Forum: FPGA, VHDL & Co. Altera Timequest signal als clock identifiziert
von MALGUCKEN (Gast)
Hallo anbei ein kleine Ausschnitt aus meine versuch eine rs232
Schnittstelle zu erzeugen. Sie geht auch das ist nicht das Problem.
Erstmal der Code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity RS232_RX is
  generic(  CLK_MUL: natural := 6;
      BITS: natural := 8;
      STOPBIT: natural range 0 to 1 := 0);
  port(    RESET: in bit;
      NDATA: in bit; -- new data
      READY: out bit; -- ready for new data
      BCLK: in bit;
      databit: in bit_vector(BITS-1 downto 0);
      DO: out bit);
end RS232_RX;
architecture STRUCT of RS232_RX is
  type state is (IDLE, START, SEND, STOP);
  signal l_databit: bit_vector(BITS-1 downto 0);
  signal iclk: bit := '0';
  signal l_mstate: state;
  signal l_obit: bit := '1'; --idle bit
23
  signal l_ready: bit := '0';
24
25
begin
26
27
28
P1:   process(BCLK,RESET,databit,NDATA,l_ready)
29
  variable v_counter: integer range 0 to CLK_MUL := 0; --integer
30
  variable v_bcnt: integer range 0 to BITS-1 := 0; --integer rang 0 bis BITS;
31
  variable vcnt_stbbit: integer range 0 to 1 := STOPBIT; --anzahl der stopbits
32
  begin
33
    if RESET='1' then
34
      l_mstate <= IDLE; --set the machine to start.
35
      v_counter := 0; -- reset v_counter
36
      l_ready <= '1'; --set ready to not ready for new data i am in the process.
37
    elsif NDATA = '1' and l_ready = '1' then --new data?
38
        l_databit <= databit; --nur bei reset zuweisen
39
        l_mstate <= START;
40
        l_ready <= '0';
41
    elsif BCLK'event and BCLK='0' then
42
      if v_counter=0 then
43
        v_counter := CLK_MUL-1;
44
        case l_mstate is
45
          when IDLE => null;
46
47
          when START =>
48
            l_obit <= '0';
49
            l_mstate <= SEND;
50
            v_bcnt := BITS-1;
51
            vcnt_stbbit := STOPBIT;
52
          when SEND =>
53
            l_obit <= l_databit(0);
54
            l_databit <= '0' & l_databit(BITS-1 downto 1);
55
            if v_bcnt = 0 then
56
              l_mstate <= STOP;
57
            else
58
              v_bcnt := v_bcnt -1;
59
            end if;
60
          when STOP =>
61
            l_obit <= '1';
62
            if vcnt_stbbit = 0 then
63
              l_mstate <= IDLE;
64
              l_ready <= '1'; --ready for new data
65
            else
66
              vcnt_stbbit := vcnt_stbbit-1;
67
            end if;
68
        end case;
69
      else
70
        v_counter := v_counter - 1;
71
      end if;
72
    end if;
73
  end process P1;
74
75
PO:   process(l_obit,l_ready)
76
  begin
77
    READY <= l_ready;
78
    DO <= l_obit;
79
  end process PO;
80
end STRUCT;
So die Entwicklungsumgebung erzählt mir in der Timequest Analyzer, dass
das Signal "CONTROL:RS232CNT|RS232_RX:RS232RX|l_mstate.IDLE~1" eine
clock ist. Jetzt meine Frage warum sollte das eine Clock sein? Den
Zusammenhang verstehe ich nicht.
Bitte helft mir fürs Verständnis!
Vielen Dank
von Duke Scarring (Gast)
Uiuiui, hier sind ja gleich mehrere Sachen:
1.
       when IDLE => null;
Ein von beiden Anweisung ist definitiv überflüssig.
Ich würde die Zuweisung an l_mstate weglassen.
2.
Deine Sensitivity-Liste ist genauso unübersichtlich, wie Dein Code.
Ich versuche in meinen Designs (zu 98% gelingt das auch) nur mit CLK zu
arbeiten. Das sind sogenannte synchrone Designs.
In Einzelfällen kommt dann noch ein (asynchroner) Reset dazu.
3.
Für die gestellte Aufgabe sind das definitiv zu viele Variablen.
Hier nochmal kurz und prägnant von Lothar postuliert:
Beitrag "Re: VHDL - For-Schleife"
Ein Design (insbesondere ein Anfängerdesign) hat genau 1 Takt,
der immer auf dieselbe Flanke aktiv ist.
Es gibt keinen (und schon gar keinen asynchronen) Reset.
Externe Signale werden über 2 Flipflops einsynchronisiert.
Jede Abweichung von diesen Regeln muß fundiert begründet werden können.
Versuch mal Deinen Code dahingehend umzuschreiben...
Duke
von Freshman goes on air (Gast)
MALGUCKEN schrieb:
> Erstmal der Code:library ieee;
> BITS;
> stopbits
>   begin
>     if RESET='1' then
> process.
>         l_mstate <= START;
>         l_ready <= '0';
>       if v_counter=0 then
>         case l_mstate is
>           when IDLE => null;
            ...schnipp
>       else
>       end if;
>     end if;
>   end process P1;
Dein process ist sehr eigenwillig beschrieben. in eine sebsitixity list
gehört nur Takt und asynchroner reset, das elsif twischen reset und takt
ist auch nicht schön.
Vorschlag: Zeichne ein Blockbild es uarts aus shift Register,
Steuerung-fsm, bitzähler. für jede der drei Komponenten schreibst du
einen eigenen process.
    if RESET='1' then                        -- asynchroner Reset muss Taktsynchron inaktiv werden!
    elsif NDATA = '1' and l_ready = '1' then -- NIEMALS Kombinatorik im Reset!!!
Ganz, ganz böse Sache: asynchroner und kombinatorischer Reset. Das
Design wird niemals stabil laufen: ein einziger Glitch und ein paar FF
der SIO werden zurückgesetzt. Und zwar jedesmal irgendwelche Anderen...
BTW:
Wie viele Takte hat dein Design?
: Bearbeitet durch Moderator
Hi danke für eure Anregung.
Ich habe bezüglich eurer Antworten ein paar Fragen um als Anfänger etwas
Wissen ab zu stauben ;)
1. Ihr meint in der senstiv liste des Prozessen gehören nur CLK und
RESET.
   Ist es nicht so, dass der Compiler (Syntesewerkzeug) eh alle
gelesenen Signal nachträglich in diese Liste einfügt?
2. Ihr fragt nach den CLKs
Ich erzeuge eine BCLK aus dem CLK in Form eines Zählers, welche mir dann
einen CLK erzeugt, welche ca. 12mal Schneller als die Baud rate ist.
Angenommen dies ist falsch und ich benutze nur die CLK dann muss ich ja
in dem RS Block selber immer mit zählen was die Variablenanzahl noch
erhöht und zum andern  den Code noch unübersichtlicher gestaltet.
Die einzige Lösung die mir in den Sinn kommt (keine Erfahrung) ist
dieser schritt wie er in einigen Diskussionsthreads angesprochen wird.
begin process(CLK)
variable v_ch_bclk: bit := '1';
begin
if CLK'event and CLK='1' then
   if v_ch_blk /= BCLK and BCLK='1' then
     v_ch_blk := BCLK;
   else
     v_ch_blk := BCLK;
   end if;
end if;
end process;
Vormal ist das eine Flanken wechsle Erkennung welche synchron mit dem
TAKT läuft.
Vielen Dank :)
> RESET.   Ist es nicht so, dass der Compiler (Syntesewerkzeug) eh alle
Nein. Er ignoriert die Sensitivliste komplett und meldet bestenfalls
mit einer Info, dass die Simulation nicht merh zur generierten Hardware
passt und somit falsch ist.
> 2. Ihr fragt nach den CLKs Ich erzeuge eine BCLK aus dem CLK in Form
> eines Zählers, welche mir dann einen CLK erzeugt, welche ca. 12mal
Dacht ichs mir doch...
So werden keine Takte erzeugt. Arbeite mit 1 einzigen Takt im
gesamten Design. Und wenn du langsamere "Untertakte" brauchst, dann
arbeitest du ausschließlich mit Clock-Enables. So wie dort der "Takt"
für das Lauflicht erzeugt und über clken weitergegeben wird:
http://www.lothar-miller.de/s9y/archives/61-Lauflicht.html
Hallo Lothar Miller,
danke für deine Antworten. Ich habe es jetzt zu einer Takt enable
Schaltung umgestellt. In der tat taucht jetzt in den Timings das Problem
nicht mehr auf. Eine frage habe ich noch. ich frage jetzt den Reset nach
dem clk event ab. Als der Code sieht nun wie folgt aus. (Immer noch
etwas chaotisch)
library ieee;
entity RS232_RX is
      BITS: natural := 8;
  port(
      CLK: in std_logic;
      RESET: in bit;
      BCLK: in bit;
      DO: out bit);
end RS232_RX;
23
  signal l_mstate: state := IDLE;
24
25
26
27
begin
28
29
P1:   process(CLK)
30
31
32
33
  begin
34
35
      if RESET='1' then
36
37
38
39
40
         l_mstate <= START;
41
         l_ready <= '0';
42
      elsif BCLK='1' then
43
        if v_counter=0 then
44
45
          case l_mstate is
46
            when IDLE => null;
47
48
            when START =>
49
              l_obit <= '0';
50
              l_mstate <= SEND;
51
              v_bcnt := BITS-1;
52
53
            when SEND =>
54
55
56
              if v_bcnt = 0 then
57
                l_mstate <= STOP;
58
              else
59
60
              end if;
61
            when STOP =>
62
              l_obit <= '1';
63
64
                l_mstate <= IDLE;
65
66
              else
67
68
              end if;
69
            when others => l_mstate <= IDLE;
70
          end case;
71
        else
72
73
        end if;
74
      end if;
75
    end if;
76
  end process P1;
77
78
  begin
79
    READY <= l_ready;
80
    DO <= l_obit;
81
  end process PO;
82
end STRUCT;
MALGUCKEN schrieb:
> ich frage jetzt den Reset nach dem clk event ab.
Ein synchroner Reset, ok.
Aber: jetzt muss(!) dieser Reset auf jeden Fall auch noch synchron
inaktiv werden. Denn sonst passiert das da:
http://www.lothar-miller.de/s9y/archives/64-State-Machine-mit-asynchronem-Eingang.html
Sieh dir auch das und die verlinkten Posts dazu an:
http://www.lothar-miller.de/s9y/categories/34-Getakteter-Prozess
Und wenn NDATA ein externer (und damit meist asynchroner) Eingang ist,
dann muss der natürlich auch einsynchronisiert werden.
Übrigens: nur Schulen arbeiten mit "bit". Der Rest der Welt nimmt
std_logic...
> std_logic...
:D ja und in dem Buch wird ein ganzes Kapitel über Vor- und Nachteile
von std_logic und bit verschwendet. Die Grundaussage war, das man bit
verwenden soll wenn man std_logic nicht benötigt. Wo und Nachteile?
Tut mir leid da komme ich nicht mit. Ich habe deinen Beitrag gelesen und
die Links dazu. Dort steht nur, das die reset nach dem clk event folgen
soll. Meinst du mit "einsynchronisiert", dass das Signal extern auch mit
clk event erzeugt werden soll? Oder soetwas:
architecture bla of blbla is
signal l_reset:bit := '1';
begin
SYNC: process(CLK)
 begin
    l_reset <= RESET;
  end if;
 end process SYNC;
von berndl (Gast)
MALGUCKEN schrieb:
>> std_logic...
Falls du jemals auf die Idee kommen solltest, einen VHDL Simulator zu
verwenden, dann wuerde der dir mit 'std_logic(_vector)' wunderschoen
Konflikte und nicht initialisierte Signale anzeigen. Und das ist beim
entwickeln ein Riesenvorteil. Frueher hat man mal wegen der
Laufzeit/Rechenleistung darueber rumdiskutiert, ist aber heute kein
Thema mehr...
Und uebrigens: Warum diese komplett unnoetigen Variablen? Die
Nebeneffekte von Variablen ggue. Signalen sind dir hoffentlich bekannt?
von berndl (Gast)
Ein in VHDL beschriebener asynchroner Reset ist jetzt erstmal nix
verwerfliches, der mag ja in deiner Chiparchitektur besser implementiert
sein als ein synchroner. Ausserdem sichert er dich gegen Fehlfunktion
ab, falls mal der Takt gar nicht loslaeuft (Quartz kaputt, PLL laeuft
nicht an, ...)
ABER: Wenn du den Reset 'deaktivierst', dann must du auch dafuer sorgen,
dass innerhalb eines Taktes ALLE daran haengenden Flipflops das
deaktivieren 'sehen'. Sonst laeuft evtl. ein Zaehler falsch los (z.B.
Bit(0) sieht den weggehenden Reset erst einen Takt spaeter) oder eine
State-Machine steht im Wald...
Und deine Toolchain kann dir in diesem Fall nur helfen, wenn der Reset
'synchron' weggenommen wird, ansonsten ist raten angesagt...
Die Nebeneffekte von Variablen sind mir leider nicht bekannt. und ja
signal verwende ich auch. Bitte erklären
Danke
von berndl (Gast)
Eine Variable kannst du ja nur in einem sequenziellen, getakteten
'process' verwenden. Sie nimmt einen ihr zugewiesenen Wert sofort an.
Falls du aber diese Variable 'vorher' im Prozess schon abfragst, dann
ist das der Ausgang eines Flipflops, also einen Takt spaeter. Und das
kann ganz schoen verwirrend sein...
Ein Signal, das in einem 'process' verwendet wird, aendert seinen Wert
erst, wenn du am 'end process;' ankommst, d.h. im ganzen Prozess hat das
Signal den gleichen Wert. De facto also immer ein Flipflop.
Falls du sowas wie eine Variable brauchst (Zwischenergebnis einer
Berechnung oder sowas), dann kannst du das auch als Signal ausserhalb
eines Prozesses mit sogenannten 'concurrent' Anweisungen machen, also
z.B. "a <= '1' when xy = '0' else '0';" Das wirkt dann wie eine Variable
in einem Prozess sofort. Die Gefahr bei Variablen ist dann noch
zusaetzlich, dass sie laufzeitkritische Berechnungen gut verschleiern.
All das hat mich dazu gefuehrt, Variablen nur fuer ganz bestimmte Zwecke
zu benutzen und ansonsten auf 'concurrent' Anweisungen zu setzen. Dein
Code wird dadurch eindeutiger weil klar ist: Isses ein FF oder isses ein
Netz irgendwo in der Logik.
von berndl (Gast)
Gmpf, Korrektur...
Eine Variable kannst du ja nur in einem sequenziellen 'process'
verwenden. Sie nimmt einen ihr zugewiesenen Wert sofort an. Falls du
aber diese Variable 'vorher' im Prozess schon abfragst, dann ist das der
Ausgang eines Flipflops/Latches, also einen Takt/Zustand spaeter. Und
das kann ganz schoen verwirrend sein...
MALGUCKEN schrieb:
> in dem Buch
In welchem?
Siehe den Beitrag "Variable vs Signal"
Das hat mit Flipflop aber nichts zu tun. Das Signal verhält sich auch in
einem rein kombinatorischen Prozess so.
Ob Flipflops involviert sind, sieht man am 'event (gern auch versteckt
im rising_edge() o.ä.).
von berndl (Gast)
joh, haette ich noch auf FF/Latch aendern muessen...
von berndl (Gast)
Danke fuer den Link, den hatte ich gesucht, aber gerade nicht auf dem
Radar...
Schoen waere ja, wenn VHDL 'lokale' Signaldefinitionen im Prozess
unterstuetzen wuerde (also z.B.
hugo : process
    signal xy : std_logic := '0';
begin
end process;
Dann waere den 'lokale Variablen' Befuerwortern viel Wind aus den Segeln
genommen...
Lothar M. schrieb:
> MALGUCKEN schrieb:
>> in dem Buch
> In welchem?
Das bleibe ich schuldig Sitz im Zug ISBN kommt später nach.
Zu den variablen. Sehe ich das richtig das ihr empfehlt das alle
variablen als signale geschrieben werden sollten? Aber macht das den
code nicht noch unübersichtlicher? Wenn ich neben den normalen Signalen
Zähler Signale usw. Habe?
Meine andere Frage mit den ndata blieb offen zwecks Synchronisation.
Aber wie soll ich das anstellen wenn reset auf der linken oberen Seite
des FPGAs erzeugt wird und meine Schaltung rechts unten liegt, dann habe
ich da kein Einfluss. Das muss doch das Synthese tool sicherstellen das
meine Signale zum CLK event da sind.
von berndl (Gast)
Wenn deine Reset Schaltung links/oben liegt, du aber das deaktivieren
des Resets ueber mehrere getaktete Flipflops machst, dann kann dein Tool
ueblicherweise diese 'mehrere getakteten FFs' duplizieren und mit ein
paar Taktzyklen Latenz das auf jeden Ort auf dem Chip verteilen. Und
zwischen zwei FFs kann deine Toolchain auch wunderbar berechnen, ob dein
Timing noch zu halten ist.
Sollte also damit (Takte hinzufuegen, pipelineing, ...) kein Problem
sein, weil: Wann die Schaltung aus dem Reset rauskommt, das kann ja wohl
nicht an ein paar mal 10 Nanosekunden abhaengen...
MALGUCKEN schrieb:
> Das muss doch das Synthese tool sicherstellen das meine Signale zum CLK
> event da sind.
Du sagst der Toolchain, wie schnell du es haben willst. Und die probiert
dann, deine Anforderungen zu erfüllen und sagt es, wenn es nicht
klappt...
Guten Abend,
ich war noch das Buch schudig welches ich verwende:
VHDL-Synthese: Entwurf digitaler Schaltungen und Systeme.
ISBN:  978-3486716771
> klappt..
OK so weit bin ich noch nicht vorgedrungen. Ich denke das ist der
nächste Schritt.
Vielen Dank an alle für die sehr guten Anregungen.
von Michael W. (Gast)
gibt es eigentlich jemanden, der NICHT dieses Buch benutzt?
Sieh dir dazu mal den
Beitrag "Re: Verständnisproblem Xilinx XC9572 CPLD" an.
Aber evtl. sind die dort aufgezeigten Punkte ja schon behoben...
BTW: Peter Ashendens "Designers Guide to VHDL" ist auch recht brauchbar.
> unterstuetzen wuerde (also z.B.hugo :
Signale können 'lokal' innerhalb eines block-Statements definiert
werden:
myblock : block
    process
    begin
    end process;
end block;
Duke
von berndl (Gast)
> werden:
ups, danke! Das hab' ich in der freien Wildbahn noch nie gesehen und es
waere schoener, wenn das zwischen process und begin ginge, aber besser
als nix
von berndl (Gast)
hmmmm, bei Google mit "vhdl block statement" finde ich immer nur
Erwaehnungen von 'concurrent' statements...
Kann ich in ein "block" statement auch einen "process" reinpacken?
Muss ich bei Gelegenheit mal probieren...
berndl schrieb:
> block-Statements [...] freien Wildbahn
In meinem aktuellen Projekt kommen ca. 50 entitys vor. Ein einer davon
verwende ich 'block'.
In VHDL-Beispielen aus dem Netz und in Lehrbüchern wird oft die
kritische Codegröße gar nicht erreicht, um ein block-Statement
einzusetzen.
Duke
