1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.STD_LOGIC_ARITH.ALL;
4 | use IEEE.STD_LOGIC_UNSIGNED.ALL;
5 | --use ieee.numeric_std.all;
6 | library UNISIM;
7 | use UNISIM.VCOMPONENTS.ALL;
8 | entity spi_top is
9 | port (
10 |
11 | XADC_GPIO_0 : in std_logic; --mosi
12 | XADC_GPIO_2 : in std_logic; --slave select
13 | XADC_GPIO_3 : in std_logic; --slave clock
14 |
15 | XADC_GPIO_1 : out std_logic; --miso
16 | reset : in STD_LOGIC;
17 | rs232_uart_rxd : in STD_LOGIC;
18 | rs232_uart_txd : out STD_LOGIC;
19 | sys_diff_clock_clk_n : in STD_LOGIC;
20 | sys_diff_clock_clk_p : in STD_LOGIC
21 | );
22 | end spi_top;
23 | architecture STRUCTURE of spi_top is
24 | component design_1 is
25 | port (
26 | rs232_uart_rxd : in STD_LOGIC;
27 | rs232_uart_txd : out STD_LOGIC;
28 | dip_switches_4bits_tri_i : in STD_LOGIC_VECTOR ( 7 downto 0 );
29 | dip_switches_4bits_0_tri_o : out STD_LOGIC_VECTOR ( 7 downto 0 );
30 | out_clk : out STD_LOGIC;
31 | out_clk_1 : out STD_LOGIC;
32 | gpio_rtl_tri_i : in STD_LOGIC_VECTOR ( 0 to 0 );
33 | gpio_rtl_0_tri_i : in STD_LOGIC_VECTOR ( 0 to 0 );
34 | -- reset_gpio : out STD_LOGIC_VECTOR ( 0 to 0 );
35 | sys_diff_clock_clk_n : in STD_LOGIC;
36 | sys_diff_clock_clk_p : in STD_LOGIC;
37 | reset : in STD_LOGIC
38 | );
39 | end component design_1;
40 | signal clock_rtl1 : std_logic:='0';
41 | signal clock_rtl2 : std_logic;
42 | signal out_clk_p : std_logic;
43 | signal out_clk_p1 : std_logic:='0';
44 | signal count1m : std_logic_vector(3 downto 0):="0000";
45 | signal count1mp : std_logic_vector(3 downto 0):="0000";
46 | signal mosi_8bit: std_logic_vector (7 downto 0);
47 | signal miso_8bit: std_logic_vector (7 downto 0);
48 | signal miso_8bit_new: std_logic_vector (7 downto 0);
49 | signal miso_int: std_logic_vector (7 downto 0);
50 | signal count :STD_LOGIC_VECTOR (2 downto 0) := "000";
51 | signal control, control1, clk_out, clk_out1: std_logic;
52 | signal gpio1: std_logic;
53 | signal gpio2: std_logic;
54 | signal gpio3: std_logic;
55 | signal gpio4: std_logic;
56 | signal gpio_int: std_logic;
57 | signal int_ctrl:std_logic;
58 | signal reset_gpio_int : STD_LOGIC_VECTOR ( 0 to 0 );
59 | signal count_natural : natural:=7;
60 | signal XADC_GPIO_0_dly1: std_logic;
61 | signal XADC_GPIO_1_dly1: std_logic;
62 | signal XADC_GPIO_2_dly1: std_logic;
63 | signal XADC_GPIO_3_dly1: std_logic;
64 | begin
65 | gpio1 <= XADC_GPIO_0;
66 |
67 | XADC_GPIO_1 <= gpio2;
68 |
69 | spi_slave_mosi:process(XADC_GPIO_3)
70 | begin
71 | if rising_edge(XADC_GPIO_3) then
72 | -- gpio1 <= XADC_GPIO_0;
73 | if XADC_GPIO_2 = '0' then
74 | mosi_8bit(0) <= gpio1;
75 | mosi_8bit(1) <= mosi_8bit(0);
76 | mosi_8bit(2) <= mosi_8bit(1);
77 | mosi_8bit(3) <= mosi_8bit(2);
78 | mosi_8bit(4) <= mosi_8bit(3);
79 | mosi_8bit(5) <= mosi_8bit(4);
80 | mosi_8bit(6) <= mosi_8bit(5);
81 | mosi_8bit(7) <= mosi_8bit(6);
82 | end if;
83 | end if;
84 | end process;
85 |
86 | control_slave_mosi:process(clock_rtl1)
87 | begin
88 | if rising_edge(clock_rtl1) then
89 | int_ctrl <= XADC_GPIO_2;
90 | if (int_ctrl = '0' and XADC_GPIO_2 = '1' ) then
91 | control <= '1';
92 | else
93 | control <= '0';
94 | end if;
95 | end if;
96 | end process;
97 |
98 |
99 | spi_slave_miso:process(XADC_GPIO_3)
100 | begin
101 | if rising_edge(XADC_GPIO_3) then
102 |
103 | if XADC_GPIO_2 = '0' then
104 |
105 | gpio2 <= miso_8bit(count_natural);
106 |
107 | count_natural <= count_natural - 1;
108 | if (count_natural=0) then
109 |
110 | count_natural <= 7;
111 | end if;
112 | end if;
113 | end if;
114 | end process;
115 |
116 |
117 |
118 | clk_1mhz:process (clock_rtl2)
119 | begin
120 | if rising_edge (clock_rtl2) then
121 | if count1m=4 then
122 | clock_rtl1 <= not clock_rtl1;
123 | count1m <= "0000";
124 | else
125 | count1m <= count1m + '1';
126 | end if;
127 |
128 | end if;
129 |
130 | end process;
131 |
132 |
133 | design_inst: design_1
134 | port map (
135 | dip_switches_4bits_tri_i(7 downto 0) => mosi_8bit,
136 | dip_switches_4bits_0_tri_o(7 downto 0) => miso_8bit,
137 | gpio_rtl_tri_i(0) => control,
138 | gpio_rtl_0_tri_i(0) => XADC_GPIO_3,
139 | reset => reset,
140 | -- reset_gpio(0) => reset_gpio_int(0),
141 | rs232_uart_rxd => rs232_uart_rxd,
142 | rs232_uart_txd => rs232_uart_txd,
143 | sys_diff_clock_clk_n => sys_diff_clock_clk_n,
144 | sys_diff_clock_clk_p => sys_diff_clock_clk_p,
145 | out_clk => clock_rtl2,
146 | out_clk_1 => out_clk_p
147 | );
148 |
149 |
150 | end STRUCTURE;
