1 | Critical Warning (332148): Timing requirements not met
2 | Info (332146): Worst-case setup slack is -27.842
3 | Info (332119): Slack End Point TNS Clock
4 | Info (332119): ========= =================== =====================
5 | Info (332119): -27.842 -21772.647 plli|altpll_component|auto_generated|pll1|clk[0]
6 | Info (332119): 45.398 0.000 altera_reserved_tck
7 | Info (332146): Worst-case hold slack is 0.335
8 | Info (332119): Slack End Point TNS Clock
9 | Info (332119): ========= =================== =====================
10 | Info (332119): 0.335 0.000 altera_reserved_tck
11 | Info (332119): 0.341 0.000 plli|altpll_component|auto_generated|pll1|clk[0]
12 | Info (332146): Worst-case recovery slack is 97.410
13 | Info (332119): Slack End Point TNS Clock
14 | Info (332119): ========= =================== =====================
15 | Info (332119): 97.410 0.000 altera_reserved_tck
16 | Info (332146): Worst-case removal slack is 1.036
17 | Info (332119): Slack End Point TNS Clock
18 | Info (332119): ========= =================== =====================
19 | Info (332119): 1.036 0.000 altera_reserved_tck
20 | Info (332146): Worst-case minimum pulse width slack is 12.171
21 | Info (332119): Slack End Point TNS Clock
22 | Info (332119): ========= =================== =====================
23 | Info (332119): 12.171 0.000 plli|altpll_component|auto_generated|pll1|clk[0]
24 | Info (332119): 41.561 0.000 CLK12M
25 | Info (332119): 49.513 0.000 altera_reserved_tck
26 | Info (332114): Report Metastability: Found 1 synchronizer chains.
27 | Info (332114): The design MTBF is not calculated because there are no specified synchronizers in the design.
28 | Info (332114): Number of Synchronizer Chains Found: 1
29 | Info (332114): Shortest Synchronizer Chain: 5 Registers
30 | Info (332114): Fraction of Chains for which MTBFs Could Not be Calculated: 1.000
31 | Info (332114): Worst Case Available Settling Time: 344.972 ns
32 | Info (332114):
33 | Info: Analyzing Slow 1200mV 0C Model
34 | Info (334003): Started post-fitting delay annotation
35 | Info (334004): Delay annotation completed successfully
36 | Info (332097): The following timing edges are non-unate. The Timing Analyzer will assume pos-unate behavior for these edges in the clock network.
37 | Info (332098): Cell: altera_internal_jtag from: tck to: tckutap
38 | Info (332123): Deriving Clock Uncertainty. Please refer to report_sdc in the Timing Analyzer to see clock uncertainties.
