1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.STD_LOGIC_ARITH.ALL;
4 | use IEEE.STD_LOGIC_UNSIGNED.ALL;
5 |
6 | library UNISIM;
7 | use UNISIM.VComponents.all;
8 |
9 | entity x_blockram is
10 | Port( DOA : out std_logic_vector(1 to 32); -- Port A
11 | 32-bit Data Output
12 | DOB : out std_logic_vector(1 to 32); -- Port B 32-bit
13 | Data Output
14 | DOPA : out std_logic_vector(1 to 4); -- Port A 4-bit
15 | Parity Output
16 | DOPB : out std_logic_vector(1 to 4); -- Port B 4-bit
17 | Parity Output
18 | ADDRA : in std_logic_vector(8 downto 0); -- Port A 9-bit
19 | Address Input
20 | ADDRB : in std_logic_vector(8 downto 0); -- Port B 9-bit
21 | Address Input
22 | CLKA : in std_logic;
23 | CLKB : in std_logic; -- Port B Clock
24 | DIA : in std_logic_vector(1 to 32); -- Port A 32-bit
25 | Data Input
26 | DIB : in std_logic_vector(1 to 32); -- Port B 32-bit
27 | Data Input
28 | DIPA : in std_logic_vector(1 to 4); -- Port A 4-bit
29 | parity Input
30 | DIPB : out std_logic_vector(1 to 4); -- Port-B 4-bit
31 | parity Input
32 | ENA : in std_logic; -- Port A RAM Enable Input
33 | ENB : in std_logic; -- PortB RAM Enable Input
34 | SSRA : in std_logic; -- Port A Synchronous
35 | Set/Reset Input
36 | SSRB : in std_logic; -- Port B Synchronous
37 | Set/Reset Input
38 | WEA : in std_logic; -- Port A Write Enable Input
39 | WEB : in std_logic);
40 | end x_blockram;
41 |
42 | architecture Behavioral of x_blockram is
43 | -- RAMB16_S36_S36: Virtex-II/II-Pro, Spartan-3/3E 512 x 32 + 4
44 | Parity bits Dual-Port RAM
45 | -- Xilinx HDL Language Template version 7.1i
46 |
47 | RAMB16_S36_S36_inst : RAMB16_S36_S36
48 | generic map (
49 | INIT_A => X"000000000", -- Value of output RAM registers on
50 | Port A at startup
51 | INIT_B => X"000000000", -- Value of output RAM registers on
52 | Port B at startup
53 | SRVAL_A => X"000000000", -- Port A ouput value upon SSR
54 | assertion
55 | SRVAL_B => X"000000000", -- Port B ouput value upon SSR
56 | assertion
57 | WRITE_MODE_A => "WRITE_FIRST", -- WRITE_FIRST, READ_FIRST or
58 | NO_CHANGE
59 | WRITE_MODE_B => "WRITE_FIRST", -- WRITE_FIRST, READ_FIRST or
60 | NO_CHANGE
61 | SIM_COLLISION_CHECK => "ALL", -- "NONE", "WARNING",
62 | "GENERATE_X_ONLY", "ALL"
63 | INIT_00 =>
64 | X"0000000000000000000000000000000000000000000000000000000000000000",
