1 | library IEEE;
2 | use IEEE.std_logic_1164.all;
3 |
4 | entity vga_core is
5 | port
6 | (
7 | clk_50: in std_logic;
8 | red: out std_logic_vector(3 downto 0);
9 | green: out std_logic_vector(3 downto 0);
10 | blue: out std_logic_vector(3 downto 0);
11 | hsync: out std_logic;
12 | vsync: out std_logic
13 | );
14 | end vga_core;
15 |
16 | architecture vga_core_arch of vga_core is
17 |
18 | signal clk: std_logic;
19 | signal lineCounter: integer:=0;
20 | signal pixelCounter: integer:=0;
21 | signal bitmap_lineCounter: integer:=0;
22 | signal bitmap_pixelCounter: integer:=0;
23 | signal ascii_a0: std_logic_vector(6 downto 0):= "0011100";
24 | signal ascii_a1: std_logic_vector(6 downto 0):= "1100011";
25 | signal ascii_a2: std_logic_vector(6 downto 0):= "1111111";
26 | signal ascii_a3: std_logic_vector(6 downto 0):= "1000001";
27 | signal ascii_a4: std_logic_vector(6 downto 0):= "1000001";
28 |
29 |
30 | begin
31 | vga_clk: process(clk_50)
32 | begin
33 | if rising_edge(clk_50) then
34 | clk <= NOT clk;
35 | end if;
36 | end process vga_clk;
37 | ------------------------------------------------
38 | vga_testpic: process(clk)
39 | begin
40 | if clk = '1' then
41 |
42 | pixelCounter <= pixelCounter + 1;
43 | bitmap_pixelCounter <= bitmap_pixelCounter + 1;
44 |
45 | if pixelCounter = 800 then
46 | pixelCounter <= 0;
47 | bitmap_pixelCounter <= 0;
48 | lineCounter <= lineCounter + 1;
49 | bitmap_lineCounter <= bitmap_lineCounter + 1;
50 | end if;
51 |
52 | if lineCounter = 524 then
53 | lineCounter <= 0;
54 | bitmap_lineCounter <= 0;
55 | end if;
56 | ------------------------------------------------
57 | if pixelCounter > 0 AND pixelCounter < 96 then
58 | hsync <= '0';
59 | else
60 | hsync <= '1';
61 | end if;
62 |
63 | if lineCounter > 0 AND lineCounter < 2 then
64 | vsync <= '0';
65 | else
66 | vsync <= '1';
67 | end if;
68 | -------------------------------------------------
69 | if pixelCounter > 112 AND pixelCounter < 752 AND lineCounter > 13 AND lineCounter < 493 then
70 | red <= "0000";
71 | green <= "0000";
72 | blue <= "0000";
73 |
74 | if bitmap_lineCounter < 6 then
75 | if bitmap_pixelCounter < 8 then
76 | if bitmap_lineCounter = 0 then
77 | if ascii_a0(bitmap_pixelCounter) = '1' then
78 | green <= "1111";
79 | else
80 | green <= "0000";
81 | end if;
82 | end if;
83 | if bitmap_lineCounter = 1 then
84 | if ascii_a1(bitmap_pixelCounter) = '1' then
85 | green <= "1111";
86 | else
87 | green <= "0000";
88 | end if;
89 | end if;
90 | if bitmap_lineCounter = 2 then
91 | if ascii_a2(bitmap_pixelCounter) = '1' then
92 | green <= "1111";
93 | else
94 | green <= "0000";
95 | end if;
96 | end if;
97 | if bitmap_lineCounter = 3 then
98 | if ascii_a3(bitmap_pixelCounter) = '1' then
99 | green <= "1111";
100 | else
101 | green <= "0000";
102 | end if;
103 | end if;
104 | if bitmap_lineCounter = 4 then
105 | if ascii_a4(bitmap_pixelCounter) = '1' then
106 | green <= "1111";
107 | else
108 | green <= "0000";
109 | end if;
110 | end if;
111 | end if;
112 | else
113 | green <= "0000";
114 | end if;
115 | else
116 | red <= "0000";
117 | green <= "0000";
118 | blue <= "0000";
119 | end if;
120 | end if;
121 | end process vga_testpic;
122 | end architecture vga_core_arch;
