerstandsmessungen unter ca. 1 Ohm zu,
die ebenfalls als 0.00 Ohm angezeigt werden.
Gruß Horst
Die Ursache war eine falsche Abfrage in der Funktion GetESR.S speziell
für den ATmega644. Auch nach Beseitigung des Fehlers sind Abweichungen
des ESRs für kleine Kapazitäten feststellbar. Da muss wohl auch die
Korrekturfunktion für die ATmega644 Familie angepasst werden.
Die Korrektur für kleine Kondensatoren ist nun auch für den Mega644
angepaßt. Wie auch beim Mega328 kann man bei der ESR-Messung keine hohe
Präzision erwarten. Speziell bei kleinen Kapazitäten wird der Meßfehler
größer. Die Anzeige reicht aber meistens aus, um die Qualität von
verschiedenen Bauformen zu vergleichen. Bei Elektrolytkondensatoren kann
man "ausgetrocknete" Exemplare in den meisten Fällen erkennen.
Zum Vergleichen von Kondensatoren sollte man immer mit dem gleichen
Tester messen.
> angepaßt.
Hallo Karl Heinz,
danke für Deine Mühe - habe die neue Version des "hiland-M644" soeben
ausprobiert - alles Super.
Gruß Horst
