Warnung ****** is unused and will be removed from module ******
OP #4454025
ich bin noch recht neu im Bereich der FPGAs / von VHDL und stehe vor
einem Problem (Warnung) die mich stark verwirrt. Ich habe folgenden Code
geschrieben:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity SimpleTest is
    Port ( clk : in STD_LOGIC;
           reset : in STD_LOGIC;
           start : in STD_LOGIC;
           --burst : in STD_LOGIC_VECTOR (11 downto 0);
           frequenz : in STD_LOGIC_VECTOR (17 downto 0);
           delay : in STD_LOGIC_VECTOR (15 downto 0);
           out_signal : out STD_LOGIC);
end SimpleTest;
architecture Behavioral of SimpleTest is
signal countDelay : unsigned(15 downto 0);
signal delayReady : std_logic;
signal countFreq : unsigned(17 downto 0);
signal temp_out : std_logic;
signal temp_ones : std_logic;
begin
23
CTRD : process( clk, reset, delayReady, start )
24
begin
25
  if reset = '0' then
26
    countDelay <= (others => '0');
27
  elsif clk='0' and clk'event and delayReady='0' and start='1' then
28
    if countDelay < unsigned(delay) then
29
      countDelay <= countDelay + 1;
30
    else
31
32
      delayReady <= '1';
33
    end if ;
34
  end if ;
35
end process ; -- CTRD
36
37
CTRF : process( clk, reset, delayReady, start )
38
begin
39
  if reset = '0' then
40
    countFreq <= (others => '0');
41
  elsif clk='0' and clk'event and delayReady='1' and start='1' then
42
    if delayReady='1' and temp_ones='0' then
43
      temp_out <= '1';
44
      temp_ones <= '1';
45
    end if ;
46
    if countFreq < unsigned(frequenz) then
47
      countFreq <= countFreq + 1;
48
    else
49
50
      temp_out <= not temp_out;
51
    end if ;
52
  end if ;
53
end process ; -- CTRF
54
55
out_signal <= temp_out;
56
57
end Behavioral;
und bekomme die Warnungen:
[Synth 8-3332] Sequential element (delayReady_reg) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (temp_ones_reg) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[0] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[1] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[2] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[3] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[4] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[5] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[6] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[7] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[8] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[9] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[10] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[11] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[12] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[13] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[14] ) is unused and will be removed from module SimpleTest.
[Synth 8-3332] Sequential element (\countDelay_reg[15] ) is unused and will be removed from module SimpleTest.
Aber ich benutze sie doch oder ?
folgender Test läuft ohne die Warnung:
library IEEE;
           input_test : in STD_LOGIC;
           max : in STD_LOGIC_VECTOR (15 downto 0);
           output_test : out STD_LOGIC;
           output_test2 : out STD_LOGIC);
end SimpleTest;
signal temp : std_logic;
signal count : unsigned(15 downto 0);
begin
CTRD : process( clk, reset )
begin
  if reset = '0' then
        temp <= '0';
23
  elsif clk='1' and clk'event then
24
    if count <= unsigned(max) then
25
      count <= count + 1;
26
    else
27
      count <= (others => '0');
28
      temp <= not temp;
29
    end if ;
30
  end if ;
31
32
33
output_test <= temp;
34
output_test2 <= temp and input_test;
35
36
end Behavioral;
Kann mir jemand helfen?
Sry falls sich der Code etwas schrecklich liest aber ich stehe momentan
am Anfang des lernens ^^
Gast #4454087
Versuch mal "delayReady" in einem Resetfall auf 0 zu setzen oder es
zumindest zu initialisieren.
Für dein zweites Beispiel solltest du dir auch überlegen ob du "count"
nicht resetten oder initialisieren solltest.
Moderator (Firma: Titel) Persönliche Seite #4454106
Diese immer noch sehr ungewöhnliche Beschreibung eines Clock-Enables
solltest du in die "übliche" Schreibweise umformulieren:
http://www.lothar-miller.de/s9y/categories/6-Clock-Enable
Dann sparst du dir diese vielen Signale in der Sensitivliste, die
sowieso nichts bewirken und trotzdem rein müssen.
Nicht so richtig...
Sehen wir uns mal das temp_ones an. Weil du nirgends eine Resetbedingung
definierst, sondern das Ding nur abfrägst und dann auf '1' setzt, kann
die Optimierung dieses Signal gleich mal im Default auf '1' setzen. Du
hast dir da ja nichts gewünscht.
Genau das Selbe mit delayReady: du hast keinen Init-  oder Reset-Wert
angegeben, also geht die Toolchain her und "optimiert" das auf '1'. Und
wenn dieses Signal statisch auf '1' ist, ist auch logischerweise der
Zähler countDelay unnötig, denn der dient ja nur dazu, das Signal
delayReady auf '1' zu setzen.
Probiers mal so:
signal countDelay : unsigned(15 downto 0) := (others=>'0');
signal delayReady : std_logic             := '0';
signal countFreq : unsigned(17 downto 0)  := (others=>'0');
signal temp_out : std_logic               := '0';
signal temp_ones : std_logic              := '0';
Dominik G. schrieb:
> oder ?
Warum kommt Plenken immer mehr in Mode?
Hat so ein simples Fragezeichen denn wirklich seine eigene Zeile
verdient
