Hay everyone ,
i am trying to simulate a 8 bits comparator using 2 * 4 bits comarators
here's my code .... it's compile --> no errors
but i have 3 red lignes in the wave
this is the 4bits comparator (with 3 outputs ega , inf and sup)
1 | Library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.std_logic_unsigned.all;
4 | entity Comp_4Bits is
5 | port(
6 | A : in std_logic_vector (3 downto 0);
7 | B : in std_logic_vector (3 downto 0);
8 | SUP : out std_logic;
9 | iNF : out std_logic;
10 | EGA : out std_logic);
11 | end Comp_4Bits ;
12 | Architecture RTL of Comp_4Bits is
13 | begin
14 | process(A,B)
15 | begin
16 | if (A>B) then Sup <='1' ; Inf <='0' ; Ega <='0' ;
17 | Elsif (A<B) then Inf <='1' ; Sup <='0' ; ega <='0' ;
18 | elsif (A=B) then Ega <='1' ; sup <='0' ; inf <='0' ;
19 | end if ;
20 | end process ;
21 | end RTL;
and here is the code of 8 bits comparator
1 |
2 | library ieee;
3 | use ieee.std_logic_1164.all;
4 | use ieee.std_logic_unsigned.all;
5 | use ieee.numeric_std ;
6 |
7 | entity compa_8bits is port(
8 | A:in std_logic_vector(7 downto 0);
9 | B:in std_logic_vector(7 downto 0);
10 | ega:out std_logic ;
11 | sup:out std_logic;
12 | inf:out std_logic
13 | );
14 | end compa_8bits;
15 |
16 | architecture RTL of compa_8bits is
17 |
18 | signal sup1 , sup2 , inf1 , inf2 , ega1 , ega2 , sig1 , sig2:std_logic;
19 |
20 | component Comp_4Bits is port(
21 | A:IN std_logic_vector(3 downto 0);
22 | B:IN std_logic_vector(3 downto 0);
23 | ega:out std_logic;
24 | sup:out std_logic;
25 | inf:out std_logic);
26 | end component ;
27 |
28 |
29 | begin
30 | u1:Comp_4Bits port map
31 | (
32 | A =>A(7 downto 4),
33 | B=>B(7 downto 4),
34 | ega=>ega1 ,
35 | sup=>sup1,
36 | inf=>inf1
37 | );
38 |
39 | u2:Comp_4Bits port map
40 | (
41 | A=>A(3 downto 0),
42 | B=>B(3 downto 0),
43 | ega=>ega2,
44 | sup=>sup2,
45 | inf=>inf2);
46 |
47 |
48 | inf <= inf1 or (ega1 and inf2);
49 | sup <= sup1 or (ega1 and sup2);
50 | ega <= ega1 and ega2;
51 |
52 | END RTL;
and finally the test bench
1 | library ieee;
4 | use ieee.numeric_std ;
5 |
6 | entity compa_8bits_tb is
7 | end compa_8bits_tb;
8 |
9 | architecture BHV of compa_8bits_tb is
10 | component compa_8bits is
11 | port(
12 | A:IN std_logic_vector(7 downto 0);
13 | B:IN std_logic_vector(7 downto 0);
14 | sup:out std_logic;
15 | ega:out std_logic;
16 | inf:out std_logic
17 | );
18 | end component;
19 |
20 | signal A, B : std_logic_vector( 7 downto 0) ;
21 | signal ega, inf, sup: std_logic;
22 |
23 | begin
24 |
25 | Dut1: compa_8bits port map(
26 | A => A ,
27 | B => B ,
28 | ega=>ega ,
29 | sup =>sup,
30 | inf=>inf
31 | );
32 |
33 |
34 | process
35 | begin
36 | A<="11110000";
37 | B<="01101111";
38 | wait for 20 ns;
39 | A<="01110000";
40 | B<="01110000";
41 | wait for 30 ns;
42 | A<="10011111";
43 | B<="01101010";
44 | end process;
45 | end BHV;
