Forum: Projekte & Code Transistortester AVR
von Klaus R. (klaus2)
...ich hab deine Daten per AVR mk2 geflasht aber es passierte nix. Egal,
denn immerhin läuft es nun bei mir ja auch komplett und das war das
höhere Ziel - Danke, KH!
Klaus.
von MisterGNZ (Gast)
Hi everyone !, I have two nippon capacitors 10000 microfarad 63v, I
measure with the conponent tester, the first is correct, the second
measure: 33.01 millifarad (33000 microfarad), but its printed value is
10000 microfarad, ???????????? help!!!
von Marcel D. (derri)
> measure: 33.01 millifarad (33000 microfarad) …
The capacitor showing the larger value might be leaking, so the tester
needs more charge pulses to reach the reference voltage level (see
chapter 5.3.2 of the user manual).
Are you shure to have connected the two capacitors using the same
polarity (- on the lower number test pin)?
Have they been discharged completely? Note that even after a short
cicuit with a resistor such a large capacitor may restore a residual
voltage between its terminals when the short is removed. This memory
effect might influence your measurement.
Greetings, derri
Hi Derry, thanks for the explanation.
the capacitors are new with esr .01, maybe it is the component tester,
which has reading problems on large capacities
von Ben (Gast)
MisterGNZ schrieb:
> ... maybe it is the component tester,
Did you build the tester yourself or did you buy it?
Once i had the same error, and it was due to R11, I had made a mistake
in the Assembly and had soldered a wrong Resistor.
With me, also with larger Capacitor values too high values were
indicated.
In about every fifth Measurement a large Capacitor was correctly
displayed.
R11 must have a value of 10k (look at the Schematic).
When i soldered the 10k resistor, everything was measured correctly.
Would be worth a look.
von Leon T. (ltumm)
I had the same problem on 3 builds 1 2200 uF read as about 6850 uF.
After trying everything it seems to be the capacitor, I tried another
capacitor and it reads correct, both were new and bought together. Best
way is to try a lot of other capacitors and check if a few or a lot of
capacitors read much higher. If you have access to a bought capacitor
meter you could check the capacitor on that.
...habe mal versch gebrauchte Elkos von 3300 - 10000uF gemessen mit Pin
1 + 3 (also C-Mess-Mode!). Alle passen 1A. Tester ist der umgebaute LCR
T4.
EDIT: I measured several used elkos from 3300...10000 with dedicated (!)
C-measure-mode on pin 1&3 and all are in spec...tester is the modded LCR
T4 from above discussion.
Klaus.
I noticed that the 10000 microfarad condenser, if I shake it, moves
inside, it seems that it hits the walls as if the liquid inside it has
dried, the good one does not move. capacitor to throw away?
...you can check it with an voltage source, resistor and measure time
until 66% of supplied voltage, its an e-fcn and then calculate C from
known R, t & V. The basic way :) But if the other C is always good very
likely the other C is bad - even if I do not really understand, why it
displays a much HIGHER cap.
Klaus.
maybe they sold me fake nippon capacitors
Hi Klaus R. I gave 13v voltage to the capacitor, I had to disconnect
because it heated a lot, new never used, the tester component works very
well
...take it appart to se whats inside :) So, yes, its very likely fake.
Klaus.
Hi Klaus R. I opened it, look at pictures
Searching the net I found <
https://www.chemi-con.co.jp/products/relatedfiles/capacitor/catalog/KMHN-e.PDF
> on the manufacturers site. There you find the exact dimensions of your
caps. This could be a clue to determine a fake.
As of your pictures, they seem to show the original type, but your
specimens might well be a few years old. The remaining capacity is
largely dependent on storage conditions and duration, but could never
increase to the triple value of the original. So the device measured as
33.000 uF is (was) surely defective.
The fact that the cap heated up with only 13 Volts across shows that
there was something seriously wrong with it. In general, old chem-caps
may need reforming after very long storage durations, but then you must
use a series resistor of a few hundred Ohms to limit the leakage
current, and the voltage should correspond to the maximum operating
voltage of the device (63V in your case). After several hours, maybe
even days, the leakage current should drop to normal values. If this is
the case, you can still use the device. If it keeps on leaking strongly,
it is definitely dead and you should dispose of it.
I hope this helps,
derri
Hi Klaus R. I threw it immediately, in order not to have unpleasant
situations, I also have 4 RIFA18000 microfarad 35v capacitors, they too
have wrong measurements, but they work, I also have 2 ROE 10000
microfarad 50v, the measurement is ok, all new never used. I think when
a capacitor moves inside, it is to be thrown away, do you agree?
MisterGNZ schrieb:
> I think when
Yes, I do!
von Zhq S. (zhqsoft)
How to modify the auto exit waiting time under the menu interface? Now
it takes 1400 seconds. It's too long. I didn't find the relevant
settings in the source code.
...not in makefile and not in config.h?
Klaus.
新制作了一只M644晶体管测试仪,大家来看看吧
https://oshwhub.com/zhqsoft/M644-TransistorTester
von Horst O. (obelix2007)
... ein neuer, gut ausgestatteter Clone im Anmarsch?
Gruß Horst
I looked into the software and found that the default time out is 28
seconds.
This looks a lot like your 1400 seconds divided by 50. I guess that this
parameter is set in the makefile, the default values being defined in
autoconfig.h and config.h (search for OFF_WAIT_TIME, SHORT_WAIT_TIME and
LONG_WAIT_TIME.
Have you changed the timing parameters in the original software?
Greetings, derri
I like your design! And I really appreciate that you are publishing your
work in the spirit of the open source movement.
Congratulations for your good work!
derri
Beitrag #6781096 wurde vom Autor gelöscht.
Beitrag #6781126 wurde vom Autor gelöscht.
Hallo!
für alle, die, wie ich, des Chinesischen nicht mächtig sind, habe ich
Google gebeten, die Seite von zhqsoft ins Deutsche zu übersetzen. Ich
hoffe, das ist nützlich.
for all those, who, like me, don't speak chinese, I kindly asked Google
to translate zhqsoft's web page. Hope it helps.
Gruss / Greet's
derri
> Hi,
> seconds.
> LONG_WAIT_TIME.
> Greetings, derri
Value of parameter “SHORT_WAIT_TIME and LONG_WAIT_TIME”in the config.h
is right,The waiting time in actual use is consistent。
“SHORT_WAIT_TIME”is associated with the menu wait exit time。
Set in “function_menu.c”
ii = wait_for_key_ms(SHORT_WAIT_TIME);  // wait about 5 seconds,
It's weird here,The source code is called “SHORT_WAIT_TIME”,value
18000=1400s,I modified different values,
value 200=60s,
value 1000 More than 3 minutes。The set value is different from that in
reality,And it's not linear。Although a small value can be used to set
the menu exit time, But the key function will be abnormal when the value
is less than 1000。
von Markus R. (madires)
Have you enabled WITH_ROTARY_SWITCH by chance without having a rotary
encoder?
von Mathias N. (Firma: Kobold Inc) (alfrede)
sehe ich es richtig, dass es immer noch keine Kicad Projektdateien zu
diesem Projekt gibt?
Wenn dem so ist, würde ich dies gerne realisieren. Ich wollte nur zuvor
fragen ob es dabei etwas zu beachten gibt.
mfg
Matze
von Lötzinn V. (loeterich7)
Moin
was spielt es für das Projekt für eine Rolle mit welchem
Layoutprogramm die PCB´s erstellt wurden ???
Wenn der Quelltext offen ist wie es hier der Fall ist, würde ich auch
gerne die Schaltbilder mit einer Open Source Software öffnen können ohne
von einem Hersteller abhängig zu sein. Getreu dem Open Hardware
Gedanken. (https://de.wikipedia.org/wiki/Open-Source-Hardware)
Denn so wie sich Autodesk die letzten Jahre entwickelt hat möchte ich
nicht von so jemanden abhängig sein und mit einer "falschen"
Entscheidung bei diesen ein solchen Projekt sterben sehen.
Es sei denn der Projektleiter Karl-Heinz Kübbeler möchte dies nicht,
dann respektiere ich dies.
mfg
Matze
Mathias N. schrieb:
> Ich wollte nur zuvor fragen ob es dabei etwas zu beachten gibt.
Die Leiterbahnen zu den Testanschlüssen 1, 2 und 3 sollten möglichst
kurz sein, damit man auch kleine Kapazitäten genau messen kann.
Und es gibt jede Menge mögliche Varianten:
- Prozessor DIL oder SMD, mega328 oder mega644 usw.
- Bedienung mit Taste oder Drehimpulsgeber
- Display
- mit/ohne Spannungswandler für Z-Diodentest
- usw. usw.
Es wird wohl kaum möglich sein, alle Varianten unter einen Hut zu
bringen, so dass du wohl eine Auswahl treffen musst. Oder du machst es
wie im Beitrag von Zhq S (03.08.2021). Einen Versuch ist es allemal
wert.
Bisher haben Markus und Karl-Heinz keine Einwände vorgebracht, wenn
jemand die Schaltung abgewandelt oder eine Platine entworfen hat.
Ich bin kein Anhänger einer speziellen Software zum Platinenentwurf. Ich
benutze zwei kommerzielle Programme jeweils in einer kostenlosen
Version, aber ich bin auch der Meinung, dass bei einem Open Source
Projekt die verwendete Software auch Open Source sein sollte.
Übrigens kannst du beruhigt sein, das Projekt steht und fällt keineswegs
mit Autodesk! Es gibt Konkurrenten, die das Eagle-Format einlesen
können, darunter auch KiCad ab Version 5, siehe z.B. <
https://hackaday.com/2015/12/27/eagle-to-kicad-made-easy/ >.
Gruß, derri
Es gibt ein Dev-Board mit ATmega644/1284, welches mit KiCad erstellt
wurde (ist im Repo). Da aus Eagle inzwischen ein gewinnoptimierter SaaS
geworden ist, dürften die meisten Hobbyisten und OSHW-Projekte auf KiCad
umgestiegen sein. Selber nutze ich KiCad auch schon eine Weile.
Es gibt keine Vorgaben. Du darfst dich gerne frei austoben. :) Ich gebe
dir nur den Tipp, keine exotischen Bauteile zu verwenden und die
Schaltung kompatibel mit der Firmware zu halten.
Hallo Markus, danke für den Hinweis, aber seitdem das svn abgeschalten
ist konnte ich auf der github Seite leider keine kicad Datei zu der
Version 644 finden. Kann natürlich auch sein, dass ich blind bin. ;)
Könntest Du bitte mal schauen wo die liegt? Danke im Vorraus und, dass
Kicad Eagle Dateien inzwischen sogar brauchbar importieren kann wusste
ich aber trotzdem Danke.
Ooops - ist tatsächlich (noch) nicht im Repo. Kommt also in die
Aufgabenliste.
von Michael J. (hessemichel)
Hallo Transistortester Gemeinde
Ich schon seit Jahren stolzer Besitzer eines T4 von unseren chinesischen
Freunden.
Kurze Eckdaten:
- orange/gelbe Platine ohne Aufdruck
- Blauer Taster
- LX-12864B5 Display mit externem Backlight, 14-poligem Flachbandkabel
COG mit UC1701 Controller)
- M328P Chip mit 8 MHZ Quarz
- Chinesische Software Mtester 2.07
- Fuses Lockbyte 0xFF, H-Fuse 0xD9, L-Fuse 0xFF, E-Fuse 0xFC
Nun möchte ich ein Firmware upgrade durchführen, finde aber keine
passende Version, die das Display anspricht.
Weder 1.12k und die m-Versionen bekomme ich zum laufen.
Das Display ist ein LX-12854B5.
Nach meiner Recherche soll ein UC1701 Controller verbaut sein,
vermutlich Kompatibel zum ST7565 Controller.
Am M328P ist es scheinbar mit anderen Pins verbunden, als der Standard
Schaltplan angibt.
PD0 = RST
PD1 = A0
PD2 = SCK
PD3 = SDA
Testfirmware ist die 1.12k mit dem Makefile aus dem Verzeichnis
..\ttester_112k\trunk\mega328_T3_T4_st7565
Kompiler ist der Programmers Notepad aus meinem modifizierten
WinAVR-20100110 (GCC-Paket aus dem Arduino IDE, Anpassungen hier aus dem
Forum übernommen)
Bei meinen bisherigen Versuchen wird nur das Backlight angesprochen, der
LCD bleibt leer
Jetzt zu meiner Frage wie kann ich den Controller dazu bewegen mir eine
Anzeige auszuspucken.
Muß nur das Makefile angepasst werden?
Darf/sollte ich in der config.h rumpfuschen und dort das Pinout für das
Display ändern?
Sind noch andere Einstellungen nötig?
Über Vorschläge und Hilfestellungen bin ich sehr Dankbar.
Falls das ganze klappen sollte hab ich noch vor einen Baugleichen mit
I2c Oled mit SSD1315 Chipsatz zu bestücken, aber das ist eine andere
Baustelle
Hallo Michael,
hast Du auch die für die neueren Versionen des T4 vorgesehene
"mega328_T4_v2_st7565" Firmware von KH probiert?
Eine weitere Option ist die Firmware von Markus R. (madires), in der Du
die Portbelegung frei konfigurieren kannst und die noch einige
zusätzliche Menüpunkte (Funktionen) enthält.
Gruß Horst
Servus Horst,
Die von dir genannte V2 spiele ich gerade ein, mal schauen.
Das Teil von Markus interessiert mich auch, wo finde ich diese version
denn? ebenfalls im Trunk von
https://github.com/Mikrocontroller-net/transistortester
Grüße Michael
Edit: mit der Vorkompilierten mega328_T4_v2_st7565 hab ich immer noch
keine Anzeige im LCD.
Bevor Fragen aufkommen, ich spiele immer zuerst das Flash-file ein,
danach das Eeprom mit den Funktionen -U flash:w:xxx.hex:a und -U
eeprom:w:xxx.eep:a
Solten Fuses gesetzt werden müssen, werden zuerst der Chip gelöscht,
dann die Fuses gesetzt, danach Flash und zum Schluß das Eeprom
eingespielt
Hallo Michael,
hier findest Du die gesuchte Firmware:
https://github.com/madires/Transistortester-Warehouse/tree/master/Firmware/m-firmware
Meine vorgehensweise ist ähnlich, allerdings nutze ich die grafische
Oberfläche "AVRDUDESS", die leicht zu konfigurieren ist.
Gruß Horst
Hallo Horst
Vielen Dank für den Link.. Das kommt mir bekannt vor.
Ok, dann zieh ich mir mal die Dokumentation rein und Versuche mein
GLück.
Bei Erfolg/Misserfolg berichte ich meine Erkenntnisse
Grüße Michael
Danke für das uploaden der Kicadfiles.
Sodele ich hab en wenig Zeit gefunden und mich erneut an dem T4
versucht.
Was hab ich gemacht?
Diverse Versionen der m- Version, beginnend ab der Version 1.34 wurden
neu Kompiliert mit angepastem Makefile, config.h und sowie config_328.h.
Als Beispiel im Anhang die Variante der Version 1.44m.
Das Kompilieren ging fehlerfrei vonstatten mit einer angepassten
WinAVR-20100110 Version.
Das tolle Microchip Studio, ehemals Atmel Studio, wollte sich mangels
ausreichenden Erfahrung und Geduld meinerseits nicht so wirklich
bedienen lassen... Ja, ich bin noch zu Doof es zu bedienen.
Jede auf diese Weise erstelle Variante war scheinbar lauffähig,
allerdings zeigt das Display immer noch nichts an.
Hintergrundbeleuchtung leuchtet munter vor sich hin, LCD zegt nicht
einen Pixel
Dann kam ich auf die Idee mal mein Multimeter zu schnappen, eine
Leuchtquelle mit Lupe und bin auf Verfolgungsjagd nach der Verbindung
von Pin am LCD zu Pin am Controller gegangen und konnte bestätigen, was
unsere russischen Kollegen auf Yandex.ru veröffentlicht haben.
https://disk.yandex.ru/d/yW8xa5NJgUo5z/LCR-T4(T3)NoStripGrid/Schematic%20diagram/LCR-T4(T3)NoStripGrid.JPG
PD0 = Reset des LCD;
PD1 = SD/CD/A0 des LCD;
PD2 = SCK des LCD;
PD3 = SDA / MOSI des LCD
Langsam gehen mir die Ideen aus.
Ist der UC1701 Chip doch nicht kompatibel zum ST7565?
LCD zickig oder defekt?
Oder haben wir einen Super-DAU? (ich)
Hast du die orig. FW gerettet? Vll probiert es ja jmd mit nem ST T4 aus.
Klaus.
Hallo Michael,
Deine hochgeladenen Dateien habe ich compiliert. An meinem rel. neuen T4
(hat statt der zwei Dioden einen Spannungsteiler mit Widerständen)
fünktioniert diese Firmware, allerdings steht die Anzeige auf dem Kopf,
die Portbelegung stimmt also zumindest bei meinem Display.
Im Anhang findest Du die Orginal-Firmware.
Gruß Horst
Hallo Leute.
heute hab ich mal wieder Zeit gefunden und mich mit dem Tester
beschäftigt.
Der Fehler ist gefunden, die Folienplatine hat eine Unterbrechung direkt
am LCD, sehr ärgerlich, kann ich nicht reparieren.
Naja, hilft alle nix, dann versuche ich mein Glück das Teil auf
OLED-Anzeige umzurüsten, sollte nicht all zu schwer sein.
Die nun freigewordenen Datenpins fürs ehemalige LCD könnte ich ja für
i2c nutzen, ich meine in der Config war was drinnen gestanden.
Mal schauen, ob das zu einem Erfolg führt.
Die Originaldateien hatte ich mir bei meinen ersten Versuchen mit dem
Avrdude leider zerschossen.
Man sollte nach dem Auslesen und Speichern der Daten, diese direkt als
Sicherheitskopie in einem extra Ordner ablegen und diese nach
Möglichkeit nie wieder anfassen!
Danke für das Hochladen deiner Original Firmware.
Gruß Michael
von Javier (Gast)
Hello, I am from Uruguay and recently I bought the DTU1701 transistor
tester on Aliexpress, when I turn it on it tells me that it has firmware
1.11 and I want to know if I can update it to version 1.41.
The problem is that I never programmed on this type of chip (atmega328),
after I have the right programmer, how is the procedure to update the
firmware and what files do I have to use? Thank you
Hello Javier
I have the same Tester, only that it is labeled "BSIDE ESR02Pro". But
the PCB inside is marked "DTU-1701 V3.1".
I have updated the firmware to version 1.13k. You must know that there
are two firmware variants, the "k" and the "m" versions. M stands for
Markus alias Madires, K for Karl-Heinz Kübbeler, the two main developers
of the current software. I have not tested the m-variant on this device,
which is the 1.41 you mention.
The firmware of the Tester can be flashed via an ISP interface, J6 in
the very middle of the PCB (see attached picture DTU...). To use it, you
have to solder a 6-pin inline socket to the board and use an adapter to
connect a standard AVRISP 6-pin programming device (attached picture
ISP...).
The firmware must be configured for different clock frequencies and
hardware variants, so there are many, many different versions. Please
see https://github.com/madires/Transistortester-Warehouse for the source
code and
https://github.com/madires/Transistortester-Warehouse/tree/master/Documentation
for the documentation. If you are interested, I can provide you
schematics, source code etc. that I used successfully.
Greetings from Luxembourg,
derri.
Question is: Is it NECESSARY ( and if yes, why)...if you brick it you
have won nothing, so think twice.
Klaus.
von Große Kondensatoren (Gast)
Kann der Transistortester eigentlich richtig große Kondensatoren testen?
z.B. Supercap 5,5Volt und 0,5F oder 1F?
von Karl-Heinz K. (kubi48)
Nein, dafür ist der Innenwiderstand der Goldcaps zu hoch. Mit kleinem
Strom würde die Ladezeit zu lange, um eine nennenswerte
Spannungserhöhung zu bewirken.
von Holger B. (dreieck)
Ahoj,
ich bin gerade darauf gestoßen, dass es bei Conrad Electronic einen
"JOY-iT LCR-T7[1]" zu kaufen gibt der auf diesem Projekt zu basieren
scheint.
Ich möchte ein solchartiges Gerät gerne erwerben da ich gerade nicht die
Kapazität zum Selbstbau habe.
Da es sich hier um ein Open Source-Projekt handelt in das viel Arbeit
geflossen ist, möchte ich gerne die Menschen unterstützen die hier viel
Arbeit reingesteckt haben, und daher die Frage:
Mag mir wer sowas bauen und verkaufen? Ich fände das Fairer, als irgend
ein (China?)-Produkt zu kaufen wo am Ende weder Geld noch vermutlich
Entwicklungs-Rückfluss in das Projekt geht.
[1] JOY-iT LCR T7:
http://joy-it.net/en/products/JT-LCR-T7
Hallo Holger,
... einige Seiten vorher in diesem ellenlangen Beitrag habe ich von der
Modifikation des LCR T7 (oder TC1, baugleich) berichtet:
Beitrag "Re: Transistortester AVR"
In manchen Browsern wird nur immer zum Anfang der Seiten gesprungen,
daher hier zusätzlich: Seite 28; Beitragsdatum 14.10.2020 06:18
und auf der gleichen Seite etwas höher 13.10.2020 20:08 ein Hinweis auf
T7 und TC1.
Wenn Du Interesse daran hast, Melde Dich hier oder per PN
Gruß Horst
Wer das Transistortester-Projekt unterstützen möchte, kann dies gerne
mit Testexemplaren von Clones, Displays oder selteneren Bauteilen tun.
Bei der Doku (Übersetzungen) und beim Testen ist Unterstützung auch
willkommen. Das Herstellen und der Verkauf von "offiziellen" Testern
macht wegen der damit verbundenen hohen Kosten, wie z.B. CE oder
Elektroschrottentsorgung, für uns keinen Sinn. Ich denke, daß Karl-Heinz
das ähnlich sieht.
PS: Von den chinesischen Clone-Herstellern ist bisher Null gekommen.
Weder Sourcecode der Modifikationen noch Testexemplare. :(
Ahoj,
> willkommen.
Danke!, ich habe leider derzeit keine Kapazitäten dafür.
Ich habe mich nur "schlecht" gefühlt, von diesem Projekt zu "saugen"
ohne was zurückzugeben.
Übrigens, ich finde das ganze Projekt noch ziemlich verwirrend.
Gibt es denn irgendwo eine "Einsprung-Übersicht", wo alles was zu diesem
Projekt bisher gesammelt wurde übersichtlich kategorisiert und verlinkt
ist?
Mich schreckt ab dass ich keinen übersichtlichen Einsprungspunkt in die
Sache finde. Fände ich den, so dass die Struktur mindestens dem Inhalt
gleich auf ist, fiele es mir wohl deutlich leichter auch Kleinigkeiten
beizutragen über die ich bei Verwendung des Gerätes oder Basteleien
stoße (habe jetzt das modifizierte Gerät von "obelix2007"[1] (Danke!),
und irgendwie kommt mir in den Sinn, wenn das eh einen USB-Port hat,
dann könnte doch eine serielle Kommunikation über diesen stattfinden?,
also einen USB-Seriell-Wandler dranbasteln. Sowie einen
Hardware-Aus-Schalter, und was wäre mit allgemeiner
Spannungsmessfunktion? -- Vermutlich werde ich nur den Hardware-Schalter
umsetzen).
Weiter oben [2] ist
https://www.mikrocontroller.net/svnbrowser/transistortester/ verlinkt,
das bekomme ich jedoch nur ein "File not found".
Es gibt ja die Übersicht auf /articles/AVR_Transistorteste [3a]. Da gibt
es dann auch einen Bereich "Software" [3b]. Da wird mir aber auch nicht
klar erklärt, welche Software-Varianten (es gibt da immer so die
"Kennbuchstaben", die auf die verschiedenen Autoren verweisen, soviel
habe ich schon gelernt) jetzt was genau sind.
Dann gibt es das Archiv github.com/kubi48/TransistorTester-source [4]
Aber wo steht nun das "authorative" Archiv? In [3c] ist noch
inkonsistent von Git und SVN-Archiv die Rede (und auf nix davon
verlinkt).
Also ich bin gerade mehr verwirrt als klar über den Status des
Projektes, welche Informationen wo aktuell sind und welche veraltet und
wo es überhaupt welche Informationen gibt, etc.
Insofern wäre ich erstmal über eine "Index" auf die Informationen zu dem
Projekt dankbar.
Jedoch freue ich mich über das Gerät und dieses einfach zu benutzen.
Ich meinte ja auch nicht offiziell Verkauf in einer kommerziellen
Beziehung, sondern als Privatsache.
Gleich noch eine Frage: Können die "k" und "m"-Versionen der Firmware
jeweils verschiedene Dinge, oder ist die eine im Funktionsumfang eine
(echte) Teilmenge der anderen? Und zählen ihre Versionsnummern
unabhängig, oder ist die Firmware mit höherer Versionsnummer auf jeden
Fall neuer, egal ob "k" oder "m"?
Lieber Gruß!
[1] Modofiziertes Gerät von "obelix2007":
http://mikrocontroller.net/topic/goto_post/6439712
[2] Verlinkung von
https://www.mikrocontroller.net/svnbrowser/transistortester/:
http://mikrocontroller.net/topic/transistortester-avr?goto=6439712#6440526
[3a] Mikrocontroller.net Artikel "AVR Transistortester":
http://mikrocontroller.net/articles/AVR_Transistortester
[3b] Mikrocontroller.net Artikel "AVR Transistortester", Abschnitt
"Software (deutsch)":
http://mikrocontroller.net/articles/AVR_Transistortester#Software_(deutsch)
[3c] Mikrocontroller.net Artikel "AVR Transistortester", Abschnitt
"Verzeichnisstruktur des Git Archivs":
http://mikrocontroller.net/articles/AVR_Transistortester#Verzeichnisstruktur_des_Git_Archivs
[4] Github-Archiv "/kubi48/TransistorTester-source":
https://github.com/kubi48/TransistorTester-source/
...k und m software sind zwei inhaltlich unterschiedliche branches. Die
restlichen Fragen ergeben sich, wenn man (viel ) liest. Eine
Zusammenfassung wie bei Reklam gibts hier nicht.
Schade.
Wenn Rx/Tx frei sind? Jedoch - wofür? Messdaten loggen? Braucht man eher
selten.
Es ist ein Komponententester. Sonst "bräuchte" man auch eine
Strommessung. Etc. pp.
Sehr schön :)
Kannst du NIEMALS wirtschaftlich abbilden - nichtmals mit wohlwollenden
Verlusten.
GN8, Klaus.
Klaus R. schrieb u. a. im Beitrag #6970565:
Aber eine beispielhafte Dokumentation. Einen guten Einstieg bildet das
neue Repository auf GitHub
> selten.
Zumindest in der k-Version ist eine Ausgabe der Messdaten über die
serielle Schnittstelle, Pin TX möglich, zwecks Dokumentation.
> Holger B. schrieb:
> und was wäre mit allgemeiner Spannungsmessfunktion?
Auch das ist vorhanden.
Sehe ich auch so. Aber die Spannungsmessfunktion ist vorhanden,
allerdings nur in einem festzulegenden Bereich!
Viel Spaß beim Lesen der Doku!
Gruß, derri
Hi!
Da die meisten Fragen schon beantwortet sind, nur ein paar kleine
Ergänzungen. Das SVN ist obsolet. Bei der m-Firmware kann die
TTL-Serielle für verschiedene Funktionen benutzt werden. Da wäre die
Ausgabe der Bauteilesuche parallel zum Display, die Ausgabe der
Bauteilesuche nur über die Serielle (VT100) oder die
Fernsteuerkommandos.
ciao,
 Markus
... der Port PA6 (Pin 31) ist bei Deinem T7 ja noch frei, ebenso hat die
Eingangsschutzbeschaltung DZ1 SRV05-4 noch einen Eingang über. Du kannst
dann ja noch eine weitere Eingangsbuchse vorsehen und in der Software
einen für Deine zu messende max. Spannung geeigneten Spannungsteiler
einstellen. Diese Widerstände müssen dann natürlich auch noch zwischen
GND und Pin 31 bzw. SRV05-4 (wie bei PA0 bis PA2) eingebaut werden.
Schaltplan und die aktuellen Dokus hast Du ja bereits.
Gruß Horst
von Alexander S. (alesi)
> Sache finde.
den Einsprungspunkt (ob übersichtlich oder nicht) hast Du doch selber
als Link angegeben: AVR Transistortester  (ohne Bindestrich, mit
Bindestrich ist die Version von Markus Frejek)
  https://www.mikrocontroller.net/articles/AVR_Transistortester
Unter Downloads (deutsch)
https://www.mikrocontroller.net/articles/AVR_Transistortester#Downloads_(deutsch)
gibt es Links auf die SW auf github.com
  https://github.com/Mikrocontroller-net/transistortester/
und die Dokumentation im pdf
  https://github.com/Mikrocontroller-net/transistortester/raw/master/Doku/trunk/pdftex/german/ttester.pdf
Das Projekt ist recht komplex und eine gute, stets aktuelle Doku
erfordert viel Arbeit.
Danke für die Kommentare,
auch für https://github.com/Mikrocontroller-net/transistortester/.
Wie unterscheided sich das von den Repositories
https://github.com/kubi48/TransistorTester-*? Ist letzteres obsolet und
ersetzt durch ersteres?
Danke auch für den Hinweis auf
https://www.mikrocontroller.net/articles/AVR-Transistortester, bisher
kannte ich nur
https://www.mikrocontroller.net/articles/AVR_Transistortester.
Die PDF-Dokumentation ist ja wirklich sehr schön ausführlich, die will
ich mir auf jeden Fall reinziehen. Da gibt es ja auch die `ttester.pdf`
und die `ctester-*.pdf`. `ttester.pdf` scheint für die `k`-Firmware,
`ctester-*.pdf` für die `m`-Firmware zu sein, oder? Und werden beide
Firmware-Äste noch aktiv gepflegt und weiterentwickelt?
Es gibt doch auch PWM-Ausgang, Frequenzmessung, Infrarot-Sensor. Alles
auch was über "Bauteiltestung" hinausgeht.
... trifft bei beiden FW zu.
Gruß Horst
von Gaßtgeber (Gast)
HILFE, wenn ich mich anmelde ist die Seitenaufteilung des Threads
deaktiviert und ich muss kilometerlangen Thread laden bevor ich
kommentieren kann. Ausgeloggt wird er in 30 Seiten eingeteilt, so ist er
wenigstens handlebar.
Der T4 Tester ist sehr schön, so wies aussieht hat der Chinamann den
Sourcecode genommen verändert und auslesegeschützt auf sein Produkt
geladen. Jetzt ist das Ganze natürlich nicht communitiefreundlich. Wie
wärs wenn man einen Chinamann findet der einem das Teil bastelt, gleich
mit USB Buchse + Programm zum updaten?
https://www.youtube.com/results?search_query=how+to+find+chinese+manufacturer
https://www.youtube.com/watch?v=iH72Invs_gg  Der Kommentar von Karl. Wie
müsste man genau den 3,3V Spannungsregler für den Displaydriver
einbauen?
https://www.youtube.com/watch?v=B9iPQfGv8W0 Firmware wird ausgewechselt
vom T4 Tester.
Der T4 hat keine Kalibrationsmöglichkeit, nur einen Selbsttest. Bei
meinem wird auch keine Version oder sonstiges angezeigt.
von Walter (Gast)
Warum nicht? ISP-Port ist vorhanden, einfach neue Firmware draufflashen.
... also bei mir wird die Aufteilung der Seiten (30) benutzt und ich bin
immer "eingelogt".
Gruß Horst
von Jörg S. (profjs)
über dem Chat
Einstellungen -Seitenaufteilung abschalten
dann wird die Aufteilung aktiv
von saeed (Gast)
Hi guys
whats is problem?
Which firmware? How is the error triggered? Some more details would be
helpful.
von saeed (Gast)
saeed schrieb:
> would be
> helpful.
Thanks for follow up.
problem was the avrdudess
Vom T7 gibt es eine neue Variante mit ATmega328 und dem /RESET vom LCD
auf einem separaten Port. Speziell dazu hat jemand die m-Firmware
modifiziert: https://gitlab.com/a11059/t7_328_m.
von Mclute0 (Gast)
I downloaded 1.47m from
(my posting issue from
https://github.com/Mikrocontroller-net/transistortester/issues/7)
(I now question if 1.27m is legitimate as is not on that git)
I am not sure why, but on a new make of 1.46 on GM328A with #define
LCD_ST7735, the English ascii charters are shifted one place so I get
dpnqpofou uftufs
qspcjoh
instead of..
component tester
probing
make of 1.45 in the same environment works without issues on the same
hardware.
Is this something I did wrong? Took me some time to figure out it was
shifted and not coms gibberish.
what is the best way to resolve this to not cause other issues?
von Dieter (Gast)
Vor ungefähr drei Monaten in einem Thread erwähnte ein Postender er
wolle die SW für einen Atmega 328 adaptieren und dann veröffentlichen.
Vielleicht war er es gewesen.
This is caused by an editing mishap in font_10x16_hf.h. Simply replace
the file with the one attached.
Wenn Bedarf besteht, kann ich /RESET über einen separaten Port als
Option in den ST7735-Treiber einbauen. Ich bekomme solche Änderungen bei
den Clones auch erst mit, sobald jemand darüber stolpert und laut
schreit.
von gm (Gast)
Hello,
Ich habe einen chinesischen Klon vom AVR-Transistortest.
Ich weiß nicht, ob dies bereits erwähnt wurde, aber die Zenerdiode (6V),
die mit dem SRv05-4-Schaltkreis verbunden ist, scheint ohne Widerstand
an das VCC angeschlossen zu sein. Ich weiß nicht, ob das normal ist oder
nicht, aber dann wird sie heiß!
Sollte es keinen Widerstand geben?
(Anm.: Übersetzung Deutsch Französisch)
Vielen Dank für Ihre Antworten
cdt
Hallo cdt,
wenn der SRv05-4 Schaltkreis heiß wird, ist wahrscheinlich die interne
Zenerdiode defekt. Bei einer Nennspannung von 6,8V sollte bei 5V
Betriebsspannung kein Strom fließen.
Der SRv05-4 Schaltkreis hat nur eine geringe zusätzliche Schutzfunktion
und kann problemlos entfernt werden. Nach dem Entfernen sollte der
Tester neu kalibriert werden!!
Der Schutz des SRv05-4 Schaltkreises gegen Überspannung besteht über die
Dioden nach GND und VCC. Die Zenerdiode soll nur eine Überhöhung der VCC
Spannung (beim Entladen) verhindern. Die Eingänge des ATmega sind
übrigens auch mit Dioden nach GND und VCC abgesichert. Ich hatte nur die
Hoffnung, daß die Dioden des SRv05-4 Schaltkreises einen größeren
Strompuls aushalten.
Wenn Kondensatoren mit großer Kapazität und erheblicher Restspannung an
den Tester angeschlossen werden, wird in der Regel der ATmega328 und
meist auch der SRv05-4 Schaltkreis zerstört. So ist es immer besser,
einen Kondensator vor dem Anschließen zu entladen. Dann braucht man den
SRv05-4 Schaltkreis nicht.
Grüße,
Karl-Heinz
Vermutlich ist der 5V-Regler geschossen (Crosspost im EEVblog-Forum).
von mclute0 (Gast)
another new clone, this one is round with 2xusb.
https://www.aliexpress.com/item/1005003817143876.html
von Asko B. (dg2brs)
Seid mir nicht böse, bitte!
Aber da hat jemand nicht einfach nur "kopiert".
Sondern sogar ein wenig "Design" hereingebracht.
Da muss man ein wenig Hirnschmalz einbringen!
ICH finds gut. (Meine bescheidene Meinung)
Gruss Asko
von Carsten W. (eagle38106)
Carsten W. schrieb:
> Das hätte als Link völlig gereicht:
> https://www.banggood.com/FNIRSI-DSO-TC2 ...
Danke für den Hinweis. Habe einfach Copy/Paste gemacht und übersehen,
dass in der Mitte der eigentliche Link schon zu Ende ist und nur noch
Parameter folgen.
Gruss, derri
Ist eine neue Variante vom GM328A (AY-AT) mit ein paar Änderungen. Das
LCD hat eine eigene MCU plus Pegelwandler davor (ST7735-Emulator) und
den verdrehten Farbraum BGR (anstatt RGB). Es gibt bereits eine ältere
Variante, die diese ST7735-Emu auf der Displayplatine hat (m-Firmware:
Semi-ST7735). Neu ist ein 74HC164 (serielles Schieberegister). Wenn es
einen Schaltplan gibt, kann ich den Semi-ST7735-Treiber für den 74HC164
erweitern.
Update: Nach dem Tausch des 7550 gegen einen 78L05 läuft der Tester
wieder.
von Alex M (Gast)
Hi! Please find attached a Makefile for the Fish8840 "TFT" tester, the
one with a black case -
https://github.com/Electrobub/TransistorTester/blob/master/Fish8840-Info/Photo/Fish8840TFT(1).jpg
Two minor issues: the only matching display pinout was one of the strip
board layouts, so it triggers that warning, and also the first two rows
of the display are garbled, in part due to
CFLAGS += -DLCD_ST7565_V_OFFSET=-4
Unfortunately the default was cutting off the top of the text, and I had
to arrive at these values through experimentation.
Also please find attached a picture of the tester with an MV2301
varactor under test!
Hi Alex,
cange CFLAGS += -DLCD_ST7565_V_OFFSET=-4
to CFLAGS += -DLCD_ST7565_V_OFFSET=3
Greetings Horst
von Alex M (Gast)
Horst,
Thanks for the quick reply - some more experimentation this morning
resulted in an offset of -1 for a perfect display. Not sure how that was
missed yesterday, oops :)
Here's a corrected makefile with
CFLAGS += -DLCD_ST7565_V_OFFSET=-1
Also changed the font back to 7x12 as 6x8 was a bit difficult to read on
this screen.
Now it looks marvelous and I'm enjoying the additional functionality :)
Also looking through the thread, it seems like I'm the first one to put
this firmware on this particular device?
I do not see any pads for SMD. Can the Fish8840 "TFT" tester only be
used with THT devices?
von Alex M (Gast)
Correct, the tester only accepts devices with pins. For my purposes this
is acceptable.
One more thing I've noticed is this
von Alex M (Gast)
> is this
(whoops, misclicked the Post button too early)
... this firmware doesn't completely power off the device, the display
stays on. Since I'm powering it from an adapter instead of a battery
that's fine, but probably the power-control pinout needs to be corrected
too.
von Alex M (Gast)
One more question: how feasible would it be to add support for detecting
tunnel diodes? I've got some 3I306G parts that show as an unknown
component :)
With the current hardware design the Transistortester can't detect
tunnel diodes. We would need a curve tracer frontend.
von Alex M (Gast)
I see, that makes sense. Thanks again :)
von ponti (Gast)
bagaimana cara kerja alat ini sehingga bisa otomatis membaca
von doschi (Gast)
scheint lt. deepl  Indonesisch zu sein.
-> wie funktioniert dieses Tool, damit es automatisch lesen kann
von doschi (Gast)
von Tomas (Gast)
Hello
Please tell me the fuse bits of maga328 for 8mhz and 16mhz external
crystal
> crystal
https://www.engbedded.com/fusecalc/
You have to select the AVR partname, ATmega328P, the external frequency,
including other timings, and the other non standard settings.
von DiagSoftware (Gast)
Hello everyone, could you help me because I get these errors when
compiling with WinAVR. I've uploaded the entire build to a txt file.
IR_RX.c: In function 'IR_Decode':
IR_RX.c:782: warning: 'Command' may be used uninitialized in this
function
IR_RX.c:781: warning: 'Address' may be used uninitialized in this
function
I want to compile the latest Markus 1.47 update and test it on my Atmega
328
von Fuzzy Star (Gast)
Hello,
I was trying different font files for my tester with ST7108 display and
discovered some issues.
When I tried to compile with "FONT_8X8" There was an error about
language-dependent_characters. Inside the file "8x8_vertikal_LSB_1.h" it
says ' #include "language-dependent_characters" ' but it's missing the
'.h' extension. After correcting it I was able to compile. But I didn't
like the 8-pixel-high character rows touching each other.
I wanted to try another font and I saw there is a '7x8_vertikal_LSB_1'
font file in the fonts folder but it isn't listed in the make file
section:
"If option WITH_LCD_ST7565 is present one of the following fonts should
be choosen."
Then I added "CFLAGS += -DFONT_7X8" to the list and compiled with it and
it works. I liked the font size but I didn't like some characters. So, I
modified the following characters for consistency and my liking:
μ ! " & * / 3 A D G J M Q S \ ^ _ ` f g k m p s t w y
Attached the font file if others would like to use it. Also attached a
comparison photo of the original and modified font on my display.
> function
> function
Those two are just warnings and can be ignored. But the "/usr/bin/sh:
fork: Resource temporarily unavailable" is a problem which can be caused
by several things. The best idea is to search for that specific error.
von Dirk S. (dirksan)
Karl-Heinz K. schrieb im Beitrag
Beitrag "Re: Transistortester AVR":
> Roland B. schrieb:
>> Nun spricht mein TT wiedermit mir- aber nicht sehr lange. Nach Druck auf
>> Test normaler Ablauf, nach etwa 3 Sek. verlischt die Schrift und
>> Hintergrund-
>> beleuchtung bleibt an- erst durch Trennen von Batterie aus.
> Nachdem bei meinem T4 Tester die graphische Anzeige ausgefallen ist,
> habe ich die Software für den T3 und T4 Tester standardmäßig auf "Open
> Collector" Ausgabe der Display-Signale umgestellt.
Kurz zur Situation:
Neulich hat mich das gleiche Schicksal ereilt. Jahre tat der T3/4
klaglos seinen Dienst, dann das oben beschriebene Verhalten. Der Atmega
funktioniert dabei weiterhin. Lediglich das Display friert ein - zwar
provozierbar, allerdings nicht deterministisch. Habe jetzt ein
Ersatzdisplay besorgt und war im Begriff dieses einzulöten.
Hier nun meine Frage:
- Ist obiges Fehlerbild das eines geschädigten/defekten ST7565
Conntrollers
  => Display tauschen und 3,3V Spannungsregler nachrüsten
- oder ist das schlicht die falsche Kombination aus LCD_SPI_OPEN_COL und
PULLUP_DISABLE
  => Konfiguration ändern und neu flashen.
Bevor ich jetzt das Display (ggf. unnötig) tausche oder das Neue auch
ins Jenseits befördere - wäre ich für einen Tip zur Einschätzung der
Lage dankbar.
Unabhängig davon werde ich den Spannungsregler auf jeden Fall
nachrüsten.
PS: Bei der Suche nach einem Ersatzdisplay im asiatischen Onlineshop bin
ich über etliche Rezensionen gestolpert, wo ein Display für den
Austausch bei T3/T4 Testern geeordert wurde ;-)
Grüße,
Dirk
von AdityaWahyuArdiansah (aditya_wahyu_a)
Hallo alle meine Freunde in dieser Gruppe :D
Beste Grüße an uns alle.....
stelle mir einen neuen User aus Indonesien vor..
Gestern habe ich den neusten Typ LCR T4 gefunden.
Vielleicht ist es aus China.
weil ich es vom lokalen Markt in Indonesien bekommen habe.
Auf diesem Board sehe ich ganz anders als der LCR T4 Typ allgemein aus
China..
Es gibt eine neue unterstützende Komponente..
1. Das ist das Auffälligste. Es gibt eine Komponente LMV358. Ich weiß
nicht, wofür es funktioniert.
2. Es gibt USB-Typ-C- und CH340-Treiber mit Paketen vom Typ sop8. es
funktioniert für software upgrade (nicht für stromversorgung)
3. Es gibt eine SMD-Taste. weiß nicht wofür..
4. Im Batterieeingang befindet sich ein SMD-Mosfet ... gekennzeichnet
mit 3401
5. Es gibt eine neue Komponente. mit Markencode 6624. Wahrscheinlich als
Ersatz für tl431. Überprüfen Sie die U4-Komponenten
und in dieser Schaltung verwendet der Transistor 2n3904 (1AM)
Vielleicht gibt es Freunde, die diese neueste Art von LCR
T4-Hardware-Update bereits kennen.
Hier können Sie Ihre Erfahrungen teilen
Nachdem ich nachgesehen habe ... verwendet der Chip Atmega328PU-TH
Die T4 mit der Platine "V4.1.3_2022/5/18" haben wahrscheinlich alle
einen APT32F172K8T6 mit gefälschter Atmel-Beschriftung statt einem
echten ATmega328. Man sieht das an den unterschiedlichen Pins zur
Stromversorgung. Inzwischen sind auch T7 mit dieser MCU aufgetaucht.
Die haben bisher immer die Beschriftung "MEGA328P  U-TH  35473D /
220642H" und werden nicht von den OSHW-Firmwares unterstützt. Auch
sollen die Tester mit APT32F172K8T6 merklich schlechter laufen.
Daneben gibt es Tester mit LGT8F328P, einem ATmega-Clone, der allerdings
mehrere Unterschiede hat. Die gute Nachricht ist, dass jemand angefangen
hat, die m-Firmware dafür anzupassen.
> Conntrollers
Gut möglich. Ob es die zu hohen Spannungen oder Alterserscheinungen
sind, kann ich nicht sagen.
> PULLUP_DISABLE
Für LCD_SPI_OPEN_COL braucht es Pull-Up-Widerstände. Das können die
internen sein (5V) oder externe.
> Lage dankbar.
Eher schwierig. Die Serienwiderstände plus Klemmdioden im LCD-Controller
als Spar-Pegelwandler sind so eine Sache. Dazu kommt dann noch ein
billiges LCD mit Fragezeichen. Die Ideallösung wäre ein Pegelwandler für
alle Signale, z.B. 74HC4050.
Danke für die Antwort, Herr Markus..
möge Gesundheit immer gegeben sein...
Ich bin auch verwirrt, Sir, weil ich überprüft habe, dass sich die
Pinbelegung erheblich vom atmega328 unterscheidet.
am seltsamsten sind die RX- und TX-Pins zur MCU. dies unterscheidet sich
offensichtlich sehr von atmega328
wenn ich mir die Form (das GEHÄUSE) der MCU ansehe, ist sie etwas dicker
als die atmega328. es ist wie bei der LGT MCU..
aber für seine pinbelegung ähnlich wie MCU APT
es riecht jetzt wieder nach vielen ATmega328-Klonen, daher ist es
schwer, den Unterschied zu erkennen, Sir
Markus R. schrieb:
>> Conntrollers
Hallo Markus,
vielen Dank für die freundliche Antwort.
Habe das Problem mit dem Display mittlerweise ausmachen können - es war
ein Haarriss im Flachbandkabel kurz vor dem eigentlichen Display.
Beim Einlöten musste ich dann feststellen, dass ich versehentlich den
falschen Anschluß bestellt hatte. Sollte das ausser mir noch jemandem
passieren (und sei es auch nur wegen Beschaffungsengpässen) poste ich
hier mal ein Bild, wie es dann trotzdem funktionierte ;-) Und ja, das
geht schöner... aber es war halb drei Uhr morgens... ;-)
Grüße,
Dirk
Hello everyone, I bought a lcr t7, inside it, a small battery, my
problem is the following: it does not correctly display the internal
battery voltage, the battery measured it and it is 4.20, but on the
tester, it displays 3 , 55 v, why such a big mistake
von R. H. (snapper)
Hi
At 3,55V you are still quite far ahead ;-)
I can only imagine that it has to do with the value of the R13 1M that
gives the battery voltage to the PC4 of the atmega!
Ahoj,
ich habe [&rarr;&hairsp;diesen modifizierten
T7](/topic/transistortester-avr?goto=6439712#6439712). Nun wollte ich
nach längerer Zeit des Nichtbenutzens damit wieder was messen,
allerdings gibt es folgendes Fehlerbild:
* Nach dem Anschalten im "Automatikmodus" kommt, normal, die Anzeige
  Bauteiltester
  v1.45m
  dann
  Bat 3,67V ok
  Suche...
  und dann nach kurzer Zeit eine Anzeige
  Batterie?
  1: 443mV
  wobei hier die erste Ziffer (meistens ist es 1, manchmal 2, 3 habe ich
noch nicht beobachtet) und die Spannung (ca. zwischen 150 und 500 mV,
meist im 4xx-Bereich)  variieren.
  Daran ändert sich auch nichts, wenn ich einen Widerstand (150 Ohm)
zwischen die Anschlüsse 1-2, 1-3, oder 2-3 tue.
* Im manuellen Modus Zener-Diode an den Anschlüssen "K" und "A"
durchmessen gibt brauchbare Resultate, R oder RCL-Monitor zeigen nichts
an.
* Funktion "Selbsttest", bachdem ich der Aufforderung "Baue
Kurzschluss!" durch kurzschließen von 1, 2 und 3 nachkam, beendet sich
einfach mit "fertig!".
* Funktion "Abgleich", bachdem ich der Aufforderung "Baue Kurzschluss!"
durch kurzschließen von 1, 2 und 3 nachkam, zeigt
  Ri- 19.2&#937;
  Ri+ 23.2&#937;
  C0 34pF
  R0 0.20&#937;
  Vref 1082mV
  Vcc 4769mV *
  AComp 14mV
  *(hatte es inzwischen an externe Stromversorgung angeschlossen, daher
Vcc nun so hoch)* und nachdem ich dann weitergegangen bin
  Fehler!
Hat wer eine Idee, was kaputt sein könnte, sieht das typisch nach einer
bestimmten Art Fehler aus? Ich vermute mal Eingänge des µC kaputt, was
meint Ihr?
Habe das Gerät aufgemacht, sehe (abseits der erwähnten [modifizierten
T7](/topic/transistortester-avr?goto=6439712#6439712)) nichts
auffälliges. Kein loses Kabel, was woanders rantatscht. Schlechte
Lötstelle am Test-Sockel unwahrscheinlich, da das Problem unabhängig
davon ist welche als "1", "2" oder "3" gelabelten Anschlüsse ich nun
nehme.
Gruß!
von M. D. (Firma: Speedlimit) (speedlimit)
> Bat 3,67V ok
Diese Spannung scheint mir etwas niedrig (trotz StepUp?) Wenn du als
Spannungsversorgung einen LiPo hast, sollte der zwischen 3,8V-4,2V
betragen, darunter wäre nicht so gesund, für den LiPo!
Mess mal die Versorgungsspannung (5V) am Mikrokontroller, dann sehen wir
weiter.
Gruß Michael
M. D. schrieb:
> > `Bat 3,67V ok`
Kurz danach war sie auch noch niedriger und wurde als "low"
gekennzeichnet.
Habe dann zum laden angesteckt. War danach auch wieder um die 4V
angezeigt.
Heute wurden dann 3.8V angezeigt, und am Akku direkt 3.78 V gemessen;
ich hatte gestern auch nicht komplett aufgeladen.
Ändert nichts am beschriebenen Problem.
> Wenn du als
4.95V mit meinem Schätzeisen gemessen (die 0.05V sind auch gut im
Toleranzbereich des multimeters)
> dann sehen wir weiter.
OK!
P.S.: Kann mir wer erklären, warum in der Vorschau dieses Forum
Markdown-Formatierungen nimmt, im fertigen Beitrag dann aber der
Quelltext dasteht anstatt dass Mardown gerendert wird?
Holger B. schrieb:
>   Batterie?
>   1: 443mV
... zu dieser Anzeige kann es kommen, wenn ein angeschlossenes Bauteil
(Kondensator) nicht weit genug entladen wird. Standardmäßig ist diese
Schwelle auf 2mV festgelegt. In der KH-Software andert man das hier:
"CAP_EMPTY_LEVEL Diese Option legt die Spannung (mV) für einen
entladenen Kondensator fest. Der Wert kann höher als 3mV gesetzt werden,
wenn die Entladung nicht zum Ende kommt.
In diesen Fall meldet der Tester nach längerer Zeit „Cell!”.
Beispiel: CFLAGS += -DCAP_EMPTY_LEVEL=3"
Bei der M-Software hier:
"4.4. Bauteile entladen
Der Tester versucht vor und während des Messens das angeschlossene
Bauteil zu entladen. Wenn er das Bauteil nicht auf einen vorgegebenen
Nullwert ( CAP_DISCHARGED) entladen kann, gibt er einen Fehler mit
Angabe des Testpins und der Restspannung aus. Im Fall einer Battery
entspricht die angezeigte Spannung nicht der Batteriespannung. Die
Entladefunktion basiert nicht auf einem festen Timeout, sondern passt
sich automatisch dem Entladefortschritt an. Auf diese Weise wird eine
Batterie schneller erkannt und große Kondensatoren erhalten mehr Zeit
zum Entladen. Sollte ein großer Elko als Batterie erkannt werden, bitte
nochmal versuchen. In einer Umgebung mit vielen elektrischen Störungen
könnte auch der Nullwert CAP_DISCHARGED mit 2mV zu niedrig sein (ggf.
anpassen). Die anzeigte Restspannung hilft beim Finden des optimalen
Nullwertes."
Diese Anzeige hat nichts mit dem Ladezustand des eingebauten Li-Accus in
Deinem Tester zu tun.
Ev. mal C19 wechseln?
Gruß Horst
Andere mögliche Ursachen sind:
- MCU-Pins durch geladenen Elko gegrillt
- Verschmutzung (kommt öfter vor als man denkt)
- instabile 5V
Übrigens gab es in der 1.44m eine kleine Änderung bei der
Endladefunktion:
Bei einem Entladeproblem wird nun die unbelastete Spannung des DUTs
gemessen und von der Entlade-Fehlermeldung angezeigt, z.B. die
unbelastete Spannung einer Batterie.
von Derri (Gast)
Formatierungen sind nicht im gängigen Markdown anzugeben, sondern nach
der Anleitung in "Antwort schreiben" > "Formatierung" (*mehr
Informationen...*)!
Derri
obelix2007 schrieb:
> >   Batterie?
> >   1: 443mV
Kommt auch ohne Bauteil oder mit Widerstand oder mit Kurzschluss. Und ob
da Widerstand oder kein Bauteil oder Kondensator drinsteckt hat keinen
merkbaren Einfluss auf den angezeigten Wert (er ist eh jedes Mal anders,
im wenige-100-mV-Bereich, und das unabhängig davon was drinsteckt).
> Diese Anzeige hat nichts mit dem Ladezustand des eingebauten Li-Accus in Deinem
Tester zu tun.
Ist es die Spannung, die am Testpin gemessen wird?
Wozu ist C19 da? Im
[Schaltplan](/attachment/575725/LCR-TC1_T7_M644_.png) hängt C19 an einem
Pin des µC, und über einen 470k-Widerstand (R15) an einem anderen Pin
des µC. Ansonsten sind diese beiden Pins mit nichts weiter beschaltet.
Ist C19 eine Kapazitätsreferenz/ sind R15+C19 als RC-Glied eine
Zeitreferenz für irgend etwas?
Im Foto Deiner Modifikation (von
[hier](/topic/transistortester-avr?goto=6439712#6439712) genommen) sehe
ich da noch einen weiteren Widerstand, der mit eine Rolle spielt.
Ich habe Dein Foto annotiert -- siehe Anhang zu diesem Beitrag. -- sind
C19 und R15 in meiner Kommentierung richtig zugewiesen oder ist R15
(immernoch, entsprechend Platinenbedrucking) das Bauteil was ich mit
"??" bezeichnet habe? Was ist der zweite Widerstand, womit ist der
Verbunden -- laut Schaltplan sollten nur ein Widerstand und ein
Kondensator da sein.
Auf jeden Fall ist bei mir an der Stelle tatsächlich was kaputt:
Der bedrahtete Widerstand und der bedrahtete Kondensator sind beide von
den SMD-Lötpads losgerissen. Der mit "??" bezeichnete Widerstand ist
nicht mehr da.
Kann ich also einfach wieder festlöten! Bevor ich das mache: Gehört der
470k-SMD-Widerstand da auch wieder hin (wie auf Deinem Foto zu sehen),
oder nicht (wie es nach Schaltplan der Fall wäre?) -- Den würde ich
nämlich sonst zuerst hinlöten.
> In einer Umgebung mit vielen elektrischen Störungen könnte auch der Nullwert
CAP_DISCHARGED mit 2mV zu niedrig sein (ggf. anpassen).
Interessant ist, dass in gleicher Umgebung der Fehler vorher nicht
aufgetreten ist.
Ohne Firmware-Neukompilierung lässt sich, ob "Umgebung mit vielen
elektrischen Störungen" zutrifft, nur testen durch Testen in
störungsarmer Umgebung, oder?
Könnte der integrierte Step-Up-Wandler, der aus der Spannung des
LiIon-Akkus 5V macht, mit der Zeit so störend geworden sein dass es
plötzlich den Fehler triggert? Kann der angezeigte Spannungswert eine
solche Störung ausschließen (was bedeutet "443 mV")?
Danke übrigens für die Ausführungen!
> Informationen...*)!
Dann sollte aber die Beitragsvorschau nicht das Markdown
fälschlicherweise rendern, wenn es im fertigen Beitrag nicht der Fall
ist. Wäre schön wenn die Vorschaufunktion mit der Realität konsistent
werden würde (Hinweis falls hier ein Admin mitliest).
Hallo Holger,
... bei den 3 Testern (TC1, T7, T7-H), die ich umgebaut habe war der C19
immer knapp an der Kapazitätsgrenze > 100 nF. Die Firmware der Chinesen
hat sich nicht darum gekümmert, aber um die kh-Software oder die
m-Software darauf laufen zu lassen, habe ich C19 jeweils auf 220nF
Folientyp getauscht. Dabei ist auch R15 mit gewechselt worden.
Diese Beschaltung wird zum Autoabgleich benötigt.
Der „alte“ R15 ist da nicht mehr drin, und wenn, so dient er einseitig
als „Lötstütze“.
Falls C19 und R15 keinen Kontakt mehr zu Pin 25,30 und GND haben,
solltest Du den wieder laut Schaltplan so herstellen.
Gruß Horst
von Frank O. (frank_o)
Moin Forum!
Hab schon länger keinen mehr gekauft und auch nicht gelesen.
Ist vielleicht jemand so freundlich und schreibt mir kurz den letzten
Stand und wenn ihr ganz nett seid, auch einen Link dazu, bei ebay.
Vielen, lieben Dank!
Horst O. schrieb:
> Falls C19 und R15 keinen Kontakt mehr zu Pin 25,30 und GND haben, solltest Du
Habe ich gemacht (und per Multimeter nachgeprüft), ändert nichts am
Fehler. Es könnte sein dass die erst abgegangen sind nachdem ich wegen
des Fehlers das Gerät öffnete, und es dann eine Weile offen rumlag, ggf.
eine Scherkraft auf C19 erfahren hat.
D.h. für einen möglichst guten Autoabgleich müssten dann die Werte von
R15 und C19 möglichst gut ausgemessen und in die Firmware eingetragen
werden, damit die Referenz stimmt, richtig?, oder dient das nur als
Spannungspuffer und nicht als Zeitglied/ Kapazitätsreferenz?, oder wie
wird die Beschaltung genau verwendet?
Was ich jetzt beim durchmessen rausgefunden habe: Test-Anschluss 1 (also
direkt am Sockel) ist mit 16 Ohm nach Masse verbunden. Test-Anschluss 1
liegt ja auch direkt an Pin 37 des µC an. Das spricht für kaputten Pin
am µC, oder?
Im angeschalteten Zustand messe ich dort 472 mV, während die Anzeige
"466 mV", aber auch, wenn sie "363 mV" sagt.
Und dabei auch eine weitere Beobachtung: Die Anzeige ist immer um die
460..470 mV wenn Test-Anschluss 1 offen ist. Erst wenn ich an
test-Anschluss 1 was anschließe (z.B. einen Widerstand oder Draht nach
Test-Anschluss 2), variiert die Anzeige (nicht aber die per Multimeter
gemessene Spannung an Anschluss 1).
Wenn ich Test-Anschluss 1 direkt nach Masse kurzschließe dann erkennt
das Gerät etwas (einen N-Kanal FET mit Drain an 1, Source an 2, Gate an
3)
Habe mal am Sockel gewackelt und reingepustet, nicht dass dort irgendwo
was einen fast-Kurzschluss macht.
Hast Du Deinen Schaltplan eigentlich auch als Originaldatei? (Du hattest
mal eine JPEG-Datei eingestellt, jetzt eine PNG-Datei die
augenscheinlich aus JPEG erstellt wurde (jedenfalls sind auch da
deutliche Artefakte sichtbar), zum Weiterarbeiten ist eine Vektorgrafik
oder die Schaltplan-Erstellungs-Software-Datei gut.) Ich will meine
Modifikation (physischer Aus-Schalter) mit einarbeiten.
Ich habe noch ein paar andere Fragen zur Schaltung, die mir bei genauem
Hinsehen kamen:
* Im Schaltplan gibt es einen IC U4, Typ STC15L104W. Dies ist auch
irgend ein Mikrocontroller wie ich rausfand. Aber wo ist der auf der
Platine? Bin ich blind?
  Ich sehe einen unbestückten Platz, markiert mit U4 da, wo Deine kleine
blaue Platine mit dem BC557B und dem BC550B-Transistor und vier
Widerständen und zwei Dioden und einem 220nF-Kondensator ansetzt. Hast
Du beim Umbau den U4 entfernt und durch erwähnte Platine ersetzt (es
sieht so aus, als war da mal was angelötet)? Wenn ja, hast Du davon die
korrekte Schaltung, ohne den nicht mehr vorhandenen STC15L104W?
* Schaltregler U5, ein AK619: Ich wollte mal ein Datenblatt dazu finden
wurde aber nicht fündig. Hat wer eines dazu?
* Akku-Laderegler U6, ein 57b4: Ich wollte mal ein Datenblatt dazu
finden und fand dazu [diesen
Thread](https://www.eevblog.com/forum/projects/help-identifying-ic-131357/).
Demnach sei das ein TP4057, für den es nur chinesische Datenblätter gebe
(ich habe auch nichts anderes gefunden). Hat wer zufällig doch ein
Englisches Datenblatt für genau diesen IC?
> am µC, oder?
... die Widerstandsmessung der Testeingänge liegt bei ca. 55kOhm,
Ohmmeter mit Minus an GND und bei ca. 40kOhm mit Ohmmeter Plus an GND.
Scheint der Eingang Deines T7 ist wohl mal gegrillt worden.
Gruß Horst
.. ich könnte also versuchen, Pin 37 vom µC abzuklemmen und
Test-Sockel-Anschluss 1 auf einen noch freien Analog-Pin des µC zu
legen, z.B. Pin 31, und in der Firmware die Pinbelegung zu ändern.
Sollte gehen, falls der Schaden im µC auf diesen Pin beschränkt ist,
oder?
Warum sind Pin 37, 36 und 35 eigentlich direkt ohne einen
Schutzwiderstand mit dem Testsockel verbunden? Was geht schief, wenn man
einen Widerstand in die Leitung baut (so dass die µC-Internen
Schutzschaltungen es leichter haben), oder, wenn man wirklich "Power"
braucht, einen Booster dahinterschalten? (Ist der Pin als Eingang oder
als Ausgang definiert?)
Hast Du noch eine Antwort zu meiner Frage nach U4?
Ich schaue gerade in das Repository der "m"-Firmware und lese die
README.
Gruß!
... das kann ich mir gerade selbst beantworten durch die [Doku der
"k"-Firmware](https://github.com/madires/Transistortester-Warehouse/blob/master/Documentation/German/ttester-1.13k.Bohu.pdf).
Der Pin wird sowohl als Ausgang als auch als Eingang verwendet.
"Verbesserung" hinsichtlich µC-Schonung wäre hier wohl nur möglich durch
Hinzufügen eines externen Boosters gesteuert durch einen 4. µC-Ausgang,
und den zuerst genannten Pin über einen z.B. 100-Ohm-Widerstand an den
Ausgang des Boosters anzuschließen und als reinen Eingang zu verwenden.
Würde vier statt drei µC-Pins pro Test-Anschluss bedeuten.
von Mark S. (voltwide)
Zwischenfrage: Angenommen, man druckt diesen thread auf Endlospapier
aus. Wie oft würde könnte man dann das dann um den Äquator wickeln?
Deshalb habe ich ja gebeten, das mich jemand auf den aktuellen Stand
bringt. Welcher ist der aktuelle TT bei den Chinesen?
> oder?
... ist bestimmt 'nen Versuch wert.
Zu U4:
Es handelt sich hierbei um einen zusätzlichen Microcontroller, der für
das Starten des Programms genutzt wird und nach der Messung zur
Festlegung der Abschaltzeit. Es gibt im Netz Anleitungen zum
Umprogrammieren.
Für mich ist es einfacher, die kleine blaue Lochraster-Platine (TC1-Mod,
Lösung von Markus) zu bauen und stattdessen einzusetzen.
Gruß Horst
von R. H. (snapper)
>R. H. schrieb
Vielen Dank!
Ahoj,
ich bin ja echt erstaunt wie durch klevere Messmechanismen man doch so
schön Analogbauteile messen kann mit einem Chip, der eigentlich nicht
dafür geeignet ist ;-). Fehlt nur noch Kennlinienaufnahme.
Und wäre mal interessant, dieses Projekt mit einer aktuellen
Mikrocontrollerfamilie ([RP2040](https://en.wikipedia.org/wiki/RP2040)?,
die sind auch sehr billig, unter 5 EUR auf einem kleinen Breakout-Board
mit USB und Spannungsregler, Chip an sich noch billiger) zu realisieren,
oft lese ich in der Doku dass das Timing begrenzend sei, da würde was
schnelleres sicherlich helfen.
In der `README.de` der
["m"-Firmware](https://github.com/madires/Transistortester-Warehouse/raw/master/Firmware/m-firmware/ComponentTester-1.47m.tgz)
sowie in der [Dokumentation zur
"m"-Firmware](https://github.com/madires/Transistortester-Warehouse/raw/master/Documentation/German/ctester-1.47m.pdf)
stehen einige Hardware-Erweiterung zur Grundschaltung.
Der Schaltplan der Grundschaltung ist in der [Dokumentation zur
"k"-Firmware](https://github.com/madires/Transistortester-Warehouse/raw/master/Documentation/German/ttester-1.13k.Bohu.pdf)
gegeben, sowie der Schaltplan von ein paar Hardware-Erweiterungen.
Aber nicht von allen!
In der Dokumentation zur "m"-Firmware sind die Schaltpläne nicht
gegeben.
Wo bekomme ich die Schaltpläne her? Ich habe gerade Inspiration selbst
zu basteln.
Konkret handelt es sich um:
* L/C-Meter (auf Oszillatorschaltung beruhend)
  Es steht was von "LM311-basierter Oszillatorschaltung" im Fließtext.
  -> Wie sieht sie aus, wie wird sie genau angekoppelt/ angesteuert?
* Klingeltester
Hat jemand Schaltpläne dazu?
(Hardware-Erweiterungen, die nur direkten Anschluss an µC brauchen (und
das aus der Doku für mich so klar erkennbar war), habe ich hier
ausgelassen.)
Vorhanden in der Doku der "k"-Firmware sind Schaltungen für:
* Eingangsschutz per Relais oder Dioden
* Zenerspannungsmessung
* Frequenzgenerator
* Frequenzzähler
  - Variante mit Frequenzteiler
* Quarztestung
* Impulsdrehgeber
* Graphisches Display (monochrom/ Farbe)
Lieber Gruß!
Danke.
Meinst Du das?:
https://github.com/madires/Transistortester-Warehouse/raw/master/Hardware/TC1-Mod.pdf
Hast Du die (Vektor-/ Schaltplaneditier-)-Datei des Schaltplans, den Du
hier eingestellt hast? Da ist U4 nämlich noch drin und Deine blaue
Platine nicht. Würde gerne den "ist"-Status auf Schaltplan haben und,
wenn Du das nicht selber hast, selbst noch machen.
Und C19, wozu ist der gut? Ist das ein Spannungspuffer für den in der
Doku erwähnten Abgleich des internen Komparators?, und der exakte Wert
von R15 und C19 ist nicht wichtig?
Holger B. schrieb:
> Wo bekomme ich die Schaltpläne [für Klingeltester und L/C-Meter] her?
[Erledigt](https://github.com/madires/Transistortester-Warehouse/tree/master/Hardware).
@Moderation: Bitte meinen Beitrag #7250821 löschen, er ist obsolet.
Ich bin, nach lesen der Doku, übrigens echt erstaunt wie durch klevere
Messmechanismen man doch so schön Analogbauteile messen kann mit einem
Chip, der eigentlich nicht dafür geeignet ist ;-). Fehlt nur noch
Kennlinienaufnahme.
Hallo Holger,
... bevor Du jetzt das Rad neu erfindest - hast Du beim vorliegenden T7
mal Pin 37 mit 31 getauscht oder ist das Projekt bereits abgeschrieben?
Gruß Horst
Auch wenn Du inzwischen einen Link gefunden hast. In der zuvor genannten
Doku
https://raw.githubusercontent.com/madires/Transistortester-Warehouse/master/Documentation/German/ctester-1.47m.pdf
steht auf Seite 27 "Das L/C-Meter basiert auf einer einfachen
LC-Oszillatorschaltung, welche von mehreren preiswerten PIC-L/C-Metern
benutzt wird." Mit Suche nach "lc meter lm311" erhälst Du viele Links
auf die vielen LM311 basierten LC-Meter, z.B.
https://sites.google.com/site/vk3bhr/home/lcm1
https://www.schiessle.de/emt1/MessKleinKap/MessKleinKap1.htm
https://www.sprut.de/electronic/pic/projekte/lcmeter/lcmeter.htm
http://www.kerrywong.com/2010/10/16/avr-lc-meter-with-frequency-measurement/
Nachtrag: Vom "Surprisingly Accurate Digital LC Meter" von vk3bhr gibt
es auch eine zweite Variante, die, an Stelle des LM311, den internen
Komparator des PICs verwendet:
https://sites.google.com/site/vk3bhr/home/index2-html
Die Verwendung des internen Komparators (vom ATmega328) würde eher der
Philosophie des Transistortesters entsprechen, möglichst viel im
Mikrocontroller zu machen, mit wenigen externen Bauelementen. Der
Komparator wird allerdings bereits für die Kapazitätsmessung verwendet.
Noch nicht. Das eine ist Unabhängig vom anderen (Hardware-Erweiterungen
kann ich ja auch noch nachrüsten, da es ja noch freie Pins gibt, ich
denke an Ansteckmodule :-), und RP2040-Entwicklung habe ich nicht vor,
war nur eine allgemeine Idee).
Bin gerade am Konfigurieren der Firmware (muss ja den Pin
umkonfigurieren), und da nehme ich die aktuelle m-1.47.
Ich brauche weiterhin die Antwort auf die Frage, wozu C19 ist, um zu
wissen ob und wie ich `#define HW_ADJUST_CAP` und
#define ADJUST_PORT      PORTA     /* port data register */
#define ADJUST_DDR       DDRA      /* port data direction register */
#define ADJUST_RH        PA7       /* Rh (470k) for fixed cap */
setze.
Und: Was für ein Display ist da angeschlossen -- ich lese "Z180SN009" in
Deinem Schaltplan, aber den String "180SN" und auch "Z180" finde ich
weder in einer `config.h`/ `config_<MCU>.h`, noch in der `README` oder
in der PDF-Doku. Was muss ich da auswählen?
Der Rest scheint mir erstmal durch direkte Dokumentation oder Heuristik
eingänglich, ich berichte.
Horst O. schrieb:
> hast Du beim vorliegenden T7 mal Pin 37 mit 31 getauscht
Scheint nicht so einfach zu sein -- in der `config_644.h` steht
> Lower 3 pins of the port must be used for probes.
Pin 31 ist der Pin "PA6", das ist nicht einer der unteren 3 (PA0, PA1,
PA2).
Noch Ideen?
wenn Du die config_644.h öffnest, welche bei den mitgelieferten
Unterlagen beim Kauf des T7 dabei war, so erkennst Du anhand des
auskommentierten //#if 0 und //#endif, das hier ein ST7735 zum Einsatz
kommt.
Horst
Holger B. schrieb:
> ich berichte.
Wollte gerade die Firmware übersetzen; ein Aufruf von `make` gibt
folgenden Fehler:
avr-gcc -mmcu=atmega644 -Wall -I. -Ibitmaps -DF_CPU=16000000UL -DOSC_STARTUP=16384 -gdwarf-2 -std=gnu99 -Os -mcall-prologues -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT main.o -MF dep/main.o.d -c main.c
In file included from main.c:27:
functions.h:509:15: error: conflicting types for 'PWM_Tool'; have 'void(void)'
  509 |   extern void PWM_Tool(void);
functions.h:505:15: note: previous declaration of 'PWM_Tool' with type 'void(uint16_t)' {aka 'void(unsigned int)'}
  505 |   extern void PWM_Tool(uint16_t Frequency);
make: *** [Makefile:209: main.o] Error 1
Da scheinen Datentypen nicht zusammen zu passen.
Ich kenne mich mit C/ C++ kaum aus und traue mich nicht, da was zu
reparieren. Sind ggf. irgendwelche
Rückwärts-Kompatibilitäts-Kompileroptionen nötig? (Ich kenne mich auch
mit Kompilereinstellungen kaum aus.)
Systeminformationen:
* `avr-gcc --version | head -n1`: `avr-gcc (GCC) 12.2.0`
* `avr-ld --version | head -n1`: `GNU ld (GNU Binutils) 2.39`
  (und andere `avr-binutils`-Teile auch Version 2.39.)
> kommt.
Ah OK, danke. Ich tue mich immer etwas schwer, wenn Dokumentation
"verstreut" ist, und da ich "zentrale Doku" (PDF-Doku zur k- und
m-Firmware, Readme in der m-Firmware) gefunden hatte kam ich nicht mehr
auf die Idee, dass auch da noch was an Informationen rumliegt.
Tut mir leid für die Frage.
Das ganze als Fehler dort reported:
http://mikrocontroller.net/topic/545930
Holger B. schrieb:
> Noch Ideen?
ersetze PA0 durch PA6, Versuch macht Klug. Wenn `s nicht geht, musst Du
halt den Controller tauschen.
Horst
> 'void(void)'
> [/code]
Du hast SW_PWM_SIMPLE und SW_PWM_PLUS aktiviert. Bitte nur einen von
beiden auswählen! Da muss ich wohl noch eine entsprechende Überprüfung
ergänzen.
> beiden auswählen!
OK, danke. Ich verstand die Doku so, dass `SW_PWM_PLUS` eine Option ist
die `SW_PWM_SIMPLE` vorraussetzt.
Ja, baut jetzt erfolgreich :-).
Dann werde ich einfach mal testen, ob ich trotz
den PA6 nutzen kann durch einfache Definition in der `config_644.h`.
Sonst baue ich glaube ich wirklich mal einfach meinen eigenen Tester,
mit ATmega644 im DIP-Gehäuse oder ATmega1280 auf Arduino-Platform
(Bequemlichkeit), und recycle ein paar Bauteile vom vorhandenen T7.
OK, habe den direkten Anschluss von Testpin 1 vom µC-Pin 37 (PA0) zum
µC-Pin 31 (PA6) verlegt.
Ich habe dann erstmal das 1.45m-Firmware-Archiv von obelix2007 genutzt
was mit dem Gerät kam, und habe alleinig
#define TP1              PA0       /* test pin / probe #1 */
geändert zu
#define TP1              PA6       /* test pin / probe #1 */
make clean
make
make fuses
make upload
lief erfolgreich durch.
Nun startet der Tester mit der gleichen Fehlermeldung, allerdings ist
die angezeigt Spannung im 1-2 Volt-Bereich:
Batterie?
1: 1310 mV
(Auch mal im Bereich 15xx mV).
Auch wenn ich Testpin 1 mit Testpin 2, 3 oder GND verbinde.
Kann es sein, dass hier
zuschlägt, oder wäre das Symptom dann anders?
Weiß jemand ob:
Ist das durch eine einfache Änderung im Code umgehbar?
Um das Gerät noch zu Dingen wie ESR-Abschätzung zu verwenden, dachte ich
mir dann tausche ich die Definitionen von Testpin 1 und Testpin 2 (so
dass, für die Software, Testpin 2 der problematische wird, und die
"Spezialmessungen" an 2-poligen Bauteilen, die ja Testpin 1 und Testpin
3 wollen, weiterhin gemacht werden können).
Nun habe ich in der `config_644.h` einfach folgende defines getauscht:
* `#define TP1` und `#define TP2`,
* `#define R_RL_1` und `#define R_RL_2`,
* `#define R_RH_1` und `#define R_RH_2`.
Auch nach diesem Tausch (make clean, neu kompliliert, neu geflasht)
kommt noch die Meldung "Batterie?" mit Testpin 1(!).
In der `config_644.h` steht auch
> Please don't change the definitions of TP1, TP2 and TP3!
Kann es sein, dass man die gar nicht vertauschen kann?, kann es sein,
dass TP1 immer am niedrigsten Pin des gewählten Ports ist?
(Dass ich die richtige Datei bearbeite und das Flashen geht, habe ich
geprüft in dem ich einfach mal `#define TP_REF` und `#define TP_BAT`
getauscht habe und die Batteriespannungs-Anzeige beim startup dann eben
~2.5 V war.)
Es zeigte sich übrigens, dass das Problem wo anders war:
Als ich den µC-Pin 37 abgesäbelt hatte, gab es immernoch die ca. 15 Ohm
von Testpin 1 nach GND. Es zeigte sich, dass das Problem in der
Schutzdiodenschaltung DZ2 lag. Als ich den Pin von DZ2, der zu Testpin 1
gehört, abgesäbelt hatte, war Testpin 1 wieder hochohmig nach GND. Nun
war der µC-Pin 37 allerdings schon weg ... also dennoch Testpin 1 mit
µC-Pin 31 verbunden, neue Schutzdioden (2x BAT43) an Testpin 1, und
Firmware wie oben beschrieben geändert und beschriebenes Resultat
gesehen.
Theoretisch sollten sich die Testpins (TP1-3) ändern lassen. Irgendwann
hatte ich die feste Zuordnung im Source durch eine flexible ersetzt,
aber bisher nicht  mit anderen Pin-Zuordnungen getestet (alle Tester
haben die Testpins immer auf den ersten drei Pins vom Port).
Scheint nicht zu gehen:
http://mikrocontroller.net/topic/transistortester-avr?goto=7251267#7251267
von Horst O. (obelix2007)
... hast Du allen Ernstes den Pin direkt am Gehäuse „abgesäbelt“ - da
durchtrennt man doch zuerst die zugehörige Leiterbahn!
Beitrag #7251414 wurde vom Autor gelöscht.
Habe es gefunden! In DischargeProbes() müssen noch zwei ReadU()
angepasst werden. Aus
... = ReadU(ID);
wird
... = ReadU(DATA_read_byte(&Channel_table[ID]));
... = ReadU(ID);
> wird
Ich bestätige Funktion (mit der 1.45m-Version von obelix2007) (getestet
ohne Bauteil und mit 270nF-Kondensator an Pin 1 und 3) (-:!
Diff der `probes.c`:
--- probes.c.orig  2022-11-13 22:03:40.858712029 +0100
+++ probes.c  2022-11-13 22:18:56.588683384 +0100
@@ -366 +366 @@
-    U_c = ReadU(ID);                    /* get voltage of probe */
+    U_c = ReadU(DATA_read_byte(&Channel_table[ID])); /* get voltage of probe */
@@ -415 +415 @@
-      Check.U = ReadU(ID);              /* get and save voltage */
+      Check.U = ReadU(DATA_read_byte(&Channel_table[ID])); /* get and save voltage */
.. dann heißt es für mich jetzt schauen, warum die 1.47m nicht will
(Display bleibt weiß), und schauen welche Erweiterung(en) ich noch
basteln mag (macht spaß) :-)
... hast Du die Portbelegung des ST7735 angepast? Die Standard-Belegung
in den Config-Dateien von Markus ist anders. Du musst die mitgelieferte
Datei als Vorbild nehmen und die Belegung von dort übernehmen!
Es sind noch zwei weitere Änderungen notwendig. In CheckProbes() von
U_1 = ReadU_5ms(Probe2);            /* get voltage at collector */
zu
U_1 = ReadU_5ms(Probes.Ch_2);       /* get voltage at collector */
und von
U_1 = ReadU_5ms(Probe1);               /* get voltage at collector */
zu
U_1 = ReadU_5ms(Probes.Ch_1);          /* get voltage at collector */
Das sollte es gewesen sein, um die drei Testpins ändern zu können. Kommt
alles in die nächste Version.
Horst O. schrieb:
> Du musst die mitgelieferte Datei als Vorbild nehmen
Da habe ich tatsächlich noch an einer Stelle was übersehen.
Holger B. schrieb:
> Hast Du [@obelix2007]Deinen Schaltplan eigentlich auch als Originaldatei?
> (Du hattest mal eine JPEG-Datei eingestellt, jetzt eine PNG-Datei die
Da von Dir keine Antwort dazu kam gehe ich davon aus, dass Du das nicht
hast.
Ich habe daher jetzt mit Kicad den Schaltplan neu gemacht.
Basis: Deine PNG-Datei [1], die "TC1-mod.pdf" [2], und mein Gerät bei
dem ich eine andere Beschaltung des Encoders feststellte (10k statt 1k
Widerstände; PD6 statt PD7.)
Ist angehangen.
Schau' doch bitte mal drauf ob das korrekt ist, oder ob da andere Sachen
grob ungut sind, bevor ich das einem Repository hinzufüge.
[1] Schaltplan T7 von "obelix2007":
https://www.mikrocontroller.net/attachment/575725/LCR-TC1_T7_M644_.png
[2] Power-Controller-Modifikation am TC-1:
... Du hast Pin 1 und Pin 3 des ZIF-Sockels kurzgeschlossen, Pin 3
gehört an Pin 4 oder 1 von DZ2! Den Rest habe ich nicht geprüft, mir
reichten die PNGs.
Horst
Oh, das hat Kicad gemacht, vermutlich bei einem Verschiebevorgang. Ich
habe eine andere Führung vor dem Inneren Auge. (Zum Verschieben bereits
vorhandener Schaltungselemente finde ich Kicad sehr nervig.)
V.A. Check, ob ich Deine Modifikationen korrekt und vollständig
wiedergegeben habe, ist Kern meiner Bitte. Schließlich sind Deine
Modifikationen ja nicht (komplett) in der von Dir geteilten Datei, kann
gut sein dass ich beim Versuch, das in einen Schaltplan
zusammenzu"kompilieren" was grundsätzlich falsch gemacht habe.
... nimm einen Durchgangstester und prüfe die Verbindungen. Schließlich
hast Du ja den Tester bei Dir. Im übrigen waren die Pläne der
Ausgangspunkt der Modifikationen und es sind meine Änderungen nicht in
den Plänen, die von Indman im eevblog veröffentlicht wurden.
> Im übrigen waren die Pläne der Ausgangspunkt der Modifikationen und es sind
meine Änderungen nicht in den Plänen, die von Indman im eevblog veröffentlicht
wurden.
Achso. Ich dachte bis eben diese Datei käme von Dir, weil Du sie immer
einfach mit Deiner modifizierten Variante mitgeliefert/gepostet hast.
Das ändert natürlich sehr meine Prämissen zu diesem Thema und macht
klar, dass Du nicht Ansprechperson zu diesem Schaltplan bist.
Danke für die Klärung wie die Informationen zusammengehören!
Ich habe jetzt durchgemessen und noch einige Abweichungen festgestellt
(und einen Fehler meinerseits).
Anbei nun ein Schaltplan, mit dem sich denke ich arbeiten lässt.
Falls interesse besteht dass das Eingang in die Doku findet (ist das
relevant?): Wo liefere ich das am besten ab/ bei welchem repository
checke ich das am besten ein?
https://github.com/madires/Transistortester-Warehouse/, oder wo anders?
Ich würde dann noch einen Text Metainformationen dazuschreiben.
Gruß!
... habe noch einen Fehler gefunden:
Du hast R13 und R14 vertauscht!
Gruß Horst
... im Übrigen, von den TC1 und T7 gibt es so viele Variationen und
"Fakes", da ist der Überblick schwer.
Die bei den versch. Quellen angebotenen Nachbauten haben alle keinen
Atmega644 eingebaut, so dass Deine Dokumentation hier nicht viel bringt.
Die paar Umbauten von mir und Indmann sind ja auch schon bestens
Dokumentiert. (siehe aktuelle Clone-Comparison-Chart.pdf)
Gruß Horst
von andy171 (Gast)
Hallo an Alle,
Ich versuch gerade dieses Display (im Anhang) zum laufen zu bringen,Ich
hab es so angeschlossen wie in der Doku 1.13 K von K.H.nach Bild 2.12
mit HC164.
Die Schaltung für den 328P hab Ich schon lange am laufen mit 2004
Display, nur jetzt gelingt es mir nicht mit dem 128x64 Display.
Grüße Andreas
von andy171 (Gast)
Hallo nochmal!
Ich hab das mit dem Display gelöst!
Hatte einen Fehler beim erstellen der Files, ich hatte die Polarietät
des Displays auf Low.
Grüße Andreas
... zeige uns doch mal ein Bild von Deinem Selbstbauprojekt?
Gruß Horst
von andy171 (Gast)
Hallo !!!
Jetzt mal die Bilder von mir, Ich nehme fürs kombilieren ein Raspberry
Pi3.
Zum Programmieren bzw. flashen soll es auch noch das Raspi werden,
aktuell nehme ich zum flashen Atmel studio 7, STK500 und Win 10.
Meinen Alten hab Ich schon ein paar Jahre, so genau weiß ich das nicht
mehr.
Die auf dem Foto zu erkennende Platine ist auch in etwas verbesserter
Variante in meinem Alten drinnen.
Auf meiner Platine ist auch eine Ladungspumpe verbaut (ICL7660), wegen
der alten Displays 1602 und 2004.
Freundliche Grüße
Andreas
von Marcel D. (derri)
Alles selbst gemacht ... Hut ab!
Gruss, derri
... wenn es einen Ort gibt, an dem man den "Orginal-Plan" findet, dann
beim Hersteller des Gerätes.
Da die chinesischen Erbauer aber bisher kaum Dokus zu ihren Produkten
bereitstellten, wird das im Falle der Schalpläne wohl auch weiterhin
nichts werden.
Gruß Horst
von MisterGNZ (Gast)
Good morning everyone, I want to share my experience with you, I solved
the problem of the LCR T7, I changed the internal battery with a 1500
mha one, and now the size of the battery is perfect, inside before there
was a tiny battery and definitely faulty, because it gave false values,
3.45v
von andy171 (Gast)
Hallo
So mein Neuer ist nun fertig!
Grüße an Alle, und noch nen schönen 2. Advent
von Klaus R. (klaus2)
Sehr schöne Idee mit dem Pultgehäuse, auch gute Fassungen. Ich würd
nochn Smd Feld spendiert haben.
Klaus.
... ein Impulsdrehgeber mit Taster könnte die Bedienbarkeit des Menüs
noch erheblich verbessern.
Gruß Horst
von andy171 (Gast)
Hallo Obelix2007,
Leider reichen die Ports nicht aus, Die werden schon für das Display
verbraucht.
Gruß Andreas
Ahoj,
> Es sind noch zwei weitere Änderungen notwendig. [...]
Danke!
Angehangen dann der neue Patch.
Wann geht das ganze "upstream", bzw. gibt es irgendwo eine jederzeit
aktuelle git-Version?
diff -r -U2 ComponentTester-1.47m.orig/probes.c ComponentTester-1.47m.fix-testpin-free-assignments/probes.c
--- ComponentTester-1.47m.orig/probes.c  2022-02-18 17:57:40.000000000 +0100
+++ ComponentTester-1.47m.fix-testpin-free-assignments/probes.c  2022-12-09 19:55:39.079013128 +0100
@@ -364,5 +364,5 @@
       continue;
     if (U_c < U_old[ID])                /* voltage decreased */
@@ -413,5 +413,5 @@
       Flags = DATA_read_byte(&Rh_table[ID]) | DATA_read_byte(&Rl_table[ID]);
       R_DDR &= ~Flags;                  /* disable load resistors */
       Counter = 0;                      /* end loop */
@@ -942,5 +942,5 @@
       wait5ms();
       R_DDR = Probes.Rl_2 | Probes.Rl_3;  /* pull down base via Rl */
-      U_1 = ReadU_5ms(Probe2);            /* get voltage at collector */
+      U_1 = ReadU_5ms(Probes.Ch_2);       /* get voltage at collector */
23
24
25
@@ -978,5 +978,5 @@
26
       R_DDR = Probes.Rl_1 | Probes.Rl_3;     /* select Rl for probe-1 & Rl for probe-3 */
27
       R_PORT = Probes.Rl_1 | Probes.Rl_3;    /* pull up collector & base via Rl */
28
-      U_1 = ReadU_5ms(Probe1);               /* get voltage at collector */
29
+      U_1 = ReadU_5ms(Probes.Ch_1)           /* get voltage at collector */
30
31
> verbraucht.
Doch, Du kannst den Drehgeber an die Display-Ports hängen:
https://github.com/madires/Transistortester-Warehouse/raw/master/Documentation/English/ttester-1.13k.Bohu.pdf:
> 2.2.5 Using of a rotary pulse encoder
> All signals for the connection of the rotary
> pulse encoder are available at the plug connector
> for the LCD. [...]
und
https://github.com/madires/Transistortester-Warehouse/raw/master/Documentation/English/ctester-1.47m.pdf:
> 6.2.1. Hardware options
> rotary encoder for user interface
> - could be in parallel with LCD module
... es gibt etliche TT-Versionen mit grafischem 160x128 Pixel Display -
auch in Farbe - die zusätzlich noch den Impulsdrehgeber bedienen. Dieser
wird in der Regel an zwei Display-Ports angeschlossen. In der Doku
ttester.pdf von Karl-Heinz Kübbeler ist das schön beschrieben.
Gruß Horst
P.S. Holger war scheller
Ahoj,
so, ich habe nun an meinem Komponententester (von @obelix2007 umgebauter
T7) noch etwas gebastelt.
Und zwar:
* Intern waren schon Löt-Löcher für einen Erweiterungsanschluss
vorhanden (einige Microcontrollerpins sowie Versorgungsspannungen). Ich
habe dort eine Buchsenleiste angelötet sowie ins Gehäuse die passende
Aussparung gefräst.
* Alle Microcontroller-Anschlüsse, die irgendwie ins freie Geraten,
wurden mit Schutzdioden versehen.
* Eingangsimpedanz Frequenzmessung/ Impulszählung erhöht, und
Ruhespannung am dazugehörigen Microcontroller-PIN nun justierbar.
* Pull-Up-Widerstände am Drehencoder von 1k auf 10k erhöht (Verringerung
der Stromaufnahme; der Encoder kann in der Ruhestellung ja auch mal
geschlossene Kontakte haben, da würden sonst dauernd 5mA schon allein
deswegen fließen).
* Der Signalgenerator-Ausgang, der von @obelix2007 nachgerüstet wurde,
wurde mit einem 680-Ohm-Kurzschlussschutzwiderstand versehen.
* Es wurde die Zener-Spannung über ein Kippschalter abschaltbar gemacht.
Somit kann der Zener-Messanschluss auch zum messen von Spannungen
verwendet werden.
* Der interne Akku ist über einen Kippschalter nun abschaltbar.
* Über den selben Schalter, über den der interne Akku abgeklemmt werden
kann, wird stattdessen, wenn der interne Akku abgeschaltet ist, ein
zusätzlich hinzugefügter Anschluss anstatt des internen Akkus
zugeschaltet. Somit kann das Gerät als "poor man"s LiIon-Akku Lade-/
Spannungsprüfgerät verwendet werden.
* Auf der Platine einen 220µF-Kondensator dorthin gelötet wo der Akku
hingehört. Scheint nötig damit mit nur-USB-Versorgung (ohne Akku) das
Ding angeht, ggf. zum Puffern von Spannungsspitzen, denn der
Akku-Lade-IC, durch den der gesamte Strom vom USB auch geht, hat einen
Kurzschlussstrom von unter 90 mA, und anscheinend auch eine
nicht-konstante Leerlauf-Ausgangsspannung wenn kein Puffer dranhängt.
* Zener-Dioden-Spannung mit einem zusätzlichen 22µF-Kondensator
gepuffert.
* Weiterhin wurden die noch brach liegenden Microconteoller-Anschlüsse
PD0 und PC7 rausgeführt.
* Der Anschluss, an dem bisher Eingang für Frequenzmessung/
Impulszählung, Signalgenerator-Ausgang und GND anlagen, wurde getauscht
gegen eine Buchsenleiste an der nun folgende Signale anliegen:
  - GND,
  - +5V,
  - Anschlussmöglichkeit externer Akku,
  - Eingang Frequenzmessung/ Impulszählung,
  - Ausgang Signalgenerator,
  - PC7,
  - PD0.
* Das Display ist nun steckbar, dies war nötig damit ich die
Überspannungs-Schutzdioden am Erweiterungsport anbringen konnte.
Anbei aktueller Schaltplan und ein paar Fotos.
Für den nun frei liegenden Erweiterungsport möchte ich bei Gelegenheit
mal die Präzisere LC-Messerweiterung bauen.
Für die Impulszählung möchte ich noch einen ansteckbaren Taster bauen,
so dass ich Tastendrücke zählen kann.
Eine FRAGE habe ich noch:
Auf der Platine ist ja so ein Kontakt der mit "EN" gelabelt ist. Hängt
am PD0-Pin des Microcontroller, der mit 10k nach VCC gezogen ist. Die
Gegenseite des Kontaktes ist auf Masse. (Vgl. Schaltplan.)
Bedienbar ist der Kontakt nur bei geöffnetem Gerät durch herstellen
eines Kurzschlusses auf der Platine.
Wozu ist das Ding da? Hat das Ding in der "m" oder "k"-Firmware eine
Funktion, oder ist das nur ein Relikt von der China-Firmware für irgend
eine Debug-/Service-Funktion? (Wenn es keine aktuelle Funktion mehr hat
würde ich den Pull-Up-Widerstand entfernen wollen, um einen "sauberen"
PD0-Port zu haben. Oder ist an genau dem Port aus anderen Gründen ein
externer Pull-Up-Widerstand sinnvoll?)
Lieber Gruß!,
und danke allen, die hier so fleißig beigetragen haben!
von Markus R. (madires)
Mit der 1.48m. Ein git-Repo mit der aktuellen Entwicklungsversion gibt
es bei der m-Firmware nicht.
Das soll eine Spachauswahl für Englisch/Chinesisch sein.
von Joachim B. (jar)
> verbraucht.
auch mit I2C Porterweiterung?
Sollte doch mit PCF8574(a) kein Problem sein, ich sehe eher das Problem
von flash und RAM und denke immer wieder an ATmega1284p
Holger B. schrieb:
>... (von @obelix2007 umgebauter
> T7)
... oh ha, kaum noch wieder zu erkennen!
Gruß Horst
von Holger B. (dreieck)
Hat jemand eine Idee, ob so ein eInk-Display:
https://www.aliexpress.com/i/32870097847.html
(TZT 1.54 inch, 200x200 Pixel, schwarz auf weiß oder schwarz+rot auf
weiß)
von der Firmware schon unterstützt wird bzw. ob dies einfach möglich
wäre? (Ich weiß, die Antwort kann sehr schwierig sein, aber vielleicht
kennt ja jemand schon diese Displays, oder es gibt die Erfahrung dass
das meistens Standard-Controller sind.)
Gruß!
Ahoj,
zu der Frequenzmess- und Impulszählerweiterung (einfache Variante) habe
ich ein Unverständnis:
Wenn ich mir die Doku
anschaue -- sowie Schaltpläne (Schaltplan angehangen) (und auch das
Gerät welches ich erhalten habe), so ist der Frequenzeingang über einen
470-Ohm-Widerstand und einen Entkoppelkondensator an einen
Mikrocontroller-Pin geführt. Über einen Spannungsteiler wird eine feste
DC-Spannung an dem Pin eingestellt.
Nun kann dies, wenn ich eine Freqzenz mit TTL-Pegel messen will, dies
doch zu Überspannung am Mikrocontroller führen:
Wenn der Frequenzeingang an die zu messende Stelle geschaltet wird, und
da erstmal eine konstante Gleichspannung von z.B. 0V anliegt, dann
stellt sich am Mikrocontroller-Pin über den Spannungsteiler und wegen
der Entkopplung durch den Kondensator ca. 2.5V ein. Der Kondensator ist
mit 2.5V aufgeladen.
Nun ändert sich das Eingangssignal zu 5V. Am Mikrocontroller-Pin liegen
nun, über den Kondensator, knapp 7.5V an!, strombegrenzt nur über den
470-Ohm-Widerstand.
Ist das wirklich so zulässig? Müssen da nicht noch zusätzliche
Schutzdioden hin?
Gruß!
> weiß)
Wenn der Display-Controller bekannt ist, es ein englisches Datenblatt
zum Controller gibt, und jemand ein Testexemplar mir schickt, kann ich
gerne einen Treiber für die m-Firmware schreiben.
> Schutzdioden hin?
Solange es nur wenige mA sind, sind die internen Klemmdioden vom ATmega
ausreichend.
>> weiß)
[url=https://www.aliexpress.com/i/32870097847.html]in den
Fragen-Antworten[/url] steht
> search arduino library for waveshare. use second one
Sehr hilfreich, "second one", aber immerhin sagen sie damit, dass es
kompatibel zu irgend einem Waveshare-Display ist.
[url=https://www.waveshare.com/product/displays/e-paper/epaper-1.htm?dir=asc&order=price]bei
Waveshare[/url] finde ich aber nur mit Auflösung 640x480 und aufwärts.
Internetsuche nach "TZT ePaper datasheet" findet dann bei Waveshare aber
[url=https://www.waveshare.com/w/upload/7/77/1.54inch_e-Paper_Datasheet.pdf]dieses
Datenblatt für ein schwarz-weiß-Display[/url], was das hier verbaute
sein könnte -- allerdings für das Panel selber, nicht für das mit
SPI-Anschluss wie es bei Aliexpress verkauft wird.
Ich habe mal explizit nachgefragt, ob sie mehr sagen können, und ein
Datenblatt haben.
Gefunden habe ich dann noch
[url=https://www.hackster.io/xxlukas84/simple-e-ink-display-mh-et-live-1-54-for-your-projects-003efb]diesen
Beitrag auf hackster.io[/url], da gibt es auch eine Verlinkung zu
[url=https://github.com/ZinggJM/GxEPD2]einer Arduino-Bibliothek
"GxEPD2"[/url]
Macht das Zuversicht, dass zum Laufen zu bekommen?
Ich könnte Dir direkt von Aliexpress eines bestellen, das spart doppelte
Versandkosten. Wenn das passt, schreib' mir doch privat.
Holger B. schrieb:
> dann
... durch diese Vorspannung wird die beste Eingangsempfindlichkeit
erreicht. Schon ab ca: 800 mV zählt dann das Gerät  mit sinusförmigem
Signal bis etwa 1 MHz, mit etwas höherer Spannung (bis max. 2,5 Volt)
arbeitet der Zähler bis 7 MHz (an meinem TC1 mit Software 1.47m
getestet).
Gruß Horst
P.S. ... bei höheren Frequenzen ist die Zeile mit der aktuellen Frequenz
kaum noch zu lesen?!?
Auf der Seite vom GxEPD2 sind einige Displays mit Controllern gelistet.
Die 1.54" 200x200 scheinen wohl öfters den SSD1681 zu haben. Warten wir
mal ab, was der Verkäufer antwortet.
Was sollte denn der Vorteil eines eInk sein? Weils so cool ist?
Technisch hat man doch bereits alles, was man braucht.
Klaus.
Niedriger Stromverbrauch im Vergleich zu einem
dauerhintergrundbeleuchteten TFT. (Also wenn man die Variante mit
Grafikdisplay bauen will.) Wodurch der interne Akku länger hält (wenn
man ein Gerät mit internem Akku hat.)
Reflektive Grafik-LCDs, die ebenfalls mit wenig Strom auskommen, gibt es
ja leider kaum.
Beantwortet das Deine Frage?
Wie zu erwarten keine brauchbare Antwort. Der Verkäufer von den beiden
gefragten, der noch die sinnvollere(!) Antwort gab schrieb "I am just
the salesman. Please check the relevant material."
Also würde ich es einfach mal probieren wollen.
Ja, hatte ich vermutet. Halte ich bei Verwendung von 18650ern aber schon
für ein eher schwaches Argument 😅
Anyway, viel Erfolg!
... ja, die T-Tester TC1, T7 und Ähnliche haben einen relativ schwachen
Li-Akku und halten nur so ca. 2 - 4 Std. durch. Ein transflektives
Display in geeigneter Größe könnte da sicher die Akkulaufzeit
verbessern.
Meine Fittness-Uhr hat ein solches Disply und hält `ne Gute Woche mit
einer Aufladung durch (allerdings nicht bei Training mit
GPS-Aufzeichnung, da geht nach 3-4 Tagen der Saft aus).😅
Im Anhang Bilder der Akkus und der Messung der Stromaufname meines T7-H.
Werde morgen zum Vergleich mal den T4 mit und ohne Beleuchtung messen.
Gruß Horst
... Strommessung mit 2 AtMega328P - T4 und GM328A-AY-AT-Color;
zusätzlich noch mit AtMega644 - CT1.
Man sieht beim Vergleich von CT1 und AY-T - beide haben das gleiche
Color-Display - daß der Stromverbrauch im wesentlichen vom eingebauten
Controller und der eingesetzten FW abhängt.
Gruß Horst
Wenn du die Unterschiede zwischen den Firmware-Varianten untersuchen
möchtest, dann bitte jeweils den selben Tester nehmen. TC1 und Co
brauchen wegen den Boost-Konvertern (Vcc und Zener-Check) deutlich mehr
Strom als z.B. der AY-AT/GM328A.
... ja, ist schon in Arbeit, dauert aber noch an.
Der Fragesteller hatte es diesmal auf die unterschiedlichen
Display-Arten bezogen. Da muß ich wohl auch noch ein wenig an der
Hardware frickeln, um zu zeigen, wie die Stromaufnahme sich
zusammesetzt.
Danke übrigens für Deine neue FW 1.48!
Gruß Horst
Bei LCDs ist primär das Backlight (LEDs) der Stromfresser. Bei OLEDs ist
es etwas komplizierter und hängt von der Pixelfarbe ab. Farbige Flächen
sind mit OLEDs effizienter, aber weisse Flächen dafür ineffizienter.
Farbiger Text auf schwarzem Hintergrund wäre mit OLED also sparsamer als
mit LCD. E-Paper dagegen braucht quasi nur bei Änderungen Strom und hat
noch ein paar weitere Vorteile, wie z.B. Lesbarkeit bei direktem
Sonnenlicht.
Über welche(n) Kanal(e) gibt es die Information, dass es eine neue
Version gibt?
Danke auch, übrigens!
Gruß!
> Version gibt?
... Markus ist oft hier unterwegs:
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg4579492/#msg4579492
Gruß Horst
Wenn noch mehr hier über neue Firmware-Versionen informiert werden
möchten, dann kann ich das gerne auch hier posten.
... das wäre schön!
Gruß Horst
hello guys, i have a problem, i programmed atmega328p, with fusebit low:
F7, high: DF, ext: F9, quartz 16MHZ, but, when I turn on the component
tester, with 16x02 display, all squares appear to me, with the writing :
eta, but if I put a capacitor, on pidini 1e3 it works regularly, what
can be the cause ???
Have you also programmed the EEPROM?
von Lukey S. (lukey3332)
Hallo Zusammen,
Ich habe den Joy-It JT-LCR-T7 und will ein paar alte Kondensatoren
testen.
Laut wiki wird ja ab 20 nF der ESR angezeit. Allerdings ist das bei mir
nicht so: Ich hab jetzt mehrere Kondensatoren >= 100uF getestet und nur
ab und zu wird der ESR angezeit.
Bei brandneuen Low-ESR Kondensatoren wird der ESR garnicht angezeigt.
Wie sind diese messungen zu Interpretieren? Kein ESR = Niedriger ESR?
von Ingo W. (uebrig) Benutzerseite
Würde ich so sehen. Schalte doch mal einen Widerstand von einigen Ohm in
Reihe!
Ich weiss nicht, ob es deinen Tester betrifft, aber wegen den aktuell
hohen Preisen für ATmegas kommen manche Tester mit LGT8F328P oder
APT32F172K8T6 als MCU. Die Hersteller dieser Tester haben die Firmware
nicht wirklich an die anderen MCUs angepasst, und deshalb liefern die
Tester u.A. bei der ESR-Messung keine brauchbaren Ergebnisse. Ansonsten
nicht vergessen, den Selbstabgleich laufen zu lassen.
