Problem: SPI Remap am STM32F407ZG
Gast #4076254
Hallo Forengemeinde,
der REMAP von MOSI funktioniert nicht, woran kann das liegen? Ist ein
REMAP für SPI überhaupt möglich? Hab ein Eval-Board wo der MOSI auf
einer anderen Peripherie liegt, daher wollte ich einen REMAP
durchführen.
Besten Dank
void init_SPI1(void){
  GPIO_InitTypeDef GPIO_InitStruct;
  SPI_InitTypeDef SPI_InitStruct;
        // enable peripheral clock
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  // enable clock for used IO pins
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        /* GPIO Deinitialisation */
        GPIO_DeInit(GPIOA);
        GPIO_DeInit(GPIOA);
        GPIO_DeInit(GPIOA);
  /* configure pins used by SPI1
   * PA4 = SCK
   * PA5 = MISO
   * PA6 = MOSI
        // connect SPI1 pins to SPI alternate function
24
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_SPI1);
25
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);
26
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1);
27
28
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
29
  GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
30
  GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
31
        GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_DOWN;
32
33
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4;
34
  GPIO_Init(GPIOA, &GPIO_InitStruct);
35
36
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5;
37
38
39
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
40
41
42
43
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
44
45
  /* Configure the chip select pin
46
     in this case we will use PE7 */
47
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7;
48
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;
49
50
51
  GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;
52
  GPIO_Init(GPIOE, &GPIO_InitStruct);
53
54
  GPIOE->BSRRL |= GPIO_Pin_7; // set PE7 high
55
56
  /* configure SPI1 in Mode 0
57
   * CPOL = 0 --> clock is low when idle
58
   * CPHA = 0 --> data is sampled at the first edge
59
60
61
        SPI_I2S_DeInit(SPI1);
62
  SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex; // set to full duplex mode, seperate MOSI and MISO line
63
        SPI_InitStruct.SPI_Mode = SPI_Mode_Master;     // transmit in master mode, NSS pin has to be always high
64
  SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b; // one packet of data is 8 bits wide
65
  SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low;        // clock is low when idle
66
  SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge;      // data sampled at first edge
67
  SPI_InitStruct.SPI_NSS = SPI_NSS_Soft | SPI_NSSInternalSoft_Set; // set the NSS management to internal and pull internal NSS high
68
  SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; // SPI frequency is APB2 frequency / 4
69
  SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;// data is transmitted MSB first
70
  SPI_Init(SPI1, &SPI_InitStruct);
71
72
  SPI_Cmd(SPI1, ENABLE); // enable SPI1
73
74
75
/* This funtion is used to transmit and receive data
76
 * with SPI1
77
 *       data --> data to be transmitted
78
 *       returns received value
79
80
uint8_t SPI1_send(uint8_t data){
81
82
  SPI1->DR = data; // write data to be transmitted to the SPI data register
83
  while( !(SPI1->SR & SPI_I2S_FLAG_TXE) ); // wait until transmit complete
84
  while( !(SPI1->SR & SPI_I2S_FLAG_RXNE) ); // wait until receive complete
85
  while( SPI1->SR & SPI_I2S_FLAG_BSY ); // wait until SPI is not busy anymore
86
  return SPI1->DR; // return received data from SPI data register
87
88
89
int main(void){
90
91
  uint8_t received_val = 0;
92
93
  init_SPI1();
94
95
  while(1){
96
97
    GPIOE->BSRRH |= GPIO_Pin_7; // set PE7 (CS) low
98
    SPI1_send(0xFA);  // transmit data
99
    received_val = SPI1_send(0x00); // transmit dummy byte and receive data
100
    GPIOE->BSRRL |= GPIO_Pin_7; // set PE7 (CS) high
101
102
Gast #4076316
PS: An die Standard SPI IOs je Port bekomme ich die Signale ohne Problem
gemapped.
#include "includes.h"
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
   * PA5 = SCK
   * PA6 = MISO
   * PB5 = MOSI
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_5;
  GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
23
24
25
26
        GPIO_Init(GPIOB, &GPIO_InitStruct);
27
28
29
30
31
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_SPI1);
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
  SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex; // set to full duplex mode, seperate MOSI and MISO lines
55
56
57
58
59
60
  SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4; // SPI frequency is APB2 frequency / 4
61
62
63
64
65
66
67
68
 * with SPI1
69
70
71
72
73
74
75
76
77
78
79
80
81
int main(void){
82
83
84
85
  init_SPI1();
86
87
  while(1){
88
89
90
    SPI1_send(0xAF);  // transmit data
91
    received_val = SPI1_send(0xAA); // transmit dummy byte and receive data
92
93
94
(Firma: matzetronics) #4076328
>         GPIO_DeInit(GPIOA);
>         GPIO_DeInit(GPIOA);
>         GPIO_DeInit(GPIOA);
Ich sags dreimal und dann ist es wahr? Hehehe, einmal reicht hier.
Ich glaube, du hast dich in den AF Funktionen verlesen, Datenblatt Seite
60, Funktion AF5:
PA4 = NSS
PA5 = SCK
PA6 = MISO
PA7 = MOSI
Das kannst du einfacher haben:
// SPI1 korrigiert
   GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7;
   GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN;
