Transistortester AVR
OP #3344328
Marco schrieb:
> is it possible to use a 16 MHz crystal instead of the standard 8 MHz?
Tomas P. schrieb:
> You can find it in the original manual.
> Specifically:
> Chapter 4 - Configuring the TransistorTester
> page 21 - option OP_MHZ
But you should know, that there is no significant advantage to use the
16 Mhz crystal. The controller just takes more current and wait faster
for completing the ADC or for the expiring the wait times. You should
not expect to make the tester faster or to increase the resolution or
precision of the measurements.
Regards, Karl-Heinz
Gast #3344336
Hello Karl-Heinz,
I figured out too that there is no advantage but I happen to have many
16MHz crystals and no 8MHz ones at the moment.
I tried internal 8MHz RC clock and external 16 MHz crystal and infact
there is almost no difference.
Everything runs fine but the shut off time is always twice the expected:
28 sec instead of 14 with both clocks sources.
I use a Mega328P and the auto shut off circuit
Any idea?
Thank you
Marco
OP #3344627
> Any idea?
Hello Marco,
Thank you for reporting the bug.
Some users had found the 14 seconds too short. So I had increased the
wait time to 28 seconds (#define LONG_WAIT_TIME 28000 in file config.h).
But I had forgotten to change the documentation!
Longer display time make sense for newer software versions because the
sleep mode of the ATmega is used by default to save power.
Regards, Karl-Heinz
Gast #3344900
Hello Karl-Heinz,
Glad to help you.
I built an early version of the tester a lot of time ago.
It was already very good but the last versions are really awesome!!!
Thank you for sharing and supporting it.
Best regards,
Marco
Gast #3347317
Hallo, ich habe noch den "Uhrvater" des Testers hier, mit einem Mega8
und ohne Automatische abschaltung. Welche Software könnte ich für dieses
Gerät noch verwenden? Es ist ein 2x16 LCD verbaut.
Danke!
OP #3347347
Hallo Andreas,
im Prinzip jede der veröffentlichten Versionen mit der k Endung der
Versionsnummer.
Ohne Prozessortausch (ATmega8 <--> ATmega328) wird aber auf viele
Meßmöglichkeiten verzichtet. Wenn kein Pullup Widerstand (10k) an Pin 13
nachgerüstet wird, muß die Makefile Option PULLUP_DISABLE entfernt
werden und die Software neu übersetzt werden.
Wenn der Prozessor getauscht wird, sollte entweder die Software mit
Entfernen der Makefile-Option NO_AREF_CAP angepaßt werden oder der 100nF
Kondensator am AREF Pin gegen einen 1nF getauscht werden. Wenn kein 8MHz
Quarz nachgerüstet wird, muß bei den neueren Versionen auch die Makefile
Option RESTART_DELAY_TICS=6 gesetzt werden oder die Schlaf-Funktion des
ATmega mit der Makefile Option INHIBIT_SLEEP_MODE verhindert werden.
Der Prozessor sollte aber auf jeden Fall mit 8 MHz Takt betrieben werden
und nicht bei 1 MHz wie die alte Version!
Die Umrüstung ist auch in der PDF Dokumentation beschreiben.
Grüße, Karl-Heinz
OP #3347613
Hallo Transistortester Freunde,
wie einige vielleicht schon bemerkt haben, habe ich die Entwicklung für
die 1.08k Version abgeschlossen.
Mit der neuen Makefile Option LCD_DOGM kann jetzt auch ein Display mit
ST7036 Controller (DOG-M von Electronic Assembly) angeschlossen werden.
Wegen Speichermangel beim ATmega168 kann die Stromverstärkung nur noch
in Kollektorschaltung (oder Emitterschaltung) bestimmt werden. Beim
ATmega328 wird in beiden Schaltungen gemessen und der höhere Wert
ausgegeben. Deshalb gibt es jetzt zwei neue Unterverzeichnisse mega328
und mega328_strip_grid für die Programmdaten des ATmega328.
Bei Einzeldioden wird jetzt auch der Strom in Sperrichtung gemessen.
Deswegen entfällt bei der Ausgabe der Text "Diode".
Bei der Bestimmung der Stromverstärkung in Emitterschaltung wird der
Kollektor-Reststrom berücksichtigt. Dies ergibt für Germanium
Transistoren realistischere Werte für die Stromverstärkung.
Die Spannungsgrenze für die Erkennung von Verarmungs FETs wurde
verändert, um eine Verwechslung mit Germanium Transistoren mit höherem
Kollektor-Reststrom zu vermeiden.
Außerdem habe ich entdeckt, daß eine neue chinesische Version des
Testers bei Ebay aufgetaucht ist. Diese Version benutzt einen ATmega328
Prozessor in der DIP Version und für die Testports eine Textool Fassung
und zusätzlich ein SMD-Testfeld. So weit ich erkennen kann, sind nur
bedrahtete Bauteile verwendet worden. Als Software wird entweder die
1.07k oder die 1.08k verwendet (Vloss erscheint bei der
Kondensatormessung!).
Grüße, Karl-Heinz
#3354907
Alternative means of power supply using adjustable output step-up DC/DC
converter MAX757. It can also be used MAX576 with a fixed voltage 5V.
Circuit works reliably from 0.7V.
The power supply can be used:
- 1x or 2x AA (AAA) battery
- charger for mobile battery
- USB port
This is not my solution - the documents I received from the author of
this modification. To ensure the functionality of this solution is
needed slight adjustment software, which has the effect of removing the
initial testing 9V batteries. If necessary, I can also attach software,
which I edited.
Gast #3356052
Hello,
I would like to ask about the value of the parameter DCAP_EMPTY_LEVEL
for stable operation china clone, I use a different PCB, but sometimes
people want, I already have on my china clone soldered capacitor and now
I have to try, thanks for the info M
OP #3356166
Hello Milhaus,
the parameter CAP_EMPTY_LEVEL defines the maximum voltage of a
discharged capacitor in mV units. Normally this parameter need no
change. If you are shure, that your VCC voltage is stable and that the
VCC and AVCC power voltage is blocked with sufficient capacity, you can
increase the default value of 4 to 6 or 8 mV. But incresing this value
can cause a inexact capacity value of capacitors, especially those with
bigger capacity.
Unloading of capacitors is done even if there is no capacitor connectet!
You can also try to set the option INHIBIT_SLEEP_MODE to prevent the
ATmega to switch to sleep mode. This will result to a more stable
current consumption. But your battery will be empty faster.
Does your tester report the "Cell!" message?
Regards, Karl-Heinz
#3357126
Hallo Karl-Heinz, hallo Forum
nachdem ich die ursprüngliche Version von Markus Frejek fertig gestellt
und getestet hatte, bin ich natürlich auch auf die hier beschriebene
Weiterentwicklung gestossen, die ich sehr interessant finde. Meine
Hardware: z.Z. Mega-8 ohne Quarz (1MHz, 8MHz intern). Als Einstieg habe
ich die Software 120217 - und zwar die vorkompilierte Datei
TransistorTester8MHz.hex auf den Prozessor übertragen - Fuse Bits für
8MHz wie angegeben, 65ms Startup - funktionierte bestens! Damit ich die
Software auch ändern und kompilieren kann, habe ich dann der Anleitung
von Michael D. vom 13.07.2012 folgend die Quelltexte (v120217) nach
AVR-Studio migriert, mit dem Ergebnis, dass der Compiler mit "Build all"
auch alles fehlerfrei übersetzt und eine neue Hex-Datei erzeugt. Nur die
läuft dann nicht mehr auf meiner Hardware. Da ich nicht so ein C-Freak
bin, handelt es sich sicherlich um einen Anfängerfehler. Was könnte ich
falsch gemacht haben?
Thomas N.
OP #3357346
Thomas Neveling schrieb:
> Damit ich die
Hallo Thomas,
wie Du wahrscheinlich weisst, benutze ich AVR Studio nicht. Ich empfehle
die Benutzung von WinAVR oder Linux. Wenn die vorkompilierte Version
läuft, muß der Pullup Widerstand (PD7) eigentlich schon nachgerüstet
sein. Ich gehe auch davon aus, daß meine Makefile aus dem mega8
Unterverzeichnis benutzt wurde.
Was genau passiert denn mit dem AVR Studio kompiliertem Programm?
Schaltet der Tester ein (LED leuchtet) und auch wieder nach etwa 30
Sekunden aus? Wenn ja, kann man mit einer an die Testpins
angeschlossenen Leuchtdiode sehen, ob die Testfunktion läuft (LED
flackert). In diesem Fall könnte ein Problem bei der LCD-Ausgabe liegen.
Grüße, Karl-Heinz
#3357498
Hallo Karl-Heinz,
danke für die sehr schnelle Antwort. Ich habe den Fehler gefunden: Das
Makefile der Version 120217 war noch auf 1MHz eingestellt. Das habe ich
auf 8MHz geändert jetzt läuft es. Ich benutze übrigens noch die ganz
einfache Hardware ohne Batterieabschaltung, LED etc, Taster zwischen PD7
und GND ohne Pull-up Widerstand, denke aber über ein neues Eagle Layout
mit Quarz etc nach. Bei Dioden bekomme ich immmer 0pF
Sperrschicht-Kapazität angezeigt. Liegt das an der schlechten Qualität
des internen Oszillators?
Grüße
Thomas
OP #3357780
Hallo Thomas,
die ATmega8 Version hat wahrscheinlich keine halbautomatische
Kalibration der Nullkapazität. Dann ist wahrscheinlich etwa 39pF
voreingestellt. Wenn der aktuelle Aufbau weniger Eigenkapazität hat,
werden kleine Kapazitätswerte nicht angezeigt. An dem fehlenden
Quarz-Takt kann es nicht liegen. Der interne Oszillator hat
normalerweise auch eine brauchbare Genauigkeit. Die aktuellen Versionen
im SVN-Archiv
http://www.mikrocontroller.net/articles/AVR_Transistortester#Downloads
haben die Kalibration (Selbsttest) nur für den ATmega168/328 integriert.
Wenn die Dioden höhere Restströme in Sperr-Richtung haben, funktioniert
die Kapazitätsmessung nicht (z.B. bei Germaniumdioden oder bei
Leistungs-Schottkydioden). Hier hilft manchmal kühlen der Diode mit
Kältespray.
Zum Test kann man aber der Diode einen Kondensator (z.B. 100pF) parallel
schalten, um die Meßfunktion zu überprüfen.
Grüße, Karl-Heinz
Gast #3358106
Hallo, ich hab ein Problem mit dem Aufbau des Testers. Ich hab mir eine
Platine aud dem Beitrag
Beitrag "Re: Transistortester AVR" erstellt. Wenn ich
die Schaltung OHNE AVR teste, ist alles ok, die Spannungen wie sie sein
solten. Stecke ich aber den AVR in seinen Sockel, wird in kürzester Zeit
der Spannungsregler heiß, und nichts tut sich. Kurzschlüsse auf der
Platte können es ja nicht sein, würde sich ja auch ohne den AVR
bemerkbar machen. Bitte um Hilfe!
OP #3358142
Hallo Andreas,
bitte überprüfe spannungslos und ohne Prozessor mit einem Ohmmeter oder
Durchgangsprüfer, daß Pin 22 und 8 mit GND verbunden ist und Pin 20 und
7 mit VCC. Kein anderer Pin sollte eine direkte Verbindung zu VCC oder
GND haben.
Grüße, Karl-Heinz
OP #3358187
Andreas schrieb:
> Belegung ist einwandfrei, keine anderen pins haben verbindung mit GND
> bzw. VCC.
Ließ sich der ATmega einwandfrei programmieren?
Vielleicht besteht ja sonst die Möglichkeit, den ATmega auf einem
Steckbrett oder in einem provisorischen Sockel anzuschließen und die
Stromaufnahme zu messen. Dabei brauchen nur die Pinne 8 und 22 an GND
und die Pinne 7 und 20 an 5V angeschlossen werden.
Grüße und viel Erfolg, Karl-Heinz
#3359372
Gibt es irgendwo die Möglichkeit einen Tester fertig montiert im Gehäuse
und der aktuellen Version zu erwerben?
Habe bisher nur ausländische Produkte gefunden, meistens ohne Gehäuse
und dann auch nicht die aktuellen Softwareversionen.
Anschlussmöglichkeit sollte über SMS Pad, Strippen und Klemmbock,
ähnlich wie bei den Chinatestern möglich sein.
Vielleicht ist ja jemand aus dem Forum bereit einen aufzubauen. Ich
schaffe es momentan zeitlich einfach nicht.
OP #3359796
Hallo Manfred,
da ist mir leider auch nichts bekannt.
Bei Ebay werden zwar auch chinesische Tester im Gehäuse angeboten.
Wahrscheinlich verwenden die aber die SMD-Platine und der Name MK-168
läßt auf einen ATmega168 schließen. SMD-Pads und eine Textool Fassung
werden als Aufsteckmodul ebenso wie Kabel mit Klemmen mitgeliefert.
Die neueste Version der China-Tester verwendet aber einen ATmega328 in
der DIL Version und auch sonst bedrahtete Bauteile. Das Display ist bei
dieser Version verschraubt und für die Test-Ports verwendet dieser
Tester neben einem SMD-Feld einen Textool Sockel. Diese Version wird
ohne ISP-Stecker geliefert, so daß der ATmega328 zum Umprogrammieren aus
dem Sockel genommen werden muß. Wenn man die Platine in ein Gehäuse
baut, könnte man auch einen ISP-Stecker auf einer Lochraster-Erweiterung
mit Kabeln nachrüsten.
Nach meinem Wissen verwendet diese Version die Software 1.07k und kostet
bei einigen Anbietern nur 25 Dollar.
Grüße, Karl-Heinz
OP #3360929
Manfred G. schrieb:
> oder gibt es da
> irgendwas wesentliches zu bemängeln aus deiner Sicht?
der Innenaufbau ist mir nicht bekannt, lediglich der mega168 ist für die
aktuelle Software etwas knapp. Besser wäre der mega328. Wahrscheinlich
muß auch die Software noch auf den letzten Stand gebracht werden.
Bei einer ebay Suche mit Stichwort "transistor tester ESR" findet nan
auch den mit dem mega328. Der hat allerdings kein Gehäuse!
Grüße, Karl-Heinz
OP #3361038
Manfred G. schrieb:
> Meinst du das man das anpassen könnte?
Die drei Anschlußschnüre mit Krokodilklemmen könnte man in den Textool
Sockel stecken, auf der Seite des Textool Sockels am besten angelötet an
eine Stiftleiste. Auf ein Gehäuse könnte man verzichten wenn man nur die
Unterseite mit einer Platte gegen Kurzschlüsse schützt. Vielleicht kann
man die Platte dann etwas größer machen und die Batterie mit einer
Klammer montieren. Mit mehr Aufwand ist auch ein Gehäuse-Einbau
möglich.Jedenfalls ist bei dieser China-Version der Prozessor
austauschbar. Damit könnte man den ATmega gegen einen programmierten mit
der letzten Software tauschen. Ein programmierter ATmega328 wird
übrigens derzeit von Guloshop für 3 € angeboten.
Grüße, Karl-Heinz
#3361115
Toll, das wäre die richtige Lösung. Der Atmega der momentan da drin ist
hat wohl schon den neuesten Software Stand.
Insofern wäre ein Tausch doch jetzt nicht nötig.
Du meinst sicher den Tausch für zukünftige Updates oder?
Herzlichen Dank für deine kompetente selbstlose Hilfe.
Gruß Manfred
OP #3361150
Leider weiß ich nicht genau, welche SW installiert ist, das wird aber am
Ende des Selbsttest ausgegeben. Auf einer amerikanischen Webseite hat
man die Version 1.07k festgestellt. Diese Version hat manchmal Probleme
bei der Erkennung von Germanium Transistoren mit höherem Reststrom.
Bei der 1.08k wird auch der Reststrom von Einzeldioden gemessen und der
Kollektor-Reststrom bei der Ermittlung der Stromverstärkung von
Transistoren in Emitterschaltung berücksichtigt.
Grüße, Karl-Heinz
#3361429
Eine Frage ist mir noch eingefallen. Ich hatte bisher von ELVIS de ESR
Tester ELV1 zum bestimmen des ESR in Circuit im Einsatz. Funktioniert
durch die niedrige Messspannung auch sehr gut.
Kann ich diesen nun in den Ruhestand schicken weil unser Universaltester
dies auch kann?
Ich glaube der Avr Tester nimmt aber höhere Messspannung Idas Pn.
Übergänge durchgeschaltet würden wenn in Circuit gemessen wird. Wenn dem
so wäre müsste ich den Elvis ja noch im Messpark belassen.
Gruß Manfred
OP #3361936
> dies auch kann?
Hallo Manfred,
der Transistortester verwendet bei der ESR-Messung auch eine kleine
Meßspannung. Aber die anderen Bauteilerkennungen werden zuerst gemacht.
Deswegen ist der Tester normalerweise nicht für die "in circuit" Messung
geeignet. Außerdem wird zuerst die Kapazität gemessen und danach erst
der ESR. Bei der Kapazitätsmessung ist der Spannungswert bei der Messung
abhängig von der Kapazität. Bei kleineren Kapazitäten ist die
Meßspannung gleich wie die interne Spannungsreferenz (1.1V). Bei
größeren Kapazitäten kann die Meßspannung auch nur 60mV betragen.
Vielleicht entwickle ich auch mal eine Software für die ESR /
Kapazitätsmessung, welches in der Schaltung messen kann. Dafür wird aber
ein anderer Prozessor verwendet werden.
Grüße, Karl-Heinz
Gast #3362112
mein Gerät funktioniert so weit recht ordentlich, nur Thyristoren
mag das Gerät nicht. Von ca. 10 versch. Typen werden nur recht alte
von TESLA sicher erkannt. Germaniumdioden (DDR-Typ GYxxx) werden
grundsätzlich als Kondensatoren mit ca. 25pF ermittelt.
Irgendwie seltsam, oder?
OP #3362193
Hallo Frank,
bei Thyristoren muß ein kleiner Zündstrom und auch ein kleiner
Haltestrom vorhanden sein, damit sie erkannt werden. Das ist meistens
nur bei Kleinsignal Thyristoren (TRIACs) der Fall. :-(
Eine GY100 Diode wird bei mir einwandfrei erkannt:
1-|<-2   Ir=7.6uA
UF=254mV  C=0pF
Der hohe Reststrom verhindert eine Kapazitätsmessung!
Wenn ich mit Kältespray kühle, geht der Reststrom zurück und es wird
eine Kapazität von 16pF ermittelt.
Welche Software-Version wird denn benutzt?
Wurde der Selbsttest/Kalibration durchgeführt?
Grüße, Karl-Heinz
OP #3363962
Michael D. schrieb:
> Stromversorgung mit nur einer Knoppzelle?
Hallo Michael,
die Hardware dieses Testers wurde ja von Funkamateuren entwickelt.
Der Tester besitzt auch eine USB-Schnittstelle, die in der
Standardversion für die Power-Versorgung genutzt werden kann.
Der Tester kann aber auch auf LiPo-Akku umgerüstet werden, wenn man die
Ladeschaltung auf dem Board nachrüstet. Auch eine serielle Ausgabe über
den USB-Port kann nachgerüstet werden! Näheres findet man im oben
genannten Artikel in der "Funkamateur" und im oben angeführten Wiki.
Grüße, Karl-Heinz
#3364220
Hallo Ihr,
ich habe den Transistortester auf der Platine von Moritz A. aufgebaut
und jetzt festgestellt, das sich die Messwerte beim Betrieb des Testers
an einem Netzteil von denen bei Batteriebetrieb unterscheiden.
Aufgefallen ist mir dies am Sperrstrom von Dioden. Bei gleicher Diode
messe ich im Batteriebetrieb 4nA, im Netzteilbetrieb zw. 24 und 32nA.
Und das reproduzierbar.
Dabei spielt es keine Rolle, ob es sich um ein unstabilisiertes
Steckernetzteil mit konventionellen Trafo, ein stabilisiertes
"EcoGreen"-Schaltnetzteil oder ein lineares Labornetzteil handelt. Immer
ist der Wert stark erhöht. Kennt jemand diesen Effekt?
Ich könnte mir vorstellen, das dies an Einstreuungen liegt, denn ich
löse im Steckernetzteilbetrieb schon eine Messung aus, wenn ich mit dem
Finger an die Basis von T2 komme, bzw. an den entsprechenden Pin vom
Taster.
Ist dies normal so oder muss ich von einem Schaltungsfehler bei mir
ausgehen?
Gruß Dirk
OP #3364312
> ausgehen?
Hallo Dirk,
von einem Schaltungsfehler gehe ich erst einmal nicht aus. Mit
verschiedenen Aufbauten habe ich versucht, den Effekt bei mir zu
reproduzieren. Sowohl mit der modifizierten China-Version als auch mit
anderen Aufbauten habe ich kaum einen Effekt beobachtet.
Auch die Version der Funkamateure im Gehäuse zeigt keine deutliche
Änderung der Restströme beim Betrieb an der USB 5V.
Gibt es denn eine Änderung, wenn man zusätzlich den GND mit dem
Schutzleiter verbindet? Wie verhält es sich, wenn man nur den GND mit
dem Labornetzteil verbindet? Ansonsten würde ich die Abblockung von VCC
und des Spannungseingangs mit Kondensatoren überprüfen bzw. probeweise
Kondensatoren nachrüsten. Man könnte auch an eine Drossel auf der
Plus-Seite der externen Versorgung nachdenken, wenn der Test mit der GND
Verbindung zum Netzteil bei Batteriebetrieb keine Änderung ergibt.
#3364340
Hallo Karl-Heinz,
vielen Dank für Deine Lösungsvorschläge. Zwei der Dinge konnte ich eben
überprüfen.
- Schutzleiter an GND bei Steckernetzteilbetrieb lässt den Effekt
verschwinden
- GND an Labornetzteil bei Batteriebetrieb lässt den Effekt entstehen.
Die Abblock-Cs schaue ich mir morgen an.
Gruß Dirk
#3365602
in wie fern ist der -
"Bausatz für einen universellen Bauteiltester nach DF3DCB/DH8GHH" -
mit dem hier durch gedachtem Tester Vergleichbar?
Bis jetzt konnte ich feststellen, das die Funkamateure einem Mega 168
einsetzen.
Was an dem Funken interessant ist das sie kompletten Bausatz Anbieten.
Grüß
bongobongo
OP #3365703
Der Meßteil des Testers ist absolut identisch. Die Software wurde nur
bezüglich der geringeren Batteriespannung (Makefile-Option) angepaßt.
In der Software sind viele Anregungen von den Funkamateuren
eingeflossen.
So z.B. die Stromspar-Funktion und die Möglichkeit, die Abschaltgrenze
der Batteriespannung auf sehr kleine Werte setzen zu können wegen dem
verbauten DC-DC Wandler.
Der Aufbau des Testers ist sehr klein. Trotzdem fehlt nichts
wesentliches, das Testpad für SMD-Bauteile ist vorhanden in das auch
bedrahtete Bauteile in Durchkontaktierungen gesteckt werden können. An
der Seite kann ein Kabelsatz mit Testclips zugesteckt werden. Ein
ISP-Stecker für eventuelle Software-Updates fehlt trotz des kompakten
Aufbaus auch nicht.
Der Preis ist zwar für einen Bausatz nicht gerade billig, man muß aber
berücksichtigen, daß eine vorbestückte SMD-Platine und ein bearbeitetes
Alu-Gehäuse mitgeliefert wird. Zur Zeit können Abonnenten der
Funkamateur Zeitschrift den Bausatz für 69,-€ vorbestellen.
Grüße, Karl-Heinz
OP #3365721
Dirk K. schrieb:
> Kannst Du anhand meiner Beobachtungen vielleicht sagen, was den nun das
> Problem sein könnte?
Hallo Dirk,
einerseits verschwindet der Effekt der unterschiedlichen Meßwerte
(Netzteil/Batterie), wenn der Netzteilausgang mit dem Schutzleiter
verbunden ist. Andererseits werden andere Meßwerte bei Batterie-Betrieb
gemessen, wenn nur der GND des Netzteils mit dem GND der Testers
verbunden ist. Dies läßt eigentlich nur den Schluß zu, daß die Testports
irgendwie als Antenne für die über das Netzteil eingeschleppte
Wechselspannung wirken.
Wie hoch ist denn die Wechselspannung des Netzteilausgangs hochohmig
gegen den Schutzleiter gemessen?
Grüße, Karl-Heinz
#3365746
Hallo Karl Heinz.
habe den Funkbummi gerade zu liegen aber den Artikel noch nicht gelesen.
Habe mich lediglich beim Durchblättern für die Quellenangabe
interessiert, da ich hier schon was davon gelesen hatte.
Bei den Quellenangaben tauchst Du unter 4. auf.
Beziehen die sich auf Dinge die Du gegenüber Markus F. anders/ besser
gemacht hast? Oder haben die einfach nicht bemerkt das Du den Tester von
Markus verbessert hast und die Grundidee von Markus stammt ?
Ist nicht abwertend gemeint. Ich schätze Deine Mühe und Arbeit.
Mich interessiert lediglich der Zusammenhang.
Danke und Gruß
Stephan
#3365776
Hallo Karl-Heinz,
je nach Netzteil sind das zw. 60V und 75V. Kann das an meiner dämlichen
Hausverkabelung liegen?! Habe hier leider noch ein  TN-C-System in der
Wohnung. Hat das diese Auswirkungen?
Ich werde am WE überprüfen, ob noch weitere Kenngrößen betroffen sind.
Ansonsten tangiert mich der Sperrstrom selten.
Dank Dir jedenfalls für Deine Mühe mit mir.
Gruß Dirk
OP #3367823
Wojtek Jan schrieb:
> bedeutet das,dass der hier erdachte Tester auch Induktivitäten Testen
> kann?
Hallo Wojtek,
bedingt ja. Es wird erst der ohmsche Widerstand bestimmt. Wenn der
Widerstand eines einzelnen Bauteils unter 2100 Ohm liegt, wird die
Induktivität bestimmt. Dabei ist die Meßauflösung 10uH, wenn der
Widerstand unter 24 Ohm beträgt. Bei höherem Widerstand (<2100 Ohm)
beträgt die Meßauflösung 100uH.
Die Induktivitätsmessung durch Bestimmung der Zeitkonstante ist etwas
problematisch, funktioniert aber meistens recht gut. Problematisch sind
Eisenkerne wegen der Remanenz.
Die Fähigkeiten sind kurz in der Übersicht
beschrieben. Näheres zu den Meßverfahren und Ergebnissen stehen in der
PDF-Beschreibung (deutsch/englisch).
Grüße, Karl-Heinz
OP #3368161
Dirk K. schrieb:
> Ist das normal so?
Hallo Dirk,
vielen Dank für die Meldung eines Problems.
Bisher kann ich das Fehlverhalten nur bei warmweißen LEDs beobachten.
Bei mir wurde allerdings eine Kapazität von 247pF gemeldet, was sicher
auch nicht richtig ist.
Der Tester erkennt das Diodenverhalten an dem Spannungsunterschied beim
Betrieb mit dem 680 Ohm Widerstand und dem 470 kOhm Widerstand. Es ist
offenbar schwierig, für alle erdenklichen Fälle wie Germaniumdioden,
Leistungsdioden und LEDs die Grenzen bei der Spannungserkennung richtig
zu setzen. Ich werde den Fall noch genauer untersuchen und
gegebenenfalls eine angepaßte Version herausgeben. Bis dahin bitte die
Problem-LED zurücklegen, da meine ww-LED sich offenbar wieder anders
verhält als Deine.
Grüße, Karl-Heinz
OP #3368252
Dirk K. schrieb:
> mir ist bei meinem Tester aufgefallen, das weiße LEDs mit einer
> Flußspannung zw. 3,0 und 3,2V als unbekanntes Bauelement gemeldet
> werden.
Hallo Dirk,
im Software/trunk Zweig habe ich eine neue Version mit etwas veränderter
Diodenerkennung eingestellt. Zur Unterscheidung habe ich schon die
Versionsnummer auf 1.09k hochgesetzt. Meine LED wird jetzt sauber
erkannt.
Bitte um Rückmeldung, was Deine Problemfälle machen.
Grüße und nochmals vielen Dank, Karl-Heinz
#3370715
Hallo Karl-Heinz,
habe die Möglichkeit gehabt, die neue Software zu probieren.
Alle Problemfälle der weißen LEDs, die vormals als unbekanntes Bauteil
oder als einfache Kapazität erkannt wurden, wurden jetzt korrekt als
Diode erkannt, mal mit Reststromangabe, mal ohne. Dies ist aber bei
unproblematischen LEDs auch so gewesen.
Anhand der nun angezeigten Werte kann ich aber keinen Unterschied zu den
unproblematischen weissen LEDs ausmachen.
Alle Messwerte waren im normalen Rahmen, diese Leds waren also keine
Ausreißer. Alleine die Flussspannung war im Mittel 5mV geringer als bei
den unproblematischen Dioden.
Muss ich noch etwas anderes gegenchecken? Kann die Programmänderung
Auswirkung auf die Erkennung andere Bauelemente haben oder auf die
Messwerte derselben?
Danke vielmals für Deine prompte Reaktion und noch schnellere
Problemlösung.
Gruß Dirk
Gast #3371030
> das ist schon erwähnt worden. Auch ein Link auf das Projekt wurde von
> Nikolas S. am 17.10. mitgeteilt.
Hallo Karl-Heinz,
ah, ok, dann sorry :-). Bis die Zeitschrift bei mir in der Innerschweiz
ankommt dauert es etwas länger. Womit das Klischee der langsamen
Schweizer bestätigt ist.
Dir auch meinen Dank für Deine Arbeit. Ich bin beeindruckt!
Grüsse aus Luzern,
René
#3375452
Hallo Manfred G.,
falls es um Trasistorentest im Eingebautem zustand geht, da gab es vor
Jahren im Elektor eine Schaltung Namens - In-Circuit-Transistor-Tester.
Ganz Simpel aber funktioniert bei mir seit über 30 Jahren.
Beim bedarf kann ich die Schaltung sowie Layout bereits stellen.
Grüße
bongobongo
#3380262
Für alle die, aus welchen Gründen auch immer, einen Eigenbau des AVR
Transistortesters scheuen, kann ich die Fernostvariante im
Fertigteilgeäuse aus dem Auktionshaus
(http://www.ebay.de/itm/160995123823) durchaus empfehlen. Im Inneren
werkelt ein 328P im DIL-Format und es ist die Firmware mit der
ESR-Messung drauf. Allerdings wird mir die Firmwarevers. nicht
angezeigt. Ich nehme an, 1.08k ist somit noch nicht drauf.
Das Gerät wird mit einem 9V-Block betrieben, kann aber auch mit NT
arbeiten.
Platine, Bestückung und Gehäuse machen, in Relation zum Preis, einen
sehr wertigen Eindruck. Genial finde ich die aufsteckbare
Textoolfassung, ein geschichtes Feature, was tatsächlich sehr gut
funktioniert. Dazu gibt es noch drei Kabelklemmen für erweiterte
Bauteilanschlussmöglichkeiten.
Für einen Preis von ca. 30 Euro, kann man das nicht wirklich selber
bauen...
Als autarken Bauteiltester wird das Gerätchen zukünftig einen festen
Platz auf meiner Werkbank haben ;-)
Einzig und allein eine ISP-Schnittstelle wurde nicht vorgesehen und
schreit förmlich nach Nachrüstung ;-). Sonst muss man zum Programmieren
des Atmega das Display abschrauben und ihn aus der Fassung ziehen.
Ein Eigenbau kommt für mich nicht mehr in Frage.
Ich hätte dadurch jetzt zwei Platinensätze von Moritz über ;-)
Danke an die Entwickler für dieses sehr nützliche Tool!
OP #3380403
Meine Version aus China sieht so aus.
Bei den Fuses war der "Brown Out" deaktiviert (hfuse=0xdc, efuse=0xff).
Die Version meldet bei der Kalibration Version 1.07k!
Die Nullwerte für die Widerstandsmessungen liegen ziemlich niedrig, die
Nullwerte der Kapazitätsmessung etwas höher.
Die 680 Ohm Widerstände habe ich nachgemessen, die scheinen besser als
1% zu sein. Die Spannungsreferenz fehlt, was aber nicht weiter schlimm
ist, wenn die 5V genau sind. Bei mir habe ich 4.97V gemessen.
Ich habe meine Version inzwischen auf Version 1.09k aus dem
Software/trunk Zweig ohne Probleme umprogrammiert. Dafür hatte ich den
mega328P in ein anderes Board umgesteckt, da der ISP-Stecker fehlt.
Grüße, Karl-Heinz
OP #3381081
Michael D. schrieb:
> Was ist denn für ein Regler verbaut?
Bei meinem Tester (ohne Gehäuse) ist ein AMS1117-5.0 verbaut. Der Regler
ist ein low drop Typ mit nach dem Datenblatt guter Regelgenauigkeit,
aber einem Ruhestrom von etwa 5mA. Den anderen Tester im Gehäuse kenne
ich nicht, wenn da aber der gleiche Regler verbaut ist, ist die fehlende
Spannungsreferenz wahrscheinlich nicht schlimm. Da vermisse ich eher bei
beiden Versionen den ISP-Stecker.
Grüße, Karl-Heinz
#3381127
Hallo Karl-Heinz,
Der MCP1702 schlägt da mit 5µA zu buche, also unschlagbar, ebenso der
Ripple!
Mein Favorit!
Wie man sieht, gibt es da auch keine Möglichkeit zum nachrüsten, was bei
dem Platz eigentlich kein Ding gewesen wäre...
@Bernd Nedes
Ja, gelle? Das würde mich auch mal interessieren, vor allem der
Textoolsockel! Mal im Netz stöbern, vielleicht findet sich da was.
Gruß Michael
OP #3381357
Mit meinem China-Tester (V3.0 vom 13.8.2013) habe ich eine Reihe
Widerstände von 1 Ohm bis 50 MOhm gemessen. Die verwendete
Software-Version ist die 1.09k vom Entwickler-Pfad. Die Abweichungen
sind in beigefügten Bild graphisch aufgetragen. Die ausgelieferte
Software-Version 1.07k sollte aber gleiche Ergebnisse zeigen, da die
Widerstandsmessung identisch ist.
Grüße, Karl-Heinz
Gast #3383959
Hy Christian,
rückst Du das Layout raus? Wie ich gesehen habe verwendest Du auch easy
PCB, das könnte ich mir direkt im Tonertransfer machen. Dann hätte ich
morgen was sinnvolles zu tun ;)
Gruß,
           Andreas
#3384252
Hallo Christian
Layouts zu diesem Projekt gibt es ja mittlerweile
wie Sand am Meer.
Da kann man schon mal durcheinander kommen.
zB die einseitigen Layouts von "Tom666"
Dann die Layouts vom "Funkamateur" oder sogar
von chinesischen Anbietern.
Selbst Karl-Heinz hat eine Variante auf einer
Streifenleiterplatte veroeffentlicht.
Und auf allen Varianten laeuft die neueste
Softwareversion.
Installiere doch einfach die neueste
Version der freien Variante von Eagle, und
Du kannst Dir die meisten Veroeffentlichungen
ansehen oder ausdrucken.
Gruss Asko.
zB. Beitrag "Re: Transistortester AVR"
Gast #3384785
Muss ich anders sagen, die Layouts hab ich gesehen, mich würden die
EasyPCB files interessieren. Die könnte ich nämlich 1:1 für den
Tonertransfer nutzen da ich auch EasyPCB auf dem Rechner habe. Eagle
stresst mich...
Gruß,
              Andreas
#3384925
Andreas schrieb:
> Eagle stresst mich...
Da Du Eagle (kostenlose Version) nur zum Drucken brauchst und nicht zum
Designen, sollte sich der Stress in Grenzen halten und die Installation
von Eagle zumutbar sein.
Eagle mag ja für den Multimedia-Mausschubser etwas gewöhnungsbedürftig
sein, ich benutze es aber seit rund 20 Jahren (seit Version 2.1) und
kann über die Bedienung nicht klagen. Damals brauchte man zum Drucken
noch das externe Programm Xplot, heute gibt es einen gut sichtbaren und
nicht nervenden Klick-Button zum Öffnen des Drucker-Dialogs. Das Drucken
von Tonertransfer funktioniert damit bestens.
#3386790
Hallo Andreas
Sicher nicht die einfachste Methode.
Aber lade Dir doch die letzte Version im Eagle-Format
herunter, loesche die "oberseite" und Du hast eine
einseitige Leiterpaltte a´la Christian.
Bedingt aber, das man Eagle installiert.
Ich persoenlich haette aber mehr Bauchschmerzen
bei mir Facebook und Co. zu installieren.
Gruss Asko.
#3387561
> (http://www.ebay.de/itm/160995123823) durchaus empfehlen. [...]
> bauen...
Naja, ~40€, denn Währungsumrechnung ist nicht umsonst, und der Rest geht
an den Zoll. Wir sind ja schließlich keine Steuerhinterzieher, gell?
Und noch ne OT-Frage: Mir geht die Länge des Threads auf die Nerven, da
immer ALLES dargestellt wird. Ich folge ja gern, aber beim Öffnen steht
mein Browser einfach mal ne halbe Minute komplett still, bis alle Bilder
geladen sind und der ganze Kram durchgeparst wurde. Auf dem Handy
reinzuschauen ist komplett unmöglich. Anscheinend ist auf µc.net auch
keine automatische Unterteilung in Seiten implementiert, wie es in
Boards so üblich ist. Aber manch einer hat das laut Sufu als ne Art
Betatest erhalten. Kann ich das auch irgendwo einstellen, oder ist noch
jemand der Meinung, dass man hier mal splitten könnte?
#3387562
Hallo, ich habe mir jetzt auch einen Komponententester aufgebaut, aber
ein kleines Problem bei der aktuellen Firmware (v1.10m). Bei
Kondensatoren wird mir immer ein wert angezeigt, der um das 10-fache
höher ist als der Tatsächliche. Aus 2,2µF werden 22µF, aus 47 werden
470. Aber 100nF und 33pF werden richtig erkannt und mit etwas abweichung
angezeigt.
Ich verwende einen ATmega328P mit 8MHz-Quarz, welchen ich auch im
Projekt so angegeben habe. Auch den selbsttest und die Kalibrierung habe
ich durchgeführt
Auch wird bei der allerersten Messung nach dem Einschalten, immer ein
Kondensator mit 62pF angezeigt, obwohl nichts angeschlossen ist, bei der
zweiten und folgenden Messungen wird dann "No Component found" angezeigt
#3387632
Das War es nicht. Ich habe testweise mal eine PWM ausgeben lassen und da
wird die Frequenz richtig vom Oszi erkannt.
Auch habe ich festgestellt, dass 100nF Kondensatoren richtig erkannt
werden. Wenn ich welche parallel schalte geht das gut, bis ich die
500nF-Grenze überschreite, dann wird der Wert plötzlich verzehnfacht
OP #3387653
Die Seitenaufteilung läßt sich am Ende des Threads einschalten. Einmal
eingeschaltet, bleibt die Seitenaufteilung erhalten. Es wäre
wahrscheinlich trotzdem sinnvoll, die alten Eintragungen auszulagern. Da
ich keine Administrator-Rechte habe, kann ich da nichts selber machen.
Grüße, Karl-Heinz
OP #3387670
Hallo Chris,
möglicherweise handelt es sich um einen Fehler der 1.10m Version. Ich
habe die letzte Version von Markus R. nicht getestet, kann also dazu
leider nichts sagen. Man kann den Autor der Software-Version aber über
die in der README angegebenen Email erreichen. Bei nächster Gelegenheit
werde ich die Version mal selber testen.
Grüße, Karl-Heinz
#3387674
> Grüße, Karl-Heinz
Da muss man erstmal drauf kommen, dass das da platziert ist.
Funktioniert, mal schauen, ob das cookie- oder accountbasiert ist. Auf
jeden Fall eine deutliche Besserung. Danke!
#3387685
Ich habe jetzt mal die 1.09, geflasht und habe immer noch das gleiche
problem.
100nF erkennt er als 98µF, geht also. Aber bei 0,47µF werden mir schon
wieder 5100nF angezeigt, bei 100µF werden mir 997µF angezeigt. Also
wieder das Zehnfache.
Woran könnte das denn überhaupt liegen, dass ich mal effektiv auf
Fehlersuche gehen kann.
[EDIT] habe nochmal getestet: bei 4x100nF werden mir 389,9nF angezeigt.
Bei 5x100nF schon 5331nF. Bei 0,47µF werden mir auch irgendwas um die
5000nF angezeigt
#3387711
und Parasiten hast du auch, oder die Zuleitungen sind zu lang...
#3387735
Ich hab das Komplette Layout nochmal überprüft, keine Zinnbrücken. Auch
alles nachgelötet habe ich nochmal. Immernoch das selbe.
Mitlerweile bin ich den code mal durchgegangen und konnte feststellen,
das das Problem auftritt, wenn in die Funtion LargeCap gesprungen wird.
Hier werden falsche ergebnisse angezeigt, wenn danach nochmal in
SmallCap gesprungen wird, werden für die kleinen Kondensatoren korrekte
Werte angezeigt. Auch viel mir auf, dass die Grenze zwischen SmallCap
und LargeCap nicht, wie angegeben 4,7µF sind, sondern etwa 0,47µF.
Für die Widerstände habe ich 680 Ohm und 470 kOhm
Ich habe jetzt mal meine Kondensatordekade dran gehangen und bei etwa
403nF hört er auf in die Funktion SmallCap zu springen.
Die Spannungen habe ich überall gemessen, die sind so wie sie sein
sollen. Auch mit dem Oszi keine Störungen messbar
OP #3387856
Hallo Chris,
die 1.10m Version habe ich bei mir kurz getestet und ich kann den Fehler
nicht bestätigen. Bei mir werden Kapazitäten von 660nF, 1uF und 2.2uF
richtig gemessen. Die Meßabweichung habe ich dabei nicht weiter
analysiert.
Eine mögliche Fehlerquelle wäre noch ein zu großer Kondensator am AREF
Pin. Hier sollte nur etwa 1nF angeschlossen sein, um für den ADC den
schnellen Wechsel zwischen der internen 1.1V Referenz und der 5V (AVCC)
Referenz zu ermöglichen.
Grüße und viel Erfolg bei der Fehlersuche, Karl-Heinz
#3389625
Keine Ahnung warum du bei einem als "Case" gelabelten, mit 10 euro
ausgepreistem Warenversand noch Zoll zahlen willst...
Und wenn ich Oanda bemühe, komme ich bei 40 Dollar nunmal beim besten
Willen nicht auf 40 Euronen... aber wahrscheinlich ist dir das einfach
zu teuer und du baust dann doch lieber selber ;-)
OP #3390918
Fredek schrieb:
> Do You have PCB files for mega328 version ?
All PCB layouts can be assembled with the ATmega328. The mega328 has a
identical pin layout as the mega168 or mega8. There are differences in
the PCB layout corresponding to the used display type or implemented
hardware options or the way of powering the tester. Some users use a
DC-DC converter to power the device instead of the 9V battery. Other
users do not implement the power off logic.
You can find two designs in the download section of the tester:
 http://www.mikrocontroller.net/articles/AVR_Transistortester#Downloads_.28english.29
The design of Markus R. you will find in the Hardware/Markus folder,
my design for strip grid boards you can find in the Hardware/strip_grid
folder. There are also some different designs from other users in this
thread.
You should know, that some designs require setting of options in the
Makefile to create the matching programming data!
Regards, Karl-Heinz
OP #3391433
Fredek schrieb:
> Thanks, but I mean PCB for SMD version Mega328.
A very compactly design is build by the radio amateur DF3DCB and DH8GHH.
The composition is published here:
http://o28.sischa.net/bauteiltester/trac and in the german magazine
"Funkamateur". You can buy a pre-assembled set from the shop of this
magazine:  http://www.box73.de/product_info.php?products_id=3006
This set is expensive, but you get a compact tool with a finished
aluminium box.
Regards, Karl-Heinz
Gast #3392782
es ist wirklich das perfekte Gerät für etwa einen Monat lief ich mit dem
Lot (ich war faul zu entwerfen und produzieren PCBs)
http://www.freeimagehosting.net/ufby4
und dann fand ich bereits entworfen PCB (Aufruf zum tschechisch-Klon),
sah ziemlich anständig, damit ich geätzt entsprechend seiner eigenen und
zwar nicht so gut wie das Original. Und ich bin mit diesem Vorschlag
sehr zufrieden. Also für Inspiration Ich lege Links zu der Platine, die
mich inspiriert.
http://avrtester.tode.cz/pictures/galleries/2/522aee61ddb9b.jpg
http://avrtester.tode.cz/pictures/galleries/2/522aee3f449a6.jpg
Gast #3395340
Forgot what i said before!
with normal fuses i get this:
Part is a tantalium polarized capacitor with label value of 10uF
Pin1 on -
Pin2 on +
read value 11.01uF good
Pin1 on -
Pin2 on +
Pin1 on +
Pin2 on -
read value 8293nF bad
Pin1 on +
Pin3 on -
read value 8255nF bad
Pin2 on -
Pin3 on +
read value 10.67uF good
Pin2 on +
Pin3 on -
read value 8191nF bad
same behavour with an atmega328p and an atmega168 (non p)
#3395881
Ich habe hier einen China-Tester, der nicht funktioniert.
Auf der Platine steht V2.4 2013/07/01.
Hat vielleicht jemand ein ähnliches Gerät? Ich suche den Schaltplan für
die Fehlersuche.
Es scheint ein vereinfachtes Layout zu sein, da die LED neben dem Button
nicht auch bedrahtet ausgeführt ist.
OP #3395883
Hello Simone,
tantalium capacitors does not like the wrong polarisation direction.
The capacity measurement of tester is usually done with the lower pin
number as minus pole. With all other types of capacitors I have never
noticed this preferred direction because the used measurement voltage is
very low.
I don't know any easy way to prevent this characteristic. If you try out
both directions automatically, the measurement would take twice the time
for all capacity measurements.
Best Regards, Karl-Heinz
OP #3395914
Hallo Pete,
das scheint eine Version ohne Quarz zu sein. Normalerweise sind aber
alle mir bekannten China Versionen exakt nach der Vorlage aufgebaut.
Lediglich die Pinnummern des ATmega ändern sich wegen der SMD Version
und die Transistoren sind andere Typen. Bei Deiner Version scheint auch
eine 2.5V Zenerdiode anstatt einer Präzisionsreferenz verbaut zu sein.
Hinweise zur Fehlersuche findet man auch in der PDF-Doku im Hardware
Kapitel.
Wurde dann schon mit dem Händler Kontakt aufgenommen? Wenn das Teil
nicht läuft, ist das auf jeden Fall ein Reklamationsgrund
Grüße, Karl-Heinz
OP #3395997
Pete K. schrieb:
> Wie verläßlich ist dieses
> Meßergebnis?
Hallo Pete,
die Auflösung des angezeigten ESR-Wertes beträgt zwar 0.01 Ohm, das ist
aber leider nicht die Genauigkeit. Der Meßwert wird durch Mittlung von
vielen Meßwerten gewonnen. Die Auflösung des ADC reicht nicht für eine
echte 0.01 Ohm Auflösung. Daher muß man das Ergebnis bei großen
Kapazitäten (kleiner ESR) mit Vorsicht betrachten. Bei kleineren
Kapazitätwerten werden die Angaben aber verläßlicher und entsprechen in
etwa den Ergebnissen bei einer Meßfrequenz von 10 kHz.
Die Kapazitätswerte werden bei Elektrolyt-Kondensatoren weniger präzise
ermittelt wie bei Folienkondensatoren. Ganz schlechte
Kapazitätsergebnisse bekommt man mit alten Papierkondensatoren. Hier
gibt der hohe Parameter Vloss (Spannungsverlust) aber einen Hinweis auf
die schlechte Güte des Kondensators.
Grüße, Karl-Heinz
Gast #3396222
Yesterday I tested the electrolyte tantalum capacitors with the
following results:
10.49 / 11.07 uF
106.3 / 107.0 uF
10.81 / 10.72 uF
9795nF / 10.31 uF
1030nF / 1019 nF
21.71 / 25.23 uF
the higher values ​​are in the correct direction, I think it's not so
bad, just the higher value is the right one, they tantalum never like
polarity.
The ESR resistance from 0.00 to 0.03 that is within the noise.
Electrolytic capacitor, it is not resistance, ktrý bud always emit the
same value, there are ongoing charging and discharging phenomena and the
measurement is always reflected in the result in the lowest orders.
I would like to thank Karl-Heinz for his work, it's just a smart thing
to put together, thanks again.
OP #3396555
Pete K. schrieb:
> Ich wollte mal schauen, was bei meinem Chinateil so eingebrannt ist.
Hallo Pete,
die Versionsnummer der Software wird normalerweise am Ende des
Selbsttests für eine Sekunde auf dem LCD angezeigt. Die Versionsnummer
ist in der Regel auch als ASCII in den EEprom Daten zu finden, wenn das
Auslesen nicht durch Setzen des Sicherheitsbits verhindert wird.
Der Selbsttest startet automatisch, wenn bei einer Messung alle drei
Pins miteinander verbunden sind und eine Messung gestartet wird. In der
neuesten Entwicklerversion (Software/trunk im SVN-Archiv) ist zusätzlich
eine Bestätigung durch einen zusätzlichen Tastendruck innerhalb von zwei
Sekunden erforderlich. Sonst startet eine normale Messung.
Durch die zusätzliche Betätigung des Tasters kann ein versehentlicher
Selbsttest verhindert werden, wenn beispielsweise ein defekter
Transistor (Schluß zwischen allen Anschlüssen) getestet wird.
Grüße, Karl-Heinz
#3396750
Beim Versuch, das ganze mit AVRStudio 6 zu überseten, habe ich das
Problem, dass scheinbar Transistortester.h nicht richtig gelesen wird.
Bei der ersten Datei Autocheck.c bekomme ich mehrere Fehler, dass einige
Strings aus Transistortester.h nicht definiert sind (siehe Anhang).
Die Compilerflags habe ich aus dem Makefile übernommen.
Was mache ich falsch?
OP #3397008
Pete K. schrieb:
> Es ist die 1.05k.
Die 1.05k Version ist schon etwas älter, vom Anfang des Jahres. Danach
sind einige Verbesserungen und Ergänzugen eingebaut worden. Unter
anderem sind das eine verbesserte ESR Messsung, der Spannungsverlust der
Kondensatoren (Vloss) und der Sperrstrom von Einzeldioden (Ir). Da
sollte sich ein Update auf jeden Fall lohnen. Dabei sollte man möglichst
auch die Abblockung der Betriebsspannung mit Kondensatoren nahe am
Prozessor verbessern.
Grüße, Karl-Heinz
#3397107
Pete K. schrieb:
> Ich habe jetzt den aktuellen trunk übersetzt und bekomme nach der
> Batterieanzeige (9.5V ok) und langer Wartezeit (15s) die Meldung
> "CELL!".
> Egal, ob ich PINS 1,2,3 verbunden habe oder nicht oder ein Kondensator
> eingesteckt ist.
> Warum?
> Makefile anbei.
Versuchen Sie, dieses Programm zu übersetzen, es gibt immer gearbeitet
http://sourceforge.net/projects/winavr/files/latest/download?source=files
hat ein paar Megabyte und es ist wirklich gut
(Firma: ☣ ⍵ ☣) Persönliche Seite #3397151
Pete K. schrieb:
> Also Fehlermeldungen habe ich keine bekommen und auch den aktuellen
> Trunk benutzt. Das Programm lässt sich auch flashen und ausführen (siehe
> Batterieanzeige), da verstehe ich nicht den Zusammenhang zwischen
> Compilierung und der Anzeige "CELL!" nicht so ganz.
Das hier hast du gelesen?
Aus Doku:
CAP_EMPTY_LEVEL Diese Option legt die Spannung (mV) für einen entladenen
Kondensator
fest. Der Wert kann höher als 3mV gesetzt werden, wenn die Entladung
nicht zum Ende kommt.
In diesen Fall meldet der Tester nach längerer Zeit „Cell!”.
Beispiel: CFLAGS += -DCAP_EMPTY_LEVEL=3
Sind auf der platine hochohmige Brücken? Lötreste, Flussmittel?
#3397152
Ich habe die Version 1.09k mit dem AVR-Studio4, es sollte eigentlich
egal sein welche Version man nimmt, kompiliert.
Bei einer Serie von Standardbauteilen gab es nicht die geringsten
Probleme oder unplausiblen Ergebnisse. Die Ergebnisse habe ich immer mit
einem zweiten Tester mit der Version 1.08k verglichen.
OP #3397163
> "CELL!".
in allen mir bekannten Fällen war die Meldung "Cell!" auf eine
ungenügende Abblockung der VCC (AVCC) Spannung zurückzuführen. Es sollte
möglichst nahe am Prozessor abgeblockt werden. Den CAP_EMPTY_LEVEL
hattest Du ja schon auf 6mV erhöht. Den Wert würde ich wieder auf
Standard (4mV) zurücksetzen, wenn die Abblockung verbessert ist. Als
vorübergehende Maßnahme kann man die Option INHIBIT_SLEEP_MODE setzen.
Dann steigt der mittlere Stromverbrauch wegen der fehlenden Ruhezustände
des ATmega an, wegen der gleichmäßigeren Stromaufnahme bleibt aber die
Versorgungsspannung ruhiger.
#3397230
> "CELL!".
This is a tested version of the software.
Fuses:
ATmega168, ATmega168p:
RC 8Mhz - lfuse:0xe2 hfuse:0xdc efuse:0xf9
Crystal 8Mhz - lfuse:0xff hfuse:0xdc efuse:0xf9
ATmega328, ATmega328p:
RC 8Mhz - lfuse:0xe2 hfuse:0xd9 efuse:0xfc
Crystal 8Mhz - lfuse:0xff hfuse:0xd9 efuse:0xfc
OP #3397374
Manfred G. schrieb:
> Wo hast du deine China Version denn bestellt?
Hallo Manfred,
bei Ebay nach "Transistortester ESR" suchen ergibt einige Anbieter,
unter anderem auch eine mit Textool Fassung und mega328 in DIL Fassung.
Eine weitere Variante ist im Gehäuse mit aufsteckbarer Textool-Fassung.
Neuerdings gibt es auch eine Variante mit Bananen-Buchsen, bei der ich
nicht weiß, welcher Prozessor verwendet wird. Ich würde auf jeden Fall
eine Version mit mega328 bevorzugen.
Grüße, Karl-Heinz
OP #3398003
Manfred G. schrieb:
> Hatte schon letzte Woche bestellt. Entspricht meine Wahl den von dir
> vorgeschlagenen Vorgaben ?
Hallo Manfred,
den gleichen Typ hatte ich auch bestellt, der ist soweit in Ordnung
(ATmega328 im DIP Sockel). Die 2.5V Präzisionsreferenz fehlt, dafür
scheint aber der Spannungsregler ziemlich genau zu sein. Die Referenz
dient nur der Überwachung der VCC Spannung und wird bei hoher
Genauigkeit des Reglers nicht gebraucht.
Es fehlt eine ISP-Programmierschnittstelle. Wegen des 8 MHz Quarzes muß
die externe Programmiervorrichtung einen Takt zuführen. Alternativ
könnte man eine ISP-Schnittstelle per Kabel an den Sockel anlöten, wenn
man das Teil in ein Gehäuse einbaut.
Grüße, Karl-Heinz
Gast #3398109
also auch ich habe die "Billigversion" aus China (wie Pete K.) für
umgerechnet 12€ inkl. Versand und bin eigentlich damit recht zufrieden.
Die Zenerdiode kann man jederzeit ersetzen (bevorzugt LM336, weil
ausreichend genau und am günstigsten), ebenso den 78L05. Der fehlende
Quarz ist gewöhnlich bei konstanten Temperaturverhältnissen im
Bastelzimmer auch verschmerzbar.
Auch die Verwendung von "normalen" Widerständen macht sich nicht negativ
bemerkbar, denn die Abweichungen in den Selbsttests sind
vernachlässigbar (möglicherweise sind die Widerstände ja ausgesucht).
Zusätzlich hat man die ISP-Schnittstelle schon vorbereitet.
Wem das zu wenig ist, der kann ja eins der "Altgeräte" mit gesockeltem
ATmega 8 für knapp 8€ inkl. Versand kaufen und mit allen goodies
umrüsten...
P.s.: ich habe auch schon die aktuelle Trunk compiliert und geflashed,
allerdings mit den Fuses low: 0xD2 ext: 0x01 (0xF9) high: 0xDF
OP #3398167
Für welchen ATmega?
Wenn es ein mega168 ist, läuft er auf internem RC-Takt mit verkürzter
Startzeit (4.1ms) und die Unterspannungserkennung (Brown out) ist
abgeschaltet.
Die Standardeinstellung ist für den mega168 RC-Betrieb:
low:0xE2, high:0xDC, ext:0xF9
und für den mega168 Quarz-Betrieb:
low:0xF7, high:0xDC, ext:0xF9
Für beide Betriebsarten ist eine Startverzögerung von 65ms und ein Brown
Out Pegel von 4.3V eingestellt.
Für einen ordentlichen Betrieb sollte die VCC Spannung stabil bleiben.
Ohne die Startverzögerung und die Brown Out Erkennung startet der
Prozessor möglicherweise zu früh. Mit der Standard-Einstellung startet
der Prozessor erst bei Überschreiten des Brown Out Pegels und wartet
noch zusätzlich 65ms. Bis dahin sollte die VCC Spannung stabil sein und
der LCD-Controller bereit sein.
Grüße, Karl-Heinz
Gast #3398687
Hi KHK,
ja 168 ohne Quarz, dachte das geht aus Referenz zu Chinaboard von Pete
K. hervor.
Ich denke, dass die Fuse-config für ein Batteriegerät mit lin. Regler
angemessen ist, besonders wo es mit akt. Brownout ja gelegentlich
Probleme gegeben haben soll ....
Gast #3399141
Hello,
I bought the PCB to www.avrtester.tode.cz, it is a professional job, I
just have a question. I chose resistors and now I do not know what
values should have self-test.
Me is based on the      T2-4 -5 -6
                        T3 4 -4  8
is that correct? Nowhere are the limits of self test, or is there an
indication somewhere?
Thanks for the info Miki
OP #3399335
Hello Miki,
the output values of the self test are differences to the theoretical
value in mV units. The ADC resolution is about 5mV. The intermediate
values are only given by building mean values of several measurements.
In addition the difference to the theoretical value is not only
dependent on the resistance values of the 680 Ohm and 470 kOhm
resistors. The internal error of the ADC and multiplexor are also
relevant. So your results does not indicate any error. If your results
exeed much more than 10mV, you should check your circuit.
#3399360
Hi KHK,
zwei Fragen:
1) wäre es eigentlich möglich, den Tester nach der Messung während der
Anzeige der Ergebnisse auch schlafen zu lassen bis zum nächsten
Tastendruck oder dem Abschalten? Irgendwie ist es frustrierend, dass
während der Messung weniger Strom verbraucht wird als im Leerlauf ....
2) wäre es möglich für den Mega168 eine Version zu machen mit
erweiterter ß Messung aber ohne "Selbsttest"? Dann könnte man zuerst mit
der "Selbsttestversion" den Abgleich machen, die Parameter werden ins
EEProm geschrieben, man liest sie aus und danach lädt man die
"Normalversion" plus ausgelesenes EEprom und man bekommt die selben ß
Werte wie auch mit der Mega 328 ?
Gruß,
schufti
OP #3399438
G. H. schrieb:
> zwei Fragen:
Die erste Frage verstehe ich nicht richtig. Der ATmega schläft ausser
der Meß- und Rechen-Zeit eigentlich die ganze Zeit. Auch während den
Messungen wird in den längeren Wartezeiten geschlafen. Wenn die
Ergebnisse angezeigt werden, schläft der Prozessor auch fast die ganze
Zeit.
Zu der zweiten Frage werde ich noch mal in Ruhe nachdenken. Vielleicht
hilft es auch, wenn man Teile des Selbsttests und der Kalibration
trennt. Vielleicht gelingt es dann ja, für den ATmega168 die B
Ermittlung in beiden Schaltungen durchzuführen, wenn man nur auf den
Selbsttest-Zweig verzichtet.
Grüße, Karl-Heinz
OP #3399520
G. H. schrieb:
> mir ist nur aufgefallen, dass mein Tester während der Messung ca. 8-10mA
> zieht, nach der Messung aber 15mA.
Das ist sehr ungewöhnlich. Nach der Messung wird der PC4 Pin auf GND
geschaltet wegen der Relay-Erweiterung zum Schutz der Eingänge. Mit der
vorgeschlagenen R16 Bestückung von 2.2k wird hier zusätzlich Strom
verbraucht. Der Strom, der normalerweise die 2.5V Spannungsreferenz
speist, wird dadurch auf etwa 2.2mA verdoppelt. Liegt hier etwa ein
Bestückungsfehler vor?
R16 ist der Widerstand von der 2.5V Spannungsreferenz nach VCC.
Grüße, Karl-Heinz
OP #3400916
Pete K. schrieb:
> Gibt es die Doku auch als fertiges PDF?
Die Doku ist in Deutsch und Englisch zu jeder Version im SVN Verzeichnis
Doku/tags Verzeichnis zu finden. Die Doku zu der Entwicklerversion
findet man im SVN Verzeichnis Doku/trunk/pdftex/german bzw. die
englische Version in Doku/trunk/pdftex/english . Das fertig kompilierte
PDF heißt immer ttester.pdf, sowohl die englische als auch die deutsche
Version. Es sind aber auch die pdftex Quellen im SVN enthalten.
Die bisherige Art der Versionsvergabe möchte ich beibehalten. Wer
möchte, kann jede einzelne Änderung direkt im SVN nachschauen.
Grüße, Karl-Heinz
OP #3400939
G. H. schrieb:
> @KHK: ja, Widerstand ist geprüft 2k2 ...
da weiß ich zunächst auch keinen Rat mehr. Während der Anzeigezeit
sollte der Tester nicht mehr Strom ziehen als beim Messen.
Wurde beim Übersetzen in der Makefile die Option RESTART_DELAY_TICS=6
gesetzt? Die ist ohne Quarz notwendig, damit die Wartezeiten wegen des
anderen Aufwachverhaltens stimmen.
Grüße, Karl-Heinz
#3400954
Ich hatte auch einmal eine aktuelle Version unter
Beitrag "Re: Sammelbestellung Transistortester III - schnelle Runde" hochgeladen.
G. H. schrieb:
> ja, entweder das svn clonen oder als Archiv runterladen. Über den
> svn-Browser ist es mir nicht gelungen das runterzuladen.
Ja, hat der leider auch nicht als Feature.
#3400993
Das ist kein Problem. Das ID-Tag zeigt die eingecheckte Version an (z.B.
187), bei Bedarf kann man dann den ganzen Baum mit einem Tag versehen
(z.B. 1.09k). Dieses Tag kann man dann auschecken und hat alle Files,
die zur Version 1.09k gehören.
#3401794
Hallo!
Ich habe jetzt auch endlich mal die Platine aus der SB I bestückt.
Die Platine geht an, nach eienr Zeit auch wieder aus, die PowerLED
bleibt and  und auch der µc lässt sich per ISP programmieren.
Das Problem ist nur, dass mein Display nichts anzeigt! :(
Ich habe das hex und eep File auf folgendem Pfad eingespielt:
transistortester.tar\transistortester\Software\tags\ttester_108k.zip\tru
nk\mega328\
Bei der Bestückung habe ich mich an den Warenkorb von Moritz gehalten.
Wo ist mein Problem, bzw wo muss ich ansetzen?
Nachtrag: Fuses sind wie folgt gesetzt:
low 0xFF, high 0xD9 und efuse 0xFC
OP #3402258
Hallo Christian,
wenn Du ein DOGM LCD verwendest, muß die Software angepasst sein. Das
muß man durch Setzen der Makefile Option LCD_DOGM machen. Diese Option
ist normalerweise nur als Kommentar gesetzt.
Für den aktuellen Entwicklerpfad habe ich ein neues Verzeichnis
Software/trunk/mega328_dogm mit den fertigen Programmdaten ergänzt.
Bei der Entwicklerversion (Vorversion der nächsten 1.09k) muß der
Selbsttest innerhalb von zwei Sekunden mit einem Tastendruck bestätigt
werden, sonst startet eine normale Messung.
Grüße, Karl-Heinz
#3402306
Selbst der wird nicht direkt funktionieren, da das StripGrid-Layout bei
mir zum Routen günstiger war, wie auch in
Beitrag "Re: Sammelbestellung Transistortester"
dokumentiert.
OP #3402344
Schande über mein Haupt. Ich muß zugeben, daß ich die Variante nicht gut
genug beobachtet hatte. Ich habe zusätzlich noch den Pfad
Software/trunk/mega328_strip_grid_dogm ergänzt. Hier habe ich auch die
Option für die serielle Schnittstelle herausgenommen, passend für dir
Zenerdioden-Option.
Schöne Grüße und vielen Dank für den Hinweis,
Karl-Heinz
#3402669
Erstmal vielen Dank für eure Hilfreichen antworten.
Moritz A. schrieb:
> Probiere mal Beitrag "Re: Sammelbestellung Transistortester"
Hab ich gerade drauf gebrutzelt, leider ist immernoch nichts zu sehen.
Spielt es eine Rolle ob die Files für einen 328 oder einen 328P
compiliert wurden?
Meine oben genannten Fuses hab ich richtig gesetzt? (Ich verwende einen
328P)
Du hattest in dem anderen Thread auch folgendes geschrieben:
>Zusätzlich werde ich dann mit dem Versand auch passende Hex-Files
bereitstellen.
Hast du dies getan? Ist ja eine der Platinen von dir ;) Dann bräuchte
ich mich nicht mehr mit dem Makefile beschäftigen g
> Hallo Christian,
Hallo Karl Heinz,
vielen Dank für deinen Hinweis. Ich verwende das DOGM LCD. Werde mir am
WE mal die Zeit nehmen das Makefile anzusehen (wobei das für mich auch
Neuland ist) und auch die Doku ein wenig genauer.
PS: Echt ein super Messgerät und total klasse, was ihr da so macht!
Vielen Dank!
OP #3402689
> Dann bräuchte
Die Entwicklerversion hat zwei neue Unterverzeichnisse für DOGM
Displays. Für Deine Version müßte das Unterverzeichnis
mega328_strip_grid_dogm passen. Hier ist die Makefile entsprechend
eingestellt und die Programmierdaten müßten für einen mega328 oder
mega328p passen. Die beiden Prozessortypen haben zwar eine
unterschiedliche Kennung, die Programmdaten und die Einstellung des
Fuses sind aber identisch. Man braucht mit dem SVNbrowser nur dieses
Unterverzeichnis als GNU tarball herunterladen
Wenn die LED nach dem Start für etwa 30 Sekunden leuchtet, läuft das
Programm. Zusätzlich kann man aber auch eine LED als Testobjekt
anschließen. Beim Testen flackert die LED ein paar Mal.
Sind die Anschlüsse des LCD's auf korrekte Verbindung und eventuellen
Kurzschluß überprüft worden?
#3402858
@Christian:
Ich habe gestern die Moritz-sche Platine bestückt (mit ATmega328P) und
diese Dateien über AVR Studio geflasht:
Bei den Fuses habe ich nur die Clock-Source auf den 8MHz Quarz
eingestellt (Clock-Devider natürlich aus) und die Brown Out auf 4,3V
gestellt.
Dann lief es auf anhieb.
Gast #3404934
Besten Dank an die Autoren.
Ich habe auch die Ebay Hardware "V2.4 2013/07/01" aus China erhalten und
versucht, sie mit ATMega328p (SMD) aufzurüsten.
http://www.atmel.com/Images/Atmel-8271-8-bit-AVR-Microcontroller-ATmega48A-48PA-88A-88PA-168A-168PA-328-328P_datasheet.pdf
Leider war ich offenbar beim Flashen nicht vorsichtig genug und es stieg
Rauch auf - leider weiß ich nicht, woher. Der 7805 tat noch, was er
soll, und der Mikro liess sich auch ansprechen.
Aber die Schaltung ohne alles "zog" nach dem Aufwecken 90 mA (am
Netzteil mit 7.3 V).
Durch Reset des Controllers fiel auch der Strom weg.
Das Auslöten der D1 änderte am Strom nur unwesentlich etwas.
Auf dem LCD tat sich nichts sichtliches.
100 nF an AVCC bzw. Supply änderte leider auch nichts.
Also hatte ich offenbar Pin(s) des Mikros zerschossen? Oder weicht die
Hardware von der Standardschaltung ab?
*LÖSUNG*:
Das Poti für die LCD-Kontrastspannung ist beim Heißluftlöten beschädigt
worden und hat mehr oder minder einen Kurzen verursacht. Dass dann am
Display nichts zu sehen war, ist auch kein Wunder.
Fuses für 8 MHz RC: -U lfuse:w:0xe2:m -U hfuse:w:0xd9:m -U
efuse:w:0xfc:m
Software rev 187:
http://www.mikrocontroller.net/svnbrowser/transistortester/Software/trunk/mega328/
http://www.mikrocontroller.net/svnbrowser/transistortester/Software/trunk/mega328/Makefile?revision=180&view=markup
Die Fuses konnte ich mit AVR Studio problemlos schreiben, avrdude 6.0.1
hat aber beim Rücklesen das weiter oben schon erwähnte Problem, nur eine
4 zurückzubekommen.
Lassen sich auch krumme Quarzfrequenzen nutzen (Stichwort
"Baudratenquarz", 8 bzw. 1 MHz sind ja relativ fest im Makefile)?
Die Versionsnummer wird offenbar nur bei der Selbsttestabfrage
(Kurzschlussstecker) angezeigt? -> 1.09k
Display ist ein ZIJING ELECTRONICS ZJM162A MST01D002. Der Kontrast ist
nicht so toll.
#3404952
> 4 zurückzubekommen.
Dieses verhalten ist ja insofern korrekt bzw "nicht falsch", als dass
nicht festgelegt ist wie ungenutze Bits zurückgegeben werden.
Das habe ich in Beitrag "Re: Sammelbestellung Transistortester" auch
nochmal näher erläutert gehabt.
OP #3404954
Leider lassen sich nur glatte Frequenzen nutzen. Als Quarz getestet ist
nur 8 MHz und 16 MHz. Der 1 MHz Betrieb ist durch /8 Teiler der
Taktfrequenz einstellbar (fuses), aber nicht sinnvoll. Beim Nachrüsten
eines 8 MHz Quarzes habe ich auf die 22 pF Kondensatoren ohne erkennbare
Probleme verzichtet.
Grüße, Karl-Heinz
Gast #3406057
If i try to compile with debug options enabled i get errors becouse of
missing semicolon at the end of every DisplayValue(..) line.
Ex:
DisplayValue(lirx1,1,LCD_CHAR_OMEGA,4)
should be
DisplayValue(lirx1,1,LCD_CHAR_OMEGA,4);
OP #3406436
Hello Simone,
you are right with your error report. Thank you for the hint. I have
corrected the SVN already.
For the debugging of the tester you have to connect a 4x20 character LCD
instead of the standard 2x16 LCD.
