Wittig(welec) DSO W20xxA Open Source Firmware (Teil3)
Gast #2010368
Hallo Hayo,
I tried the RS232 Updater on Welec Website, but after a few minutes
trasfer stopped and appear the message:programmierung fertig.Gesamtdauer
0.00.30. and dso hangs.
No more boot also with former 1.4
Let me know how to proceed
BR
Alex
#2011210
Alex schrieb:
> Hallo Kurt,
> I done      Exactly       what is described there.Hang after 30 seconds
> Now any update is accepted anymore.
Hi Alex,
don't worry, update over RS232 is possible at every time, because the
GERMS-Loader Routines are not part of the firmware. They are stored in a
separate memory area.
So lets analyze what went wrong and how we can solve this.
Did You use the .flash file or did You rename the .ram file?
Are You using an USB to RS232 converter or do You have a legacy RS232
Port in Your PC?
Which OS do You use (WinXP, Windows Vista, Windows 7, Linux)
In which version (32 Bit/64 Bit)
The converters may cause problems in some cases, but mostly they work
without problems.
Did You use the original RS232 Kable which was delivered with the DSO?
Checking the RS232 connection can be done with a terminal program (like
teraterm).
Did You start the GERMS-Monitor correctly? The screen makes a short
white flash when switchíng to the monitor mode.
If this doesn't work at all, try to use another PC (from a friend or on
the work etc.)
Hayo
Gast #2011585
Hallo Hayo,
I used flash file directly,I use a real RS232 interface and changed
already the PC.
OS is XP 32bit (tried also ME), I used the original cable ,but changing
the cable is the same.
RS232 link to PC before upgrade attempt was good, I trasfered some
picture and settings in both directions. Germs monitor start correctly
but stops after 30 seconds with RS232 welec updater.
I know Perl should overwite the firmware, now I can't install the serial
file on perl , but  may
be we can understand why.
Alex
#2011798
Alex schrieb:
> Hallo Hayo,
XP 32bit is good - do You have Admin rights?
How did You do this with the original firmware??? It doesn't support the
RS232 Interface!
Can You copy the screen of the WELEC-Updater after trying the update and
post it here? May be this helps us understanding.
The WELEC-Updater should overwrite it also. Be shure You startet the
GERMS-Monitor correctly. If You push the second key first and then the
first key on the left it is only a reset. You must push the left button
first and then the second button.
Don't connect the USB cable at the same time as the RS232 cable. The
RS232 cable should be the only connection to the PC.
Did You try to upload the original firmware with the WELEC-Updater? Are
You using the latest Version 0.4.8A22?
To check the function I made an Upload with the 2.7 Tomcat.flash. It
worked fine. Upload duration was 13 minutes (see screenshot)
Also I renamed the .ram file to .flash and tried it once more.
It also worked without problems.
Hayo
Gast #2011993
Hallo Hayo, good news,we solved the problem.
The cause was conflict in the bios setting of the RS232.
Changing this,I tested the download 1.4 with Welec updater and was
successful,then I uploaded last FW version.
What stops download,and upload of course,is also:a slower PC,must be at
least
1GHz CPU and screen/power savers.
Your firmware is a great improvement for this DSO.
If you like,I can report you some small modification:in FFT mode Hanning
window
is missing and for its good freq response would be nice to have.Shape
and trigger
upper than 50 MHz for sine wave are like 1.4 .Next days I'll go
deeper,it's amazing.
I would like to partecipate to this improvement project as RF
technician(up to 8 GHz and more).
Thank you, also to all for the info in this forum.I like the way this
new year started.
Ciao
Alex
Gast #2016598
Ciao a tutti, pare ci siano problemi con i tempi della ustb, il valore
in secondi impostato non sembra corrispondere alla realtà, è molto più
veloce di quello che dovrebbe essere, qualcuno può confermare?
Visto che ci sono, mi sapete dire quante letture ci stanno in una
schermata?
Caspita peccato proprio ora che mi serviva!! :)
Hello everyone, it seems there are problems with the timing of ustb, set
the value in seconds does not seem to correspond to reality, is much
faster than it should be, can anyone confirm?
Since there are, you tell me how many there are readings on one screen?
Wow sin right now I needed! :)
Gyppe.
Gast #2016619
Scusate mi sono accorto ora come funziona, il massimo è 1Sa/4s la
schermata quindi registra 200s. E' poco mi sembra, prima i tempi
andavano da 1 a 200 secondi o mi sto confondendo? Sarebbe possibile
allungare i tempi magari a 1Sa/minuto o anche 1Sa/2 minuti così da
registrare almeno 1-2 ore?
Sarebbe utilissimo in tante misure.
Sorry, I realized now how it works, the maximum is the screen then logs
1Sa/4s 200s. It 'just seems to me the first time ranged from 1 to 200
seconds or am I confused? It would be possible to lengthen the time or
maybe even 1Sa/minuto 1NT / 2 minutes in order to register at least 1-2
hours?
It would be very useful in many cases.
Gyppe.
#2016691
@hayo
ist es eigetlich absicht das im singel modus die TB nur um 3 werte
aendern laesst und die V/Div gar nicht ? :(
waehre es moeglich die sperre aufzuhaeben ?, auch waehre nett
wenn die verschiebung der Achse in Y Richtung funktionieren
wuerde (Drehgeber direkt ueber den BNC buchsen)
vlG
Charly
#2016758
Charly B. schrieb:
> @hayo
Jain, es ist durch die Sache an sich vorgegeben.
Nein, das Prinzip ist ja, daß im Single/Stop Mode die Daten des bereits
gemachten Samples ausgewertet werden. D.h. hier kann man nur aus dem
vorhandenen schöpfen. Die Anzahl der Zeitstufen ergibt sich dabei aus
der Abtastrate und der Speichertiefe. Die Spannung kann man natürlich
nicht verstellen, da der Drehregler ja auf die Eingangstufe wirkt und
natürlich keine neuen Werte kommen, sondern nur die Alten weiterhin aus
dem Speicher gelesen werden.
> auch waehre nett
Geht leider nicht, bzw. nur unter erheblichem Aufwand da die
Nullinienverschiebung mit den DACs der Eingangsstufe gekoppelt ist und
daher das gleiche Problem besteht wie bei der Verstellung der
Spannungsbereiche.
Hoffe das war einigermaßen verständlich
Gruß Hayo
#2016772
@Gyppe
Did I understand correct, Your timing in the USTB is not korrekt (1s -
200s/Div)?
I adjusted it with a precision function generator, but after that I
optimized some parts in the firmware to make it faster. This could take
effect to the USTB-timing but I didn't check this in the last time.
Also the number of active channels may have influence to the timing.
So let me know if there is any problem.
Regards Hayo
Gast #2017617
No è a posto, 1Sa/4s, 40 minuti l'intera schermata.
Le volte precedenti se non sbaglio i tempi erano molto più lunghi no?
E' possibile allungarli un po in futuro? Magari 2 ore tutto lo schermo,
sarebbe perfetto per vedere le curve di scarica di accumulatori o cose
simili.
No, it's okay, 1Sa/4s, 40 minutes the whole screen.
The previous times, if I remember the times were much longer right?
you can stretch it a bit in the future? Maybe 2 hours the entire screen
would be perfect to see the discharge curves of batteries.
Grazie, Gyppe.
#2017661
No, I didn't change the sample rates. But before I build the USTB
functions there wasn't any functionality in the slow ranges (as in the
orig. 1.4 firmware).
The real sample rate was 50ns/div in all ranges from 2s - 200s/div. So
the ranges where useful for nothing. Most users didn't know that because
they never used the slow time bases.
I have to check how long the maximum interval of the timer which is used
can be.
regards Hayo
Gast #2017702
Tutto chiaro grazie :)
I see, thanks:)
I wonder too! It 's a very useful function in a DSO!
can be.
Wow thanks:) Hopefully!
Gyppe.
#2019442
wenn i das Oszi mit druecken der Single Taste 'scharf'
schalte ist es ja noch 'ungetriggert', wenn es dann
getriggert hat leuchtet ja Run/Stop und das ergebniss
ist auf dem Schirm zu sehen, das ist dann 'getriggert'
ich kenns halt so mit den 'fachausdruecken' :)
(i hoff i hab dich nicht verwirrt ;) )
vlG
Charly
Gast #2019554
Hallo Hayo und alle,
was Charly B. angesprochen hat, das nachträgliche Ändern der
Einstellungen, ist das, was mir als allererstes negativ auffiel.
Das muss sich ändern. ;-)
Wer einmal mit einem LeCroy gearbeitet hat, will nicht mehr darauf
verzichten, weil es dort vorbildlich gelöst ist.
Hayo, hast Du Dir das ddsScope.exe schonmal angeschaut? Genau so stelle
ich mir das vor. Nachträglich zoomen und verschieben in allen
Variationen.
Außerdem habe ich noch nicht herausgefunden, ob und wenn ja, wie Du das
Force Trigger gelöst hast.
Ich stelle mir das so vor:
Wenn im Norm- oder Single-Mode kein Trigger kommt, will ich trotzdem
manuell einen Trigger auslösen können, indem ich auf die Single-Taste
drücke. Die jetzige Funktion, dass bei Drücken der Single-Taste er von
Norm- in den Single-Mode wechselt, würde ich entfernen, da das über die
Stop-Taste geht.
Im Stop-Mode muss sich die Zeitbasis ändern lassen.
Im Auto-Mode muss eine Zeit (maxWait, default 2 Divisions) einstellbar
sein, nach der der Strahl automatisch startet.
Im Norm- und Auto-Mode muss eine Zeit (holdoff, default=0) einstellbar
sein, innerhalb der kein Trigger stattfinden kann.
Die Triggered-Led sollte kürzer leuchten, bzw. es sollte auch
einstellbar sein, dass sie leuchtet, sobald ein gültiger Triggersignal
anliegt, unabhängig davon, ob er zum Auslösen eines Triggers führt (also
auch im Stop-Mode).
Die Ready-Led sollte so schaltbar sein, dass sie im Stop-Mode aus ist.
Trigger soll also ein AND aus Ready-LED und Trigger-LED sein.
Gast #2022415
Ich entschuldige mich für den fordernden Ton meines letzten Posts, ist
normal nicht mein Stil, sondern aus einem "Wunschzettel" entstanden.
Ich hoffe, den einen oder anderen Teil selbst dazu beitragen zu können.
Auch glaube ich, durch diese Ideen wird das Programm wesentlich
einfacher und schneller, und die Funktionalität noch besser.
Darf ich auf meinen Abzweigung des HW-Threads hinweisen, der sich auf
die Bedienelemente (Tasten, Drehgeber, Display, Stecker) beschränkt:
Beitrag "Welec W20xx Bedienelemente modifizieren: Drehgeber Encoder LED BNC-Buchsen"
kollegiale Grüße
Gast #2022537
hallo Zusammen,
es war keine leichte Entscheidung für mich, aber jetzt steht es fest –
ich werde mein W2024 zum Verkauf anbieten.
Das Gerät ist momentan in dem Zustand wie hier beschrieben:
http://welecw2000a.sourceforge.net/docs/Hardware/PCB_messung_1.pdf
Ich hoffe daß jemand an dem erreichten Entwicklungsstand der
Huckepack-Platine anknüpfen und weitermachen möchte (und dazu noch das
Gerät braucht). Weitere 4 teilbestückte (LMH6518) Huckepack-PCBs gebe
ich mit.
Ich fände es schade alles wegzuschmeißen, das Gerät in dem
Originalzustand zurückzubauen und so zu verkaufen, also wenn jemand
interessiert ist – bitte mailen.
Für Rückfragen und Diskussionen werde ich nach wie vor zur Verfügung
stehen.
Walter
Gast #2027798
Hallo Walter,
ich finde es sehr schade, dass du abgesprungen bist! Hoffentlich wird
eure Platine doch noch eingesetzt, wäre ja ein Jammer wenn die
Entwicklung umsonst gewesen wäre (und ich meine vier Platinen wegwerfen
müsste).
Michael
#2038209
Hallo liebe Leute,
nach meiner Winterpause geht es jetzt wieder weiter!
Als Einstieg hier einige Änderungen die Ihr in der Zwischenzeit als
Wunsch geäußert hattet.
Was ist neu?
- Ausgabe der Zahlenwerte überarbeitet. Teilweise wurde durch
Rundungsfehler ein xx.999 Wert ausgegeben, das ist jetzt korrigiert
- Holdoff. Das Thema der letzten Wochen des Jahres 2010. Ich habe den
Wertebereich auf 150ms beschränkt, da einer von Euch gemessen hatte dass
ab 134ms aufwärts keine Veränderung mehr festzustellen ist.
Ich habe die ganze Zähllogik komplett überarbeitet. Die kleinste
Schrittweite ist jetzt 8ns. Kleinere Schritte kann die Hardware nicht
abbilden. Ab 1ms ist die Schrittweite 1µs. Es gibt jetzt 3
Nachkommastellen.
Durch mehrfaches Drücken der Holdofftaste kann in 10er Schritten
weitergeschaltet werden.
- USTB -> es gibt wie von gyppe vorgeschlagen zwei neue Zeitbasen
500s/div und 1000s/div die sich besonders dafür eignen Lade und
Entladekurven von Akkus aufzuzeichnen.
What is new?
- Numeric output improved. Rounding Errors like xx.999 are corrected
now.
- Holdoff. Range is limited to 150ms now. Maximum Value which is working
correctly is 134ms.
New count logic. Smallest step width is 8ns. Smaller steps are limited
by the hardware. The 1ms range has the step width 1 µs. Display has 3
digits after the dot know.
Pushing the Holdoff button multiple switches the value in 10th steps.
- USTB -> Like suggested by gyppe there are two new timebases 500s/div
and 1000s/div which are made for accumulator loading characteristics.
Gruß Hayo
Jörg H. schrieb:
> eProfi schrieb:
>> Z.b. in der Display::PIXELP (wenn ich das richtig sehe, wird der gesamte
>> Bildschirmaufbau darüber gemacht und dementsprechend oft aufgerufen) und
>> allen diese Funktion aufrufenden Routinen:
>> planeadr wird etliche Male durchgereicht, das braucht jedes Mal Zeit.
>> Ist es möglich, das über eine globale Variable zu lösen?
>> Außerdem wird set verwendet. Ich fände es besser, auf 2 Routinen
>> umzuschreiben, einen PIXELC (clear) und eine PIXELS (set)
>> Vorteil: set entfällt und muss nicht geladen, gestackt und ausgewertet
>> werden.
> Das habe ich schon so gemacht und vor vielleicht einem Jahr bei
> Sourceforge eingecheckt. Zusammen mit diversen anderen Optimierungen im
> Bereich der Zeichenfunktionen.
> Jörg
Ich habe das mal geprüft indem ich die pixelp() als inline definiert
habe. Dann fällt das Stacken auch weg - nur der Code wird etwas größer.
Meine Performancemessungen haben keine Änderungen in der Geschwindigkeit
ergeben!! Die Framerate ist exakt die gleiche vorher und nachher. Ich
habe daher alles so gelassen wie es vorher war.
War aber einen Versuch wert.
Gruß Hayo
Gast #2038824
Hayo Tanks:)
> - USTB -> Suggested by gyppe Like there are two new> timebases 500s/div
> Which 1000s/div and are made for loading accumulator> characteristics.
Very good! The'm already trying to get the discharge curve of a
rechargeable battery, 3 hours are just fine, thanks:)
Gast #2038913
Hallo Hayo,
wie schaut es eigentlich mit der Unterstützung für den 16bit DAC
(LTC2602) aus? Im Zusammenspiel mit der Huckepackplatine wäre es schön,
wenn dieser mit unterstützt würde, da sich ja kleinere Spannungsbasen
ergeben.
Gruß, branadic
#2039940
Hi branadic,
Du mußt mich erstmal thematisch ins Boot holen, da ich die Hardware
Details zum Teil nicht so aufmerksam verfolgt habe.
Der 16 Bit DAC hat doch nichts direkt mit der Platine zu tun, sondern
ist optional, oder?
Wenn ich Walters Ausführungen richtig in Erinnerung habe ist der LTC2602
Softwarekompatibel zu dem alten DAC (14 Bit), das heißt er sollte nach
dem Austausch ohne Änderungen an der FW (bedingt) funktionieren, nur
dass er nicht den vollen Bereich der 16 Bit ausschöpft - auch richtig?
Man müßte also nur den numerischen Ansteuerbereich auf die 16 Bit
erweitern, oder müssen auch die Skalierungsfaktoren geändert werden?
-> heißt konkret: ist die Fullscale-Ausgangsspannung identisch?
(ich vermute mal ja)
Das hieße umgesetzt, dass statt wie jetzt die Endwerte bei +/-8192
(16384 Stufen) dann bei +/- 32768 (65536) liegen - korrekt?
Gruß Hayo
#2039958
Und hier geht es schon wieder weiter mit dem nächsten Release.
Angeregt durch die Hinweise von eProfi habe ich die Triggerlogik
geändert. Es werden jetzt auch Triggerevents im Stop-Modus angezeigt
(rote LED bzw. Kanal 4 LED), auch wenn kein Signal eingelesen wird.
Im Stop-Modus ist die Triggerbereitschafts LED (grün) aus.
Es gibt im Mode/Coupling Menü einen neuen Button "Manual Trigger".
Dieser ist verfübgbar im Single-Mode und bei Triggermodus "Normal".
Es kann hiermit ein Triggerereignis manuell ausgelöst werden.
So jetzt werde ich mir erstmal für die anstehenden Lötarbeiten eine
Lötstation bestellen, man muß ja mittlerweile aufrüsten wenn man diesen
filigran-Kram noch bearbeit können will. Und das wo die Augen immer
schlechter werden...
Next version is released now...
Fixed little stop/single bug, changed logic for trigger event LEDs,
added manual trigger in Mode/Coupling menu.
Function is described in the document Special Functions.txt
Gruß Hayo
Gast #2039993
> ist optional, oder?
Vollkommen richtig, zunächst einmal ist der Austausch nicht zwingend
notwendig. Er wird jedoch notwendig, wenn man den Vorteil durch die
Huckepackplatine nutzen will, auch kleinere Spannungsbasen darzustellen
(bis runter zum 1mV/div).
Vollkommen richtig.
Nein, die Skalierungsfaktoren sind davon unbetroffen.
branadic
Gast #2040036
Hallo Hayo,
such es dir aus, Digikey, RS, Farnell...
Hätten wir früher drüber gesprochen hätte ich sie dir mitbestellen
können, jetzt ist es zu spät, denn meine Bestellung ist bereits raus.
Ich hoffe im Laufe der nächsten Woche die Bauteile hier zu haben, dann
bekommst du deine Huckepackplatinen zugeschickt.
Aber ich bin sicher, dass hier der ein oder andere seine
Huckepackplatine ebenfalls langsam mal bestücken will. Vielleicht könnt
ihr wirklich mal eine Sammelbestellung anleiern? Das würde die
Diskussion um "Digikey ist teuer im Versand" abschwächen, denn ab 65,-€
Bestellwert ist der Versand kostenlos. Wenn sich nur zwei Leute zusammen
tun ist der Bestellwert bereits beieinander. Zudem tun sich die Leute
leichter mit der Bauteilauswahl.
branadic
Gast #2040131
Drin hab ich sie noch nicht, aber zumindest schon hier liegen. Der Plan
war es alles in einem Abwasch auf die Welec-Platine zu pflanzen, sonst
muss man mehrfach das Gerät öffnen und da war ich jetzt nicht so der
Freund von.
branadic
#2040584
@Hayo & all
die 2.9 ist meiner Meinung nach 'Buggy'
Reproduzierbar so:
Ch1 auf die interne 1khz, dann Run/Stop, bild steht prima, jetzt
Tastkopf weg von den 1khz, 'Bild' auch weg obwohl Run/Stop rot ist
mach grad downgrade uff die 2.8, hoffe es ist dort nicht
(Downgrade beendet, da ist der Fehler nitt)
ps. warum so kompliziert mit dem manuellen triggern im Single mode ?
im Single mode (Single=rot) koennte doch ein erneutes druecken der
Single Taste ein Triggern ausloesen, oder ?
oder man nimmt die Edge Taste denn mit der geht im moment sowieso
in einen 'undefinierten' zustand (Ver. 2.8)
vlg
Charly
Gast #2041445
Hallo Hayo,
noch ein paar Anregungen für Implementierungen, einige hatte ich bereits
erfragt.
Tastkopf-Kalibrier-Menü:
Wäre es möglich ein Kalibriermenü einzufügen? Aktive Tastköpfe weisen in
der Regel eine Abweichung des DC-Offsets auf. Hier wird diese für den
Tastkopf wegkalibriert, ohne Einfluss auf die ADC-Kalibrierung
vorzunehmen.
Dazu wird der Tastkopf an das Probe-Signal gehängt und der
Gleichspannungsanteil korrigiert. Das Menu besteht aus der Auswahl des
Kanales, an dem der Tastkopf hängt und aus den beiden Einträgen: "Lösche
Tastkopfkalibrierung" und "Kalibriere Tastkopf".
Es handelt sich dabei um eine reine vertikale Kalibrierung.
Deskew-Menü:
In diesem Menu kann man eine Phasenkompensation des Tastkopfes
vornehmen, soll heißen der Tastkopf bekommt wieder das Probesignal an
seinen Eingang und wird nun in der Zeitachse soweit kalibriert, bis
Signaldurchgang und Triggerpunkt übereinstimmen. Das geht sowohl für
positive als auch für zeitlich negative Werte.
Falls sich soetwass implementieren ließe wäre das für das Oszi eine
echte Bereicherung, da sonst nur teure Geräte eine solche Funktion
aufweisen.
branadic
#2041637
Möglich ist es...   - allerdings habe ich einen Solchen nicht und könnte
daher auch die Funktion nicht testen.
Weiterhin müßte sich das doch auch über die normale DAC-Kalibrierroutine
bewerkstelligen lassen, oder?
> Deskew-Menü:
Dazu müßte es eine Rückkopplung des Probesignals in die Firmware geben
(quasi ein Referenztrigger) um das automatisch machen zu können.
Auch das sollte sich manuell uber die Delay-Einstellungen im
Hardwaremenü machen lassen.
> Eine kleine Anregung noch.
> Wäre es vielleicht sinnvoll, einen Meüstrukturplan zu erstellen? Das
> könnte zugleich als Dokumentation zur Firmware dienen.
Eine Vorstufe davon befindet sich in der Programmers Reference. Ein
richtiger Strukturplan wäre natürlich nicht übel.
@all - Wer fühlt sich berufen diesen zu erstellen?
Schon mal als Info:
Die Unterstützung des LTC2602 16 Bit DAC ist schon in Arbeit und kommt
mit dem nächsten Release. Wer baut Ihn denn schon mal ein damit wir
testen können?
Gruß Hayo
#2041748
Hi Hayo,
Danke für die neue Version 2.9.C2.
Ich habe mir die Holdoff-Funktion noch einmal kritisch angesehen: Der
Einstellbereich muß definitiv noch etwas weiter eingeschränkt werden, da
scheinbar ab einem eingestellten Wert von 134.218 ms nicht nur keine
Veränderung mehr festzustellen ist, sondern etwas völlig anders abläuft.
Rainer
#2041842
Ok, kann ich machen. Ich habe die Funktion nur oberflächlich geprüft
aber keine genaue Analyse gemacht.
Ich hatte die 150ms gewählt damit man noch einen gewissen Spielraum für
Streuungen hat. Möglich ist natürlich, dass man mit größeren Werten
quasi einen Buffer Overflow verursacht und dann andere
Harwarekomponenten falsch angesteuert werden.
Gruß Hayo
Gast #2041870
Ich meld mich bei dir deswegen.
Ja klar lässt sich das damit machen, allerdings ist diese Lösung dirty.
Schöner wäre dafür ein eigenes Menü, weil ich dann am Kanal einfach den
Tastkopf wechseln kann, ohne gleich einen komplett neuen DAC-Abgleich
des gesamten Gerätes durchführen zu müssen. Stattdessen hätte ich einen
zusätzlichen Abgleich für einen ausgewählten Kanal.
> testen können?
Werd ich die Tage mal angehen.
branadic
#2041928
Zur Logik die dahinter steckt:
- Stop ist halt Stop. D.h. da geht nix, alles ist angehalten.
- die manuelle Triggerung macht nur in einem Triggermodus Sinn, nämlich
beim Normal-Trigger, da bei den anderen Trigger-Modi durch den
Trigger-Timeout ohnehin ein Triggerevent ausgelöst wird. Nur beim
Normaltrigger kommt halt nichts, da steht das Signal so lange bis was
kommt.
Der Normal-Trigger ist aktiv wenn:
- der Trigger-Mode auf "Normal" steht
- der Single Mode aktiv ist
D.h. nur dann funktioniert sinnvollerweise der manuelle Trigger. Wenn
man im Stop-Mode manuell triggern will muß man nur auf "Single" schalten
und kann dann triggern.
Hayo
Gast #2042396
Könnte man das nicht einfach erledigen, indem vom HW-Setup mehrere
numerierte Versionen gespeichert werden können. Die Standardtastköppe
sind dann mit Setting0 verknüpft. Dann braucht man für die Tastköpfe
nur noch einen Menüeintrag "spezial" und bei dessen Aufruf wird wird
dann neben Name und Teilverhältnis auch die Nummer des Settings
eingestellt.
Das könnte man später auch auf Stromsensoren usw. ausbauen.
Gast #2042436
Danke Hayo, dass Du Dir gleich Zeit für die Verbesserungen genommen
hast.
Allerdings dachte ich an das manuelle Auslösen über ein zweites Drücken
der Single-Taste, wie Charly schon schrieb:
> ps. warum so kompliziert mit dem manuellen triggern im Single mode?
> der Single Taste ein Triggern ausloesen, oder ?
Ich bevorzuge möglichst wenige Tastendrücke.
Das mit dem Inlinen muss man nochmal im ASM-Listing prüfen, ich habe
nämlich schon erlebt, dass bei einem Inline nur der Call weggespart
wird, aber die Stack-Geschichte blieb. Jörg Wunsch hat mir dazu erklärt,
dass das von den Compiler-Einstellungen und dem Programm-Aufbau abhängt
(es gibt z.B. auch _always_include_). Steht in der gcc-Doku ziemlich
gut beschrieben.
> nämlich beim Normal-Trigger, da bei den anderen Trigger-Modi durch
> den Trigger-Timeout ohnehin ein Triggerevent ausgelöst wird.
> Nur beim Normaltrigger kommt halt nichts, da steht das Signal so
> lange bis was kommt.
Ehrlich gesagt, musste ich das mehrmals lesen, bis ich es verstand.
Warum schriebst Du nicht einfach:
Die manuelle Triggerung macht nur im Normal- und Single-Triggermodus
Sinn?
Autor: Jörg H. (idc-dragon) Datum: 05.01.2011 14:08
Hayo, hast Du die anderen Verbesserungen mal angeschaut?
Ich würde schon begrüßen, dass die Verbesserungen eingearbeitet werden,
wenn Jörg sich schon so viel Mühe gemacht hat.
Ich schlage einen Teil 4 vor. Das Scrollen hier dauert eine halbe
Ewigkeit.
#2042481
Also das Letzte zuerst,
ja ich denke es macht zum neuen Jahr durchaus Sinn einen neuen Hardware
und Softwarethread zu starten. Gleicher Name und eine Nummer höher, dann
hat man den Bezug.
Wer macht es diesmal? Nicht vergessen den alten Thread sauber
abzuschließen, damit da nicht ewig weitergepostet wird.
Ihr habt alle echt gute Ideen und Vorschläge, seit mir nicht böse wenn
ich die nicht sofort alle umsetze. Zum Teil muß ich da erst drüber
nachdenken und ich habe natürlich auch nur begrenzt Zeit für die
Umsetzung. Die Sachen die sich interessant anhören notiere ich mir auf
jeden Fall und gehe sie dann bei Gelegenheit an.
Guats Nächtle
Hayo
#2042628
Hallo Hayo,
ein paar Anmerkungen wegen den Screenshots:
1. Du hast die B/W screenshots im OS_CompMode wegrationalisiert. Lösung:
if(OS_CompMode)
  if(marker == 'B') OS_SCREENSHOT();
  else if (marker == 'P') OS_SCREENSHOT_BW();
  return;
2. Ein Screenshot mit der OS-Version dauert höchstens 20s. Die
BF-Version braucht maximal 29s. Gibt es einen guten Grund an der
BF-Version festzuhalten? Sonst machen wird die OS zum Standard und an
Stelle der BF baue ich meine Routinen zur Übertragung an den SD/USB-Host
ein.
3. Finde ich es sinnvoller den Softkey "Save to BMP" in "Save color"
umzubenennen und "Save to PGM" in "Save B/W". Das ist eindeutiger,
außerdem wechselt man eh nicht ständig das Dateiformat. Das kann ja
weiterhin von der PC-Software bestimmt werden.
4. In deinen *.zip liegt im Screenshot_0.92OS Ordner ein kaputtes pdf.
5. Habe ich gerade vergessen. ;-)
Mfg,
Kurt
#2043014
Hi Kurt.
> if(OS_CompMode)
>   return;
Wozu brauchst Du denn Schwarzweiß-Screenshots? Ich dachte die wären eher
überflüssig. Kann ich aber wieder nach Deinem Vorschlag einbauen wenn
das benötigt wird.
> ein.
Ja es gibt einen Grund, den hatte ich auch schon mal vor einiger Zeit
erläutert. Die OS-Screenshotverion ist zwar von der Kompressionsroutine
her auf aktuellerem (heißt schneller) Stand, aber mir gefällt das
Bedienkonzept der remote Steuerung bei der OS-Version nicht so gut. Ich
möchte lieber die Steuerung direkt am Oszi vornehmen.
Das ist aber leider nicht ganz korrekt, da auch PGM in Farbe gespeichert
wird. Der Unterschied ist im Wesentlichen, dass bei PGM die Farblayer
einzeln erzeugt werden, und bei BMP werden diese gleich "gemerged" zu
einer Datei.
Was ich mir vorstellen könnte wäre, dass abhängig von der Auswahl BF/OS
die Buttons eine jeweils eigene Beschriftung und Funktion haben (dann
könnte man da für die OS auch BW mit einbauen) -> also ein dynamisches
Menü, dann kann jeder nach eigenem Gutdünken arbeiten.
Muß ich mal prüfen, ich hatte den Ordner einfach so kopiert ohne den
Inhalt zu checken.
Kenn ich, das ist altersbedingt. Versuchs mal mit nem Reset...
Gruß Hayo
#2043054
Eine extra Taste für den manuellen Trigger braucht man aber auf jeden
Fall, da man sonst im laufenden Betrieb bei "Normal" Triggerung nicht
manuell auslösen kann. Ich kann aber den manuellen Trigger zusätzlich
als weiteren Druck der Single-Taste mit einbauen. Sehen das die Anderen
hier auch so?
> Sinn?
Sorry wenn ich das unnötig verkompliziert habe.
Gruß Hayo
#2043079
Ich brauche die garnicht, aber vieleicht jemand anders? Keine Ahnung.
Das heißt du könntest nur die Kompressionsroutine übernehmen?
> wird.
Du sagst es. Ein Portable Graymap wird in Farbe abgespeichert. Der
Button sollte dann "Save to PPM" heißen.
Gute Idee! Bekomme ich dann den 5. Soft-Button als "Save to USB"?
Mfg,
Kurt
